How to Make TikTok Edits in DaVinci Resolve (Step-by-Step)
DaVinci Resolve is one of the most powerful free video editors available, and it handles TikTok content far better than most creators expect. If you have moved beyond mobile editing apps already. This guide shows the full TikTok workflow in DaVinci Resolve. It covers setup, cutting, effects, color work, and export steps.
Why Use DaVinci Resolve for TikTok Editing?
DaVinci Resolve’s free version includes professional-grade color grading, smooth speed ramping, and full export control that apps like CapCut simply cannot match. The main challenge is a steeper learning curve. DaVinci Resolve was made for film and broadcast editors. It was not designed for mobile creators. But once you learn the TikTok workflow, your video quality improves clearly. This guide focuses only on what you need to make strong TikTok content, so you will not be navigating features you do not need.
Setting Up Your TikTok Project in DaVinci Resolve
Getting the project settings right before you edit is the most important step. The most common beginner mistake is editing in the default 16:9 format and trying to reframe everything at the end — this wastes time and degrades quality.
Follow these steps to configure a proper vertical TikTok project:
  1. Open DaVinci Resolve and click “New Project” on the Project Manager screen.
  2. Name your project and click “Create.”
  3. Go to File > Project Settings (or press Shift+9).
  1. Select “Master Settings” in the left panel.
  2. Under Timeline Resolution, click the dropdown and select “Custom.”
  3. Enter 1080 for width and 1920 for height. This sets the 9:16 vertical aspect ratio for TikTok.
  4. Set the Timeline Frame Rate to 30fps. This is the standard for TikTok content. If you are shooting in 60fps for slow-motion, you can still set the timeline to 30fps.
  5. Click “Save.”
Note: Always configure project settings before adding any clips to the timeline. Changing resolution after you have started editing can misalign or scale your footage unexpectedly.
Choosing the Right Page — Cut Page vs. Edit Page
DaVinci Resolve’s multi-page layout can feel overwhelming at first. For TikTok editing, you will primarily work across two pages:
  • Cut Page: Faster, simpler interface designed for rapid assembly. Great for beginners making short TikTok clips with straightforward cuts.
  • Edit Page: Full timeline with multi-track support, more precise trimming tools, and access to the Inspector panel for effects like Dynamic Zoom. Better for effects-heavy or multi-layer edits.
Recommendation: Start on the Cut Page to assemble your rough edit, then switch to the Edit Page to add transitions, text, and effects. Most TikTok edits do not require anything beyond these two pages.
Importing and Organizing Your Footage
With your project settings saved, bring your footage into Resolve:
  1. Go to the Media Page (first tab at the bottom).
  1. Navigate to your footage folder in the left-side file browser.
  2. Drag clips into the Media Pool, or use File > Import Media (Ctrl/Cmd+I).
  3. Create bins by right-clicking in the Media Pool and selecting “New Bin.” Organize by shoot day or content type.
  1. Check your file formats — Resolve natively handles MP4, MOV, H.264, and H.265 without conversion.
  2. Older or lower-spec machines: Right-click clips and select “Generate Proxy Media” to improve playback performance during editing.
Cutting and Arranging Clips for TikTok Pacing
TikTok rewards fast pacing. Clips that linger for more than three seconds without movement or change tend to lose viewers. Here is how to build a tight, rhythm-driven edit:
  1. Drag your first clip onto the timeline. In the Cut Page, this auto-creates a new timeline. In the Edit Page, drop it into the empty timeline track.
  1. Watch your footage through once and identify your strongest moments. Delete or move anything that does not add energy.
  2. Use the Blade tool (Ctrl/Cmd+B) to split clips at the exact point you want the cut. Click the playhead position, then press Ctrl/Cmd+B to cut.
  1. Delete dead air: Select the unwanted segment and press the Delete or Backspace key.
  2. Target 1–3 seconds per clip for the core of your TikTok. Your hook, the first clip viewers see, must begin with motion. It should grab attention through strong visual interest right away.
  3. Align cuts to your music beat. Import your background track first (see the audio section), then zoom into the waveform in the timeline to snap your cuts to peaks and drops.
Key shortcuts to memorize: - Ctrl/Cmd+B — Blade/razor cut - Ctrl/Cmd+Z — Undo - J/K/L — Rewind, pause, fast-forward playback - , and . — Nudge a clip left or right one frame
Adding TikTok-Style Transitions and Effects
Three transitions dominate TikTok content right now. All three are achievable in the free version of DaVinci Resolve.
  1. Jump Cut
  • Trim the end of one clip and the start of the next so the subject appears to teleport slightly in the frame.
  • Works best when there is a slight camera or subject movement between the two shots.
  • No special tools required — this is a pure editing rhythm technique executed entirely with the blade tool and precise trim points.
  1. Zoom / Punch-In Transition
  • Select the clip in the Edit Page timeline.
  • Open the Inspector panel (top-right corner).
  • Scroll to Dynamic Zoom and enable the toggle.
  • Resolve animates a smooth zoom from a wider frame to a tighter one across the clip.
  • Adjust the start and end zoom boxes in the viewer to dial in your preferred look.
  1. Whip Pan Transition
  • The most convincing version requires a matching camera pan when shooting. Edit so that one clip ends mid-pan and the next begins mid-pan in the same direction.
  • For a stylized version in post, you can find free whip pan transition overlays (MOV files with transparency) and layer them over the cut point on a track above your main footage.
  • Full motion-blur whip pans using the Fusion page are possible but go beyond the scope of this guide.
Note: Dynamic Zoom and most standard effects in this section are available in the free version of DaVinci Resolve. Some noise-reduction and advanced Fusion-based effects require DaVinci Resolve Studio.
Using Speed Ramping for Cinematic TikTok Moments
Speed ramping, where a clip slows down and then snaps back to full speed at a beat drop, is one of the most searched TikTok editing techniques and one of the clearest advantages Resolve has over mobile editors.
Follow these steps for a smooth speed ramp:
  1. Source footage shot at 60fps or higher gives you the most flexibility. Slower source footage limits how far you can slow down without visible stuttering.
  2. Right-click your clip in the timeline and select Change Clip Speed for a simple percentage-based speed change (e.g., 50% for half-speed slow motion).
  1. For a smooth, animated speed curve, right-click the clip and select “Retime Controls” (or press Ctrl/Cmd+R). A speed bar appears below the clip.
  1. Change the percentage of speed by clicking the downward arrow at the bottom of the Speed change track. Also, add a keyframe.
  1. Change the view to Curve View and check or toggle on Retime Speed.
Color Grading Your TikTok Clips
Color is one of the fastest ways to make your TikTok content look intentional rather than raw. Navigate to the Color Page (the palette icon at the bottom) and follow this streamlined workflow:
  1. Start with a node. You will see a single node already in the Node Editor at the bottom right. All adjustments you make here are non-destructive.
  2. Correct exposure first. Use the Lift/Gamma/Gain wheels on the left to fix dark shadows (Lift), mid-tone balance (Gamma), and highlight brightness (Gain). Bring the scopes (Waveform or Parade) up under View to make accurate judgments.
  1. Boost saturation for the TikTok look. In the Color Wheels panel, drag the Saturation slider to the right — start around 55–65 (default is 50). This gives the punchy, vivid look common to high-performing TikTok content.
  1. Apply a LUT for a cinematic or moody style. Right-click in the Node Editor, choose “Add Node > Add Serial,” then in the LUTs panel (Gallery or the OpenFX library), drag a LUT onto the new node. Free LUTs are available from sites like Ground Control and RocketStock.
  1. Use the Curves tool for targeted adjustments. Lift the shadows slightly for a faded film look, or increase contrast by creating an S-curve on the Custom Curve.
Two to three solid adjustments on the Color page take about five minutes and make a visible difference in content quality.
Adding Text, Captions, and Titles
On-screen text is a standard part of TikTok content. Here is how to add it cleanly in Resolve:
  1. Go to the Edit Page and open the Effects (top-left panel).
  2. Navigate to Titles in the left sidebar and locate Text+. Drag it onto a video track above your footage in the timeline.
  3. Double-click the Text+ clip in the timeline to open the Inspector panel on the right.
  1. Type your caption or title in the text field. Adjust font, size, and color in the Inspector.
  2. Reposition the text by clicking and dragging it in the viewer, or use the Transform controls in the Inspector to set an exact on-screen position.
  3. Animate text with keyframes: Move your playhead to where you want the text to appear, click the keyframe diamond next to the Opacity parameter, set it to 0. Move forward a few frames and set Opacity to 100. This creates a fade-in effect.
  4. For auto-caption-style subtitles, use the Subtitle Track option: Right-click in the timeline track header area and select “Add Subtitle Track.” Type captions frame by frame or import an SRT file.
Syncing Audio and Music
Good audio editing keeps a TikTok edit tight and professional.
Import your music or voiceover by dragging it from the Media Pool to an audio track in the timeline. Expand the audio track height to see the waveform, then align your cut points to the beats visually.
To adjust clip volume, select the audio clip and use the Inspector > Volume slider, or drag the horizontal white line on the clip up or down directly in the timeline. For basic noise reduction and EQ, switch to the Fairlight page.
If you are recording voiceovers or talking-head clips for TikTok, starting with clean wireless audio (like the Hollyland LARK M2, a 9g clip-on mic with 40-hour battery life built for vloggers) means less noise correction work in Fairlight and a faster overall edit.
Exporting Your TikTok Edit from DaVinci Resolve
The Deliver page is where many tutorials leave creators confused. Use these exact settings to export a TikTok-ready file:
  1. Navigate to the Deliver Page (the rocket icon at the bottom).
  1. Click “Custom Export” in the Render Settings panel on the left.
  2. Set Format to MP4 and Codec to H.264.
  3. Confirm Resolution is 1080 x 1920. This is the most commonly missed step — if your project settings were correct, it should populate automatically, but always double-check.
  4. Set Frame Rate to match your project (30fps for standard TikTok content).
  5. Under Bitrate Settings, select “Restrict to” and enter 10–20 Mbps. Higher bitrate preserves more detail before TikTok re-compresses on upload.
  6. Click “Add to Render Queue,” then start rendering.
Settings Reference Table:
Setting
Recommended Value
Format
MP4
Codec
H.264
Resolution
1080 x 1920
Frame Rate
30fps
Bitrate
10–20 Mbps
Max File Size
Under 500MB
Q: Can I make TikTok edits in the free version of DaVinci Resolve?
Almost every step works in the free version. In DaVinci Resolve, you can cut clips, adjust speed, color grade, add text, and export videos easily. Only AI noise reduction and some Fusion effects require Studio. For TikTok editing, the free version is fully sufficient.
Q: What frame rate should I use for TikTok edits in DaVinci Resolve?
30fps is the standard for TikTok. If your source footage was shot at 60fps or higher, keep your timeline at 30fps. The extra frames give you usable slow-motion range when you apply speed ramping without dropping below a smooth playback threshold.
Q: Why does my TikTok video look blurry or low quality after upload?
TikTok re-compresses every upload. To minimize quality loss, export at 10–20 Mbps in H.264, keep the file under 500MB, and confirm your resolution is exactly 1080x1920. Uploading over a stable Wi-Fi connection also helps TikTok retain more of your original quality.
Q: Can DaVinci Resolve make vertical (9:16) videos?
Yes. Before you begin editing, go to File > Project Settings > Master Settings and set a custom timeline resolution of 1080x1920. Set this before adding clips to the timeline to avoid scaling or cropping issues later.
You now understand the full TikTok editing workflow. In DaVinci Resolve, this includes vertical setup, fast cuts, speed changes, transitions, color work, captions, and export settings. The free version covers all of it without limits. Keep the export settings table for future TikTok edits. Return to color grading anytime you want a different look.
