MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
MELO P1
1 / 18
MELO P1
New
MELO ON THE GO - A Complete Wireless Studio for Singing, Streaming and Recording
$249.00
Add to Wishlist
Feature
  • All-in-One Wireless Studio
  • Fully Wireless Connectivity
  • Ultra-Light & Portable Design
  • Studio-Grade Sound Quality
  • Pro Sound Mixing · App Control
  • AI Noise Cancellation
  • Long-Lasting Battery Life
  • Durable & Premium Design
Product Description
MELO P1 is a groundbreaking, All-in-One wireless studio that condenses a traditionally complex multi-device setup into a single, ultra-lightweight system. It preserves every sonic nuance, delivering uncompromising high-fidelity right out of the box. With the HollyAudio App, professional tuning becomes effortless—giving you access to over 100 expert presets tailored to your unique voice. So you can just bring your musical spark, and MELO P1 will take care of the rest.
[All in one. One for all.]-MELO P1 is a fully integrated, wireless record-and-mix studio built to capture inspiration the moment it strikes.
[No messy cables, no complex routing]-Just studio-grade capture, real-time DSP mixing, and monitoring in a backpack-friendly setup, built for creating on the go.
[Your studio, to go.]-Ultra-light, fully wireless[1], and instant-connect—the MELO P1 lets you capture your next big idea anywhere within 60 meters, instantly.
[1] Microphones and earphones connect to the smart audio mixer over 2.4 GHz wireless with a 60m range in general environments and 8m in complex environments; phones used for backing-track playback and the remote control connect to the mixer over Bluetooth up to 10m.
[Your Voice At Its Best]-Every device is meticulously crafted to deliver studio-grade sound without compromising on portability, bringing the ears and expertise of a master audio engineer right into your grab-and-go setup.
Microphone:A 1-inch large-diaphragm condenser mic with a shock-absorbing chamber and AI noise cancellation for ultra-clear, natural vocals.
Smart Audio Mixer:Weighing just 55g, this Dual-DSP mixer enables 4-source [2] real-time mixing and 32-bit digital processing for polished, studio-grade sound.
Earphone:Custom-tuned 10mm drivers deliver balanced monitoring via 2.4GHz wireless and Bluetooth in an ultra-lightweight, comfortable fit.
[2] Four input sources consist of two wireless microphones, one 3.5 mm instrument input, and one Bluetooth backing-track input.
[MELO. Mix. Made Easy.]-Nail your perfect mix in HollyAudio.
[100+ presets tailored for your voice. ]-Explore expertly tuned presets in HollyAudio to shift your mix on the fly when singing or chatting. To further cut the prep work, Record for Preview is built to save your time on soundchecks once and for all. This is all designed to free your creativity from technical limits.
[Fine-tune your mix.]-Whenever you want to dive deeper, a pro-grade chain of 9 studio effects gives you the ultimate precision to sculpt every detail.
[10 Effects]- EQ, full-band compression, multiband compression, sidechain compression, de-essing, reverb (delay, hall), harmonic saturation, and M/S EQ.
[From your desk to the world.]-MELO P1 excels everywhere you create—bringing professional-grade performance to streaming, recording, and live shows.
[Keep the power going.]-Lasts 40 hours[3]. MELO P1 always keeps pace with your creativity. Speed to start. Power to finish.
[3]:On a single charge, the Smart Audio Mixer provides up to 8 hours of operation, while the microphone delivers at least 12 hours with AI noise cancellation on (or up to 13 hours with AI noise cancellation off) and the monitoring earphones provide up to 9 hours. The charging case can fully recharge each device up to three times, enabling a total system runtime of up to 40 hours.
[Design that holds up.]-Crafted with a premium matte finish and a durable build, MELO P1 feels right in hand and is built to last through every challenge.
[Stay in the flow.]-Trigger effects, switch presets, or adjust reverb instantly with tactile remote shortcuts, ensuring you never miss a beat.
[The best of both platforms.]-Dual USB-C ports deliver your mix to two platforms at once. Integrated power management ensures your audio and fast charging [4] never skip a beat. Two phones, fully powered. One stream, twice the reach.
[4] PD-compatible fast charging, up to a combined 60 W.
[Stream in seconds. ]-MELO P1 gets you live in seconds—no DAW, no installation, no complex setup.Simply connect it to your phone or computer, with all controls and tuning handled in the HollyAudio app.
MELO P1  Solo
MELO P1 Solo
$249.00
MELO P1  Combo
MELO P1 Combo
$399.00
MELO P1
MELO P1 Ultimate Combo
$449.00
Accessories Options
MELO P1-Dynamic Handheld Microphone
$139.00
MELO P1-Smart Audio Mixer
$119.00
MELO P1-Interchangeable Dynamic Capsule
$59.00
MELO P1
$249.00
