Finding trending audio can decide whether your Reel grabs attention or gets skipped. Instagram does not have one place showing every trending sound right now. That leaves many creators wondering which audio is actually getting popular. This guide shares five simple ways to spot trending sounds inside Instagram. It also includes extra tools for creators posting Reels almost every day. Every method is easy to repeat and takes less than five minutes.
What “Trending” Audio Actually Means on Instagram
Many people think trending audio only means popular songs on Instagram. In reality, it includes any sound quickly growing across Reels. Instagram highlights some rising sounds with a Trending label.
Eligible professional accounts can also check the Trending Audio section. Picking popular audio helps creators join conversations people already follow. Still, Meta never confirmed that those sounds automatically increase Reel reach. Instagram ranks Reels through several signals, including engagement and overall content quality.
Method 1: Browse Trending Audio Directly in the Reels Camera
The fastest native method is the Reels camera audio browser, which surfaces trending sounds in real time without any external tools.
Open Instagram and tap the + icon, then select Reel.
Tap the camera tile to record a live reel. Or, select a recorded video.
Tap the Audio option (music note icon) on the left side of the camera screen to open the audio browser.
Look for a Trending tab at the top of the screen, next to Suggested.
Tap Trending to see a live list of sounds Instagram is currently surfacing to creators.
Preview a track by tapping it. Tap Use (arrow facing to the right) to attach it to your Reel.
This list refreshes daily. Checking it before you film is the single most time-efficient trending audio habit you can build.
How to Spot the “Trending” Arrow Indicator
Next to many audio titles in the browser, you will see a small upward arrow icon. This is Instagram’s visual signal that a sound’s use count is actively growing, not sitting at a plateau.
Here is how to read it:
Arrow present, moderate use count: This gives you the best chance to join the trend early. The sound keeps growing, yet too many creators have not used it. Posting now lets your Reel catch the trend before interest slows.
No arrow, high use count: The track is popular but has likely peaked. Still usable, though the algorithmic push will be smaller.
Arrow present, high use count: Worth considering if the sound only recently hit mainstream volume and the content angle fits your niche.
Prioritize the arrow over the raw number. A rising signal at 50,000 uses often outperforms a flat signal at 500,000.
Method 2: Discover Trending Sounds by Scrolling the Explore Page
Your Explore page and Reels feed work as a passive trend radar. When the same sound appears across multiple unrelated creators in a single scroll session, that repetition is an algorithmic signal worth acting on.
Open Instagram and tap the magnifying glass (Explore) or scroll your Reels feed.
Scroll for two to three minutes while paying attention to the audio name at the bottom of each Reel.
Note any track that appears repeatedly across different creator types and content topics.
When you spot a recurring sound, tap the audio name on any Reel to open the Audio Detail Page.
Review the detail page before deciding whether to use the sound in your next post.
This method takes slightly longer than the Reels camera browser, but it shows you how other creators are framing the audio, which helps you plan your own angle before filming.
Use the Audio Detail Page to Confirm a Sound Is Trending
The Audio Detail Page is your confirmation step before committing to a sound. Look for the following:
Total video count: A figure in the hundreds of thousands, combined with the trending arrow, is a strong green light.
“Use Audio” CTA: One tap loads the sound directly into your Reels editor.
Related Reels grid: A scrollable preview of how other creators are using the audio right now, which also serves as content angle inspiration.
Creator credit: Shows whether the audio is an original creator sound or a licensed track, which affects availability on business accounts.
If the use count is rising and the related Reels grid shows a wide variety of creator types, the sound is in active trend territory.
Method 3: Search and Filter the Instagram Music Library
The music library inside the Reels editor and Stories panel lets you browse by mood, genre, and popularity. This method works well when you have a specific content style in mind and want trending audio that fits it.
Open the Reels camera and tap the Audio icon (music note).
Tap on the search bar at the top (no need to write anything in the search field). Then, browse the genre or mood tiles, which typically include options like Happy, Chill, Playful, and more.
Look for a Popular, Vibe, or Trending filter tab near the top (availability varies by region and account type). And scroll through the results.
Preview any track and check its use count before making a final choice.
Method 4: Save Trending Audio Before You’re Ready to Create
You will not always be ready to film the moment you find a great trending sound. The Save Audio feature lets you bookmark sounds and return to them when it is time to post.
Find any Reel using a trending sound via the methods above.
Tap the audio name at the bottom of the Reel to open the Audio Detail Page.
Tap the bookmark icon to save the audio to your collection.
Access your saved sounds at: Profile > Menu (three lines) > Saved > Audio tab.
Keep a rolling library of three to five saved sounds at any given time. When you sit down to create, you will have pre-vetted trending options ready without scrambling under time pressure.
Method 5: Use Third-Party Tools to Track Instagram Audio Trends
For creators posting at high frequency or managing multiple accounts, third-party tools can supplement native discovery. They are not essential for casual creators but add an early-signal layer for those who need it.
TrendTok Analytics: Tracks trending audio on TikTok with country and category filters. Since sounds frequently migrate from TikTok to Instagram Reels within days, this gives you a reliable head start.
TikTok Creative Center (free): TikTok’s public dashboard shows top trending songs by region. Cross-referencing it with your Instagram feed builds a forward-looking picture of what is likely to arrive on Instagram next.
Manual cross-platform scan: Spend a few minutes in TikTok’s Reels-equivalent each morning and note the dominant audio. Flag anything rising there that has not yet appeared on your Instagram feed.
These tools complement the native Instagram methods rather than replacing them.
Tips for Using Trending Audio Effectively in Your Reels
Act within 48 hours: Trend windows are short. Post while the upward arrow is still active.
Match energy to content: A fast-tempo track paired with slow visual cuts creates friction. Choose audio whose pace and mood complement what you are showing.
Start at the hook: Open your Reel at the audio’s most recognizable or highest-energy moment to maximize the first-three-second watch rate.
Do not force the fit: Using trending audio without a connection to your content tends to hurt watch time, which the algorithm weighs heavily.
Record clean narration: If your Reel includes on-camera talking or a voiceover, vocal clarity matters as much as the background track. A plug-and-play option like the Hollyland LARK A1 (available in USB-C and Lightning versions, with three-level noise cancellation) makes it easy to capture clear voice audio on a smartphone without any complicated setup, so your narration sits cleanly over the trending sound.
Why can’t I see the Trending tab in my Instagram audio library?
If the Trending tab does not appear, update Instagram before anything else. Make sure you are using the Instagram mobile app too. Business accounts may see fewer licensed music choices than creators. Switching to a Creator account can unlock more licensed tracks. Even then, the Trending Audio section may still stay unavailable. Region, account eligibility, and feature rollouts also affect access.
How often does trending audio change on Instagram?
Most trending sounds stay popular for about 3 to 7 days. Some culturally popular tracks keep growing for two or three weeks. Checking the Trending tab every day gives better results than weekly. This matters even more if you post Reels on a regular schedule. Try finding audio while it is still gaining more attention. Waiting too long usually means many creators have already joined the trend. But Meta does not say how often trending audio changes on Instagram. The company also gives no recommended schedule for checking trends.
Can I use trending audio on a business account?
Yes, but there are a few limits you should know first. Business accounts cannot access every licensed song on Instagram. Commercial licensing rules limit some popular music for those accounts. If one track stays unavailable, pick commercially licensed audio instead. That includes music from the Meta Sound Collection and other eligible sounds. Creator accounts often unlock a larger licensed music library than Business accounts. Even then, available music still depends on licensing agreements and your region.
Does using trending audio actually increase Reels reach?
The correlation is real but not a guarantee. Trending audio can earn a Reel broader initial distribution, but the algorithm weighs watch time, saves, shares, and comments together. Think of trending audio as an entry ticket into wider reach, not a result by itself. Strong audio paired with strong content consistently outperforms trending audio used on weak content.
Getting started is easy. Open the Reels camera and tap the music icon. Next, open the Trending tab and find sounds with the upward arrow. Save the audio right away for quick access later. That saves time before you publish your next Reel. Posting consistently matters more than chasing every popular sound.
