How to Edit Audio for a Podcast: A Complete Step-by-Step Guide
Raw recordings rarely sound broadcast-ready. Background noise, uneven volume, and scattered tangents are normal, and all of them are fixable. Podcast audio editing is the process that transforms those raw files into a polished, professional episode your audience actually wants to listen to. This guide explains every step of podcast audio editing from beginning to end. It covers choosing software, reducing noise, controlling dynamics, adjusting audio levels, and exporting the finished episode.
What Really Happens During Podcast Audio Editing?
Podcast editing is more than cutting awkward pauses. A full podcast editing session includes four main parts.
What Podcast Audio Editing Actually Involves
Cleanup: Removing background noise, room artifacts, and unwanted sounds captured during recording.
Content editing: Cutting filler words, long silences, false starts, and off-topic tangents to improve pacing.
Dynamics and frequency processing: Using EQ to shape tonal quality and compression to even out volume inconsistencies.
Delivery preparation: Normalizing loudness to platform standards, adding music or intro segments, and exporting the file in the correct format.
Each area requires a separate pass or set of tools. That is why editing takes time, and why skipping steps tends to surface in the final product.
Choosing the Right Software Before You Start
No single tool fits every podcaster. The table below matches common use cases to the right software so you can make a decision and start working rather than spending hours comparing feature lists.
Software
Best For
Cost
Platform
Audacity
Beginners who need a capable, no-cost editor
Free
Windows, Mac, Linux
GarageBand
Mac users who want an intuitive multitrack editor
Free
Mac / iOS only
Adobe Audition
Professional workflows with integrated noise tools
~$20/month (Creative Cloud)
Windows, Mac
Descript
Talk-format shows where transcript-based editing saves time
Free tier; paid plans from $12/month
Windows, Mac
Reaper
Podcasters who want DAW-level power at a low price
$60 discounted license
Windows, Mac, Linux
Audacity and GarageBand are the right starting points for most new podcasters. Descript is valuable if your episodes are heavily conversational and you spend most of your editing time hunting for specific lines. Adobe Audition and Reaper make more sense once you are managing complex multitrack projects or producing episodes at high volume.
Step-by-Step Podcast Audio Editing Workflow
Complete each step in the right order. Every stage depends on the one before it. Skipping ahead often creates extra editing later, especially before cleaning the audio first.
Step 1: Import and Organize Your Files
Before any editing, get your session structured.
  1. Create a project folder for each episode. Keep raw recordings, project files, and exports in separate subfolders.
  2. Name your files clearly. EP042_Host_Raw.wav and EP042_Guest_Raw.wav are far easier to navigate than recording1.wav and recording2.wav.
  3. Import all tracks into your editor. If you recorded host and guest on separate devices (a double-ender setup), import both.
  4. Align timing. Use a verbal sync cue, such as “starting in 3, 2, 1,” or a single clap, to manually line up separate recordings.
  5. Confirm your project sample rate is set to 44.1 kHz before you begin. Mismatched sample rates between tracks cause pitch and timing errors.
Good organization at this stage protects your original files and makes every subsequent pass faster.
Step 2: Do a First-Pass Listen and Mark Problem Areas
Do not start cutting immediately. Listen through the entire episode at normal playback speed and place markers wherever you notice:
  • Long pauses or dead air over two seconds
  • False starts, repeated sentences, or verbal stumbles
  • Sudden volume spikes or drops
  • Background noise events such as a phone buzz, chair scrape, or door slam
  • Sections that run too long or wander off topic
This pass is diagnostic, not surgical. The goal is a map of the episode before making permanent changes. Cutting while listening for the first time leads to inconsistent pacing and decisions you will want to undo.
Pro Tip: Use your DAW’s marker or label feature to tag problem types, such as “noise,” “cut,” or “tighten.” Working from tagged regions during subsequent passes is significantly faster than searching from memory.
Step 3: Remove Background Noise and Room Artifacts
Noise removal belongs before EQ or compression. Applying dynamics processing to a noisy track locks that noise in at a more consistent level, which makes it harder to address afterward.
Noise reduction by tool:
  • Audacity: Use the Noise Reduction effect in the Noise Removal and Repair option of the Effect menu. Sample 0.5 to 1 second of room tone (silence between words), build a noise profile by selecting the Get Noise Profile button, then apply it to the full track. Reduce sensitivity in small increments, as overprocessing creates a hollow, watery artifact on voices.
  • Adobe Audition: The Noise Reduction effect in Adobe Audition is found in the Effect menu (Effect > Noise Reduction / Restoration > Noise Reduction (process).
But to successfully apply this effect, you will need to:
  1. Select the part of the audio that needs a fix.
  1. Go to the Effects tab, hover over Noise Reduction / Restoration, and select Capture Noise Print.
  1. Once done, click the Noise Reduction (process) to open the noise reduction effect waveform editor.
  2. Adjust the noise reduction levels and click Apply.
  • Descript: Studio Sound applies AI-based noise reduction automatically and performs well on moderate background noise without manual configuration.
Noise gate: A noise gate silences audio that drops below a volume threshold, which is useful for cutting bleed-through between speech. Set the threshold just above the noise floor of the recording. It will not remove noise during speech, only in the gaps. In Audacity, you can find Noise Gate in the Effect > Noise Removal and Repair > Noise Gate.
Room reverb: Excessive reverb from recording in a large or reflective space is the hardest artifact to fix in post. Spectral repair tools such as iZotope RX can reduce it, but results vary, and correction is rarely complete. In
Note: The most effective noise removal happens before the recording, not after. The Hollyland LARK MAX 2 features 32-bit Float Internal Recording, OWS earphones for live audio monitoring, and onboard AI Noise Cancellation, capturing a cleaner signal at the source and meaningfully reducing the corrective work required in post. If your recordings are consistently noisy, a hardware fix upstream is a higher-leverage investment than any software tool.
Step 4: Cut, Tighten, and Structure the Episode
This is the content editing pass. Work through your marked problem areas and make deliberate decisions about what stays.
  1. Remove obvious errors first: False starts, repeated phrases, and extended dead air over two seconds are safe cuts without much deliberation.
  2. Handle filler words selectively: Not every “um” or “uh” needs to go. Isolated filler words add human texture to conversation. Remove clusters of three or more in a row, and any that land in the middle of a key statement.
  3. Tighten long pauses: Aim for a natural breath space of 0.3 to 0.5 seconds between thoughts. Conversations with no air at all sound rushed.
  4. Use ripple delete: When you remove a section, ripple delete closes the gap automatically so you are not left with silent holes in the timeline.
  5. Cut off-topic tangents: If a segment does not serve the episode’s topic or the listener’s time, remove it even if the content itself is worthwhile. Save it as a clip for social media.
  6. Check every edit point: After making a cut, play back across the boundary to confirm the audio flows naturally. Listen for breath cuts that create an audible gasp, or consonants clipped at the edit boundary.
Step 5: Apply EQ to Clean Up Frequency Problems
EQ for podcasting is corrective, not creative. The goal is a voice that sounds clear and natural, not processed.
High-pass filter (essential for every voice track): Cut everything below 80 to 100 Hz. This removes low-frequency rumble from HVAC systems, traffic, and mic handling noise that is not audible on its own but muddies the overall mix.
Reduce boxiness (200 to 400 Hz): If a voice sounds muffled or congested, a small cut of 3 to 6 dB in this range often clears it up. Use a narrow Q for a targeted cut or a wider Q for a broader tonal adjustment.
Presence and intelligibility (2 to 5 kHz): If a voice sounds thin or lacks presence, a gentle boost here adds clarity. Be conservative, as too much in this range makes consonants harsh and fatiguing to listen to.
De-essing (5 to 8 kHz): Sibilant sounds, the “s,” “sh,” and “ch” sounds, can become piercing on certain microphones. A de-esser plug-in or a narrow cut in the 5 to 8 kHz range softens this without dulling the voice overall.
Reference: For podcast speech, aim for a relatively flat response between 100 Hz and 8 kHz, with a firm roll-off below 80 Hz. This is a starting point, not a rule. Adjust for the specific qualities of each voice.
Step 6: Apply Compression to Even Out Volume Dynamics
Compression reduces the gap between the loudest and quietest parts of a speech recording. For podcasting, the goal is consistent, comfortable volume rather than a dramatic effect.
How it works in practice: When a voice peaks above a set threshold, the compressor reduces it by a ratio you define. A 3:1 ratio means that for every 3 dB above the threshold, only 1 dB passes through. The result is a tighter, more uniform level.
Starting settings for podcast voice:
  • Ratio: 3:1 to 4:1
  • Threshold: Set so the compressor engages on louder portions of speech, not on every syllable
  • Attack: 10 to 30 ms, moderate enough to preserve the natural transient of consonants
  • Release: 100 to 250 ms, fast enough to recover naturally between words
  • Make-up gain: Bring the output level back up after compression reduces the peaks
Compressor vs. limiter: A limiter is a high-ratio compressor, typically 10:1 or higher, that functions as a hard ceiling. Use a limiter on your master output as a final safety net, set to -1 dBTP, to prevent clipping during export. A limiter is not a substitute for compression.
Step 7: Add Music, Intros, and Sound Effects
Add music and produced elements after your voice tracks are processed. Mixing music against an unprocessed voice track is inefficient, as the levels will shift again once EQ and compression are applied.
  1. Layer your intro, outro, and any music beds on separate tracks from the voice.
  2. Set relative levels. Music beds typically sit 15 to 20 dB below the voice track during speaking passages.
  3. Use short fades of 1 to 2 seconds when music enters or exits under speech. Abrupt cuts in music are distracting.
  4. Source royalty-free music from platforms like Epidemic Sound, Artlist, or the Free Music Archive. Unlicensed commercial tracks can result in episodes being muted or removed from distribution.
  5. Check the full mix at normal listening volume. If the music prompts you to reach for the volume control, it is too loud.
Step 8: Normalize and Match Loudness to Platform Standards
Loudness normalization is the final processing step before export. It brings your episode to the volume level podcast platforms expect.
What LUFS means: LUFS stands for Loudness Units Full Scale. It measures perceived loudness over time, which is a more meaningful metric for spoken audio than peak levels. A file at -16 LUFS integrated sounds consistently loud without distortion.
Platform
Target LUFS (Integrated)
True Peak Ceiling
Apple Podcasts
-16 LUFS
-1 dBTP
Spotify
-14 LUFS
-1 dBTP
General / RSS
-16 LUFS
-1 dBTP
Use loudness normalization, not peak normalization. Peak normalization adjusts only the single loudest moment in a file and does nothing for overall perceived volume. Loudness normalization analyzes the full episode and adjusts accordingly.
In Audacity, use the Loudness Normalization effect under the Effect menu. Adobe Audition’s Match Loudness panel handles batch processing across multiple files. Set your True Peak ceiling to -1 dBTP to prevent inter-sample peaks from clipping during the MP3 encoding process.
Exporting Your Podcast File Correctly
Once your mix is complete, export with the following settings.
Format:
  • MP3 is the standard for podcast distribution. It is universally supported by podcast apps and keeps file sizes reasonable for streaming.
  • WAV for your archival master. Always export a lossless version of the final mix before encoding to MP3. You cannot recover quality from a compressed file.
Export settings:
  • Bitrate: 128 kbps for mono; 192 kbps for stereo
  • Sample rate: 44.1 kHz
  • Channels: Mono is sufficient for most talk-format podcasts. Stereo adds file size without a meaningful benefit unless the episode includes music or sound design with true stereo separation.
Metadata: Embed your episode title, episode number, season, creator name, and artwork before or immediately after export. This data surfaces in podcast apps and makes your episodes easier to identify in directories.
One rule to keep: Never export directly over your project file or raw recording. Maintain three separate files: the raw recording, the project file, and the exported MP3. Losing any one of these can mean re-editing from scratch.
Common Podcast Audio Editing Mistakes to Avoid
  • Over-editing natural speech: Removing every filler word, breath, and micro-pause makes dialogue sound robotic. Listeners notice even when they cannot identify why.
  • Skipping EQ and relying only on compression: Compression evens out levels but does nothing for frequency problems. A voice with 300 Hz boxiness will still sound boxy after a compressor pass.
  • Using peak normalization instead of loudness normalization: Peak normalization addresses one moment in the file. Podcast platforms measure integrated LUFS, so peak normalization gives you a false sense of being loud enough.
  • Editing in a noisy listening environment: Your ears become less accurate after hearing constant background sounds. Edit in a quiet room with closed-back headphones whenever possible. Stop for a short break every 45 to 60 minutes.
  • Not saving project files separately from exports: Once you have only the MP3 and your project file is gone, you lose the ability to make non-destructive corrections.
  • Applying noise reduction too aggressively: Strong noise filtering can leave voices sounding thin and artificial. Make small changes instead of pushing the effect too far. Listen to both versions before deciding whether more adjustment is needed.
How long does it take to edit a podcast episode?
For beginners, expect to spend two to four times the episode’s runtime on editing. A 30-minute episode may take 60 to 90 minutes once you have a consistent workflow in place. Experienced editors can often work at a 1:1 to 1.5:1 ratio. Using a transcript-based tool like Descript can compress this significantly for conversational formats.
Do I need to edit every “um” and pause from my podcast?
Not always. A few "um" sounds and short pauses make conversations feel natural. Remove repeated filler words that appear too often. Cut verbal mistakes that interrupt the speaker's thoughts. Delete silent gaps longer than two seconds. Trying to make every sentence perfect can make speech sound less natural.
What LUFS level should my podcast be at?
Aim for -16 LUFS integrated with a True Peak ceiling of -1 dBTP. This meets Apple Podcasts guidelines and is broadly accepted across major platforms. Spotify normalizes playback to -14 LUFS, so a file delivered at -16 LUFS will be turned up slightly on that platform, which is completely normal and not a problem.
Can I edit podcast audio on my phone?
Simple editing is easy with mobile apps like Ferrite Recording Studio on iPhone. Many phone apps also include noise removal, EQ, and compression tools. AI-powered editing has made mobile apps much more capable today. Desktop DAWs still provide better accuracy and detailed audio controls. Even so, phone editing is a practical choice for creating podcasts anywhere.
What’s the difference between noise reduction and a noise gate?
Noise reduction targets consistent ambient sound, such as HVAC hum or room tone, and removes it from the entire file using a captured noise profile. A noise gate silences audio that drops below a set volume threshold between speech, cutting bleed-through during pauses. They solve different problems and are often used together in the same session.
The editing process follows eight steps from beginning to end. Start by organizing files before reviewing the full recording. Then clean unwanted noise and edit the spoken content. Next, adjust EQ, apply compression, and add background music. Finish by normalizing the audio and exporting the episode. Practice this complete process before trying faster editing methods. After that, learn about podcast microphones, remote guest recording, and hosting platforms.
