9-Person Noise-Cancelling Intercom System
$649.00 $812.00
Add to Wishlist
  • Push-to-Talk Wireless Intercom: Beyond the Walkie-Talkie Experience
  • 24-hour Long Duration: Each Headset comes with an Extra Battery-Never Run Out of Power
  • Active Environment Noise Cancellation
  • Up to 1100ft (350m) Transmission Range
  • Full Duplex Communication
  • Backward Compatible with the First Generation Solidcom C1
-20%
Solidcom C1 Pro - 2S
$649.00 $812.00
-20%
Solidcom C1 Pro - 4S
$1,299.00 $1,624.00
-20%
Solidcom C1 Pro - 4S DH(Double Earmuff)
$1,399.00 $1,749.00
Solidcom C1 Pro Hub4S
$3,299.00
Solidcom C1 Pro Hub8S
$4,499.00
-20%
Solidcom C1 Pro - 3S
$979.00 $1,224.00
-20%
Solidcom C1 Pro - 6S
$1,949.00 $2,437.00
-20%
Solidcom C1 Pro - 8S
$2,549.00 $3,187.00
Accessories Options
$359.00
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1100' 2-Way Operating Range DECT for Stability and Security Instant Pairing, Easy to Use...
$339.00
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1000' 2-Way Operating Range DECT for Stability and Security Instant Pairing, Easy to Use...
Solidcom C1 Pro Master Headset Double-Ear Version
$389.00
Enhanced Noise Reduction with Dual Microphones Dependable 1.9 GHz DECT 6.0 Technology Cable-Free Headset for True Wireless Experience Dual-Ear Design for Comfortable Fit Clear Audio Performance wi...
Solidcom C1 Pro Remote Headset Double-Ear Version
$369.00
Solidcom C1 Pro Hub
Solidcom C1 Pro Hub
$1,799.00
Enhance the functionality of your intercom system by incorporating the Hollyland Solidcom C1 Pro Hub Base. Although the Solidcom C1 Pro system is capable of operating up to 8 headsets without a Hub...
$649.00
$812.00
Saved $163.00
