How to Turn Videos Into Shorts: Best Tools and Methods That Actually Work
Turning long videos into short clips can give creators big results, but many struggle with doing it efficiently.If you create content on YouTube, podcasts, or social media, this guide explains three main ways to make Shorts: AI tools, manual editing, and platform features. You can pick the best method and start posting Shorts that get results.
What Does It Mean to Turn a Video Into Shorts?
Turning a video into Shorts means extracting the most compelling moments from a longer, typically horizontal video and reformatting them into vertical, sub-60-second clips optimized for YouTube Shorts, TikTok, and Instagram Reels.
What It Means to Turn a Video Into Shorts
The main challenge is not just cutting the video short. You also need to change the aspect ratio from 16:9 to 9:16, pick the moments worth keeping, and follow each platform’s formatting rules. A 45-minute podcast episode, for example, might contain eight clips worth posting. But finding them, reframing the shot, adding captions, and exporting correctly takes time without the right workflow in place.
Method 1 — Use AI Tools to Auto-Generate Shorts (Fastest)
If you’re dealing with high video volume or simply want the fastest path from long-form to short-form, AI repurposing tools are the clear winner. These platforms analyze your video’s transcript, pacing, and engagement signals to automatically detect highlight moments, clip them, reframe the shot for vertical, and add captions. All of this isoften done in under five minutes.
This method requires the least technical skill and dramatically reduces editing time, making it the go-to choice for creators managing multiple channels or repurposing content at scale.
Top AI Tools for Turning Videos Into Shorts
Tool
Best For
Key Feature
Free Plan?
Opus Clip
Long YouTube videos, podcasts
AI virality scoring, auto-reframe
Yes (limited)
Vidyo.ai
Batch repurposing
Auto-captions, brand templates
Yes
Klap
TikTok-focused creators
AI punchline detection
Paid (But free trial available)
Captions.ai
Mobile-first workflow
Auto-captions + face tracking
Yes
Each tool takes a slightly different approach, but the underlying logic is the same: upload your video, let the AI score and segment it, then review and export the clips it recommends.
Step-by-Step: Using Opus Clip to Turn a Video Into Shorts
Opus Clip is one of the most widely used AI tools in this space, and its workflow generalizes well to most similar platforms.
  1. Create a free account at opus.pro and log in. You will see the 7-day free trial prompt. Then, navigate to the clip creation dashboard.
  1. Paste your video URL (YouTube, Vimeo, or upload a file directly) and click “Get Clips.”
  1. Wait for AI analysis — Opus Clip transcribes the video and assigns a “virality score” to potential clip segments, usually within 2–5 minutes, depending on video length.
  2. Review the suggested clips — browse the scored clips and preview each one. The AI ranks them by predicted engagement, but you can manually select any segment you prefer.
  3. Use Auto Reframe to convert the selected clip from 16:9 to 9:16, with subject-tracking to keep the speaker centered in the vertical frame.
  1. Add or edit captions — Opus Clip generates captions automatically; customize font, style, and positioning to match your brand.
  1. Export your clips in the correct resolution (1080×1920 for Shorts) and download or schedule directly to your platform.
The free plan allows a limited number of exports per month. If you’re repurposing regularly, the paid tier is worth evaluating against your publishing volume.
Method 2 — Edit Manually in a Video Editor (Most Control)
Manual editing takes more time than AI tools but gives you complete authority over every creative decision—which moments to clip, how the captions look, what text overlays appear, and how the final frame is composed. This is the right approach for creators with a strong visual brand or those who don’t want algorithmic choices driving their content.
CapCut is the recommended starting point for anyone using this method. It’s free, available on both mobile and desktop, and was effectively built with short-form video in mind. Adobe Premiere Pro and DaVinci Resolve are worth knowing about for advanced use cases, but they’re overkill for most repurposing workflows.
How to Manually Convert a Video to Shorts in CapCut?
  1. Open CapCut and select Create Project. W Choose a 9:16 aspect ratio from the Modify tab on the right side of the editor’s interface before importing any footage.
  1. Import your source video from your device or cloud storage. Drag and drop the video from the Import section to the Timeline. Once done, the player will show the video in a 9:16 aspect ratio.
  1. Scrub through the timeline and use the split tool to isolate the segment you want to use as your Short — aim for a natural start and end point that works as a standalone clip.
  1. Delete the footage outside your selected segment to leave only the clip you’re working with.
  1. Reposition and scale the footage within the vertical frame to center the main subject.
  1. Add auto-captions via Text > Auto Captions. Review for accuracy, adjust styling, and position them in the lower third of the frame.
  1. Add any additional text overlays, B-roll, or sound effects as needed for pacing or context.
  2. Export at 1080×1920, 30fps minimum—CapCut defaults to the correct settings for Shorts. Save to your camera roll or share directly to your platform.
CapCut’s templates library also includes Shorts-native formats if you want a faster starting point with pre-built title cards and transitions.
When to Use Premiere Pro or DaVinci Resolve Instead?
If you already edit videos professionally, using CapCut just to make Shorts isn’t needed. Premiere Pro and DaVinci Resolve make more sense in these situations:
  • You need to batch-process a large backlog of episodes with consistent color grading and branding across every clip.
  • Your source footage requires significant color correction or audio repair before it’s usable.
  • You’re delivering to a client who requires a specific project file format or edit history.
For simple repurposing of finished content, these tools are good enough.
Method 3 — Use Platform-Native Tools (Lowest Friction)
If you already upload to YouTube or TikTok, you may not need any additional software at all. Both platforms include built-in tools for creating short clips from existing uploads, making this the fastest path to zero—no new accounts, no downloads, no learning curve.
YouTube Mobile App “Remix” Feature:
Note: The YouTube Remix feature, available only in the app, converts horizontal videos into a vertical Shorts format. This option works only with your own videos. If you try to use another creator’s video, the feature will not be available.
  1. Open your YouTube mobile app.
  2. Play the video and check below the player. You will see the “Remix” option in the same area as the “Share” button.
  1. Tap “Edit into a Short”
  1. Drag the handles on the timeline to select your clip (up to 15 seconds) and click “Done.”
  2. Apply filters or effects (optional) and click “Next.”
  3. Caption your short, set visibility, and tap the “Upload Short” button.
TikTok’s built-in editor lets you upload a horizontal video and trim, add captions, and apply basic effects—though reframing options are limited compared to dedicated tools.
Instagram allows you to trim existing video into Reels during the upload flow, but offers minimal reframing control for horizontal source footage.
The honest trade-off: Platform-native tools are fast and frictionless but lack AI highlight detection, smart reframing, and caption customization. They’re best for one-off clips where you already know exactly which moment you want—not for systematic repurposing at volume.
How to Choose the Right Method?
Your workflow should match your priorities. If you’re unsure which method fits, this table makes the decision straightforward.
Your Priority
Best Method
Top Pick
Speed & volume
AI Tool
Opus Clip
Full creative control
Manual editor
CapCut
Zero extra software
Platform-native
YouTube Remix
Many creators mix methods: AI tools to process older content in batches, CapCut for clips needing special visuals, and YouTube Studio for quick, single reposts.
Best Practices to Make Your Shorts Actually Perform
Converting a video to vertical format is only half the job. These are the factors that separate Shorts that get traction from ones that stall at 200 views.
Hook in the First 3 Seconds
The algorithm doesn’t care how good your content is at the 10-second mark if viewers have already scrolled. Start with the most compelling, specific, or provocative moment in the clip—not context-setting, not an intro, not “hey guys.” Drop the viewer directly into the payoff.
Example: If your clip is a surprising business insight, open with the insight itself. Then explain the “why” afterward. Show the outcome first, then tell the story.
Add Captions (Non-Negotiable)
Over 85% of short-form videos are watched without sound, particularly on TikTok and Instagram. If your Short doesn’t have captions, a majority of your potential audience will scroll past before they’ve processed a single word. Tools like CapCut and Captions.ai generate accurate auto-captions in seconds—there’s no reason to skip this step.
Reframe for Vertical — Keep the Subject Centered
Static cropping from 16:9 often cuts off the speaker’s face, especially when they move. AI tools with subject-tracking (Opus Clip, Captions.ai) handle this more reliably than a fixed manual crop. If you’re editing manually, use CapCut’s Auto Reframe or zoom in and reposition the clip in the vertical frame so the speaker’s eyes land in the upper third of the shot—not centered at mid-frame.
Don’t Let Bad Audio Kill Your Short
Sound quality greatly affects how well Shorts perform.  A compact wireless mic like the Hollyland LARK M2—coin-sized with a 40-hour battery life—solves the problem at the recording stage, which is always easier than fixing it in an editor.
Match Length to Platform Norms
Platform
Optimal Length
Notes
YouTube Shorts
Under 60 seconds
Hard cap; vertical required
TikTok
15–60 seconds
Shorter performs better for new accounts
Instagram Reels
15–30 seconds
Highest reach in this range
Going shorter is almost always the safer bet for algorithmic discovery, especially on newer accounts.
Q: Can I turn a YouTube video into Shorts directly from YouTube?
Yes—YouTube Studio has a built-in Clip feature that lets you create Shorts from existing uploads without any third-party software. Select a segment up to 60 seconds, add a title, and publish directly to your channel. It’s limited in editing control and doesn’t offer smart reframing or captions, but it’s the fastest option for quick one-off clips.
Q: What’s the best free tool to turn videos into Shorts?
CapCut and Opus Clip’s free tiers are the strongest free options available. CapCut has no export restrictions, supports 9:16 projects natively, and includes auto-captions. Opus Clip’s free plan offers AI-powered clip detection with limited monthly exports. For most beginners, CapCut covers everything needed without a paid subscription.
Q: Do I need to refilm my video vertically to make Shorts?
No. Most AI tools and manual editors include auto-reframe or smart-crop features that convert horizontal 16:9 footage to vertical 9:16 automatically, tracking the primary subject to keep them in frame. You can repurpose existing library content without reshooting anything.
Q: How long can a YouTube Short be?
YouTube Shorts must be 60 seconds or under and filmed or exported in vertical 9:16 format. TikTok and Instagram Reels technically allow longer videos, but algorithm performance strongly favors clips under 60 seconds for discovery reach, especially for accounts still building an audience.
Q: Does audio quality matter for Shorts?
Yes, significantly. Bad audio, like muffled or echoing sound, makes viewers scroll away quickly, even with good visuals. Clear audio from the start saves editing time and keeps viewers engaged. That’s why focusing on recording quality first is much easier than fixing audio later.
AI tools are best when you need to process videos quickly and in large amounts, and manual editing is better when you want precise control and consistent branding. Platform-native tools work well when the video is already uploaded, and you want a smooth process. So start with one video to test the workflow before scaling. If things go smoothly, carry on with the next one.
