7-Inch Wireless Monitor
$599.00 $688.00
Add to Wishlist
KEY FEATURES
  • 1TX & 4RX (1 Monitor in box)
  • 1300ft (400m) & 0.06s Latency
  • 2.4 GHz & 5 GHz Dual Band
  • Auto Frequency Hopping
  • TX, RX, and Monitor – All in One
  • Dual-View Quick Monitoring Switch
  • 7-Inch & 1500 nits
  • Precise Image Analysis
  • SDI & HDMI Loopout
  • RTMP Streaming
-12%
$599.00 $688.00
-20%
Pyro 7 Dual Kit
Pyro 7 Dual Kit
$999.00 $1,249.00
-16%
Pyro 7 & Pyro S Bundle
$1,049.00 $1,249.00
Accessories Options
Monitor Hood (7-Inch)
$26.99
What's in the Box Monitor Hood (7-Inch)*1
G-Mount Battery Plate
$119.99
Power Pyro 7 Transceiver/Monitor Replaces Original Battery Plate Fits One Gold Mount Battery Provides up to 10-18V Power
$49.99
Compatibility MARS M1 ENHANCED/Pyro 7/Pyro 5 What's in the Box Side & Bottom Mounted Aluminum Handle*1
$4.99
Compatibility Pyro H/Pyro S/Pyro 7 What's in the Box Cylindrical Antenna (2.4GHz & 5GHz)*2
$23.99
Compatibility MARS M1 ENHANCED/Pyro 7/Pyro 5 What's in the Box D-Tap to Locking DC Power Adapter Cable*1
$11.99
Features  For Pyro S/H RX or TX RP-SMA Antenna Supports 2.4 and 5 GHz Frequency Bands Supports up to 1300' Transmission What's in the Box Paddle Antenna (2.4GHz & 5GHz)*1
Dual Rosewood Handles (7-Inch)
$109.99
Adjustable length Wide shoulder strap What's in the Box Shoulder Strap 01*1
Shoulder Strap 01
Shoulder Strap 01
$19.99
12V/2A DC Power Adapter
$30.00
Features Compatible with Wireless Tally System, Pyro S, Pyro H 12 VDC with DC Barrel Connectivity What's in the Box 12V/2A DC Power Adapter*1
V-Mount Battery Plate
$119.99
Power Pyro 7 Transceiver/Monitor Replaces Original Battery Plate Fits One V-Mount Battery Provides up to 10-18V Power
Pyro Series-Thumb Antenna 2.4GHz & 5GHz
$11.99
CompatibilityPyro 7Pyro HPyro S   What's in the BoxThumb Antenna(2.4GHz & 5GHz)*2
$599.00
$688.00
Saved $89.00
