Clipped audio is one of the most frustrating problems a content creator can face. You nail the interview, finish the session, then open your DAW and hear crackling distortion on every loud moment. The good news is mild clipping can often be fixed with software. Even better, the right recording setup helps stop clipping before it happens. This guide explains both sides, from software repair tools you can use today to recording habits that stop clipping before it starts.
What Is Audio Clipping and Why Does It Sound Distorted?
When recorded sound becomes louder than a digital system allows, clipping happens. Digital recorders cannot capture anything above 0 dBFS, their highest limit. Extra volume gets chopped off instead of being recorded correctly. The waveform loses its rounded peaks and flat edges appear instead. That change creates a distorted signal instead of the original sound.
That flat-topped waveform is what causes the harsh, buzzy distortion you hear. The squared shape introduces harmonic frequencies that were not present in the original sound, and your ears perceive them immediately as unnatural and harsh.
This article covers fixing audio that already sounds clipped and distorted. It also explains how to stop clipping during your next recording.
What a clipped waveform looks like: In any DAW, a clipped waveform shows flat horizontal lines at the top and bottom of the wave rather than smooth, rounded peaks. Most DAWs flag these sections in red on the meter or directly on the waveform display.
How to Fix Already-Clipped Audio (Software Repair Methods)
If you have a recording with clipped audio, you have four main software options. Before you start, set realistic expectations. Mild clipping where only a few peaks briefly touch 0 dBFS is usually recoverable to an acceptable level. Severe clipping, where long sections of audio are flat-topped, has lost harmonic information that no software can fully reconstruct. You may improve the result, but you may not fully restore it.
Using iZotope RX (De-clip Module)
iZotope RX’s De-clip module is the most capable automated repair tool available for this problem. It analyzes clipped peaks and reconstructs missing information using spectral data from the surrounding audio.
Open your clipped file in iZotope RX.
Navigate to the Module list and select De-clip.
Click Learn to let RX detect the clipping threshold automatically, or set the threshold manually based on where distortion begins.
Adjust the Makeup gain to prevent the restored peaks from re-clipping at the output stage.
Click Preview to audition the result before committing.
Click Render to apply to the selected region or the full file.
Note: iZotope RX is the strongest option for moderate-to-severe clipping. The De-clip module works in standalone mode or as a plugin inside your DAW. A trial version is available if you want to evaluate it before purchasing.
Using Adobe Audition (Clip Restoration Effect)
Adobe Audition includes a built-in DeClipper effect that requires no additional plugins. It works well for mild-to-moderate clipping and is a practical first option if you already have an Adobe Creative Cloud subscription.
Open your file in Adobe Audition’s Waveform Editor.
Select the clipped region, or press Ctrl+A (Cmd+A on Mac) to select the entire track.
Go to Windows > Diagnostics
Choose the DeClipper effect from the dropdown menu in the Diagnostics panel.
From the Preset dropdown menu, select Heavy Reduction, Light Reduction, or Medium Reduction (as required). If you are unsure, you can leave the choice to Default and proceed to the next step.
Click Scan and then click on the Repair All button.
Once the process is complete, preview your audio file to check the results.
Using Audacity (Clip Fix)
Audacity’s Clip Fix effect is free and straightforward. It is best suited to light clipping where only a small percentage of the waveform was affected.
Open your audio file in Audacity.
Select the clipped portion of the track, or press Ctrl+A to select all.
Go to Effect > Clip Fix.
Set the Percentage of peaks to try to restore slider. The default of 95% is a reasonable starting point.
Click OK to apply.
Listen back and undo (Ctrl+Z) if the result sounds worse than the original.
Note: Clip Fix is a solid starting point for podcasters and hobbyists who need a quick, free fix. For anything beyond light clipping, iZotope RX will produce noticeably better results.
Manual Waveform Editing (Last Resort for Isolated Clips)
If the clipping is limited to one or two short transients, such as a single loud hand clap or an unexpected shout, you can redraw the waveform peak manually using your DAW’s pencil or draw tool.
Zoom into the clipped transient at the sample level until individual samples are visible.
Switch to the pencil or draw tool, available in Audacity, Logic Pro, Adobe Audition, and most other DAWs.
Draw a smooth, curved peak over the flat-topped section, mirroring the shape of the surrounding waveform.
Zoom out and listen back.
This method requires patience and a trained ear. It is only practical for a few isolated clipped frames in an otherwise clean recording. Attempting this across longer damaged sections is not a productive use of time.
How to Prevent Audio Clipping While Recording
Repairing clipped audio takes time and rarely produces a perfect result. The more reliable approach is a recording setup that prevents clipping from occurring. These five steps will help you record clean audio consistently.
1. Set input gain to a safe target level. Aim for peaks sitting between -12 dBFS and -6 dBFS on your recorder or DAW meter. This gives you headroom, the buffer between your loudest expected level and 0 dBFS, so unexpected volume spikes do not cause clipping. Recording louder does not mean your audio will sound better. Leaving enough headroom keeps your recordings much cleaner and safer.
2. Enable a hardware or software limiter. A limiter sets a hard ceiling on the signal level. Any peak that would exceed the threshold gets automatically attenuated before it can clip the recording. Many audio interfaces, field recorders, and preamps include a built-in limiter. Enable it. If your device does not have one, use a limiter plugin on your input channel in your DAW as an additional safety net.
3. Monitor input levels in real time. Using headphones during recording and watching your meter is not optional if you want clean audio. A moving meter tells you exactly where your signal sits. If peaks are consistently approaching -3 dBFS or beyond, reduce your input gain before the actual take begins.
4. Run a loud test before recording. Ask your subject to speak at their loudest expected volume. If the context involves laughter or raised voices, test those too. Check the meter. Adjust gain. This 30-second test prevents more clipping problems than any software repair tool available.
5. Maintain consistent microphone-to-source distance. Moving a microphone closer to a loud source mid-recording raises the effective gain and can push levels into clipping even when you set everything correctly at the start. Lavalier and clip-on microphones are particularly useful here because they maintain a consistent distance from the speaker throughout the recording.
Eliminate Clipping at the Hardware Level With 32-Bit Float Recording
Standard digital audio uses a fixed bit depth, typically 24-bit, which means there is a hard ceiling at 0 dBFS. If your signal exceeds that ceiling, clipping occurs, and the data is permanently gone. 32-bit float recording uses a floating-point data format that captures an enormous dynamic range with no fixed ceiling at the converter stage. Gain errors that would destroy a standard recording simply do not result in clipping in the digital domain.
Microphones with built-in 32-bit float recorders, like the Hollyland LARK MAX 2, address this problem at the source. The LARK MAX 2 records internally at 48 kHz / 32-bit Float, which means even if you misjudge your gain in a loud environment, the built-in backup recording captures the full signal without clipping. Combined with AI Noise Cancellation and low-latency wireless monitoring via OWS earphones, it removes the post-production repair burden entirely for field and interview work.
Pro Tip: 32-bit float does not eliminate the need for sound gain staging practices, but it does act as a reliable safety net when recording conditions are unpredictable, such as live events, documentary interviews, or run-and-gun video production where there is no time to dial in levels between takes.
Quick Comparison: Software Tools for Repairing Clipped Audio
Tool |
Best For |
Cost |
Clipping Severity |
iZotope RX De-clip |
Moderate to severe clipping |
Paid (trial available) |
Moderate to Severe |
Adobe Audition Clip Restoration |
Mild to moderate; Audition users |
Subscription |
Mild to Moderate |
Audacity Clip Fix |
Light clipping, free option |
Free |
Mild |
Manual pencil editing |
Single isolated transients |
Free (any DAW) |
Very Mild |
Q: Can all clipped audio be fixed?
No. Mild clipping where peaks are just touching 0 dBFS is usually recoverable to a usable standard. Severe clipping, where large sections of audio are flat-topped, has lost harmonic information that software cannot fully reconstruct. In those cases, the result may be improved but not fully restored. Prevention is always more reliable than repair.
Q: What does clipping sound like?
A harsh, buzzing, or crackling distortion on loud sounds, often described as similar to a blown speaker. Clipping is easiest to notice during sudden jumps in volume. Speech pops, drum hits, loud laughter, and similar sounds trigger it most often. These quick peaks can rise above your recording level without warning.
Q: Does recording louder always cause clipping?
Not always. It depends on your input gain and the headroom available in your recording path. The risk increases significantly when peaks approach 0 dBFS. Consistently targeting peaks between -12 and -6 dBFS provides enough headroom to handle unexpected loudness without clipping.
Q: Will a compressor fix clipped audio?
No. A compressor manages dynamic range but cannot restore waveform data that was never captured. Applying compression after clipping can actually make the distortion more audible by raising it in the mix. For repair, you need a dedicated de-clipping tool like the iZotope RX De-clip module.
Q: Is 32-bit float the same as 32-bit audio quality?
Not exactly. 32-bit float is a recording format with an extremely wide dynamic range. It does not have the same fixed recording limit as standard formats. That gives it much more room to capture sudden volume changes safely. It is primarily about preventing clipping and preserving dynamic range during capture, not simply a “more bits equals better quality” improvement in the traditional sense.
If you have already recorded clipped audio, start with iZotope RX for moderate-to-severe damage or Adobe Audition’s De-Clipper for lighter cases. For future recordings, target peaks between -12 and -6 dBFS, use a limiter, and monitor your levels in real time. If you regularly record in unpredictable environments, a 32-bit float recorder like the Hollyland LARK MAX 2 removes the clipping risk entirely at the hardware level.
