How to Remove Background Noise from Your Microphone (7 Methods That Actually Work)
Background noise is one of the most common audio problems for remote workers, content creators, and podcasters. The good news is you do not need expensive studio equipment. Microphone noise can come from humming vents, keyboard clicks, or room echo. There is still a solution matching your recording setup and budget. This guide covers seven proven methods, from free placement fixes to AI-powered tools, so you can find the right approach for your specific situation.
Why Your Microphone Picks Up Background Noise?
Three root causes explain almost every case of unwanted mic noise:
  • Environment: Fan noise, HVAC hum, room echo, traffic, and ambient sound reflect off surfaces and reach your mic.
  • Hardware: A microphone positioned too far from the source requires higher input gain, which amplifies background noise along with your voice.
  • Software: No suppression is active, so the raw signal, including all noise, reaches your application unfiltered.
Understanding which cause applies to your situation matters because the best fix always targets the source. Software suppression cannot fully compensate for poor placement, and better placement reduces the work any suppression tool needs to do.
Common noise types include:
  • Low-frequency hum (HVAC, fans, refrigerators)
  • High-frequency hiss (preamp noise, high gain settings)
  • Room echo and reverb
  • Wind and handling noise
  • Keyboard and mouse clicks
Method 1 — Reduce Noise at the Source (Placement and Hardware)
The most effective fix costs nothing and improves every downstream method you layer on top of it. Correcting mic placement and hardware settings raises the signal-to-noise ratio before any software is involved.
  1. Position your mic 6 to 12 inches from your mouth: Closer placement means your voice registers louder at the capsule, so you can lower input gain without losing volume. Lower gain directly shrinks the noise floor and reduces how much background sound gets captured.
  2. Use a cardioid polar pattern microphone: Cardioid mics capture sound in a focused forward direction and reject sound arriving from the sides and rear. This directional design naturally ignores ambient room noise that approaches from off-axis angles without requiring any processing.
  3. Lower your input gain: Open your OS sound settings or your audio interface control panel and reduce microphone input gain until background noise becomes inaudible during silent pauses. Then raise gain only enough to bring your voice to a healthy level. Every decibel of unnecessary gain adds audible noise to your recording.
  4. Add a windscreen or pop filter: Foam windscreens reduce wind noise and breath pops. A pop filter adds a physical barrier that stops plosive sounds, the burst of air from letters like “p” and “b,” from overloading the capsule and causing distortion.
  5. Mount your mic on a shock mount or mic arm: Desk vibration, keyboard impacts, and handling noise travel through solid surfaces directly to the mic stand. A shock mount decouples the microphone from physical vibration and eliminates a common source of low-frequency rumble.
  6. Keep the mic away from noise sources: Place the microphone on the opposite side of your body from your computer fan or air conditioning vent. Even a small shift in position can dramatically reduce fan bleed into your recording.
Pro Tip: Before applying any software filter, record a 10-second silent clip and listen back through headphones. If you can clearly hear background noise, placement and gain are the first two variables to address. Software suppression performs far better on a low-noise starting signal.
Method 2 — Use a Microphone with Built-in Noise Cancellation
Software suppression processes audio after it enters your computer, which means each application handles it separately. A microphone with built-in noise cancellation removes noise at the hardware level, before the signal reaches any app. The result is cleaner audio on every platform simultaneously, with no per-app configuration and no additional CPU load on your machine.
This method helps most during live recording situations without editing afterward. It fits field interviews, livestreams, or video calls in changing environments.
Hollyland LARK MAX 2 — AI Noise Cancellation for Professional and Field Use
The LARK MAX 2 is a wireless clip-on microphone system built for cameras, computers, and mobile devices. It uses an AI-based noise cancellation model trained to isolate voice from background noise in real time, and it records at 48kHz with 32-bit Float internal backup, which preserves audio quality even when noise levels shift unexpectedly mid-session.
Steps to activate AI Noise Cancellation on the LARK MAX 2:
  1. Connect the Hollyland LARK MAX 2's USB-C receiver to your recording device (phone or laptop). Once connected, RX will turn on, and the LED will start blinking blue. This means the unit is not yet linked with the transmitter.
  1. Power on the transmitter by pressing and holding the power button until the LED activates and turns solid blue, ensuring that the TX unit is paired with the receiver unit (RX). On the other hand, the RX LED will also turn into a stable blue.
  1. Open the Hollyland LarkSound app (HollyAudio)  on your connected device and navigate to the microphone settings panel.
  2. Locate the Noise Cancellation section within that panel.
  3. Toggle AI Noise Cancellation to the ON position. The app confirms the setting is active.
  1. Check the LED indicator on the transmitter unit. When AI NC is active, the LED changes state to solid green, giving you a visual confirmation without reopening the app.
  1. To monitor the audio in real time, connect OWS earphones wirelessly via Bluetooth or 2.4GHz connectivity options. This low-latency monitoring lets you confirm the cleaned audio before it reaches your camera or recording device.
Hollyland LARK A1 — 3-Level Noise Cancellation for Beginners
The LARK A1 is a plug-and-play wireless microphone designed for smartphones. The receiver connects directly via USB-C or Lightning with no app, no driver installation, and no Bluetooth pairing required. Noise cancellation is controlled entirely by a physical button on the receiver, making the setup fast even for first-time users.
Steps to activate and adjust noise cancellation on the LARK A1:
  1. Insert the Hollyland LARK A1 receiver into your phone’s USB-C or Lightning port. The system connects automatically with no pairing step.
  1. Clip the transmitter to your collar or lapel, roughly 15 to 20 centimeters below your chin.
  1. Press the noise cancellation button on the transmitter or receiver to activate noise cancellation. The LED will turn green.
  1. To set different levels of noise reduction, make sure your mic is linked to the LarkSound app (HollyAudio app).
  2. Then, look for the noise cancellation section of the app and set the levels by tapping the Low, Medium, or High.
  1. Record a short test clip and review playback to confirm the noise floor is acceptable before beginning your full session.
When to Use Low Noise Cancellation in LARK A1: This setting lowers small amounts of background noise gently. It fits quiet rooms or indoor studios with light echo. It also helps reduce soft air conditioner humming sounds naturally. Your voice still sounds open and mostly unchanged afterward.
When to Use Medium Noise Cancellation in LARK A1: This setting removes a moderate amount of background noise clearly. It fits everyday places like quiet cafes or light traffic areas. The audio sounds cleaner without changing your natural voice tone heavily.
When to Use High Noise Cancellation in LARK A1: This setting removes heavy background noise very aggressively. It fits loud places with traffic, wind, or large crowds nearby. Your voice stays clearer and easier to understand afterward.
Method 3 — Remove Background Noise in Audacity (Post-Production)
Audacity is a free, open-source audio editor that includes a two-step Noise Reduction tool. It works by sampling a section of pure background noise, building a reference profile from that sample, and then subtracting that noise pattern from the full recording. This method is the most accessible option for cleaning audio files that have already been recorded.
Steps to remove background noise in Audacity:
  1. Open your audio file in Audacity via File > Open.
  1. Find a section of the recording that contains only background noise with no voice or intended audio, ideally 0.5 to 2 seconds long. Click and drag to select that region.
  2. Go to Effect > Noise Removal and Repair > Noise Reduction > Get Noise Profile. Audacity samples the selected region and stores it as the noise reference.
  1. Press Ctrl+A (Windows) or Cmd+A (macOS) to select the entire track.
  1. Then again, go to Effect > Noise Removal and Repair > Noise Reduction again to open the main reduction panel.
  2. Set the following values as a starting point:
  • Noise Reduction: 12 to 18 dB
  • Sensitivity: 6
  • Frequency Smoothing: 3
  1. Click Preview to hear the result before committing. Adjust values if the voice sounds too thin or the noise floor is still audible.
  2. Click OK to apply the reduction to the full track.
  1. Export the cleaned file via File > Export Audio > Export as MP3 or as WAV for a lossless output.
Note: Avoid setting Noise Reduction above 24 dB. Aggressive suppression removes too much signal and introduces a robotic, underwater quality to the voice. The goal is to lower the noise floor, not eliminate all background content at the cost of vocal clarity.
Method 4 — Apply Real-Time Noise Suppression in OBS
OBS Studio includes a built-in Noise Suppression filter that processes your microphone signal in real time, with no post-editing required. This is the preferred solution for streamers and live recorders. The filter affects the signal for all outputs simultaneously, including both recordings and stream broadcasts.
Steps to add Noise Suppression in OBS:
  1. Open OBS Studio and locate your microphone source in the Audio Mixer panel at the bottom of the interface.
  2. Click the three vertical lines button under the "Mic/Aux" section to view the menu.
  1. Select Filters.
  1. On the Filters window, click the + button at the bottom-left corner and select Noise Suppression.
  1. Rename the filter if you want to or leave it as it is, and click OK to continue.
  1. Choose your suppression method:
  • RNNoise: An AI-based algorithm suited for noisy environments with fans, traffic, or HVAC noise. More aggressive and more effective on complex noise.
  • Speex: A lighter DSP-based algorithm with a lower CPU cost. A better choice for relatively quiet rooms or for systems already under load during streams.
  1. Click Close..
Method 5 — Enable Noise Suppression in Zoom, Teams, and Discord
Each major communication platform includes built-in noise suppression that requires no additional software or hardware. These settings are the fastest fix for users who only need clean audio in one specific application.
Zoom
  1. Open Zoom, click your profile image, and choose Settings from the menu.
  2. Select Audio from the left-side menu.
  3. Scroll down to the Microphone modes section.
  4. Make sure Noise removal (default) is checked.
  5. Under Suppress background noise, choose your level:
  • Auto: Zoom adjusts the level dynamically based on detected noise conditions.
  • Low: To mitigate faint background noise
  • Medium: Suited for a typical home office setup.
  • High: Best for loud or unpredictable environments such as open offices or rooms with audible fans.
  1. Close Settings. The change applies immediately to active and future calls.
Microsoft Teams
  1. Click your profile picture in the top-right corner, then select Settings.
  2. Navigate to Devices.
  1. Toggle on Noise Suppression.
Discord
  1. Open Discord and click the UserSettings gear icon near your username in the lower-left corner.
  1. Select Voice & Video from the left-side menu.
  1. Scroll down to the Noise Suppression section and select Krisp from the dropdown menu to enable it.
Method 6 — Adjust Microphone Settings in Windows or macOS
Operating system audio settings apply noise processing at the system level, before any application receives the microphone signal. This makes OS-level suppression a useful baseline fix that works across all apps without requiring per-platform configuration.
Windows 10 / 11
  1. Right-click the speaker icon in the system tray and select Sounds.
  1. Go to the Recording tab.
  1. Right-click your active microphone and select Properties.
  2. Click the Enhancements tab.
  3. Check Noise Suppression and Acoustic Echo Cancellation.
  4. Click Apply, then OK.
Note: The Enhancements tab is not available for all USB microphones or audio interfaces. If it does not appear, your device driver handles audio processing independently, and this method does not apply to your setup.
macOS
  1. Go to the app that supports Mic Modes. For example, Zoom or FaceTime.
  2. Click on the video icon in the menu. Click "Mic Mode."
  3. Choose "Voice Isolation" from the list of available options.
Method 7 — Use AI-Powered Noise Removal Tools
When platform or OS suppression is not strong enough, these standalone AI tools offer a more powerful option. Each targets a distinct use case. No full tutorials are needed here since each tool has dedicated documentation. Use this table to identify which fits your workflow.
Tool
Best Use Case
Real-Time or Post
Cost
Notes
Adobe Podcast Enhance Speech
Quick post-production cleanup
Post-production
Free (web)
Browser-based, drag-and-drop, no installation required
NVIDIA RTX Voice / Broadcast
High-quality real-time suppression
Real-time
Free
Requires an NVIDIA RTX GPU
Krisp
Cross-app real-time, no GPU needed
Real-time
Free tier + paid
Functions as a virtual mic device in any application
Which Method Is Right for Your Situation? (Quick Reference)
Not every noise problem calls for the same solution. Use this table to match your situation to the right method and jump directly to the steps you need.
Situation
Recommended Method
Jump To
Live Zoom or Teams call, need a quick fix
Platform noise suppression
Method 5
Streaming or live recording in OBS
OBS RNNoise filter
Method 4
Cleaning an already-recorded audio file
Audacity noise reduction
Method 3
Outdoor or field recording with frequent noise
Mic with built-in AI NC (LARK MAX 2)
Method 2
Beginner recording on a smartphone
Plug-and-play mic with NC (LARK A1)
Method 2
Free fix, no tools or additional software
Mic placement and lower gain
Method 1
Q: Why does my microphone still pick up background noise after enabling noise suppression?
Software suppression handles steady-state noise like hum and hiss well but struggles with sudden or highly variable sounds. The most reliable fix is to combine suppression with better mic placement. Moving the microphone closer to your mouth raises the signal-to-noise ratio, which gives suppression less residual noise to process and produces a noticeably cleaner result.
Q: Can I remove background noise from a video after it is already recorded?
Yes. Import the video into Audacity or extract the audio track, run the Noise Reduction process described in Method 3, then reattach the cleaned audio to your video in any video editor. Alternatively, drag the file into Adobe Podcast Enhance Speech for a one-step browser-based fix that requires no software installation or audio editing experience.
Q: Does noise cancellation affect voice quality?
It can, if the settings are too aggressive. Heavy suppression thins the voice and can introduce a robotic character to the audio. Start at moderate levels, such as Level 2 on the LARK A1 or a Noise Reduction value of 12 dB in Audacity, and increase only if residual noise remains clearly audible after reviewing a short test recording.
Q: What is the difference between noise suppression and noise cancellation?
Noise suppression is a software process that lowers steady-state background sounds by reducing their level in the signal. AI noise cancellation, as used in the LARK MAX 2 or Krisp, applies a trained machine learning model to actively identify and remove dynamic noise in real time, including variable sounds like traffic or overlapping voices. AI cancellation handles complex noise more effectively but requires more processing resources.
Q: Is a wireless mic better for reducing background noise?
A wireless microphone with built-in AI noise cancellation records cleaner audio. It stays closer to your mouth than laptop microphones usually do. This improves the signal compared to unwanted background noise nearby. The AI processing also happens directly inside the transmitter or receiver hardware. Some apps or operating systems may still need proper audio settings.
Start by placing your microphone closer before changing anything else. Lower the input gain slightly for cleaner audio during recordings. These two changes improve every other noise reduction method afterward. If you record often in loud places, the Hollyland LARK MAX 2 removes noise before apps even receive the audio. Software tools like OBS Studio's RNNoise or Audacity can clean remaining noise later. Using both methods together usually gives much better recording results.
