What Is Gain in Audio? A Plain-English Guide for Beginners
If you have ever turned up a gain knob and ended up with crackling distortion, or kept it too low and ended up with a hiss-filled recording, you are not alone. Gain is one of the most misunderstood controls in audio, partly because it looks and feels like a volume control. This guide explains what gain actually is, how it differs from volume, and how to use it correctly from the start.
The Core Definition — What Gain Actually Means in Audio
In audio, gain is the amplification applied to a signal at a specific point in the signal chain. It controls how strong an audio signal is as it enters or passes through a device, not how loud the final output sounds to the listener. That distinction matters more than it might initially seem.
To understand gain, it helps to understand the signal chain: the path audio travels from its source (a microphone, an instrument, or a playback device) through a series of stages — preamplifier, processor, mixer or audio interface — before it reaches an output such as speakers, headphones, or a recorded file. Gain operates at these intermediate stages, shaping signal level before it moves to the next link in the chain.
A microphone produces a very weak electrical signal. Without amplification, that signal would be far too low for a recording device or speaker to work with. Gain boosts that weak signal to a usable level. But as with most things in audio, more is not always better.
What is gain in audio? Gain is the amplification applied to an audio signal at a specific point in the signal chain, controlling signal strength before it reaches the output stage.
Gain vs. Volume — Why They Are Not the Same Thing
Gain and volume are the two most commonly confused controls in audio, and you can see why: both seem to make things louder. But they operate at different points in the signal chain and have very different consequences when misused.
Gain affects the incoming signal level before it is processed or amplified for output. It shapes the raw strength of the signal entering a stage. Volume (also called output level or fader level) controls how loud the processed signal is when it leaves a device and reaches your speakers or headphones.
A useful analogy: think of a garden hose. Gain is the water pressure at the source — how forcefully water flows into the pipe. Volume is the tap at the far end — how wide you open it to let water out. You can open that tap all the way, but if the pressure at the source is barely a trickle, opening it wider just gives you a slow, weak trickle at louder volume. Worse, any impurities in that weak flow get amplified along with it.
That is the practical problem with confusing these two controls. If your gain is set too low and you compensate by turning up the volume, you are not recovering a strong, clean signal. You are amplifying a weak signal along with all the noise sitting underneath it. The result is a louder recording that is also noticeably hissier.
Gain
Volume
What it controls
Incoming signal strength
Output level to speakers or headphones
Where in the chain
Input / preamp stage
Output stage
Too high causes
Clipping, distortion
Listener discomfort; no damage to the signal
Too low causes
Noise floor becomes audible
Quiet playback; signal quality unaffected
Types of Gain in Audio
Gain appears in several forms depending on where you are in the signal chain. Here is a brief overview of the three most common types you will encounter.
Preamp (Input) Gain
Preamp gain is the most critical type for anyone recording audio. A preamplifier (preamp) takes a mic-level or instrument-level signal and boosts it to line level so that downstream devices can work with it properly. This is where the most consequential gain decisions are made: too much preamp gain introduces clipping and distortion that cannot be removed later; too little leaves the signal buried in noise. The gain knob on an audio interface or mixer is almost always controlling preamp gain.
Output Gain
Output gain controls how loud a signal is as it leaves a device or processing stage. Unlike preamp gain, adjusting output gain does not change the upstream signal quality — it simply raises or lowers the level going into the next stage. You will find output gain controls on power amplifiers, audio interfaces, and individual channels on a mixing console.
Digital Gain
Digital gain applies amplification to a signal that has already been converted to digital data, typically inside a DAW or digital mixer. This gives editors flexibility in post-production. The key limitation, however, is that digital gain cannot recover information lost during recording. Boosting a clipped or noisy digital signal does not restore the original audio — it only makes the problem louder.
What Is Gain Staging and Why Does It Matter?
Gain staging is the practice of setting the optimal signal level at each stage of the signal chain — strong enough to rise clearly above the noise floor, low enough to avoid clipping. It is not a single knob adjustment; it is a discipline that spans every stage from microphone to final mix.
To understand why it matters, picture the signal travelling through a corridor with a floor and a ceiling. The floor is the noise floor: the baseline level of electrical hiss and background interference present in any recording system. The ceiling is the clipping point: the maximum level a device can handle before the waveform distorts. Between these two limits is the usable dynamic range — the zone where audio sounds clean and controlled.
If your signal sits too close to the noise floor (gain too low), even a small amount of background hiss becomes audible relative to the signal. If it hits the ceiling (gain too high), it clips — producing harsh, crackling distortion that is permanent in digital recordings. No amount of post-processing brings back a digitally clipped waveform.
The concept of unity gain is a useful reference point here. Unity gain (0 dB) means a signal passes through a stage at the same level it entered: no amplification, no attenuation. Gain staging is not about achieving unity gain at every stage — it is about keeping each stage within a healthy range so that problems do not compound as the signal moves forward.
The most important reason gain staging matters: mistakes made early in the signal chain are very difficult or impossible to correct later. A cleanly captured signal at the recording stage gives you flexibility at every stage that follows.
Pro Tip: In digital recording, a practical starting target is signal peaks sitting between -18 dBFS and -12 dBFS. This leaves enough headroom to handle loud transients without clipping, while keeping the signal well above the noise floor.
How to Set Gain Correctly — Practical Steps
Setting gain correctly does not require expensive equipment or years of experience. It requires a consistent process and attention to your meters.
Follow these steps when setting input gain:
  1. Start with your gain control at its lowest position. Beginning from zero prevents accidental clipping the moment you introduce a signal.
  2. Perform at your intended recording level. Speak, sing, or play at the same volume you plan to use in the actual session — not softer. Gain set for a quiet test will be too low when you perform at full energy.
  3. Watch your input meter while you perform. On most audio interfaces and DAWs, peaks should land between -18 dBFS and -12 dBFS during the loudest moments.
  1. Adjust the gain knob slowly upward until peaks land in that range. If the meter hits 0 dBFS or turns red, the signal is clipping.
  2. Check the noise floor. Stop performing and listen at low volumes. If you can hear obvious hiss even before the performance starts, your gain chain may have a noise issue — or the microphone may need to be repositioned closer to the source.
  3. Leave extra headroom for unpredictable sources. Voice and acoustic instruments can vary significantly in level between phrases. Targeting -18 dBFS peaks gives you a safer buffer than -12 dBFS when the source is dynamic.
What clipping looks like: The meter turns red and the waveform in your DAW will appear flat-topped, with the peaks literally cut off.
What clipping sounds like: A harsh, crackling, or buzzing distortion layered over the original audio.
Different sources require different starting points. A loud electric guitar direct-in will push a preamp far more quickly than a quiet voice in a treated room. Trust the meter, and use your ears.
Gain in Wireless Microphones — And How 32-Bit Float Changes the Rules
Setting gain in a controlled studio is manageable. In field recording, live event coverage, or run-and-gun video work, it is considerably harder — you often cannot predict when a subject will suddenly shout or a sound source will spike unexpectedly.
This is where 32-bit float recording changes the rules. Instead of capturing audio at a fixed bit depth where clipping is permanent, 32-bit float captures the full dynamic range of a scene. If the signal exceeds what you anticipated, the information is still present in the file and can be corrected in post without distortion.
The Hollyland LARK MAX 2 wireless microphone system records internally at 48 kHz / 32-bit float, meaning the transmitter preserves the complete dynamic range regardless of how external gain is set.
Combined with AI noise cancellation, this effectively removes the most common and costly gain-setting mistake in unpredictable recording environments — a meaningful practical benefit for solo creators and videographers who cannot monitor levels continuously.
What does 0 dB gain mean?
Zero dB gain is unity gain — the signal passes through a stage without any amplification or attenuation, meaning the output level equals the input level. It is a standard reference point in gain staging that tells you a device is neither amplifying nor reducing the signal as it passes through.
Is higher gain always better?
No. Higher gain amplifies everything in the signal, including background noise, hum, and any distortion already present in the chain. The goal is the correct gain for your signal level, not the maximum gain available. Too much causes clipping; too little leaves the signal lost in noise.
What does gain clipping sound like?
Clipping produces a harsh, crackling, or buzzing distortion layered over the original sound. In digital audio, a clipped signal has its peaks permanently cut off — no post-processing can restore the lost information. If you hear unexpected crackling on a recording, checking input gain is always the first diagnostic step.
What is the difference between gain and amplification?
Amplification is the process of increasing a signal’s strength. Gain is the measurement and control of how much amplification occurs, typically expressed in decibels (dB). In practical terms: amplification is what the circuit does; gain is the control that tells it how much to do it.
Gain controls signal strength at a point in the chain — not the volume a listener hears. Gain staging keeps every stage in the optimal range between the noise floor and the clipping ceiling. And getting gain right at the source is always easier than trying to fix a flawed recording in post. Start clean, and everything downstream becomes more manageable.
Go deeper with these related guides: - How to Set Up a Microphone for Recording - Gain Staging Explained: A Deeper Dive for Home Producers - Best Audio Interfaces for Beginners
