Mars 4K Receiver
Mars 4K Receiver
$209.00 $329.00
Add to Wishlist
 KEY FEATURES
  • Professional Video Receiver
  • Receive up to UHD 4K30 Video up to 450'
  • SDI & HDMI Outputs, 5 GHz Frequency Band
  • Smart Channel Scanning, Touchscreen LCD
  • Low 66 ms Latency, 12 Mb/s Data Rate
  • DC, L-Series & USB-C Power Options
-36%
Mars 4K RX
Mars 4K RX
$209.00 $329.00
Mars 4K Receiver
$209.00
$329.00
Saved $120.00
A new generation wireless video transmitter that starts an age.
Take a closer look
The new Hollyland Mars 4K wireless video transmission system is capable of a 450ft (150m) LOS range and ultra-low latency of 0.06s. The Mars 4K is designed to combine high performance and reliable quality at an affordable price.
4K UHD Video Transmission
The Mars 4K supports 4K UHD video transmission at 30fps for the discerning videographer looking for high-resolution production capability.
*The Mars 4K also supports FHD and HD formats at varying frame rates–24p, 30p, and 60p.
450ft (150m) LOS Range and 0.06s Ultra-low Latency
The Mars 4K achieves an incredible LOS range of 450ft (150m) and ultra-low latency of 0.06s. Its upgraded dual-core codec chip is capable of a data rate ranging from 8 Mbps to 20 Mbps, with 12 Mbps as the default.
HDMI & SDI Dual Interfaces
The Mars 4K supports HDMI and SDI input and output for expanded connectivity and compatibility. The SDI provides expanded frame rate flexibility for both broadcast and production frame rate (decimal-point frame rate) standards and compatibility through production and postproduction.
Flexible Monitoring Options
The Mars 4K transmitter is compatible with up to two receivers or four mobile devices with the app installed. Up to four mobile devices with the app installed allow a maximum of four parties (such as the director, producer, light control personnel, and audio personnel) on the site to monitor the shooting at the same time.
Operational Efficient Design Form Factor
The Mars 4K is featured with superior corrosion and wear resistance for outstanding durability. With disassembly-free, bullet-styled antennas attached, the well-thought-out design form factor optimizes operational functionality for fast configurations.
Smart Channel Scan
The optimum channel is automatically selected after powerup with no manual selection required. For manual setting, you can easily identify any interference-free channel for connection with the smart channel scan feature.
Color LCD with an Exclusive Rocker-Styled Button
The Mars 4K features a color LCD with a user-friendly UI design that enables quick configurations and status checks. Its uniquely designed rocker-styled button greatly improves the operational setup experience.
Multiple Power Supply Options
The Mars 4K supports a wide range of DC power options—6V to 16V, NP-F batteries, and USB Type-C chargers.
