Your iPhone records awesome videos, but the audio editing story isn't as exciting. The Photos app barely gives you anything to work with. Whether you want to add background music, record a narration, or drop in a sound effect, you need a dedicated editing app. This article explains three free ways to add audio to videos. It covers iMovie, CapCut, and InShot, with clear step-by-step instructions for each so you can choose the one that fits your workflow.
What Does “Adding Audio” to an iPhone Video Actually Mean?
Knowing your goal first makes the whole editing process much easier. “Adding audio” covers three distinct use cases:
Background music: Layering a song or instrumental track underneath your existing footage.
Voiceover or narration: Recording your voice directly over the video to explain or describe what is happening.
Sound effects: Dropping in short audio clips to enhance specific moments in the video.
The native Photos app cannot do any of these. It can only mute or lower existing audio. To add new audio of any kind, you need a video editing app. All three options covered in this guide are free and available on the App Store.
Method 1: How to Add Audio to a Video Using iMovie
iMovie comes pre-installed on most iPhones and is Apple’s own free video editor. It supports multiple audio layers, voiceover recording, and volume mixing, making it the most capable free option for adding audio to iPhone videos.
How to Add Background Music in iMovie
Open iMovie and tap Start New Project, then select Movie.
To import a clip, tap on the video to select it. Then tap the Create Movie option at the bottom of the screen.
In the timeline editor, tap the “+” icon above the timeline to add media.
Tap Audio at the top of the media browser.
Select Soundtracks for Apple’s built-in library, or tap My Music to import a track from your Apple Music library.
Tap a track to preview it, then tap the “+” button to add it to the project.
Drag the audio clip along the timeline to align it with your footage.
Tap the audio clip, then tap the Speaker icon, and use the volume slider to balance it against the original video audio.
Tap Done, then tap the Share icon to export.
Note: To remove the original video audio entirely, tap the video clip in the timeline, tap the speaker icon, and drag the volume slider to zero. This is useful when you want to replace the original sound with music or a narration track.
Tip: Use the Soundtracks library for any content you plan to publish publicly. These tracks are royalty-free and cleared for YouTube, Instagram, and TikTok, so you avoid content strikes after uploading.
How to Record a Voiceover in iMovie
Open your iMovie project with the video already in the timeline.
Drag the playhead (the white vertical line) to the point where your voiceover should begin.
Tap the + icon above the timeline and select the Voiceover option (microphone icon) from the menu.
Also allow the microphone access if you haven’t already.
Tap Record. iMovie counts down from three before it starts capturing audio.
Speak clearly, then tap Stop when finished.
Review the recording. Tap Accept to keep it or Retake to re-record.
Tap the voiceover clip in the timeline to trim its start and end points.
Use the volume slider to balance the voiceover against the original video audio.
Tap the Share icon to export the finished video.
Tip: Record in a quiet room and hold the iPhone about six to eight inches from your mouth. Bathrooms and rooms with tile floors create an echo that is difficult to remove in editing.
Method 2: How to Add Audio to a Video Using CapCut
CapCut is a free app especially popular with TikTok and Instagram Reels creators. Its audio workflow is faster and more visual than iMovie’s, and it includes a large built-in music library with tracks pre-cleared for social platforms.
Open CapCut and tap New video.
Select your video from the media library and tap Add.
In the bottom toolbar, tap Audio.
Choose one of the following sources:
Sounds to browse CapCut’s built-in library, searchable by name, mood, or genre
From Device (Sounds > Your Audio (Folder icon) > Device) to import an audio file saved locally on your iPhone
Extract to pull the audio track from another video on your phone
Tap a track to preview it, then tap the “+” button to add it to the timeline.
Move the audio clip until it lines up with the right video section. Place it where you want the sound to begin playing.
Tap the audio clip and use the trim handles to cut it to the right length.
Tap Volume and adjust the slider to set the desired audio level.
Tap the checkmark to confirm, then tap Export to save the video.
How to extract audio from another video in CapCut: Under the Audio menu, tap Extract and select any video from your library. CapCut strips the audio from that clip and places it as a standalone track in your project timeline. This is helpful for isolating music or dialogue from a reference clip without needing a separate audio file.
Note: CapCut adds a watermark to exported videos by default. To remove it, tap the watermark overlay in the editing view and tap Delete. This is available at no cost and does not require a paid subscription.
Method 3: How to Add Audio Using InShot
InShot is a practical alternative for users who already have it installed or prefer its interface. It covers the essentials without the more advanced controls found in iMovie.
Open InShot and tap Video to import your clip.
Tap the Audio icon from the toolbar and choose Music. Or, if you want to capture your voice, select Record.
Choose Featured for InShot’s built-in library and My Music to import from your device.
Select a track, preview it, and tap the checkmark to add it.
Drag the audio to align it with your video in the timeline.
Tap Volume and adjust the level using the slider.
Tap the checkmark to confirm, then tap Save to export.
InShot is a strong choice for quick edits. If you need precise timeline control or a dedicated voiceover recording workflow, iMovie handles those tasks more reliably.
How to Get Better Audio to Add to Your iPhone Videos
The most common frustration after adding audio is discovering that the recorded voiceover still sounds hollow or noisy. Editing apps can layer and trim audio, but they cannot fully recover poor source quality. A few recording habits make a significant difference:
Record in a soft, quiet room: Bedrooms and living rooms with carpet and furniture absorb echo. Bare walls and tile floors amplify it.
Get close to the microphone: The iPhone’s built-in mic works best within 6 to 8 inches of your mouth.
Eliminate background noise sources: Switch off fans, air conditioning, and televisions before starting a voiceover recording.
Use earbuds with an inline mic: The microphone on Apple’s EarPods sits closer to your mouth than the iPhone’s built-in mic and can noticeably improve voiceover clarity without any additional gear.
For creators who regularly record narration or conduct interviews on their iPhone, a dedicated wireless microphone solves the background noise problem at the source rather than in post-production. The Hollyland LARK A1 connects directly to iPhone via Lightning or USB-C with no Bluetooth pairing or companion app required. It includes 3-level intelligent noise cancellation and captures clean, directional audio even in moderately noisy environments, making it a practical upgrade for anyone who finds their voiceovers consistently sound thin or echo-heavy.
Q: Can I add audio to a video on iPhone without an app?
Not meaningfully. The native Photos app can only mute or adjust the volume of existing audio and cannot import a separate music track or record a voiceover. You will need iMovie, which is free and pre-installed on most iPhones, or a third-party app like CapCut to add new audio to your video.
Q: How do I add music from Spotify or Apple Music to my iPhone video?
Streaming-licensed tracks cannot be directly imported into video editors due to DRM restrictions. Use Apple Music tracks you own outright, royalty-free tracks from iMovie’s Soundtracks library, or copyright-safe music from CapCut’s built-in audio library. Doing so avoids copyright claims and content strikes on YouTube, TikTok, and Instagram.
Q: Why is there no sound after I added audio in iMovie?
Make sure the audio volume in iMovie is above zero before previewing. Turn up your iPhone's media volume during playback as well. The silent switch does not control preview audio. Also, check that the video finished exporting without any problems. An interrupted export may create a video with missing sound.
Q: Can I replace the original audio in a video on an iPhone?
Yes. Select the video clip from the editing timeline first. Tap the speaker icon and lower the volume to zero. You can also open Actions and choose Detach instead. This places the original sound on its own blue track. Delete that track before adding your new audio. Another option is tapping Extract audio from the toolbar. This moves the sound below the video as a separate track. Delete the extracted waveform, then add your replacement audio.
Q: What’s the best free app to add audio to a video on iPhone?
iMovie is a great option if you want more editing control. It also exports videos without adding a watermark. CapCut is a better fit for quick edits and social media posts. Its simpler layout and built-in music library save editing time. iMovie is completely free without any subscription costs. CapCut offers free editing, but some audio tools and music require a Pro subscription.
For most iPhone users, iMovie is the best starting point. Why? Because it comes pre-installed in iPhones, it’s watermark-free and capable of handling both music and voiceover in one place. CapCut is the faster choice for social media clips and offers a ready-made licensed music library. InShot works well if it is already part of your editing routine. Whichever app you choose, improving your source audio at the recording stage will always produce cleaner results than trying to fix it in editing afterward.
