Fuel Your Connections
$189.00 $239.00
Add to Wishlist
KEY FEATURES
  • 1 Transmitter & 4 Receivers (1TX & 1RX in box)
  • 1,300ft (400m)
LOS Range
  • 0.06s Low Latency
  • 2.4GHz & 5GHz Dual Band
  • 4K30 Transmission
  • HDMI Loopout
  • UVC Streaming
  • Smart Channel Scan
-22%
$369.00 $479.00
-20%
Single Transmitter
Single Transmitter
$189.00 $239.00
-20%
Single Receiver
Single Receiver
$189.00 $239.00
Accessories Options
Screw Fitting for Stabilizer
$9.99
Mount Pyro H TX or RX onto Gimbal Provides Single 1/4"-20 Mounting Thread Mounts Using Shoe Adapter L-Shaped, Lightweight Construction
$4.99
Compatibility Pyro H/Pyro S/Pyro 7 What's in the Box Cylindrical Antenna (2.4GHz & 5GHz)*2
Rotatable Cold Shoe Mount
$9.99
Pyro Series-Thumb Antenna 2.4GHz & 5GHz
$11.99
CompatibilityPyro 7Pyro HPyro S   What's in the BoxThumb Antenna(2.4GHz & 5GHz)*2
$189.00
$239.00
Saved $50.00
