If you’ve tried to share custom audio on Instagram and ended up confused by the options, you’re not alone. Many creators assume “original audio” works like picking a song from Instagram’s music library. It doesn’t. Original audio follows its own workflow, and once you understand it, the process is straightforward. This guide walks you through three reliable methods to add original audio to an Instagram Reel, plus how to make that audio discoverable after you post.
How to Add Original Audio to an Instagram Post (Step-by-Step)
What “Original Audio” Actually Means on Instagram
On Instagram, “original audio” refers to any sound in a Reel that does not come from Instagram’s licensed music library. That includes your speaking voice, a song you recorded yourself, ambient sound from your surroundings, a podcast clip, or any audio embedded in a video you produced. If your Reel contains sound that Instagram did not license, the platform automatically labels it “Original Audio” and creates a shareable audio clip tied to your account.
This is worth clarifying because many users expect an explicit “add original audio” button inside the Reels editor. There isn’t one. The feature works differently: Instagram detects the absence of a library music track and generates the original audio label on its own. Your job is simply to make sure no competing licensed track is layered over your content before you publish.
That auto-generated audio clip is more useful than it might seem. Once your Reel is live, other creators can tap the audio label on your post, view your clip listed under a dedicated audio page, and hit “Use Audio” to borrow your sound for their own Reels. If you name the audio before or after publishing, it becomes searchable inside Instagram’s audio browser, giving you a small but compounding discoverability advantage every time someone reuses your sound.
Method 1: Record a Reel Directly with Your Own Audio
Steps
This is the most direct path. When you record a clip inside Instagram, your device microphone captures the live audio, and Instagram automatically classifies it as original audio.
Open Instagram and tap the + icon at the top of the screen.
Select Reel from the format options at the bottom.
Press and hold the record button to capture your clip. Speak, perform, or let ambient sound record naturally.
Once recorded, tap the music note icon in the left-side toolbar to open the audio panel. Confirm that no additional music track has been added. If one was pre-selected, remove it.
Tap the Next to proceed to the editing and preview screen.
Tap Share to publish.
Instagram generates the original audio page linked to your account as soon as the Reel is live.
Method 2: Upload a Video from Your Camera Roll
If you recorded your video outside of Instagram (on your phone’s default camera app, a DSLR, a screen recorder, or any other device), you can upload that file and the embedded audio travels with it.
Open Instagram, tap the + icon, and select Reel.
Instead of recording live, tap the gallery icon in the lower-left corner to open your camera roll.
Select the video clip you want to upload.
Once the clip loads in the editor, tap the Music (🎵) icon and make sure no Instagram music has been added. If your video already contains audio, Instagram will preserve it as the original audio unless you add a music track.
If you previously selected an Instagram music track, remove it before continuing so your video's original audio remains unchanged.
Tap Next to continue to the preview and sharing screen. Add your caption and any other post details, then tap Share to publish your Reel.
Before uploading, play the clip on your device to confirm the audio track is actually there. Some editing apps export video as silent by default, which will leave your Reel without any audio after upload.
Method 3: Add a Voiceover Inside the Reel Editor
The voiceover tool is built into Instagram’s Reel editor and lets you record a narration layer over a clip that is already loaded. Instagram still classifies this as original audio.
Load your video clip into the Reel editor by recording or uploading from the camera roll.
Tap Next to open the editing screen, then tap Voiceover (microphone icon) if the option is available.
Move the playhead to the point where you want your voiceover to begin.
Tap and hold the record button to capture your voiceover in real time.
After recording, adjust the Voiceover and Original Audio volume levels if needed.
Tap Next, add your caption and other post details, then tap Share to publish your Reel.
If the original clip is silent, your voiceover becomes the sole audio track. If the clip has its own audio, both layers blend together at the levels you set.
How to Name and Share Your Original Audio So Others Can Use It
Naming your original audio is a short step with a real downstream impact. When audio has a name, it appears in Instagram’s audio search results. Other creators can discover it, tap “Use Audio,” and build Reels around your sound, each of which links back to your audio page and your profile.
Here’s how to set it up effectively:
Name it before you post. On the share screen, tap the audio label at the bottom and type a short, descriptive name. Keep it relevant to your content or brand.
Name it after posting. Open the published Reel, tap the audio label at the bottom of the post, and select the rename option.
Set visibility to Public. Confirm the audio is set to Public, not Private. Private audio can only be used by you.
Use a consistent naming convention. If you produce audio content regularly, consider using a recognizable brand name or prefix so your clips are easy to attribute and reuse across posts.
Named, public original audio builds over time. Every Reel another creator makes with your sound adds another post to your audio page.
Tips for Better-Quality Original Audio on Instagram
Record in a quiet space. Background noise competes directly with your voice and reduces overall clarity on playback.
Stay close to the mic source. Whether you use your phone’s built-in mic or an external one, distance degrades the signal quickly.
Avoid recording near music or a TV. Ambient licensed audio picked up by your mic can trigger a content match that overrides your original audio label entirely.
Consider a compact wireless mic. For creators who record Reels on the move, a lightweight option like the Hollyland LARK M2 (9 g, button-sized, 40-hour battery) clips to your shirt and delivers clean, low-noise audio without adding bulk to a mobile setup.
Can I add original audio to a regular Instagram feed post, not a Reel?
Standard photo and video feed posts do not support the original audio labeling system. That feature is specific to Reels. Audio from a feed video will still play when someone watches it, but it is not indexed, searchable, or shareable as a named audio track the way Reel audio is.
Why does my original audio show as “Private”?
Instagram defaults original audio to Private when your account is set to Private. To make it Public, switch to a Professional or Public account type, open the published Reel, tap the audio label, and update the visibility setting to Public.
Can I add original audio to an already-published Reel?
No. Once a Reel is published, you cannot swap in a new audio track or add one that was not included at upload. To fix the audio, delete the Reel and repost it with the correct audio attached from the start.
Adding original audio to an Instagram Reel comes down to three paths: record live in-app and let Instagram tag the audio automatically, upload a pre-made video with audio already embedded, or use the voiceover tool to narrate over an existing clip. Whichever method you use, name your audio and set it to Public right after posting. That one extra step is what turns a single Reel into a reusable sound other creators can find and build on.
