How to Fix Bad Audio Quality in a Video Using Premiere Pro
Bad audio can sink otherwise great footage. Whether you recorded in a noisy room, used a built-in camera mic, or forgot to check your gain, Premiere Pro has a solid set of tools to rescue the audio in post. This guide walks through every major fix in the order you should apply them — from the Essential Sound Panel’s one-click repairs all the way to Adobe Audition for the toughest cases.
Why Your Video Audio Sounds Bad (Quick Diagnosis)
Before applying any fix, identify what you are actually dealing with. Applying the wrong tool wastes time and can introduce new problems. Match your symptom to the right section:
  • Constant background hiss or white noise (mic noise floor, HVAC, wind) → Reduce Noise Slider
  • Hollow or distant sound, room echo (large room, hard surfaces) → DeReverb
  • Low buzzing or humming tone (power cable interference, ungrounded gear) → DeHum
  • Muddy or difficult-to-understand dialogue (poor mic placement, muffled recording) → Enhance Speech
  • Audio too quiet or too loud (gain staging issues, inconsistent levels) → Fix Audio Levels
  • Dull, boxy, or overly harsh sound after repair (frequency imbalance) → Parametric Equalizer
  • Severe clipping, heavy reverb, or irreparable damage → Send to Adobe Audition
Most real-world recordings have two or three of these problems at once. Work through them in the order above, not all at the same time.
Start Here — The Essential Sound Panel
The Essential Sound Panel is Premiere Pro’s built-in audio repair hub. It is non-destructive, does not require plugins, and covers the majority of common problems in one place. Start here before reaching for anything else.
  1. Open the Essential Sound Panel. Go to Window → Essential Sound
  2. . If it is not visible, it may be docked in your Audio workspace. Switch to the Audio workspace via Window → Workspaces → Audio.
  3. Select the audio clip on your timeline that needs repair.
  4. Tag it as Dialogue. In the Essential Sound Panel, click the Dialogue button under the Audio Type section. This tells Premiere what kind of audio it is and unlocks the appropriate repair tools.
  5. Navigate to the Repair tab. Inside the Dialogue options, click the Repair tab. You will see sliders for Reduce Noise, Reduce Reverb, DeHum, and an Enhance Speech button.
  6. Apply adjustments one at a time. Enable each slider individually, set a value, then preview the result. Stacking all sliders at maximum is one of the most common mistakes — each tool adds processing artifacts, and they compound.
  7. Use presets as a starting point, not a final answer. Premiere’s built-in presets (such as “Noisy Interview” or “Music Recording”) set reasonable starting values, but your specific recording will almost always need manual tweaking.
The non-destructive nature of the Essential Sound Panel means every adjustment can be undone or changed at any time without touching the original media file.
How to Use the Reduce Noise Slider Without Over-Processing
Reduce Noise is the most commonly used repair tool in Premiere Pro — and the most commonly abused. It works by attenuating frequencies that do not change over time, which is exactly the pattern of consistent background hiss or mic noise.
The sweet spot for most recordings sits between 20% and 40%. Below 20%, the effect may be imperceptible. Above 40–50%, you will start to hear artifacts: dialogue begins to sound watery, metallic, or slightly robotic, as if the speaker is underwater. That effect is harder to fix than the original noise.
Before exporting, always render a preview of the affected clip at your chosen value (press Return/Enter to render the timeline). Listening on headphones rather than laptop speakers will reveal artifacts you would otherwise miss until the final export.
Pro Tip: If you need more noise reduction than 40% provides, do not push the slider higher. Instead, combine a moderate Reduce Noise value (30–35%) with Enhance Speech enabled. The two tools address different aspects of the audio signal and together achieve cleaner results than either can alone at high values.
Removing Echo and Reverb with DeReverb
DeReverb is the right tool when your audio sounds hollow, distant, or like it was recorded in a bathroom or hallway. It works by detecting the reverberant tail of sounds and reducing their energy.
To use it, enable the Reduce Reverb checkbox in the Repair tab and start with a value around 20–30%. Increase it slowly while playing the clip. Light-to-moderate room reverb responds well, and dialogue will sound noticeably more present and direct.
One important limitation: DeReverb has a ceiling. If the original recording was made in a large, live room with heavy reflections, no amount of DeReverb will fully restore intelligibility. In those cases, the audio needs to go to Adobe Audition’s more advanced spectral tools (covered below). Think of DeReverb as a polish tool, not a reconstruction tool.
Eliminating Electrical Hum with DeHum
Electrical hum is the steady low-frequency buzz that appears when audio cables are ungrounded, when a cheap power adapter is too close to a microphone, or when ground loops occur between devices. It typically presents at 50 Hz (common in Europe and Asia) or 60 Hz (common in North America).
To remove it, enable the DeHum checkbox in the Repair tab. If you know your local power grid frequency, select the matching option. If you are unsure, listen to the clip carefully — 60 Hz hum sounds slightly higher-pitched than 50 Hz. Premiere also includes an Auto detection option that analyzes the clip and selects the dominant frequency.
Apply DeHum at its default setting first. In most cases, default is sufficient. Only increase the amount if the hum is still audible after rendering a preview.
Enhance Speech — Premiere Pro’s AI Audio Fix
Enhance Speech is arguably the most powerful and underused feature in Premiere Pro’s current audio toolset. Introduced in recent versions, it applies an AI model trained specifically on human speech to improve dialogue clarity, reduce mud and distance, and pull forward the key frequency ranges of a speaker’s voice.
Here is how to enable it:
  1. Select your dialogue clip on the timeline.
  2. Open the Essential Sound Panel and confirm the clip is tagged as Dialogue.
  3. Under the Repair tab, locate the Enhance Speech toggle and turn it on.
  4. Choose between Standard and High quality models. High quality produces better results but requires longer processing time.
  5. Play the clip and compare it to the original. The difference is often dramatic on recordings made with low-quality or distant mics.
Enhance Speech outperforms manual EQ when the problem is general muddiness, poor microphone proximity, or a recording that sounds intelligible but lacks presence. It is not a replacement for Reduce Noise or DeReverb — it works best when those are applied first, or alongside them at moderate values.
The main caveat is time. On long clips or slower machines, processing can take several minutes. For a full-length interview or documentary, batch the clips and let Premiere process overnight if needed.
Fix Audio Levels — Gain, Normalization, and Compression
Three separate problems fall under the umbrella of “audio levels,” and each has a different fix.
Step 1: Fix clips that are too quiet or too loud with Audio Gain. Right-click the audio clip on the timeline, select Audio Gain, and either set a specific gain value (in dB) or use the Normalize Max Peak To option and type -6 dB. This brings the loudest moment of the clip to -6 dBFS, giving you headroom to work with.
Step 2: Tame dynamic inconsistency with the Dynamics effect. If a speaker’s volume jumps around — quiet one sentence, loud the next — apply the Dynamics effect (found under Effects → Audio Effects → Amplitude and Compression → Dynamics). Enable the Compressor section, set a ratio of 3:1 to 4:1, and use a threshold around -18 dB. This narrows the gap between loud and quiet moments and produces more even, broadcast-ready dialogue.
Step 3: Set final loudness with the Essential Sound Panel. Back in the Essential Sound Panel under the Dialogue tag, navigate to the Loudness tab and click Auto-Match. Premiere will target -14 LUFS, which is the standard for YouTube and most streaming platforms.
Platform
Target Integrated Loudness
Peak Ceiling
YouTube
-14 LUFS
-1 dBTP
Podcast / Spoken word
-16 LUFS
-1 dBTP
Broadcast (EBU R128)
-23 LUFS
-1 dBTP
Dialogue peak (general)
-12 to -6 dBFS
How to Normalize Audio in Premiere Pro
Normalization is a fast way to bring clip levels into a workable range before applying more detailed processing.
  1. Select one or more audio clips on the timeline.
  2. Right-click and choose Audio Gain.
  3. Select Normalize Max Peak To and enter -6 dB for dialogue, or Normalize All Peaks To if you selected multiple clips and want them to match each other.
  4. Click OK.
Peak normalization adjusts the clip so the single loudest sample hits your target value. It is useful for a quick level fix but does not account for overall perceived loudness. Loudness normalization (via the Essential Sound Panel’s Auto-Match) measures the entire clip and targets an integrated LUFS value, which is more accurate for final delivery. Use peak normalization early in the workflow and loudness normalization at the end.
Use the Parametric Equalizer to Improve Clarity
After repair tools have addressed noise, reverb, and hum, the Parametric Equalizer handles remaining tonal problems. This is the right tool if dialogue still sounds boxy, dull, or harshly sibilant after basic repair.
Find it under Effects → Audio Effects → Filter and EQ → Parametric Equalizer. Apply it to the audio clip, then open the effect controls.
Practical adjustments for dialogue:
  • High-pass filter at 80–100 Hz: Cuts low-frequency rumble (traffic, HVAC, footsteps). Set a High-Pass filter at 80 Hz with a slope of 12 dB/octave. Almost all dialogue benefits from this cut.
  • Slight boost at 2–5 kHz (+2 to +4 dB): This is the presence range for human speech. A gentle boost here adds intelligibility and makes dialogue feel “forward” and clear.
  • Cut at 200–400 Hz (-2 to -4 dB) if audio sounds boxy: Recordings in small rooms often accumulate mud in this range. A narrow cut cleans it up without thinning the voice.
  • Cut at 6–8 kHz if audio is harsh or sibilant (-2 to -3 dB): Cheap condenser mics and some wireless systems boost this range. A narrow cut reduces the harshness of “s” and “sh” sounds.
Avoid adding too many bands at once. Two or three targeted adjustments almost always outperform a complex multi-band EQ curve applied without careful listening.
When Premiere Pro Isn’t Enough — Send to Adobe Audition
Premiere Pro’s native tools are capable, but they have a ceiling. For severely damaged audio — heavy hiss, hard clipping, prominent pops and thumps, or dense reverb — Adobe Audition offers more precise tools. If you are on Creative Cloud, Audition is likely already available to you.
  1. Right-click the audio clip on the Premiere Pro timeline.
  2. Select Edit Clip in Adobe Audition. Premiere creates a copy of the audio and opens it in Audition. Your original timeline is not affected.
  3. Capture a Noise Print for consistent noise (hiss, hum): Select a short section of audio that contains only the noise (no speech), go to Effects → Noise Reduction / Restoration → Noise Reduction (process), click Capture Noise Print, then apply it to the full clip.
  4. Use the Spectral Frequency Display to isolate and remove specific sounds: View → Show Spectral Frequency Display. One-off intrusions like a door slam, a cough, or a phone buzz appear visually as bright spots. Use the Healing Brush or selection tools to paint over and remove them without affecting surrounding audio.
  5. Save and close Audition. The edited audio automatically updates in your Premiere Pro timeline. No re-linking required.
Audition’s main advantages over Premiere’s built-in tools are its Noise Print-based noise reduction (which is more accurate for variable or complex noise floors), the DeClipper effect for recovering clipped waveforms, and the visual surgical editing of the Spectral Frequency Display. None of those workflows are available inside Premiere itself.
Note: Edits made in Audition via the “Edit Clip in Adobe Audition” workflow update the Premiere timeline automatically. This is not a destructive split in your project — it is a managed round-trip that keeps everything linked.
Prevent Bad Audio Before You Shoot
The most effective audio fix in Premiere Pro is the one you never have to make. Mic placement matters more than mic price: a mid-range microphone six inches from the speaker will outperform an expensive mic across a room. Record as close to the source as possible, and use a dedicated wireless microphone system rather than the camera’s built-in mic to avoid picking up camera noise, handling noise, and a high noise floor.
A system like the Hollyland LARK MAX 2 illustrates what clean source audio looks like in practice. It records at 48 kHz / 32-bit Float with AI Noise Cancellation built into the transmitter, so dialogue arrives in your Premiere timeline already clean and level-stable. Its 32-bit Float Internal Recording also eliminates the risk of clipped audio, removing one of the few problems post-production genuinely cannot fix.
Q: Can Premiere Pro fix distorted or clipped audio?
Partially. The Parametric Equalizer can reduce harsh frequencies caused by light distortion, but true hard clipping — where the waveform is flatlined at the top — cannot be recovered in Premiere. Adobe Audition’s DeClipper effect gives the best chance of recovery by reconstructing the lost peaks. For any project where clipping is a recurring issue, adjusting gain at the source is the only reliable solution.
Q: How do I reduce background noise in Premiere Pro without making it sound robotic?
Keep the Reduce Noise slider at or below 40%. At higher values, the artifact commonly called “watery” or “underwater” processing becomes noticeable. For better results, combine a moderate Reduce Noise value (around 30%) with Enhance Speech enabled. Always render a preview and listen on headphones before exporting to catch artifacts early.
Q: Is there a free plugin for fixing audio in Premiere Pro?
Premiere Pro’s native Essential Sound Panel is included with your subscription and handles the majority of common repair tasks at no additional cost. For advanced users, iZotope RX Elements integrates with Premiere via ARA2 and is occasionally available at steep discounts or as part of bundle deals. No consistently reliable free third-party plugin covers the same ground without meaningful limitations or quality trade-offs.
Q: Why does my audio sound tinny or hollow after using Reduce Noise?
That is an over-processing artifact caused by setting the Reduce Noise amount too high. Reduce the slider to 25–35%, apply DeReverb separately to address any hollowness, and use the Parametric Equalizer to add warmth back by boosting gently around 200–400 Hz. The goal is to use multiple tools at moderate settings rather than pushing any single tool hard.
Work through audio repair in layers: start with the Essential Sound Panel (Reduce Noise, DeReverb, and Enhance Speech), then address levels with gain normalization and compression, then refine tone with the Parametric Equalizer. Only escalate to Adobe Audition when the damage genuinely exceeds what Premiere’s native tools can handle. Applying one tool at maximum is almost always worse than using three tools at moderate settings. Fixing audio in post saves footage — but recording clean audio at the source saves editing time on every future project.
