USB-C to USB-C Cable
1 / 2
$19.90
The USB-C to USB-C cable enables easy connection between the receiver and a mobile device with a Type-C port. It also facilitates file transfer from the built-in storage of the Lark Max Transmitter.
Compatibility
Lark Max, Lark M2
Features
  • Cable Length: 1 ft./0.3 m
  • Digital audio transmission
  • Compatible with all Android devices with Type-C port
  • Flat-head design for enhanced compression and torsion resistance
Weight: 0.0238kg (0.84oz)
Size: 120mm x 70mm x 20mm(4.7" x 2.7" x 0.79")
Included: USB-C to USB-C Cable *1
$19.90
$19.90
