Instagram makes adding music to a Story look easy — until you realize the “Add Music” sticker only pulls from a licensed library. If you want to use your own voice recording, original song, or podcast clip, you need a different approach. This guide walks you through three methods that actually work, from a quick native option built into the app to a flexible third-party workflow that handles any audio file type.
How to Add Your Own Audio to an Instagram Story: 3 Methods That Actually Work
What “Your Own Audio” Means on Instagram (and Why the Music Sticker Won’t Help)
Instagram’s “Add Music” sticker is connected to a licensed library of tracks — it has no option to import a personal audio file. “Your own audio” refers to anything you created or saved outside of Instagram: a voice memo, an original song, a podcast highlight, or a saved sound file. All three methods below are built around that reality, so you can skip the frustration of searching for an upload button that does not exist.
Method 1 — Use Instagram’s Built-In Voiceover Feature
Instagram includes a native Voiceover tool inside the Stories editor. It records a live narration layer directly over a photo or video with no extra app required.
Open Instagram and tap the camera icon in the top-left corner, or swipe right from your feed, to enter Stories.
Capture a new photo or video, or swipe up and select one from your camera roll.
Tap the three-dot menu (⋮) in the top-right corner of the editor.
Select Voiceover from the options that appear.
Press and hold the record button to narrate over your content. You can record in multiple short segments.
Drag the voiceover clip along the timeline to adjust when it starts.
Tap Done, then tap Your Story to publish.
Note: Voiceover records audio in real time inside the app. It does not accept imported audio files. If you need to use a pre-recorded file, skip to Method 2 or Method 3.
When to Use This Method
You want to add live spoken commentary or narration to a static photo.
You need a quick explainer track and do not have a pre-recorded file ready.
You prefer to stay inside the Instagram app with no extra steps.
Method 2 — Upload a Video That Already Contains Your Audio
This is the most straightforward path for pre-recorded audio. Record or export a video in any app — your Camera app, Voice Memos, GarageBand, or a podcast tool — with your audio already baked in. Instagram preserves the embedded audio exactly as-is when you upload it to Stories.
Open the app where your audio lives and record or export your content as a video file.
Save the video to your camera roll.
Open Instagram Stories by tapping the camera icon or swiping right from your feed.
Tap the gallery icon in the bottom-left corner and select your video clip.
Trim the video if needed. Instagram automatically splits longer videos into multiple Story segments.
Add captions, stickers, or other elements as desired.
Tap Your Story to share.
MP4 is the most compatible format for uploading to Stories. Formats like AVI or MKV may cause upload errors or strip the audio, so convert them first if needed.
Best for These Situations
You recorded an original song or instrumental in GarageBand and want to share a short clip.
You have a podcast teaser already exported as a video with a static cover image.
You filmed a talking-head video on your camera and the audio is already embedded.
You used a voice memo app that exports with a waveform or image visual.
Method 3 — Merge Your Audio With a Visual in a Third-Party App, Then Post to Stories
If you have a standalone audio file (MP3, WAV, or M4A) that is not yet attached to any video, a third-party editing app is your best option. You choose the visual, import the audio file, sync and trim everything, then export a finished video to upload to Stories. This method works with any audio format and gives you the most control over the final result.
Download CapCut or InShot from the App Store or Google Play (both are free).
Open the app and start a New video.
Import your photo or video as the visual base for the Story.
Tap the Audio or Music option in the editing toolbar, then select Extract (CapCut) or My Files (InShot).
Choose your audio file from your phone’s storage. MP3, M4A, and WAV are all supported.
Trim and position the audio clip so it syncs with your visual.
Adjust volume levels if needed.
Tap Export and save the finished video to your camera roll.
Open Instagram Stories, select the exported video from your gallery, and post.
Pro Tip: In CapCut, use the “Detach Audio” option if you’re working with a video that has unwanted background noise you want to swap out for your own audio file.
Recommended Free Apps
App |
Platform |
Audio Import |
Export Quality |
Cost |
CapCut |
iOS & Android |
MP3, M4A, WAV |
Up to 1080p |
Free |
InShot |
iOS & Android |
MP3, M4A, WAV |
Up to 1080p |
Free (watermark on free tier) |
Adobe Express |
iOS & Android |
Limited |
Up to 1080p |
Free with account |
How to Make Your Recorded Audio Sound Better Before You Post
Even the best upload method cannot rescue poor-quality audio. A few simple habits before you record make a real difference:
Record in a quiet space. Background noise is the most common quality problem. A small room with soft furnishings or a closet works well in a pinch.
Position the microphone correctly. Keep your mic 6 to 8 inches from your mouth for clear, balanced levels.
Use noise reduction in your editing app. Both CapCut and InShot include noise reduction tools under their audio settings — worth enabling before you export.
If you record voiceover or spoken content regularly, a dedicated microphone is a worthwhile step up. The Hollyland LARK M2 is a 9-gram clip-on wireless microphone built for vloggers and social content creators — it delivers broadcast-quality audio, runs up to 40 hours on a single charge, and is compact enough to disappear on camera. For creators just starting out who prefer a wired option, the Hollyland LARK A1 plugs directly into your phone’s USB-C or Lightning port and features 3-Level Intelligent Noise Cancellation with zero configuration required — plug it in and record.
Can I add an MP3 or music file directly to an Instagram Story?
Instagram does not have a native audio file import button for Stories. The “Add Music” sticker only works with Instagram’s licensed library and will not accept personal files. To use an MP3, follow Method 3: import the file into CapCut or InShot, pair it with a visual, export it as a video, and upload that video to your Story.
Why can’t I hear audio when I post a Story from my camera roll?
Instagram Stories automatically mute video when your device is set to silent mode. Your audio is still embedded in the file — viewers just need to tap the screen to unmute. A simple text label like “Tap to unmute” added directly to your Story frame is an easy way to prompt them.
Can I add my own audio to an Instagram Story on Android and iPhone?
Yes. All three methods in this guide work on both iOS and Android. Menu labels and icon placements may look slightly different depending on your app version, but the core features — Voiceover, gallery video upload, and third-party app export — are available on both platforms.
Is there a way to add audio from Spotify or Apple Music to my Story?
No. Tracks from Spotify and Apple Music are protected by DRM and cannot be imported into Instagram or third-party editing apps. Only tracks available in Instagram’s own licensed “Add Music” library can be attached natively to a Story.
What is the difference between adding audio to a Story vs. a Reel?
Reels offer more built-in audio editing, including camera roll audio import in some regions. Stories are more limited natively, which is why the third-party app method is often the most reliable route when you need to add custom audio to a Story specifically.
Next Step
Match the method to your audio source: use the Voiceover feature for live narration recorded inside the app, use a camera roll video upload when your audio is already embedded in a video file, and use CapCut or InShot when you are starting from a standalone audio file. Clean audio makes every method sound more professional — if you are ready to upgrade your recording setup, start with the microphone guide linked below.
