Wind noise is one of the most frustrating audio problems to fix in post-production. If you shot outdoor footage and the mic caught everything the wind had to offer, the good news is that Premiere Pro has several native tools that can recover usable audio. This guide walks through each method in order, explains when to combine them, and tells you honestly when you need to reach for something more powerful.
Why Wind Noise Is Hard to Remove Without Damaging Your Audio?
Wind noise sits primarily in the low-frequency range, roughly below 200 Hz. The problem is that human voice fundamentals occupy some of that same range, around 85 Hz for a deep male voice, up to 255 Hz for a higher female voice. That overlap means any tool aggressive enough to wipe out wind energy will also chip away at the warmth and presence of the voice underneath.
The second challenge is that wind is rarely constant. A steady hiss is easier to profile and remove than gusting, variable wind, which changes character frame by frame and resists static noise profiles.
Results depend heavily on severity. Light wind haze over a clear voice is very recoverable. Heavy, gusting wind that is louder than the speaker is a harder problem, and some recordings simply cannot be fully restored regardless of the software. The methods below are ordered from fastest to most powerful, and knowing when to stop is as important as knowing how to start.
Method 1: Remove Wind Noise Using the Essential Sound Panel
The Essential Sound panel is the fastest starting point for most editors. It is built directly into Premiere Pro, requires no additional effects, and the Reduce Rumble slider is specifically designed for low-frequency wind energy.
Steps:
Open the Essential Sound panel: go to Window > Essential Sound.
Select the audio clip on your timeline, then click Dialogue to tag it in the panel.
Scroll down to the Repair section and expand it.
Check the box next to Reduce Noise and start with the slider at around 5.0.0%.
Check the box next to Reduce Rumble and start at 6.060% for moderate wind or 7.0-7.570–75% for heavier wind. This slider targets sub-200 Hz energy specifically, making it the more targeted tool for wind compared to Reduce Noise.
Play back the clip at full volume through speakers or headphones and adjust both sliders gradually until the wind is reduced without the voice sounding muffled or hollow.
Note: Reduce Rumble and Reduce Noise do different jobs. Reduce Rumble is tuned for low-frequency thump and roar. Reduce Noise addresses broadband noise across the full spectrum. For wind, start with Reduce Rumble. Add Reduce Noise only if a hissing or rushing quality remains after.
Recommended Settings Starting Point
Use the table below as a calibration baseline. These are starting points, not absolute targets. Always ear-check at full playback volume rather than relying only on metering.
Setting |
Starting Value |
Max Before Artifacts |
Reduce Noise |
40–50% |
65% |
Reduce Rumble |
60–70% |
80% |
Pushing either slider past these upper limits tends to produce a muffled, underwater quality on dialogue. If you need more reduction at these ceilings, move to Method 2 or Method 3 rather than forcing sliders higher.
Method 2: Apply the DeNoise Audio Effect for Targeted Reduction
The DeNoise audio effect gives you more manual control than the Essential Sound sliders and works well as either an alternative or a complement to Method 1. It is particularly effective for constant, steady wind noise rather than gusting or variable wind.
Steps:
Go to the Effects panel and navigate to Audio Effects > Noise Reduction/Restoration > DeNoise.
Drag the effect onto your audio clip in the timeline.
Open the Effect Controls panel and find the DeNoise effect. Click Edit to open the full effect dialog.
If there is a section of the clip that contains only wind noise with no dialogue, play that section and click Learn to let Premiere Pro sample the noise profile. This improves accuracy.
Adjust the Amount slider. Start at 40% and increase gradually. Keep the value below 70% to avoid stripping voice presence along with the noise.
Listen to the output. If the voice sounds thin or phasey, reduce the Amount and consider combining with Method 3 to handle what remains.
Note: DeNoise reduces general background noise across many frequencies. It is not strong against low-frequency wind thumps. Apply it after Reduce Rumble in the Essential Sound panel. This combination gives better results in difficult wind noise cases.DeNoise handles the broadband character of noise well, but it is less effective at the specific low-frequency thump that wind produces. Use it after or alongside Reduce Rumble from the Essential Sound panel for best results on complex wind problems.
Method 3: Use a High-Pass Filter to Cut Low-Frequency Wind Rumble
A high-pass filter is a precise tool for wind rumble removal. It removes all audio below a chosen frequency level. This creates fewer unwanted distortions than noise reduction tools usually produce. For many clips, this single step improves the sound clearly.A high-pass filter is often the most surgical tool for low-frequency wind rumble. Because it simply cuts everything below a set frequency, it introduces fewer processing artifacts than noise reduction algorithms. For many clips, this step alone makes a significant difference.
Steps:
In the Effects panel, go to Audio Effects > Filter and EQ > Parametric Equalizer. Drag it onto the clip. Alternatively, you can use the High Pass filter under the same Filter and EQ folder for a simpler interface.
In the Effect Controls, click Edit to open the Parametric Equalizer dialog.
Enable the High Pass (HP) band on the left side of the equalizer.
Set the cutoff frequency between 80 and 120 Hz. For voice content, 80–100 Hz is a safe starting point that removes deep rumble without touching voice fundamentals.
Set the roll-off slope to 12 dB/octave for moderate wind or 24 dB/octave for heavier low-end rumble. Steeper slopes cut more aggressively below the cutoff.
Play back the clip. If the voice sounds thin or lacks body, lower the cutoff frequency slightly. If wind rumble remains audible, raise the cutoff gradually, checking at each step.
Applying the high-pass filter as the first step makes the noise reduction tools in Methods 1 and 2 more effective. When you remove the loudest low-frequency content first, the remaining noise is less intense, which means noise reduction algorithms require less processing to handle what is left. That reduced processing load directly lowers the risk of artifacts.
Combining Methods: The Right Order of Operations
Using all three methods in the wrong sequence can compound artifacts or make it harder to diagnose where quality is being lost. Follow this order for the best results:
Apply the High-Pass Filter first. Remove the bulk of low-frequency rumble before any noise reduction runs. This gives subsequent tools a cleaner signal to work with.
Apply Reduce Rumble in the Essential Sound panel second. After the worst sub-bass energy is removed, Reduce Rumble handles the remaining low-frequency wind texture without needing to work as hard.
Apply DeNoise last. With the low-frequency content already addressed, DeNoise can focus on any remaining broadband wind hiss or rushing noise at a lower Amount setting, which protects voice quality.
Moving in this sequence removes the biggest problem first at each stage and avoids asking any single tool to do more than it should. If any step is producing audible artifacts, reduce that tool’s strength before moving to the next.
When Native Tools Aren’t Enough: Using iZotope RX for Severe Wind Noise
For footage with heavy, variable, or gusting wind that defeats Premiere Pro’s native tools, iZotope RX is the most widely used professional solution. It includes a De-wind module built specifically for this problem, which analyzes wind noise characteristics separately from dialogue and removes them with significantly more precision than broadband noise reduction.
Workflow to send audio from Premiere Pro to iZotope RX:
Right-click the audio clip in the timeline and select Edit Clip in Adobe Audition to roundtrip the file. Open it in RX from Audition.
Alternatively, if you have iZotope RX Connect installed, you can send audio directly from Premiere Pro to RX without using Audition as a bridge.
In RX, run the De-wind module on the clip. For isolated gusts rather than continuous wind, Spectral Repair can target specific moments in the spectral frequency display and interpolate cleaner audio in their place.
Render the processed file and return it to Premiere Pro.
Cost context: RX Elements is the entry-level tier and handles most wind noise cases. RX Standard and RX Advanced include more modules and are used in broadcast and film post-production. If you only encounter wind noise occasionally, RX Elements is sufficient. If location audio is a regular part of your workflow, RX Standard is worth considering.
Keep iZotope RX as the later option when things get more serious. Premiere Pro tools usually handle light to moderate wind noise pretty well. It also saves you from extra cost and back-and-forth exporting between tools.Keep iZotope RX as the escalation path, not the starting point. Native tools in Premiere Pro handle light-to-moderate wind noise well and require no additional cost or roundtrip time.
Prevent Wind Noise Before It Reaches Your Editing Timeline
Post-production can recover a lot, but it cannot recover everything. The most reliable way to deal with wind noise is to reduce it at the recording stage.
Prevention checklist:
Use a deadcat windscreen or blimp. Foam windscreens offer minimal protection outdoors. A deadcat (faux-fur cover) or a full blimp with internal suspension is effective in moderate to strong wind.
Position the microphone behind the subject relative to the wind direction. The speaker’s body acts as a baffle and reduces direct wind exposure to the mic capsule.
Use a directional microphone. Cardioid and supercardioid polar patterns reject off-axis sound, including wind noise approaching from the sides and rear. Omnidirectional mics pick up wind from every direction.
Get the microphone close to the source. The closer the mic is to the mouth, the louder the voice signal is relative to wind noise, which improves the signal-to-noise ratio before any post-processing happens.
For outdoor and active shooting scenarios where wind noise is most likely, a compact wireless microphone with built-in noise management reduces the problem significantly before it ever reaches your timeline. The Hollyland LARK M2S, a 7g titanium clip-on designed for cycling, sports, and active movement, is engineered specifically for these conditions. For professional shoots where dialogue quality needs to survive even difficult environments, the Hollyland LARK MAX 2 adds AI Noise Cancellation and 32-bit Float internal recording, preserving more recoverable signal when conditions are unpredictable.
Q1: Can Premiere Pro fully remove wind noise?
Partially. Premiere Pro’s built-in tools reduce light to moderate wind noise when the voice is still clear underneath. For stronger or gusty wind, third-party tools like iZotope RX give better results. If the wind is too loud compared to the dialogue, full recovery is often not possible in any software.Premiere Pro’s native tools handle light-to-moderate wind noise well when the voice signal is strong underneath. For heavy or gusting wind, third-party tools like iZotope RX deliver better results. Severe wind noise that is louder than the dialogue may not be fully recoverable regardless of which software you use.
Q2: What’s the difference between Reduce Noise and Reduce Rumble in Premiere Pro?
Reduce Noise targets broadband noise across the full frequency spectrum. Reduce Rumble is specifically tuned to low-frequency energy below roughly 200 Hz, which is the range where most wind noise lives. For wind problems, start with Reduce Rumble. Add Reduce Noise afterward only if a hissing or rushing quality remains in the mid and upper frequencies.
Q3: Is there a free plugin for wind noise removal in Premiere Pro?
Premiere Pro’s Essential Sound panel and DeNoise effect are included with any Creative Cloud subscription at no additional cost. For free third-party options, Audacity’s Noise Reduction tool can be used as a roundtrip workaround. iZotope RX Elements is a paid option, but it offers meaningfully better wind noise results than any free alternative.
Q4: How do I remove wind noise without affecting voice quality?
Start with a High-Pass Filter set around 80–100 Hz to cut the deepest rumble, then bring in Reduce Rumble in the Essential Sound panel. Increase each slider gradually and listen after every adjustment rather than maximizing a single tool all at once. Over-processing is the most common cause of muffled, robotic, or hollow-sounding dialogue, and it is much easier to prevent than to fix.
Begin inside Premiere Pro by applying a high-pass filter first. Then move to Reduce Rumble and finish with DeNoise. This chain is usually enough for mild-to-moderate wind problems without extra tools. When wind gets more aggressive or messy, iZotope RX becomes the better option. In the long run, clean recording at the source gives the most dependable results.Start with Premiere Pro’s native tools in this order: High-Pass Filter, then Reduce Rumble, then DeNoise. Most light-to-moderate wind noise problems respond well to that sequence without any additional plugins. For heavy or unresolvable wind, iZotope RX is the practical next step. Long-term, the most reliable solution is cleaner source audio. For more on getting the best results from Premiere Pro’s audio toolset, see our guide on [Best Audio Settings in Premiere Pro].
