Redefine Reliability - Wireless Video Solution
$999.00 $1,299.00
Add to Wishlist
2TX & 1RX Solution
3,000ft (1,000m) LOS Range & 33ms Ultra-Low Latency
Seamless Frequency Hopping Technology with HEVO 2.0
NDI HX3 & HDMI & SDI Ports Support
UVC & RTMP Streaming & Multi-Platform Support
FPS Booster
Fractional Frame Rate
Versatile Power Options
Customizable Frozen Frame
-23%
1 Transmitter and 1 Receiver Kit
$999.00 $1,299.00
-23%
2 Transmitters and 1 Receiver Kit
$1,299.00 $1,699.00
Wireless Video Transmitter
$399.00
Accessories Options
Crab Clamp
Crab Clamp
$17.00
Features Rod diameter: 54mm (2.1") Material: Aluminium Color: Black Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 MARS 400S PRO ll What's in the Box Crab Clamp*1
D-TAP to DC 2.1 Power Supply Cable
$23.99
Usage: Connect the V-mount battery to power Hollyland video transmission products Weight: 27.5g length: 65 cm
Soft Antenna
Soft Antenna
$17.00
With its flexible stem design, the Hollyland soft antenna can be easily adjusted to different angles, allowing for optimal placement and improved signal strength. Compatibility COS...
Mushroom Antenna
Mushroom Antenna
$9.00
Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 Features 5 dBi Double High-Gain 90 to 360° Rotating Anti-Pressure 5.8 GHz Transmission Rate Anti-Pressure Material Technology Gold-Pla...
Screw Fitting 02
Screw Fitting 02
$9.90
The Screw Fitting 02 is for the use of mounting the Mars 4K or Cosmo C1 horizontally in necessary senarios. It comes a 1/4"-20 mounting thread to mount on to your cage or other gears that come with...
$999.00
$1,299.00
Saved $300.00
