Changing audio speed in Adobe Premiere Pro becomes simple after finding the right controls. These options are not inside the audio editing panels. You can find them in the Speed/Duration window or timeline tools. This guide explains both methods in clear and simple steps. It also shows how to slow down audio separately from video clips. You will also learn how to avoid unwanted pitch changes.
Why Slowing Down Audio in Premiere Pro Is Slightly Pain in the Neck?
Audio and video clips in Adobe Premiere Pro stay linked by default. A speed change affects both tracks at once unless separated first. Slowing a clip also lowers its pitch automatically during playback. This makes speech sound unnatural and music drift out of key. Both problems are easy to fix with deliberate adjustments. The steps below explain how to handle them clearly.
Method 1 — Use the Speed/Duration Dialog (Most Reliable)
The Speed/Duration dialog gives you precise control over how much you slow a clip and lets you enable pitch preservation in the same window. This is the right method for most situations.
Select your audio clip on the timeline. If the clip has linked audio and video, right-click on the file and select “Unlink.”
Right-click the clip and choose Speed/Duration from the context menu. You can also press Ctrl+R (Windows) or Cmd+R (Mac) with the clip selected.
Enter a speed percentage below 100%. Typing 50 sets the clip to half speed; 75 creates a subtle slowdown.
Check the “Maintain Audio Pitch” box. This instructs Premiere Pro to time-stretch the audio without shifting the pitch downward.
Click OK. The clip expands on the timeline to fill the new, longer duration.
Note: If you skip the “Maintain Audio Pitch” checkbox, voices will sound lower and music will shift out of key. It takes one second to check the box — always do it unless a pitch drop is intentional.
What Percentage Should You Use?
Use this as a quick reference when deciding how much to slow your clip:
Speed Percentage |
Effect |
75% |
Subtle slowdown, barely perceptible |
50% |
Half speed — clear slow-motion feel |
25% |
Dramatic effect, noticeable stretching artifacts |
Below 25% |
Heavy degradation, especially on compressed audio |
Heavy slowdowns make audio flaws easier to hear. Small issues in the original recording become more obvious. Starting with clean, high-quality audio helps reduce these problems. A 32-bit Float recording holds more detail during editing. A wireless mic like the Hollyland LARK MAX 2 records in this format. It handles strong time stretching much better. Compressed low-bitrate audio breaks apart more quickly when slowed down.
Method 2 — Use the Rate Stretch Tool for Visual Adjustment
The Rate Stretch Tool is the faster option when you want to match a clip’s duration to a specific gap on the timeline without calculating an exact percentage.
Select the Rate Stretch Tool from the toolbar. The keyboard shortcut is R.
Hover over the right edge of your audio clip until the cursor changes to a resize bracket.
Click and drag the edge to the right to stretch the clip. The further you drag, the slower the playback speed.
Release the mouse. Premiere Pro recalculates the speed automatically and displays the resulting percentage on the clip.
Note: The Rate Stretch Tool does not show a live percentage while dragging, so it is less precise than the Speed/Duration dialog. Use it when a visual fit on the timeline matters more than an exact number. After stretching, open Speed/Duration (Ctrl+R / Cmd+R) to confirm or enable “Maintain Audio Pitch.”
How to Slow Down Audio Without Affecting the Video
By default, Premiere Pro links audio and video on the same clip, so slowing one slows both. To slow only the audio track, unlink them first.
Right-click the clip on the timeline and select Unlink (see Method 1). The audio and video tracks are now independent.
Click somewhere else to deselect everything, then click only the audio portion of the clip. Confirm that the video track above it is not highlighted.
Apply Speed/Duration (Ctrl+R / Cmd+R) or the Rate Stretch Tool to the audio track only.
Manage sync manually after adjusting. You can re-link both tracks by selecting each one, right-clicking, and choosing Link, though re-linking after a speed change will not restore the original sync automatically.
Warning: Unlinking breaks the automatic sync between your audio and video. After slowing the audio, the two tracks will drift apart on the timeline. Be intentional about this before proceeding, and plan to trim or re-align the video if needed.
Fixing Pitch After Slowing Down Audio
If you have already slowed a clip and the pitch sounds wrong, there are two ways to correct it.
The fastest fix is to re-open the Speed/Duration dialog (Ctrl+R / Cmd+R), check “Maintain Audio Pitch,” and click OK. Premiere Pro applies the correction to the current speed without resetting it.
For more manual control over the exact pitch shift:
Open the Effects panel
Search for Pitch Shifter
Drag the effect onto the audio clip
Open Effect Controls and make sure the Pitch Shifter effect appears. If it doesn’t, it means you have applied the effect.
Now, click the “Edit” button and adjust the Semitones value until the pitch sounds correct
Pitch drops when you slow a clip because the audio waveform is stretched out, causing the same sound waves to complete fewer cycles per second, which the ear registers as a lower tone. The “Maintain Audio Pitch” option runs a time-stretching algorithm that compensates for this automatically.
Q: Can I slow down only part of an audio clip in Premiere Pro?
Yes. Use the Razor Tool (C) to cut the clip at the start and end points of the section you want to slow, then apply Speed/Duration or the Rate Stretch Tool to that segment only. The clips on either side stay at their original speed. Trim surrounding clips or close any resulting gaps on the timeline manually.
Q: Does slowing audio in Premiere Pro change its pitch?
By default, slowing a clip also lowers its pitch. You can stop this by enabling “Maintain Audio Pitch” in the Speed/Duration window. Open it using Ctrl+R on Windows or Cmd+R on Mac. Turn on the option before confirming the change. This setting must be applied at the same time you adjust speed. If you miss it, you cannot fix it afterward directly. You would need to reapply the speed or add an audio effect manually.
Q: Why does my audio sound distorted or robotic after slowing it down?
When audio is stretched to under 40% speed, distortion becomes easier to hear. Speech and layered sounds are affected the most. Adobe Premiere Pro has limits in its time stretch processing. Pushing it too far makes the sound feel unnatural and robotic. Using high-quality source audio helps reduce this issue. Uncompressed 48kHz WAV files hold up better during heavy slowing.
Q: Is there a keyboard shortcut to open Speed/Duration in Premiere Pro?
Yes. With a clip selected on the timeline, press Ctrl+R on Windows or Cmd+R on Mac to open the Speed/Duration dialog immediately. This shortcut works for both standalone audio clips and linked audio/video clips.
For precise control, use the Speed/Duration dialog, enter your percentage, and always check “Maintain Audio Pitch” before clicking OK. When a quick visual fit on the timeline is all you need, the Rate Stretch Tool gets the job done faster. Once your audio speed is set, a useful next step is learning how to reduce background noise using Premiere Pro’s Essential Sound panel. This is especially helpful if time-stretching has made any ambient noise more prominent in the mix.
