Seamless Team Talk - (Global Version-2.4GHz)
$367.00 $765.00
Add to Wishlist
  1. ENC Noise Reduction
    • Solidcom SE features an ENC dual - mic noise reduction design. It can dynamically recognize environmental noise with a noise reduction depth of up to 20dB.
  2. Clear Call Quality
    • It offers clear calls, with a frequency response range of 150Hz - 7KHz and a signal - to - noise ratio > 71dB.
  3. Waterproof and Design
    • With an IPX4 - level waterproof design, the overall headphone adopts precise industrial design.
  4. Automatic Frequency Tuning
    • Equipped with an automatic frequency - tuning algorithm, it can automatically adjust the frequency when encountering interference and has a 350m transmission distance without visual - range obstruction.
  5. Easy to Use
    • It is ready to use right after being powered on. It supports up to 5 - way collaborative communication.
  6. Mute Function
    • There are two mute options: the MUTE button and muting by flipping up the microphone boom. The MUTE button supports the PTT mode.
  7. Battery Life
    • The fully - charged headphone has a battery life of up to 12 hours and supports charging while using.
Note: The set includes a carrying case.
-52%
Solidcom SE-4S
Solidcom SE-4S
$367.00 $765.00
-52%
Solidcom SE-2S
Solidcom SE-2S
$183.00 $382.00
-52%
Solidcom SE-5S
Solidcom SE-5S
$463.00 $965.00
Pre-order
-39%
Stereo Remote Headset Single-Ear
$119.00 $198.00
Accessories Options
$19.99 $29.99
Compatibility Solidcom SE Solidcom SE Global Version What's in the Box USB-C to 3.5mm Cable*1
Solidcom SE Over-Ear Ear Pads
$9.90
What's in the box?Over-Ear Ear Pads*1
Solidcom SE Ear Pads
$9.90
What's in the box?Ear Pads*1
Solidcom SE Mic Cushion 01
$9.90
What's in the box?Mic Cushion 01*1
$69.90
What's in the box?  6-Slot Charging Base*1USB-A to USB-C Cable*1User Manual*1Warranty Card*1
Solidcom SE Li-ion Battery Pack 770
$19.90
Compatibility Solidcom SE What's in the Box Li-ion Battery Pack 770*1 Warranty Card*1
Solidcom SE 8-Slot Charging Base
$99.90
What's in the box?8-Slot Charging Base*1USB-A to USB-C Cable*1User Manual*1Warranty Card*1"
$367.00
$765.00
Saved $398.00
