How to Add Audio to a YouTube Video (3 Clear Methods)
If you are a content creator on YouTube, and your uploaded video has low-quality audio, then think of it as a red flag. Why? Because most viewers may leave due to the muffled sound. To save yourself from such situations, you can either fix the audio before  publishing the video. Or, you can post-edit the audio from the YouTube Studio. So we have gathered three different ways to show you how you can add background music from YouTube's own sound library, narration, and custom audio to your video.
What It Means to “Add Audio” to a YouTube Video
There are two common situations when someone wants to add audio to a YouTube video. The first is a video that is already published, where the goal is to attach background music or swap out a muted audio track. The second is a video that has not been uploaded yet, where the creator wants to add music, a voiceover, or a custom audio file before it goes live.
The biggest source of confusion is that YouTube Studio's built-in editor cannot upload your own audio files to a published video. It only provides access to YouTube’s own music catalog. If you need custom audio, a voiceover, or a licensed track from outside YouTube’s library, that audio must be added to the video file before you upload it.
Method 1: Add Music to a Published Video Using YouTube Studio
YouTube Studio includes a built-in editor with an Audio tab that lets you attach background music from its catalog to any published video without re-uploading the file. No third-party software is required. Here is how to use it:
  1. Go to studio.youtube.com and sign in to your account.
  2. Click Content in the left sidebar to see your video library.
  1. Find the video you want to edit and click the pencil (edit) icon next to it, or click the video title directly.
  1. Click Editor in the left-hand navigation panel. This opens YouTube’s built-in video editor.
  1. Select the Audio tab at the top of the editor panel.
  1. Browse or search the Audio Library. You can filter results by genre, mood, duration, and whether attribution is required.
  1. Preview a track by clicking the play button next to it.
  2. Click Add (+) next to any track you want to use. The audio attaches to your video immediately.
  1. Click Save in the upper right corner. YouTube processes the update and applies it to the published video without changing the URL, view count, or search ranking.
The Audio Library contains thousands of licensed music tracks and sound effects, all cleared for use on YouTube without triggering copyright issues.
Limitations of YouTube Studio’s Built-In Audio Tool
Before committing to this method, be aware of what it cannot do:
  • No custom file uploads: You cannot add your own MP3, WAV, or personal audio file to a published video through YouTube Studio.
  • One track only: You can add a single music track; layering voiceover over background music is not possible here.
  • Limited mixing control: Fade sliders are available, but precise volume control relative to your original video audio is not.
  • YouTube’s catalog only: External licensed music, purchased tracks, or original compositions cannot be added.
If any of these limitations apply to your situation, check out Method 2.
Method 2: Add Custom Audio Before You Upload (Using a Video Editor)
This method works for background music you have downloaded, licensed tracks from subscription services, or any audio file you own. The workflow below follows the general pattern used in DaVinci Resolve and CapCut, but applies to most editors.
Supported audio formats: MP3, WAV, and AAC all work in most editors and export cleanly for YouTube upload.
  1. Open your video editor and start a new project. Set the project frame rate to match your original video (typically 24, 30, or 60 fps).
  2. Import your video file. Drag it into the media bin or use File > Import.
  1. Import your audio file. Add your MP3 or WAV to the same project.
  1. Drag the video clip to the timeline. It will sit on the main video track.
  1. Drag the audio clip to a track below the video in the timeline. Most editors create a separate audio track automatically when you do this.
  1. Align the audio with the video. Slide the audio clip so it starts at the beginning of the video, or at the exact point you want it to begin.
  2. Trim the audio if it is longer than the video. Drag the right edge of the audio clip inward until it matches the video length.
  3. Apply a fade out at the end of the audio clip so the music ends smoothly rather than cutting off.
  1. Adjust volume. Lower the audio clip volume so it supports the video without drowning out any original dialogue or ambient sound.
  2. Export the finished video. Use H.264 (MP4) format at your original resolution. YouTube recommends at least 8 Mbps bitrate for 1080p.
  3. Upload the exported file to YouTube. You can upload it as a brand-new video or use YouTube Studio’s Replace Video option under Video Details to swap the file on an existing video.
This method gives you full control: multiple audio layers, precise volume levels, and the freedom to use any audio source you own or have licensed.
Free Tools to Add Audio Before Uploading
Tool
Platform
Best For
Cost
DaVinci Resolve
Windows / Mac / Linux
Desktop editing with professional-grade audio mixing
Free
CapCut
Mobile / Desktop
Beginners who want a fast, simple workflow on any device
Free
Adobe Premiere Pro
Windows / Mac
Creators already in the Adobe ecosystem
Paid (starting from $22.99/mo)
iMovie
Mac / iOS only
Mac users who want a straightforward, no-cost option
Free
Method 3: Record a Voiceover and Add It to Your YouTube Video
Background music adds atmosphere, but narration adds meaning. If your video needs commentary, tutorial explanation, or storytelling laid over the footage, you need to record and sync a voiceover track. Here is how to do it:
  1. Script or outline your narration. Write out what you want to say, or at a minimum, note the key points for each segment of the video. This prevents rambling and reduces the editing work later.
  2. Record your voiceover audio. Options include:
  • Your phone’s built-in voice memo app (fast and simple)
  • Audacity, a free recording program for Windows and Mac
  • A dedicated microphone connected to your computer
  1. Create a sync cue before you start speaking. Clap once sharply or tap the mic at the very beginning of your recording. This creates a visible spike in the audio waveform that makes it easy to find the exact sync point in your editor.
  2. Import the voiceover file into your video editor. Place it on a dedicated audio track, separate from any background music track.
  3. Sync the audio to the video. Slide the voiceover clip to the point in the timeline where you want it to begin. If you recorded narration for the full video, align the waveform spike from step 3 with the corresponding visual moment on screen.
  4. Adjust relative volume levels. If you are combining a voiceover with background music, bring the music down, typically between -6 dB and -12 dB below the voiceover level. The narration should always be the most audible element.
  5. Export and upload using the same steps from Method 2 (H.264/MP4, matching resolution and frame rate).
A helpful sync tip: if you are recording narration separately from filming, play the video on one screen while recording so your pacing matches the visuals naturally. This cuts down on fine-tuning later.
Getting Better Voiceover Audio
Microphone quality has a direct impact on how professional your narration sounds, and poor recording conditions can undermine otherwise good content. For creators recording narration on a smartphone, a simple clip-on wireless microphone makes a noticeable difference by reducing background noise and room echo without requiring a complex setup. If you want a simple option, consider the Hollyland LARK A1. It plugs directly into phones with USB-C or Lightning connectors. The 3 Intelligent Noise Cancellation levels help keep your voice easier to hear. No pairing process or extra apps are needed before recording. This makes it a solid choice for beginners recording voiceovers confidently.
Staying Copyright-Safe When Adding Audio to YouTube
YouTube’s Content ID system continuously scans uploaded videos for copyrighted audio. If it finds a match, your video can be muted, have its revenue redirected to the rights holder, or be blocked in certain regions. Here is how to keep your audio choices safe:
  • YouTube Audio Library: Free tracks available inside YouTube Studio. Most require no attribution, and all are pre-cleared for YouTube use. This is the lowest-risk option.
  • Epidemic Sound or Artlist: Paid subscription services (roughly $9 to $17 per month) that grant a license covering YouTube distribution. Both are widely used by working creators.
  • Creative Commons audio: Available through platforms like Free Music Archive or ccMixter. Always read the specific license terms because some require attribution and some restrict commercial use.
  • Original recordings: Any audio you record yourself, whether it is your own voice or an original musical composition, belongs to you. No copyright issues apply.
  • Avoid “royalty-free” sites without explicit YouTube licensing: The term “royalty-free” means you do not pay per use. It does not automatically grant YouTube distribution rights. Read the terms on any site before downloading tracks for use in an uploaded video.
Can I add my own music to an already-uploaded YouTube video?
No. YouTube Studio only allows music from its own Audio Library on published videos. To add a custom audio file, you need to edit the video in a video editor, include the audio in the exported video file, and re-upload it to YouTube. The original video’s URL and view count will not carry over to the re-upload.
Will adding audio to a YouTube video affect its views or SEO?
Re-uploading a video resets its view count and creates a new URL, which affects any SEO equity the original had. When possible, use YouTube Studio’s built-in audio tool to avoid this. Making changes in YouTube Studio to a published video does not reset view counts or change the video’s URL.
How do I add audio to a YouTube video on my phone?
If you want your own audio in a YouTube video, edit everything first. Open CapCut or another mobile editing app with similar tools. Add both the video and audio files to the timeline. Match everything, then export a single finished video before uploading. Keep in mind that YouTube's mobile app cannot add audio to published videos. If your video is already live, use a computer instead. Sign in to YouTube Studio and edit it through the web editor.
Can I add multiple audio tracks to a YouTube video?
YouTube Studio supports only one audio addition at a time on a published video. To combine background music and a voiceover, layer both audio tracks in a video editor before uploading. Both tracks are merged into a single exported video file, so YouTube sees them as a single audio stream.
Why is the audio I added out of sync with my YouTube video?
Sync problems most often come from mismatched sample rates between the audio file and the project settings. Export your audio at 44.1 kHz or 48 kHz in WAV format, confirm both the audio and video clips start at the same point in the timeline, and render the final file at a consistent frame rate. The sync cue clap described in Method 3 also helps catch alignment issues early.
Everything depends on one simple question. Has the video already been published or not? If it is already live, use YouTube Studio's Audio Library. It lets you add copyright-safe background music without uploading the video again. Use DaVinci Resolve or CapCut to add custom audio before uploading when you need full control over the result. Use the voiceover workflow when narration is what the video actually needs. Identify which situation applies to you, then follow the corresponding method above from start to finish.
