Team Talk on the Go
$399.00 $499.00
Add to Wishlist
  • 150Hz-7KHz wideband frequency response for clear audio
  • True wireless headset, no bodypack
  • 168g lightweight, comfortable to wear all day long
  • 1000' 2-way operating range
  • DECT 6.0 for stability and security
  • Instant pairing, easy to use
  • Premium acoustic echo cancellation
  • Rechargeable batteries and charger included
  • 2/3/4/6/8 headset package options
  • Mic boom up/down for easy talk/mute control
Note: The set includes a carrying case.
-20%
SOLIDCOM C1-2S
SOLIDCOM C1-2S
$399.00 $499.00
-30%
SOLIDCOM C1-3S
SOLIDCOM C1-3S
$599.00 $856.00
-30%
SOLIDCOM C1-6S
SOLIDCOM C1-6S
$1,183.00 $1,690.00
-30%
SOLIDCOM C1-8S
SOLIDCOM C1-8S
$1,559.00 $2,228.00
-20%
SOLIDCOM C1-4S
SOLIDCOM C1-4S
$799.00 $999.00
Pre-order
SOLIDCOM C1-Hub8S
SOLIDCOM C1-Hub8S
$3,799.00
Accessories Options
$219.00 $279.00
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1100' 2-Way Operating Range DECT 6.0 for Stability and Security Instant Pairing, Easy to...
Solidcom C1 HUB Base
$1,699.00
A/B grouping Announce key that mutes all the headsets for emergency messages from the HUB base.  UAC (USB Audio Class) function enables the HUB to join in any cloud meeting running on Zoom, Skype...
Solidcom C1 Remote Headset
$199.00 $259.00
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1000' 2-Way Operating Range DECT 6.0 for Stability and Security Instant Pairing, Easy to...
$99.00
Key Features For Use with Solidcom C1 HUB Wide Frequency Response for Clear Audio Comfortable to Wear All Day Long Cable with 3.5mm Connector
$19.00
Key Features Charges Two NP-F Batteries at Once For NP-F970, NP-F750, and NP-F550 USB Power Adapter Included LEDs Show Charging Status The Hollyland Dual-Slot Charger enables simult...
$69.00
Compatibility Solidcom C1 Feature Interface: USB Type-C interface and charging contact  Power supply: 5V/2A  Single charging port current: Approx. 420mA Weight: Approx. 140g (4.9oz) Size:  89...
$99.00
Feature/Specs Interface: DC power interface and a charging contact Input: AC 100–240V 50/60Hz Output: DC 12V/2A Single charging port current: Approx. 420mA Weight Approx. 140g (4.9oz) SIZE ...
Solidcom C1(Pro) - Battery
$19.00
For Solidcom C1(Pro) Headset Capacity: 700mAh (2.66Wh)  Runtime: Remote headset: ~10hMaster headset: ~6h (when connected with 3 remote headsets)Master headset: ~5h (when connected with 5 remote...
12V/2A DC2.1 Power Adapter
$30.00
1. Adaptor Dimensions: 5.5*2.1*15.5mm 2. Input: 100~240Vac 50/60Hz 3. Output: 12V/2A DC 4. Cable Length: 1.5m 5. Certification: TUV/UL/cUL/CE/PSE/GS
NP-F750 Battery
NP-F750 Battery
$29.00
Features Rated capacity: 4000mAh Type: Lithium-ion Weight: 205g (7.2oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
NP-F970 Battery
NP-F970 Battery
$39.00
Features Rated capacity: 6000mAh Type: Lithium-ion Weight: 300g (10.6oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS...
Solidcom C1 (Pro) Carry Case for 2 & 3 Headset Systems
Solidcom C1 (Pro) Carry Case for 2 & 3 Headset ...
$29.00
Material: Cloth bag  Color: Black Convenient and portable with a built-in compartment as well as moisture-resistant and stain-resistant design Weight:  Approx. 440g (15.5oz) Size:  200x200...
NP-F550 Battery
NP-F550 Battery
$19.00
Features Rated capacity: 2000mAh Type: Lithium-ion Weight: 100g (3.53oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
$9.90
Compatibility SOLIDCOM C1 Feature/SpecsOn-Ear Earmuff Material: Sponge (environmentally friendly, safe, and reliable) Color: Black WeightApprox. 1.0g (0.04oz) each SIZE62.1x15.6mm (2.4"x0.6") What’...
$9.90
Compatibility SOLIDCOM C1, Solidcom C1 Pro Feature Over-Ear Earmuff Material: Leather + Foam + Cloth (environmentally friendly, safe, and reliable) Color: Black WeightApprox. 22.0g (0.78oz) each ...
$19.00
Frequency range: 1.88–1.93GHz  VSWR: 1.88-1.93G≤2.0  Impedance: 50Ω Gain: 3dBi  Color: Black Weight: Approx. 28.5g (1oz) for each Size: 205x13mm (8.1"x0.5") What’s in the Box? Solidcom C1 HUB...
$49.90
Key Features Store & Transport Intercom System For Solidcom C1 and C1 Pro Headsets Hold and Organize up to 8 Headsets Designed with 3 Partitions The Hollyland Solidcom C1 Pro Carry Case for 8...
Solidcom C1 (Pro) Carry Case for 4 & 6 Headset ...
$39.00
Material: Cloth bag  Color: Black Convenient and portable with a built-in compartment as well as moisture-resistant and stain-resistant design Weight: Approx. 910.5g (32.1oz) Size: 375x200x175mm ...
Solidcom C1 (Pro) Mic Cushion ×12
$9.90
  Compatibility SOLIDCOM C1/C1 PRO Feature/SpecsMic Cushion Material: Sponge (environmentally friendly, safe, and reliable)Color: BlackSIZE18.6x26.9mm (0.7"x1.1")What’s in the Box?Solidcom C1 (PR...
RJ45 to Dual XLR Cable (CA01)
$59.00
HV-CA01
$9.90
Compatibility SOLIDCOM C1 PRO SOLIDCOM C1 Feature Material: Albumen texture for a comfortable fit with the stain-resistant and slip-resistant design What’s in the Box?  Headset Ear Pad *3 ...
$399.00
$499.00
Saved $100.00
