How to Clean Up Audio in Premiere Pro (Step-by-Step)
With poor audio, you can't win audience retention even if your video looks great. Your recording may include room hiss, electrical noise, or echo from bare walls. And that needs to be fixed. Fortunately, Adobe Premiere Pro includes tools that help repair most dialogue issues without leaving the Adobe environment. Our guide explains the full process step by step. It covers all necessary tweaks from the Essential Sound Panel to loudness adjustment. You will learn which tool to use and how much of its intensity should be applied to get better results.
What Audio Problems Can Premiere Pro Fix?
Before diving in, match your problem to the right tool. Here is a quick reference to set expectations:
Problem
Common Cause
Premiere Pro Tool
Background hiss or room noise
HVAC, ambient environment
DeNoise
Electrical buzz
Lighting rigs, outlets, ground loops
DeHum
Room echo or reverb
Untreated recording space
Reduce Reverb (DeReverb)
Harsh “S” or “SH” sounds
Microphone proximity, some condenser mics
DeEss
Clicks and pops
Handling noise, digital glitches
DeClick
Muddy or boomy low end
Room acoustics, low-frequency rumble
Parametric EQ (High-Pass Filter)
Inconsistent volume levels
Variable speaker distance or delivery
Compression / Match Loudness
Set Up the Right Workspace Before You Start
Getting your workspace ready takes less than a minute and keeps all the relevant panels in view.
  1. Go to Window > Workspaces > Audio to switch to Premiere Pro’s dedicated audio workspace. This brings the Essential Sound Panel and Audio Track Mixer to the foreground.
  1. If the Essential Sound Panel is not visible, open it via Window > Essential Sound.
  1. Confirm your Timeline is open with the dialogue clips you intend to repair. The Essential Sound Panel responds to whatever clip is selected in the sequence.
Use the Essential Sound Panel to Repair Dialogue (Core Workflow)
The Essential Sound Panel is the most efficient starting point for dialogue repair. Rather than hunting through the Effects panel for individual audio effects, this panel consolidates DeNoise, DeHum, DeReverb, and DeEss into a single interface. Work through each repair tool in order, starting with the biggest problems first.
Tag Your Clip as Dialogue
Tagging is not optional — it is what unlocks the Repair sub-panel. Without a tag, you will only see basic volume controls.
Select the clip in your timeline, then click Dialogue in the Essential Sound Panel under “Clip Type.”
This tells Premiere Pro that the clip contains spoken word, and it surfaces the appropriate repair sliders. The Dialogue tag applies to any voice track: interviews, narration, on-camera talent, podcast recording, and so on.
Note: You can select multiple clips at once and tag them all as Dialogue in a single click, which is useful when working across a long timeline.
Reduce Background Noise with the DeNoise Slider
With the Dialogue tag applied, expand the Repair section and check the box next to Reduce Noise. A slider will appear.
Start conservatively. A value between 2.0 and 4.0  should remove room noise without introducing artifacts. If it's still there, you can test values between 5.0 and 10. But keep in mind that pushing the slider above 5.0 can produces a metallic, “underwater” quality — the audio sounds processed rather than natural. Play the clip back in real time while adjusting so you can hear the effect live.
If the slider does not give you enough control, reach for the dedicated DeNoise audio effect instead. Go to Effects panel > Audio Effects > Noise Reduction/Restoration > DeNoise.
Drag it onto the clip and open it in the Effect Controls panel. This version lets you set a specific reduction amount and threshold independently, and it includes a live preview mode so you can audition the isolated noise before committing to settings.
Remove Electrical Hum with DeHum
Check the box for Reduce Hum in the Repair section. A dropdown appears asking you to choose a base frequency: 50 Hz (standard in Europe, Asia, and most of the world) or 60 Hz (standard in North America and parts of Latin America). Choose the one that matches your regional power grid.
Using the Advanced Hum-Correction Tool (DeHummer)
If the DeHum method doesn’t make much difference, try the DeHummer option. Remember, electrical hum is caused by improperly grounded equipment, fluorescent lighting, or power cables running near audio cables. Because hum has harmonics at multiples of the base frequency (100 Hz, 150 Hz, and so on), you will need to make a few adjustments in the DeHummer effect.
1. Locate the DeHummer effect in the Effects panel under the Noise Reduction/Restoration menu.
2. Drag and drop the effect on the audio.
3. Then go to the Effects Controls by clicking the Window tab and choosing "Effects Controls."
4. Next, look for the effect's name and click the "Edit" button to open advanced hum-reduction adjustments.
5. Now:
  • Customize Base Filter Frequency levels if the DeHum from the "Repair" section didn't make any difference.
  • Adjust the Number of Harmonics to control how many extra frequency layers related to the main hum get reduced.
  • Use the Harmonic Slope slider to adjust how much the reduction intensity (attenuation) should be applied to the higher harmonics compared to the fundamental (base) frequency.
When you fine-tune these controls, the hum can be reduced or removed to a great extent. This also prevents the odd “bubbly” sound that sometimes appears during cleanup. At the same time, it protects the deeper parts of a speaker’s voice, which simple noise reduction often weakens or strips away.
Eliminate Harsh Sibilance with DeEss
Sibilance is the sharp, fatiguing edge on “s,” “sh,” and “ch” sounds. Adjust the slider to reduce it. The goal is smoother consonants, not lispy speech — too much DeEss makes the speaker sound like they are mumbling. Try with light adjustments by keeping lower values on the slider and then gradually increasing the intensity (if needed). If the problem is severe, treat it here and then revisit with the standalone DeEsser effect for frequency-targeted control.
Reduce Room Echo with Reduce Reverb
Check Reduce Reverb and drag the slider slowly upward. If that does not work, try Premiere Pro’s DeReverb effect from the Effects panel. It works well on light room echo — the kind of slight hollowness you hear when recording in a home office or untreated bedroom.
Set realistic expectations here. Premiere Pro’s reverb reduction will not rescue audio recorded in a gymnasium or tiled bathroom. Heavy reverb is one of the most difficult problems to fix in post-production, and aggressive use of the DeReverb tends to produce swirly, phase-shifted artifacts. Use it to tighten the sound rather than transform it. For serious reverb problems, Adobe Audition’s spectral repair tools are the better option (see the section below on round-trips).
Clean Up Frequencies with the Parametric EQ
Once the repair tools have addressed identifiable noise problems, the next step is tonal cleanup with EQ. Think of it as shaping the character of the voice rather than removing a defect.
1. In the Effects panel, search for the Parametric Equalizer. It should appear under the Filter and EQ menu.
2. Drag and drop the effect on the audio clip.
3. Open Effect Controls and click the Edit button in the Parametric Equalizer section.
4. Then adjust:
  • High-pass filter at 80–100 Hz: Rolls off rumble, handling noise, and low-frequency room resonance that builds up below the voice. Almost every dialogue clip benefits from this cut.
  • Cut at 200–400 Hz: Reduces the “muddy” or “boxy” quality that makes voices sound like they were recorded inside a cardboard box. Use a narrow-to-medium Q and cut 2–4 dB to taste.
  • Boost at 2–5 kHz: Adds presence and intelligibility. A gentle 2–3 dB shelf or bell in this range makes voices easier to understand at low playback volume.
The Essential Sound Panel’s EQ section also includes presets — Voice-over, Interview, and Podcast — that apply sensible starting curves. Use these as a foundation, then fine-tune from there rather than starting from flat.
Control Dynamics with Compression and Limiting
Compression evens out volume inconsistencies between a quiet mumble and a loud burst. The Essential Sound Panel’s Dynamics section applies an auto-compression setting calibrated for dialogue — enable it and listen for whether the voice feels more controlled and consistent.
For more control, add the Multiband Compressor audio effect from the Effects panel. It lets you compress different frequency bands independently, which is useful when a voice is boomy in the low end but already tight in the high mid-range.
To prevent peaks from distorting downstream, add a Hard Limiter as the last effect in the chain and set the maximum amplitude to -1 dBFS. This creates a ceiling that catches any rogue transients before export.
Normalize Loudness to a Broadcast or Platform Standard
Loudness normalization is the final step, not the first. It sets the overall perceived volume of your clip to match the target level of the platform where the video will be published.
Platform
Target Loudness Standard
YouTube
-14 LUFS integrated
Podcast (general)
-16 LUFS integrated
Broadcast (TV/streaming)
-24 LUFS (ATSC A/85)
Spotify / Music Streaming
-14 LUFS integrated
To apply loudness normalization in Premiere Pro, select the clip, and in the Essential Sound Panel’s Loudness section, click Auto-Match. Premiere Pro measures the integrated loudness of the clip and adjusts gain to hit the target level. You can also right-click one or more clips in the timeline and choose Audio Gain to set a specific LUFS target manually.
Normalizing before compression or limiting will cause those effects to behave inconsistently. Always normalize last.
When to Send Audio to Adobe Audition Instead
Premiere Pro’s repair tools are built for moderate problems. When noise is severe, reverb is unworkable, or you need to remove a sound that overlaps with the voice in the same frequency range, the right move is a round-trip to Adobe Audition.
Right-click the clip in your Premiere Pro timeline and select Edit Clip in Adobe Audition. Audition opens with the clip linked — any changes you save are reflected back in Premiere Pro automatically.
Two Audition-specific tools are worth knowing:
  • Noise Print Reduction: Capture a noise print from a silent section of the recording, then subtract that exact noise profile from the entire clip. Far more precise than a slider.
  • Spectral Frequency Display: A visual representation of your audio where problem sounds show up as color patterns. You can literally paint over and remove a dog bark, a door slam, or a persistent hum without affecting the surrounding audio.
Switch to Audition if Premiere sliders create unwanted sound changes before fixing the issue.
Pro Tip: Start with Cleaner Audio to Reduce Post Work
Even Premiere Pro’s strongest repair tools have limits. Heavily damaged audio rarely restores completely. Each extra processing step can add new sound issues. Recording in a quieter environment, positioning the microphone closer to the source, and using a directional mic dramatically reduces the repair burden in post. For creators who regularly shoot in noisy, uncontrolled spaces, a wireless microphone with built-in AI Noise Cancellation and 32-bit Float internal recording — like the Hollyland LARK MAX 2 — captures cleaner source audio at the recording stage, which means less time spent fighting with sliders in Premiere Pro.
Q: Why does my audio sound robotic after using Reduce Noise in Premiere Pro?
The Reduce Noise slider is set too high. Bring it down to the 2.0 to 4.0 range and listen in real time. Subtle application almost always sounds more natural than maximum reduction, and if that is not enough, use the dedicated DeNoise effect in the Effects panel for finer threshold control.
Q: Can Premiere Pro remove wind noise?
Partially. Use the Reduce Noise slider to address the broadband hiss component of wind, and apply a high-pass filter to cut everything below 100 Hz, where wind rumble lives. Severe wind noise is difficult to fix in Premiere Pro alone because it overlaps with voice frequencies — Adobe Audition’s spectral repair tools or a dedicated plugin handle it more effectively.
Q: What is the difference between Reduce Noise in the Essential Sound Panel and the DeNoise audio effect?
The Essential Sound Panel version gives you a single slider with limited control — it is fast and useful for quick fixes. The dedicated DeNoise audio effect, found under Effects panel > Audio Effects > Noise Reduction/Restoration > DeNoise, exposes adjustable threshold and reduction amount settings separately, and includes a live preview so you can audition just the noise being removed before committing to the processing.
Q: What LUFS level should I target for YouTube?
Target -14 LUFS integrated. YouTube normalizes all uploaded content to approximately -14 LUFS during playback. If your audio is louder than that, YouTube turns it down — which is fine. If it is quieter, YouTube leaves it alone, so mastering to -14 LUFS ensures your video plays at full intended volume without the platform compressing your dynamic range.
Q: Does Premiere Pro have a spectral noise removal tool like iZotope RX?
No. Premiere Pro does not include spectral frequency editing. For that level of repair — removing a specific overlapping sound without affecting the surrounding audio — send the clip to Adobe Audition using the right-click round-trip workflow. Audition’s Spectral Frequency Display and Noise Print matching provide the closest in-Adobe equivalent to iZotope RX’s repair tools.
Follow this order for consistent results: tag your clip as Dialogue in the Essential Sound Panel, work through the Repair tools (DeNoise, DeHum, DeReverb, DeEss), shape the tone with Parametric EQ, control dynamics with compression, and finish with loudness normalization. Light-touch processing almost always sounds more natural than pushing every slider to its maximum. When the built-in tools fall short, the round-trip to Adobe Audition is the right next step.
