How to Remove Wind Noise from Audio: Prevention and Post-Production Methods
Wind noise can ruin an otherwise perfect take in seconds. Whether you recorded a travel vlog on a breezy hillside or conducted an outdoor interview without a windscreen, the low rumble of wind through a microphone is one of the most common problems in field recording. This guide covers both paths: preventing wind noise before it starts, and removing it in post-production when prevention was not an option.
Why Wind Noise Is So Hard to Remove
Wind noise is notoriously difficult to clean up because it does not occupy a clean, isolated frequency band. The low-frequency rumble produced by wind turbulence sits roughly between 20 Hz and 500 Hz, which overlaps heavily with the fundamental tones of a human voice. When you apply noise reduction to that range, you inevitably pull out some of the warmth and body of the speaker’s voice along with the wind.
Mid-frequency wind roar adds another layer of difficulty. Gusts and turbulence can push wind energy well above 200 Hz, where consonants and vocal clarity live. Removing noise in this range risks creating an unnatural, hollow or processed sound.
This is why experienced audio engineers treat prevention as the primary strategy and post-production removal as a fallback. Understanding the limitation upfront helps you set realistic expectations before you start reaching for plugins.
Prevent Wind Noise Before You Record
The most reliable fix is never capturing wind noise in the first place. Physical accessories, smart mic placement, and AI-equipped hardware each reduce the problem at the source, saving significant post-production time.
Use a Windscreen, Deadcat, or Foam Cover
Choosing the right windscreen for your recording environment matters more than most creators realize.
  • Foam windshields are suited for light indoor drafts or mild breezes. They offer minimal resistance to outdoor wind and should not be your first choice for exterior shoots.
  • Deadcat or furry windshields are the correct choice for outdoor conditions. The long artificial fur breaks up airflow before it reaches the capsule, reducing wind rumble by 20 dB or more in many cases.
  • Blimp or zeppelin systems pair a rigid housing with a deadcat fur cover and are the standard for film production in strong or sustained wind. They offer the highest level of protection for dedicated field recording.
  • Match your windscreen type to the actual conditions you expect, not to what is already in your bag. A foam cover on a windy beach will not be adequate.
Mic Positioning and Wind Shadowing
Hardware helps, but physical positioning can add meaningful protection at no cost.
  • Use your body, a wall, or any large natural surface as a wind break. Stepping slightly behind a building corner during an outdoor interview can cut wind energy dramatically.
  • Angle directional microphones slightly away from the primary wind direction. The front of a cardioid capsule is most sensitive to wind pressure; a small rotation can reduce the impact without sacrificing too much on-axis audio.
  • For lavalier microphones, routing the cable under a jacket lapel or under a light layer of clothing creates natural shielding. A small piece of gaffer tape over the mic head adds further protection and is a standard field technique.
Use a Microphone with Built-In AI Noise Cancellation
Physical windscreens and positioning are the foundation, but AI-based noise cancellation at the capture stage provides an additional layer of protection before wind artifacts enter the recording chain.
The Hollyland LARK MAX 2 combines AI Noise Cancellation with 32-bit float internal recording, making it a strong option for interviews and outdoor filming where re-recording is not practical. The Hollyland LARK M2 Series, at just 9g, suits high-mobility outdoor vloggers where carrying a full deadcat rig is not realistic.
Note: AI cancellation significantly reduces wind artifacts and ambient rumble, but it does not replace a physical windscreen in strong conditions. Use both together for the best results in demanding outdoor environments.
How to Remove Wind Noise in Post-Production
When prevention was not possible, post-production tools can recover usable audio from wind-damaged recordings. The sections below are organized from free and beginner-friendly to professional. You can jump directly to the tool you already use.
Audacity (Free)
Audacity is the most accessible free option and works well for mild to moderate wind noise.
  1. Locate a section of your recording that contains only wind noise with no speech or other desired audio.
  2. Select that section, then go to Effect > Noise Reduction > Get Noise Profile. Audacity analyzes the wind’s frequency signature.
  3. Select the full audio clip, then return to Effect > Noise Reduction. Set the Reduction value to between 18 and 24 dB. Preview before applying to check for artifacts.
  4. Apply a High-Pass Filter via Effect > Filter Curve EQ: roll off frequencies below 80–120 Hz to remove any remaining low-frequency rumble that noise reduction did not catch.
  5. Normalize the audio using Effect > Normalize to restore volume levels lost during processing.
Adobe Audition
Adobe Audition offers more precise control than Audacity and integrates well into a Premiere Pro workflow.
  1. Open the clip in the Waveform Editor view (not multitrack).
  2. Select a wind-only region, then go to Effects > Noise Reduction/Restoration > Capture Noise Print.
  3. Apply Noise Reduction (Process): keep the Noise Reduction percentage between 40 and 60 percent. Heavy reduction at this stage often degrades voice quality.
  4. In the Effects Rack, add a Parametric EQ and use the Low Cut filter to roll off audio below 100 Hz.
  5. If wind noise remains, try Adaptive Noise Reduction, then preview and adjust the settings before applying.
DaVinci Resolve / Fairlight
Editors already working in DaVinci Resolve can address wind noise without leaving the application, using the built-in Fairlight audio tools.
  1. Open the Fairlight page and select the affected audio clip.
  2. Open the Effects Library and apply the Noise Reduction plugin to the clip.
  3. Enable Learn mode and play back a section containing only wind noise, then disable Learn when complete.
  4. Adjust the Threshold, Sensitivity, Ratio, and Dry/Wet controls. Start with moderate settings and use Preview (playback) to fine-tune the result. Avoid excessive processing, as it can make the voice sound metallic.
  5. In newer versions of DaVinci Resolve, apply the AI Voice Isolation tool for an additional pass to recover speech clarity if the first pass left the vocals sounding muffled.
iZotope RX (Professional)
iZotope RX is the industry standard for dialogue repair and the best choice when other tools fail or when the recording is critical.
  1. Open the clip in the RX Editor.
  2. Use the dedicated De-wind  module.
  3. Adjust the De-wind settings.
  • Increase or decrease the Reduction slider until the wind noise is reduced while your voice still sounds natural.
  • Leave Crossover Frequency, Fundamental Recovery, and Artifact Smoothing at their default values initially. Adjust them only if you hear unwanted artifacts or loss of voice quality.
  1. Run the De-noise module next: learn a brief noise profile from a wind-only section and apply.
  2. If you hear fabric rustling or clothing rub artifacts alongside the wind noise, add a De-Rustle pass to address those separately.
  3. iZotope RX is the recommended choice for severely damaged recordings where other tools start distorting voice quality during processing.
AI-Powered Online Tools
For creators who need a fast result without installing software, AI-based web tools offer a practical shortcut.
  • Adobe Podcast (Enhance Speech): Upload an audio or video file and Adobe’s AI model automatically processes it for speech clarity. It handles mild wind well and requires no configuration. Available free in a limited capacity from a browser.
  • Auphonic: Supports batch processing with adaptive noise reduction. Well suited for podcasters processing multiple files quickly or content with consistent, moderate background noise.
  • Trade-offs: Both tools offer limited manual control. They are appropriate for casual creators or mild wind cases. For heavy wind damage on professional deliverables, they will not match the results of iZotope RX or Adobe Audition.
Which Tool Should You Use? (Quick Reference)
Your Situation
Best Tool
Need free software
Audacity
Already using Adobe workflow
Adobe Audition
Edit video in DaVinci Resolve
Fairlight built-in tools
Severely damaged or critical audio
iZotope RX
Quick fix, no software install
Adobe Podcast / Auphonic
Prevent it before recording
Windscreen + AI-equipped mic
Can wind noise be completely removed from audio? Rarely 100%. Heavy wind noise that overlaps with speech frequencies will degrade voice quality when aggressively removed. Severely affected recordings may remain unusable even after processing. Prevention consistently produces better results than even the most advanced post-production tools, which is why capturing clean audio at the source should always be the priority.
What is the best free tool to remove wind noise from audio? Audacity is the strongest free desktop option. Combining its Noise Reduction effect with a High-Pass Filter handles most mild to moderate wind cases. For users who prefer not to install software, Adobe Podcast’s Enhance Speech tool is a capable browser-based alternative for basic recovery work.
Does a high-pass filter remove wind noise? A high-pass filter removes low-frequency rumble below 80–120 Hz but will not eliminate mid-frequency wind roar. It is an effective complement to noise reduction, not a standalone solution. Use a high-pass filter after your primary noise reduction pass to clean up residual low-end buildup.
What type of microphone handles wind best? Directional cardioid or supercardioid microphones paired with a deadcat windshield perform best in outdoor conditions. Mics that combine strong directionality with AI noise cancellation, such as the Hollyland LARK MAX 2, provide an additional layer of wind protection by reducing interference at the capture stage before it reaches your recorder.
How do I remove wind noise from a video on my phone? CapCut includes a noise reduction filter in its Audio panel, accessible without a desktop workstation. Adobe Podcast’s mobile-friendly web interface is another option: upload the audio track, apply the Enhance Speech processing, download the cleaned file, and re-sync it to your video in your editing app.
The most effective approach to wind noise is a layered one. A deadcat windshield combined with smart mic positioning eliminates most problems before recording even starts, and an AI-equipped microphone like the Hollyland LARK MAX 2 adds a further layer of protection at the capture stage. When prevention falls short, work through the post-production options in order of severity: Audacity or Adobe Podcast for mild cases, Adobe Audition or Fairlight for moderate damage, and iZotope RX for critical recordings that need the most capable tools available.
