LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
LARK M1
1 / 29
LARK M1
Tiny, But Mighty.
$59.00 $79.00
Add to Wishlist
  • HearClear Noise Cancellation
  • Charge & Store Two-in-One
  • Easy to Use Plug and Play Design
  • Tiny & Light Design
  • Hi-Fi Sound Quality
  • Stable Connection
  • 650ft (200m) Transmission (LOS)
  • Wide Compatibility
-25%
Lark M1 Duo
Lark M1 Duo
$59.00 $79.00
Accessories Options
Phone Holder
Phone Holder
$12.90
Compatibility LARK 150 LARK M1 Feature 1. Aluminum alloy with lightweight and strong protection2. Integrated cold shoe design for an external microphone or fill light3. Thick protective pad4. 65~...
Universal Phone Kit
Universal Phone Kit
$49.00
Compatibility:LARK C1LARK M1LARK 150 Features:Universal phone kit for vlogging, live streaming, and video shootingIt features two cold shoe ports and multiple 1/4 threaded holes and can be connecte...
Multifunctional Tripod
$19.00
Compatibility LARK 150 LARK M1 Feature1. Lightweight and portable with an excellent load-bearing structure2. 4-segment height adjustable3. Integrated cold shoe design for an external microphone o...
Mini Tripod Stand with Universal Clip
$35.99
Multifunctional  Tripod:• Compact and lightweight with only 170g• Foldable design for both handheld and desktop use• 4-section extendable design to adapt different scenarios• Mini and portable with...
3.5mm TRS-to-Lightning Cable
$17.90
Compatibility Lark Max Lark M1 Lark 150 Features Universal audio cable for cameras 3.5 mm male TRS to male Lightning About 32cm long when fully stretched Multiple layers of protection for stron...
3.5mm TRS-to-USB Type-C Cable
$9.90
Compatibility Lark Max Lark M1 Lark 150 Feature/SpecsConvert 3.5mm TRS into USB-C audio output, suitable for Android phones Length:  45cm The interface adopts integrated molding, with stronger co...
LARK M1
$59.00
$79.00
Saved $20.00
