1 / 10
Stay Connected, Roam Freely
$9,189.00
Add to Wishlist
  • Full-duplex Communication
  • 500m Transmission Range
  • High-quality Audio
  • Hub Cascading and Expansion Interfaces
  • Roaming Functionality
  • Multiple Power Supply Options
  • UAC Function via USB
  • Upgrade Options
  • Flexible Configuration
    Solidcom C1 Pro - Roaming Hub 10S (G-mount)
    $9,189.00
    Solidcom C1 Pro - Roaming Hub 20S (G-mount)
    $12,179.00
    Solidcom Roaming Hub (G-mount)
    $5,999.00
    Solidcom C1 Pro - Roaming Hub 10S (V-mount)
    $9,189.00
    Pre-order
    Solidcom C1 Pro - Roaming Hub 20S (V-mount)
    $12,179.00
    Pre-order
    Solidcom Roaming Hub (V-mount)
    $5,999.00
    Pre-order
    Accessories Options
    Solidcom C1 Pro - Roaming Hub20S Hard-shell Carry Case
    Solidcom C1 Pro - Roaming Hub20S Hard-shell Car...
    $899.00
    Durable hard-shell construction. Specifically designed for Solidcom C1 Pro Roaming Hub20S. Accommodates 20 Solidcom C1 Pro headsets and the hub. Provides storage for other related accessories.
    Solidcom Headset Sticker
    $9.90
    Helps in organizing and identifying specific headsets easily. Facilitates quick recognition of a particular headset in a group.
    Solidcom Roaming Hub Antenna
    $39.00
    Solidcom Roaming Hub Antenna *1
    Solidcom Roaming Hub Hard-shell Carry Case
    $399.00
    Hard-shell protection. Specifically for Solidcom Roaming Hub. Convenient storage. Secure transportation.
    Solidcom Roaming Hub Waterproof Bag
    $19.00
    Waterproof protection for Solidcom Roaming Version. Durable construction to withstand various conditions. Ensures the safety of devices in wet environments. Compact and portable for easy use.
    $9,189.00
