Best Podcast Editing Techniques for Removing Background Noise
Background noise is one of those annoying podcast problems. There’s rarely one magic fix for every recording. The best method depends on your noise type and editing tools. It also matters which technique you apply first. This guide covers practical ways to clean podcast audio. We will cover noise profiles, high-pass filters, and AI tools. You will also learn the best order for cleaner vocals.
Know Your Noise Before You Edit It
Not all background noise responds to the same treatment. Applying the wrong technique wastes time at best and degrades audio quality at worst. Every editing decision starts with identifying which of two categories the noise falls into.
Steady-state noise is consistent and predictable: HVAC hum, electrical hiss, the low drone of a refrigerator, or the ambient tone of a room. Because it has a stable frequency profile, software can learn it and subtract it across the entire recording.
Intermittent noise arrives randomly: A truck passing outside, a dog barking, a chair scraping, a phone buzzing mid-sentence. It cannot be profiled and subtracted because it has no consistent pattern. Each event requires a targeted, individual approach.
Noise Type
Examples
Best Technique
Steady-state
HVAC hum, electrical hiss, room tone
Noise profiling, AI noise removal, high-pass filter
Intermittent
Traffic burst, cough, dog bark, chair creak
Spectral repair, manual cut, re-record if possible
Identifying which type you are dealing with before opening any plugin is the fastest way to reach a clean result.
Noise Profiling: The Foundation of Manual Noise Reduction
Noise profiling is the standard manual technique for steady-state noise. The software samples a short segment of room silence, learns the noise fingerprint, and subtracts that pattern across the full track. When applied correctly, it removes a consistent noise floor without audibly damaging the vocal signal.
In Audacity:
  1. Open your audio file in Audacity.
  1. Find a section of 0.5 to 2 seconds where only background noise is present — no speech, no movement.
  2. Select that section.
  1. Navigate to Effect > Noise Removal and Repair > Noise Reduction.
  1. Click Get Noise Profile. Audacity samples the selected segment.
  1. Select the entire track (Ctrl+A on Windows, Cmd+A on Mac).
  2. Return to Effect > Noise Removal and Repair > Noise Reduction.
  3. Set these starting values: Noise Reduction: 12–15 dB, Sensitivity: 6.00, Frequency Smoothing: 3.
  1. Click Preview, evaluate the result, then click OK.
In Adobe Audition:
  1. Select a clean, noise-only segment on your waveform.
  1. Go to Effects > Noise Reduction/Restoration > Capture Noise Print (or press Shift+P).
  1. Select the full clip.
  1. Open Effects > Noise Reduction/Restoration > Noise Reduction (Process).
  1. Set Reduce By to 12–18 dB.
  2. Adjust the Noise Reduction slider if artifacts appear in the preview.
  3. Preview again and click Apply.
Note: Always start with lower reduction values and increase only if necessary. The maximum reduction setting almost always introduces audible processing artifacts.
How Much Noise Reduction Is Too Much?
If the processed audio sounds metallic, watery, or hollow, the reduction is too aggressive. Rather than applying one heavy pass, apply two lighter passes at 8–10 dB each. You will reach a similar overall reduction level with significantly less damage to the vocal quality.
AI-Powered Noise Removal: Faster Results with Less Manual Work
AI noise removal tools clean audio in a different way. They don’t rely on traditional manual noise profiling methods. Instead of subtracting a static noise fingerprint, they model the difference between speech and non-speech in real time. They work better when recordings have several noises mixed together. One noise profile usually can’t catch every sound there.
AI-Powered Noise Removal — Faster Results with Less Manual Work
Three tools are worth knowing for practical podcast work:
  • Adobe Podcast Enhance
  • Access: Browser-based at podcast.adobe.com, no software installation required, no cost.
  • Best For: Quick, one-click cleanup of voice recordings with moderate background noise. Upload the file and the tool processes it automatically.
  • Limitation: With the free tier, there is limited user control over processing intensity. Voices with unusual tonal qualities occasionally develop slight artifacts.
  • Descript Studio Sound
  • Access: Integrated within the Descript desktop application on paid plans.
  • Best For: Podcasters already editing in Descript who want noise removal built into the same workflow without exporting to a separate tool.
  • Limitation: You get fewer controls than dedicated audio restoration software. It works best when voices are the main focus. Music playing underneath can make the cleanup less effective.
  • iZotope RX
  • Access: Standalone application and DAW plugin; paid, with a free trial available.
  • Best For: Professional-grade noise removal where maximum control is required. Handles complex environments including reverberant rooms, wind, and layered ambient sound.
  • Limitation: Steeper learning curve and higher cost. Appropriate for difficult recordings, but overkill for minor noise issues.
AI tools won’t always give you perfectly clean audio. If artifacts appear, lower the intensity instead of quitting. Test a 30-second clip before processing everything. It’s way easier to catch problems early that way.
Noise Gates: Silencing the Space Between Words
A noise gate is commonly misunderstood. It does not remove noise from your voice during speech. It lowers or mutes audio when levels drop too low. This mainly targets quiet gaps between sentences. Those gaps often make background noise much easier to hear. Properly configured, a noise gate makes pauses feel genuinely quiet without touching the vocal signal at all.
Noise Gates — Silencing the Space Between Words
Three parameters control how a noise gate behaves:
Threshold: The level below which the gate closes. For voice recordings, set this just above your noise floor. A starting range of –50 to –70 dBFS works for most home studio environments. If set too high, the gate clips the beginning of words; too low, and the gate never closes.
Attack: How quickly the gate opens when the incoming signal exceeds the threshold. Keep this fast, around 5–10 milliseconds, so each word opens the gate cleanly without a ramp-up delay or audible click.
Release: This controls how quickly the gate fades audio after dropping. Keep it slower, around 100 to 250 milliseconds. This keeps reverb tails and breaths sounding more natural. A release that’s too quick can make speech sound chopped.
Parameter
Recommended Range
What It Controls
Threshold
–50 to –70 dBFS
When the gate opens and closes
Attack
5–10 ms
How quickly the gate opens on voice signal
Release
100–250 ms
How long the gate stays open after speech ends
A noise gate works best after noise reduction has already lowered the noise floor. It is not a replacement for noise reduction; it is the final step that handles residual noise in the silences.
High-Pass Filter (HPF): Cutting Low-Frequency Rumble with EQ
The high-pass filter is one of the most impactful noise-reduction tools available, and it is frequently overlooked by editors who jump straight to dedicated noise reduction plugins. A high-pass filter removes all frequencies below a set cutoff point, eliminating HVAC rumble, desk vibration, traffic bass, and handling noise that lives well below the useful range of the human voice.
High-Pass Filter (HPF) — Cutting Low-Frequency Rumble with EQ
Most of what makes a voice intelligible and warm sits above 100 Hz. Low-frequency content below 80 Hz in a voice recording is almost never the vocal signal itself. It is building vibration, road noise, or electrical interference. Cutting it cleanly does not thin the voice in any perceptible way; it removes noise that was contributing nothing to intelligibility.
Recommended settings for voice content:
  • Cutoff frequency: 80–100 Hz
  • Filter slope: 18–24 dB per octave (a steeper rolloff removes more rumble without affecting frequencies just above the cutoff)
Apply the high-pass filter using any DAW’s built-in EQ plugin. Visually, the resulting EQ curve shows a flat response across the midrange and upper frequencies, then slopes sharply downward to the left below 80 to 100 Hz. Everything below that point rolls off steeply toward silence.
This step should always come first in the processing chain. Noise reduction applied to a signal that still contains low-frequency rumble works harder and produces less clean results than noise reduction applied after the rumble has already been removed.
Spectral Repair: Fixing Isolated Noise Events
Random noises hiding inside speech can be tough to remove cleanly. Noise reduction might damage the nearby voice while cleaning it. Spectral repair gives you a more precise option here. Think of phone buzzes during speech or a random car horn. mid-word, or a brief equipment click that cannot simply be recut can often be removed cleanly using the spectrogram view.
iZotope RX is the industry standard for this technique. The workflow is:
  1. Open the audio file in iZotope RX or via ARA/AudioSuite integration inside your DAW.
  2. Switch to the Spectrogram view.
  3. Identify the noise event visually. It typically appears as a bright horizontal streak, a sudden vertical burst, or an irregular smear against the background pattern of the recording.
  1. Use the selection tool to draw a box or lasso around the isolated event.
  1. Apply Spectral Repair (which interpolates audio from surrounding frequencies to fill the gap naturally)
Or Erase (which replaces the selection with near-silence).
  1. Zoom in for precision when the event overlaps with core speech frequencies.
  2. Preview the result, then commit.
When to use spectral repair: When the event is clearly visible in the spectrogram, short in duration, and disruptive enough to distract listeners.
When to skip it: When the noise event runs longer than a second or two, overlaps heavily with mid-voice frequencies across the board, or appears dozens of times throughout the recording. In those cases, an AI noise removal pass or a re-record is a more efficient use of time.
Apply Techniques in the Right Order: The Correct Signal Chain
The order of your audio edits really matters here. Compression too early can make background noise much louder. Then, noise reduction has a tougher job cleaning everything. A better chain reduces each problem before moving forward. This keeps every editing step cleaner and more effective.
Apply Techniques in the Right Order — The Correct Signal Chain
The recommended processing order for podcast audio:
  1. High-pass filter (EQ): Remove low-frequency rumble and sub-bass interference first. Narrowing the noise bandwidth before any other processing makes every downstream step more effective.
  2. Noise reduction or AI noise removal: Address steady-state noise across the remaining frequency range. Running this on a signal already cleaned by the HPF reduces the workload on the noise reduction algorithm.
  3. Noise gate: Silence residual noise in the gaps between words. By this stage, the noise floor should be low enough that the gate only needs to handle what little remains.
  4. Compression or limiting: Control the dynamic range of the voice now that the noise floor is managed. Compressing earlier in the chain would push noise up alongside the vocal signal.
  5. Final EQ for tone shaping: Shape the tonal character of the voice as the last step, working with clean audio rather than a signal still carrying noise.
Avoid Over-Processing: Knowing When to Stop
Pushing noise reduction too far is one of the most common mistakes in podcast editing. The warning signs to watch for:
Avoid Over-Processing — Knowing When to Stop
  • Voice sounds metallic or tinny, as if coming through a low-quality phone call
  • Speech has a watery or underwater quality
  • Natural breath sounds disappear or become artificial
  • The voice sounds unnaturally detached from any acoustic space, such as hollow and too dry
  • Words begin losing consonant clarity and articulation
A noise floor around -80 dBFS or lower is ideal. This level works nicely for major music platforms. Once the audio sounds clean and natural, stop editing. One gentle reduction pass usually sounds better than several. Too many passes can stack up unwanted digital artifacts..
Reduce Your Editing Workload by Recording Cleaner Audio
Every technique in this guide exists to address noise that was already captured in the recording. The fastest path to clean podcast audio is reducing how much noise enters the signal in the first place.
Two practical steps make the biggest difference before a recording session begins. First, record in a small, furnished room rather than a large, bare one. Soft surfaces, such as carpet, curtains, bookshelves, and upholstered furniture, absorb sound reflections and reduce ambient noise buildup. A reflection filter or portable vocal booth adds an additional layer of isolation without requiring permanent acoustic treatment.
Second, the microphone or wireless system used for capture directly affects the noise floor baked into the recorded signal. A system with onboard noise processing delivers audio that arrives at editing with significantly fewer problems to solve. The Hollyland LARK MAX 2, for example, includes onboard AI Noise Cancellation that filters ambient noise at the point of capture rather than leaving it for post-production. Its 48 kHz / 32-bit Float internal recording preserves enough dynamic range and headroom that any residual noise remaining after capture can be addressed with a single light editing pass rather than multiple heavy ones.
Starting with a cleaner signal does not replace post-production technique, but it changes the editing task from aggressive noise removal to light refinement. That is consistently where better-sounding results come from.
What is the best free tool for removing background noise from a podcast?
Audacity’s built-in noise reduction and Adobe Podcast Enhance are the two most capable free options. Audacity provides more control over noise profiling and reduction strength settings, which is useful when the noise situation is complex. Adobe Podcast Enhance delivers faster results through a browser-based interface with no setup required: upload the file, download the cleaned version.
Can AI noise removal make my audio sound robotic?
It can, particularly on voices with unusual tonal qualities or when a tool is applied at maximum intensity. The fix is straightforward: reduce the processing strength and test on a 30-second clip before applying the settings to the full recording. Most AI tools produce significantly cleaner results at 70–80 percent intensity rather than the default maximum setting.
Should I use a noise gate or noise reduction or both?
Both, because they solve different problems. Noise reduction targets noise that is present throughout the recording, including during speech. A noise gate only silences the gaps between words where no vocal signal is active. Start with noise reduction to lower the overall noise floor. Then add a gate for leftover noise between sentences. This keeps quiet gaps sounding cleaner without overprocessing your voice.
Does the recording environment affect how much noise I can remove in editing?
Significantly. When background noise is recorded at high intensity relative to the vocal signal, removing it cleanly in post risks pulling vocal detail out of the recording along with the noise. Post-production tools work best when refining, not rescuing. Reducing noise before recording is still the best move. Treat the room and place your microphone carefully. Hardware noise cancellation can also help keep recordings cleaner.
Effective background noise removal is a layered workflow, not a single plugin. Start with a high-pass filter to cut unwanted low sounds. Then add noise reduction, either manual or AI-based. A properly set gate can clean up quiet gaps too. When ordered right, these tools can complement each other. This helps clean vocals without making them sound overprocessed. Before editing everything, test a 30-second clip first. Listen with headphones and check how the voice sounds. If everything sounds good, process the complete recording afterward.
