Poor sound can drag down a video that looks great. You may notice light hiss, steady hum, or noise from the room. Inside Premiere Pro, several tools help clean audio without extra software. This guide explains each option from quick fixes to detailed control. You can choose what fits best and continue editing without delays.
Why Your Audio Sounds Noisy in Premiere Pro
Before applying any fix, it helps to identify what type of noise you’re dealing with. The most common culprits are:
Background hiss: Usually caused by preamp noise, a low-gain recording signal, or a cheap microphone in a quiet room
Electrical hum: A steady 50Hz or 60Hz buzz from nearby power sources, fluorescent lighting, or ungrounded cables
Room noise and reverb: Air conditioning, traffic, or ambient room tone that the microphone picked up alongside dialogue
Wind and low-frequency rumble: Common in outdoor recordings, often showing up as a low, rolling muffle beneath the voice
Each noise type responds better to a specific tool, which is why Premiere Pro offers more than one option.
Method 1: Use the Essential Sound Panel to Denoise Quickly (Best Starting Point)
The Essential Sound panel is the fastest route to cleaner audio for most users. It requires no deep audio knowledge and produces solid results in under a minute.
Open the Essential Sound panel by going to Window > Essential Sound
Select the audio clip on your timeline that needs cleaning
In the Essential Sound panel, click Dialogue to tag the clip type
Check the box next to Reduce Noise and drag the slider to start between 5 and 10
If your recording has a low-end muffle or room rumble, also enable Reduce Rumble
Press play and listen carefully through headphones to evaluate the result
Adjust the slider incrementally if needed, but avoid pushing it above 15 unless the noise is severe
Starting in the 5 to 10 range gives Premiere’s noise reduction algorithm room to work without stripping too much natural tone from the voice.
How to Avoid Over-Processing with the Denoise Slider?
Pushing the Reduce Noise slider too high is the most common mistake editors make with this panel. When the algorithm removes too much, dialogue starts to sound underwater, hollow, or robotic. Here is how to stay on the right side of that line:
Make adjustments in small increments (try 2–3 points at a time) and listen after each change
Always monitor through headphones rather than laptop or monitor speakers; artifacts are much easier to catch with headphones
Check the clip in context by playing a few seconds before and after the processed section, not just the isolated clip
If you cannot get clean audio without artifacts, move to the DeNoise effect (Method 2) for more precise control
Method 2: Apply the DeNoise and DeHum Effects for More Control
When the Essential Sound panel is not enough, Premiere Pro’s dedicated audio effects give you granular control over how noise reduction is applied.
Using the DeNoise Effect
The DeNoise effect works by analyzing the audio signal and reducing broadband noise across the frequency spectrum. It is best for hiss, tape noise, and general background noise.
Open the Effects panel (Window > Effects)
Navigate to Audio Effects > Noise Reduction/Restoration
Drag the DeNoise effect onto your audio clip or track
Open the Effect Controls panel (Window > Effect Controls)
Click Edit or Custom Setup next to the DeNoise effect to open the full editor
Adjust the Amount slider, starting around 50%, and increase gradually while listening
Use the Fine Tuning controls to reduce artifacts on specific frequencies if the voice sounds processed
The Custom Setup editor gives you access to controls that the Essential Sound panel hides, making it the better choice when you need to preserve vocal character while cutting noise.
Using the DeHum Effect for Electrical Buzz
If your audio has a constant tonal buzz rather than random hiss, you are likely dealing with electrical hum. The DeHum effect is purpose-built for this.
In the Effects panel, navigate to Audio Effects > Noise Reduction/Restoration
Drag DeHummer onto your clip
In Effect Controls, click Edit to open the DeHummer editor
Select the correct base frequency: 60Hz for North America and Japan; 50Hz for Europe, Australia, and most of Asia
Adjust the Number of Harmonics if the buzz has overtones extending up the frequency range
Play back and listen to confirm the buzz is gone without affecting vocal clarity
To tell hum from hiss: hum is a single, steady tone that does not vary in pitch. Hiss sounds more like static and changes character with the recording environment. If you have both, apply DeHum first, then DeNoise.
Method 3: Restore Dialogue with Adobe Enhance Speech (AI-Powered)
Adobe Enhance Speech uses machine learning to separate and improve voice recordings. It is particularly effective on dialogue that was recorded in a noisy or reverberant environment where standard denoise tools leave artifacts.
Select your audio clip on the timeline
Open the Essential Sound panel and tag the clip as Dialogue
Click Enhance Speech near the bottom of the Dialogue options
Premiere Pro will upload the audio to Adobe’s cloud servers for processing (internet connection required)
Once processing is complete, the enhanced version is automatically returned and applied to your sequence
Compare the original and enhanced versions by toggling the effect on and off in Effect Controls
A few things worth noting:
Works best on voice-only audio; music beds or mixed recordings produce inconsistent results
Requires an active Adobe account and internet access at the time of processing
Results are non-destructive; the original file remains untouched
Processing time varies by clip length, typically under a minute for short dialogue clips
Method 4: Use EQ to Reduce Frequency-Specific Noise
The Parametric Equalizer in Premiere Pro lets you surgically reduce noise in a specific frequency range without affecting the rest of the audio. This works well when noise is confined to a predictable zone, like low-end rumble or a harsh midrange resonance.
Applying a high-pass filter for low-end rumble:
In the Effects panel, go to Effects > Filter and EQ > Parametric Equalizer
Drag the effect onto your audio clip
Click Edit in Effect Controls to open the EQ editor
Enable the HP (High-Pass) filter on the left end of the EQ display
Set the cutoff frequency between 80Hz and 100Hz for dialogue and voice recordings
Adjust the filter slope if available; a steeper slope removes more low-end rumble
Beyond high-pass filtering, you can use the parametric bands to identify and notch out narrow frequency problems. Use Premiere Pro’s audio spectrum display alongside the EQ to spot unusual peaks in the frequency response. EQ alone works well for mild rumble or resonance, but pairs best with DeNoise when broadband hiss is also present.
Pro Tip: Prevent Noise at the Source for Cleaner Footage
The best noise reduction happens before you hit record. Post-processing tools are powerful, but they always involve some tradeoff between removing noise and preserving natural audio quality. If noisy recordings are a recurring issue on your shoots, a microphone with active noise cancellation can eliminate the problem before it reaches Premiere.
The Hollyland LARK MAX 2 is worth considering for this reason. It features AI Noise Cancellation that filters background noise in real time during recording, along with 32-bit Float Internal Recording at 48 kHz, which preserves maximum signal integrity even in loud or unpredictable environments. The result is audio that requires far less corrective work in post.
Key specs: AI Noise Cancellation, 32-bit Float Internal Recording, 48 kHz sample rate, and wireless clip-on transmitter design
Why does my audio still sound noisy after using Denoise in Premiere Pro?
The slider may be set too low to catch all the noise, or you may be dealing with multiple noise types. If Reduce Noise alone is not working, try adding DeHum for electrical buzz, or use the Parametric EQ to cut a specific frequency range. Sometimes the issue requires combining two or more methods.
Does Premiere Pro have a free noise reduction tool built in?
Yes. The Essential Sound panel’s Reduce Noise slider, the DeNoise effect, and the DeHum effect are all included with any active Premiere Pro subscription. No third-party plugins are required for basic noise removal. Adobe Enhance Speech is also included, but requires an internet connection to process.
What’s the difference between Denoise in Essential Sound and the DeNoise effect?
The Essential Sound panel offers a simplified single slider for quick results. The DeNoise effect, accessed through the Effects panel, opens a full editor with threshold, amount, and spectral fine-tuning controls. Use Essential Sound for speed; use the DeNoise effect when you need precise control, or the simplified version produces artifacts.
Can Premiere Pro remove wind noise?
Partially. Enabling Reduce Rumble in the Essential Sound panel and applying a high-pass filter below 100Hz will reduce mild wind noise. Severe wind damage often overwhelms Premiere’s built-in tools. For those cases, iZotope RX is the most effective option, or consider re-recording the affected sections if possible.
How do I fix audio that was recorded too quietly with lots of noise?
First, boost the clip’s gain to bring the dialogue to a usable level (right-click the clip > Audio Gain). Then apply DeNoise to address the noise floor that boosting revealed. Adobe Enhance Speech can also help recover detail from low-level recordings. Note that severely underexposed audio with a very high noise floor may not be fully recoverable, regardless of the tools used.
For most projects, begin with the Reduce Noise slider in Essential Sound. Move to the DeNoise effect if you need more control. Add DeHummer to remove electrical buzz from your audio. Use Enhance Speech to clean and improve dialogue clarity. Apply EQ to fix any remaining frequency-based problems.
Remember, better results come from light use of several tools together. So, avoid pushing one effect too hard on your audio track. But, if you want to spend less time in this workflow on future shoots, exploring a wireless microphone with built-in noise cancellation, like the Hollyland LARK MAX 2, is a practical next step.
