Distorted audio can ruin an otherwise solid recording. Whether your podcast clipped mid-interview, your voiceover sounds crunchy, or your video audio came out overdriven, the damage is not always permanent. This guide covers the most effective methods to remove distortion from audio using free and professional tools, what results you can realistically expect, and how to prevent the problem from happening at all.
How to Remove Distortion from Audio (Step-by-Step Guide)
What Causes Audio Distortion?
The most common cause is clipping: a signal that exceeds 0 dBFS, the maximum ceiling of a digital recording system. When that ceiling is hit, the waveform peaks get flattened because the system has no room to represent them accurately, producing the harsh, crunchy sound most people associate with distorted audio.
Other common causes include:
Cable interference or ground loops: Introduces harmonic buzz or hum into the signal chain
Over-compression artifacts: Aggressive compressor settings produce pumping, breathing, or clipping-like harshness
Analog hardware saturation: Overdriving a preamp or mixer input beyond its clean headroom
Codec compression: Lossy export artifacts from very low-bitrate audio files, particularly MP3s encoded at 64 kbps or below
Can Distorted Audio Actually Be Fixed?
The honest answer is: sometimes. How much a repair tool can recover depends almost entirely on how severe the clipping is and how long it lasts.
Mild clipping, meaning a few peaks just over 0 dBFS affecting a small fraction of the waveform, is the most recoverable. Repair software can interpolate what the missing peaks likely sounded like based on surrounding waveform data. Results are often clean enough for podcasts, YouTube videos, or social content.
Severe or sustained clipping is a different problem. When the waveform looks like a flat-top plateau for extended sections, the original audio data is simply gone. No software can recreate information that was never captured. Tools like iZotope RX can reduce harshness and make heavily clipped audio more listenable, but they cannot restore full fidelity.
Approach every repair session with realistic expectations. The tools below work well within their limits, and recognizing those limits will save you hours of trying to salvage audio that genuinely cannot be recovered.
How to Remove Distortion from Audio – Top Methods
The three methods below cover the most widely used tools for audio distortion repair, ordered from free to professional. Each section explains what the tool is, when it works best, and how to use it step by step. Start with whichever matches your current setup and the severity of the damage.
Method 1 – Audacity (Free)
What it is: Audacity is a free, open-source audio editor available for Windows, macOS, and Linux. Its built-in Clip Fix effect attempts to reconstruct clipped waveform peaks using amplitude extrapolation. There is nothing to buy or subscribe to, which makes it the right starting point for most people encountering this problem for the first time.
When to use it: Best for mild clipping on a tight budget. If your waveform shows occasional red-highlighted peaks but is not clipped throughout the entire recording, Clip Fix will deliver a usable result with relatively little effort.
Steps:
Open your audio file. Launch Audacity and go to File > Open to import your distorted recording.
Identify clipped regions. Audacity highlights clipped samples in red directly in the waveform view. If you do not see the highlights, enable them under View > Show Clipping. Scroll through the recording to assess how widespread the damage is before deciding whether to repair a selection or the entire file.
Select the affected section. Click and drag to highlight the clipped region. If clipping is present throughout the full file, press Ctrl+A (Cmd+A on Mac) to select everything.
Open Clip Fix. Navigate to Effects > Distortion and Modulation > Clip Fix.
Set the threshold. The Clipping Threshold defaults to around 0 dB. Lowering it slightly, to -0.5 dB or -1 dB, gives the algorithm more of the signal to analyze. Leave the Percentage Amplitude to Add setting at its default value as a starting point.
Preview the result. Click Preview before applying. Listen for unnatural artifacts, thin-sounding transients, or any new harshness the processing may have introduced. Adjust the threshold and preview again if needed.
Apply and export. Click OK to commit the change, then go to File > Export > Export Audio to save the repaired file.
Note: Audacity’s Clip Fix uses amplitude extrapolation rather than spectral analysis. It performs well on short, isolated peaks. For sustained clipping spread across a longer recording, iZotope RX will produce noticeably cleaner results.
Method 2 – Adobe Audition
What it is: Adobe Audition is a professional digital audio workstation included in Adobe Creative Cloud. Its Clip Restoration tool detects and repairs clipped samples using a configurable interpolation process. For video creators, it integrates directly with Premiere Pro through the Edit in Audition workflow, which makes it the most natural choice for anyone already inside the Adobe ecosystem.
When to use it: Use Audition when you are working in a video production context, when you have Creative Cloud access, or when you need more detection precision and processing control than Audacity offers. The Diagnostics panel identifies clipped regions automatically, removing the need to manually hunt through a long waveform.
Steps:
Open your file in Adobe Audition. Go to File > Open and import your distorted audio. If you are working in Premiere Pro, right-click the audio clip in your timeline and select Edit Clip in Adobe Audition to send it directly to the audio editor without exporting a separate file.
Switch to the Waveform Editor. Confirm that you are in Waveform view and not Multitrack view. Clip-level repair work requires the Waveform Editor.
Open the Diagnostics panel. Go to Window > Diagnostics. Inside the panel, select Clip Restoration from the Effect dropdown menu.
Run the scan. Click Scan. Audition automatically detects and lists every clipped sample region in the file. Reviewing this list gives you an accurate sense of how much of your recording was affected.
Apply the repair. Click Repair All to process every detected region at once. Audition applies its default gain settings automatically, but you can click Settings before scanning to adjust the Interpolation Gain. Start with the default and reduce it if results sound over-processed or pumpy.
Preview and fine-tune. Play back the repaired sections. If any section sounds unnatural, re-open Settings, lower the gain value, and re-run the repair.
Export your file. Go to File > Export > File to save the repaired audio. If you originated in Premiere Pro, simply save and close in Audition. The clip in your timeline updates automatically.
Pro Tip: The Essential Sound panel in Adobe Audition (Window > Essential Sound) includes a quick Clip Repair slider under the Repair tab. It is less precise than the Diagnostics workflow above, but it is a practical one-pass option for very minor clipping when turnaround speed matters more than surgical accuracy.
Method 3 – iZotope RX (Professional Standard)
What it is: iZotope RX is the professional benchmark for audio repair and restoration. Its De-clip module uses spectral analysis and advanced algorithmic processing to reconstruct missing audio data in clipped recordings, going substantially beyond what simple amplitude interpolation can achieve. De-clip is available across all three RX product tiers: RX Elements (entry-level), RX Standard, and RX Advanced.
When to use it: Use iZotope RX when audio quality is the priority, when clipping damage is moderate to severe, or when Audacity and Audition have not delivered clean enough results. Broadcast engineers, podcast post-production teams, and film dialogue editors use RX as their primary repair environment. Even at the RX Elements price point, the De-clip module is available.
Steps:
Open your audio file in iZotope RX. Launch the RX Audio Editor and go to File > Open to load your distorted recording.
Select the distorted region. Click and drag to highlight the clipped section of the waveform. If the file is damaged throughout, press Ctrl+A (Cmd+A on Mac) to select the entire timeline.
Open the De-clip module. Locate De-clip in the module list on the right side of the RX Audio Editor. If it is not visible, go to Modules → De-clip.
Run Clip Threshold detection. Click the Suggest button. RX automatically analyzes the selected audio and suggests an appropriate Threshold value for the clipped audio.
You can adjust the Threshold manually after using Suggest. Lower values repair more of the waveform, while higher values apply a more conservative repair.
Review the suggested Threshold setting. If necessary, adjust it manually before previewing the repair.
Review the output level after processing. If the repaired audio sounds quieter than the original, adjust the overall gain later using the Gain module in RX or your DAW.
Preview the result. Click Preview and listen carefully to the repaired section. Pay close attention to transients and high-frequency content, as these areas are the most affected by clipping.
Apply and export. Click Render to apply the repair to the selected audio. Go to File → Save to overwrite the existing file, or File → Export to create a new repaired copy.
Note: iZotope RX’s De-clip cannot reconstruct audio data that simply was not captured. If multiple passes at different threshold settings still produce unacceptable results, the recording is likely too far gone to salvage cleanly. At that point, a re-record is the most practical path forward.
Quick Fixes – Free Online Tools and Mobile Apps
If you do not have access to a desktop DAW, these browser-based and mobile options offer a faster, lower-effort route to an improved result. Expect limited control and lower output quality compared to the desktop methods above. These are appropriate for casual content; they are not suitable for professional-grade deliverables.
Adobe Podcast Enhance (podcast.adobe.com): A free, browser-based AI tool. Upload a voice recording and the service automatically reduces noise and addresses minor distortion. No software installation required.
LALAL.AI: A web-based audio processing service. Its cleanup pipeline can reduce some distortion artifacts alongside its primary stem-separation function. A free tier is available with file-length restrictions.
Krisp: Available as both a desktop app and mobile tool. Primarily a real-time noise filter, but it reduces some types of audio harshness during calls and recordings. Less suited to after-the-fact repair than to live capture.
How to Prevent Audio Distortion at the Source
Repairing distorted audio is always a compromise. Good recording habits eliminate the problem before it reaches the edit. Follow these practices consistently and you will rarely need the repair tools above.
Set recording levels to peak between -12 dBFS and -6 dBFS. This preserves headroom for unexpected loud moments without pushing the signal near 0 dBFS. Treat -12 dBFS as your safe target for spoken voice.
Practice proper gain staging throughout the signal chain. Balance gain at every stage, from microphone preamp through audio interface to DAW input. Never compensate for a weak signal early in the chain by pushing gain hard at a later point.
Engage an input limiter during live recording. Most audio interfaces and portable recorders include a hardware limiter. Enable it. It catches transient peaks that would otherwise clip before you have time to manually respond.
Monitor your levels actively during recording. Watch your input meters in real time. If peaks are consistently reaching 0 dBFS or triggering red indicators, reduce the input gain before continuing rather than planning to fix it in post.
Record in 32-bit float when your gear supports it. Standard 24-bit recording clips irreversibly if the input gain is set too high. 32-bit float captures a far wider dynamic range, meaning that a gain-staging error on set can be corrected cleanly in post without any permanent audio degradation.
For creators who record in the field and need reliable 32-bit float capture in a portable wireless system, the Hollyland LARK MAX 2 addresses this problem directly. It records internally at 48 kHz / 32-bit Float, which means that even if the analog output level going to your camera is set incorrectly during a shoot, the onboard backup recording preserves the full, unclipped dynamic range. That backup file is what makes the repair methods in this article entirely unnecessary.
Why does my audio sound distorted even at low volume?
If audio sounds distorted at low playback volume, the clipping almost certainly occurred during the original recording, not at playback. The damaged waveform data is already embedded in the file. Other causes include bit-depth artifacts from a low-quality recording format, codec compression from a very low-bitrate export such as a 64 kbps MP3, or upstream cable interference that introduced harmonic noise before the signal reached the recorder.
Is there a free way to remove audio distortion?
Yes. Audacity’s built-in Clip Fix effect (Effects > Distortion and Modulation > Clip Fix) is completely free and works well on mild clipping. Adobe Podcast Enhance is also free via browser for basic AI-based voice repair. For more severe damage, iZotope RX produces better results but requires a paid license. RX Elements is the most affordable entry point into the RX toolset.
How do I fix distorted audio in Premiere Pro?
Premiere Pro does not include a native clip restoration tool. The most effective option is to right-click the audio clip in the timeline, select Edit Clip in Adobe Audition, and follow the Audition workflow above. For lighter fixes, open the Essential Sound panel (Window > Essential Sound), assign the clip as Dialogue, and use the Reduce Noise slider under the Repair tab.
What is the difference between distortion and noise?
Distortion results from a signal being pushed beyond the system’s limits, producing harsh harmonic artifacts and flat-topped waveform peaks. Noise is a separate unwanted signal layered on top of the audio, such as hiss, hum, or room tone. They require different tools: a de-clip module for distortion, a noise reduction module for noise. A single recording can suffer from both problems simultaneously.
Can AI remove audio distortion automatically?
AI tools like Adobe Podcast Enhance can handle mild distortion automatically and often produce usable results for voice content. However, no AI tool can reconstruct audio data that was never captured. On severely clipped recordings, these tools reduce harshness but cannot restore full fidelity. For audio where quality cannot be compromised, manual processing using iZotope RX’s De-clip module will produce more consistent and controllable results.
For mild clipping, Audacity’s Clip Fix or Adobe Audition’s Clip Restoration are practical starting points that require little setup. For moderate to severe damage, or when output quality cannot be compromised, iZotope RX is the right tool for the job. When repair results consistently disappoint regardless of the software, that is a signal to address the recording chain rather than the post-production process. Proper gain staging, consistent level monitoring, and 32-bit float recording remove most distortion problems before the edit ever begins.
