LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
LARK C1
1 / 23
LARK C1
Mobile Audio Made Easy
$37.00 $49.00
Add to Wishlist
  • Plug and Play. Lark C1 is ready when out of the box, making it easy to use.
  • Usable While Charging. Both the TX and RX of Lark C1 are equipped with a Type C interface, you can power it up during use. No battery anxiety anymore.
  • Immediate Playback. Unlike similar products, you don't need to remove the plug from the phone to play the recorded audio through the speaker. Direct playback is available and helps to check the audio promptly.
  • Hi-Fi Sound Quality. The sampling rate of Lark C1 hits 48kHz. It keeps rich details of the audio. 16-bit depth provides a perfect dynamic range and better signal-to-noise ratio for video making.
  • With MFi Certification. MFi is the abbr. of made for iPhone&iPad. With this certification, the usage of Lark C1 won't affect the warranty of your iPhone. It'll be a reliable companion in your adventure of creation.
  • Smart Noise Cancellation. With Hollyland's latest wireless transmission technology, you can record crisp audio near or far away from the camera.
  • Ultra-long Duration of 32 Hours. Plus the battery of the charging case, the whole system can work for 32 hours. When fully charged, each transmitter works continuously for 8 hours, covering a full-day recording.
  • 650ft (200m) LOS Range. With Hollyland's latest wireless transmission technology, you can record crisp audio near or far away from the camera.
  • Advanced In-App Operation. Hollyland designed the HollyAudio app allowing flexible control over noise-canceling level and input audio volume. The dynamic change of the volume level and the battery status can be checked at a glance.
-24%
Lark C1 Solo / iOS(Lightning version) / Cool Black
$37.00 $49.00
-25%
Lark C1 Duo / iOS(Lightning version) / Cool Black
$59.00 $79.00
-25%
Lark C1 Duo / iOS(Lightning version) / Ivory White
$59.00 $79.00
-28%
LARK C1
Lark C1 Duo / Android(type-c version) / Cool Black
$49.00 $69.00
Accessories Options
Mini Tripod Stand with Universal Clip
$35.99
Multifunctional  Tripod:• Compact and lightweight with only 170g• Foldable design for both handheld and desktop use• 4-section extendable design to adapt different scenarios• Mini and portable with...
$19.00
Compatibility LARK 150 LARK M1 Feature1. Lightweight and portable with an excellent load-bearing structure2. 4-segment height adjustable3. Integrated cold shoe design for an external microphone o...
Phone Holder
Phone Holder
$12.90
Compatibility LARK 150 LARK M1 Feature 1. Aluminum alloy with lightweight and strong protection2. Integrated cold shoe design for an external microphone or fill light3. Thick protective pad4. 65~...
Universal Phone Kit
Universal Phone Kit
$49.00
Compatibility:LARK C1LARK M1LARK 150 Features:Universal phone kit for vlogging, live streaming, and video shootingIt features two cold shoe ports and multiple 1/4 threaded holes and can be connecte...
LARK C1
$37.00
$49.00
Saved $12.00
