GarageBand makes audio recording accessible whether you are sitting at a Mac or holding an iPhone. The process is straightforward once you know where to configure your input source and how to set healthy recording levels. This guide walks you through every step on both platforms, covers external microphone setup, and gives you practical tips to capture cleaner audio from the very first take.
How to Record Audio on GarageBand: Step-by-Step Guide for Mac and iPhone
Before hitting Record, confirm you have the following in place:
GarageBand installed: The app is free on Mac, iPhone, and iPad. Download it from the Mac App Store or iOS App Store if it is not already on your device.
A microphone: The built-in microphone on your Mac or iPhone works fine for a first session. An external microphone delivers noticeably better quality for vocals, podcasting, or acoustic instruments.
Headphones (recommended): Wearing headphones while recording prevents playback from bleeding back into the microphone and causing feedback.
An audio interface (Mac only, optional): Required only if you want to connect a professional XLR microphone. USB microphones connect directly without an interface.
A quiet space: Even a small room with soft furnishings reduces room echo before you touch a single setting.
How to Record Audio on GarageBand on Mac
Step 1: Open GarageBand and Create a New Project
Launch GarageBand from your Applications folder or Spotlight search. When the project chooser appears, double-click Empty Project. A dialog box will prompt you to confirm tempo, key, and time signature settings. These affect MIDI and music tracks but have no impact on raw audio recording, so the defaults are fine. Click Choose to open your new project.
Step 2: Add an Audio Track
With the project open, click the “+” (Add Track) button in the upper-left area of the Tracks area, or go to Track > New Track in the menu bar. A track type selector appears. Choose Audio rather than Software Instrument. An Audio track captures sound from a real microphone or line input. A Software Instrument track records MIDI note data instead, which is not the right choice for vocals, speech, or acoustic instruments. Click Create to add the track.
Step 3: Select Your Input Source
Click on the new audio track to select it, then open the Smart Controls panel at the bottom of the screen by pressing B. Locate the input selector dropdown, labeled Input 1 or similar. This list draws directly from macOS System Settings, so your microphone must already be recognized at the operating system level. If your microphone is missing from the list, go to System Settings > Sound > Input, confirm it appears there, then return to GarageBand and recheck the dropdown. Select the built-in microphone for the internal mic, or choose your external device by name.
Step 4: Set Your Recording Level and Enable Monitoring
Speak or play into your microphone and watch the level meter on the track header. Aim to keep peaks in the yellow zone, roughly between -12 dBFS and -6 dBFS. If the meter frequently flashes red, reduce input gain using the slider in Smart Controls or turn down the gain knob on your audio interface.
The Input Monitoring button, shown as a small speaker icon on the track header, lets you hear yourself in real time through GarageBand. Enable it only when you are wearing headphones. Without headphones, the open speakers will feed back into the microphone.
Note: If you notice a clear delay when monitoring through an external audio interface, reduce the I/O buffer size under GarageBand Preferences > Audio/MIDI. A smaller buffer size lowers latency at the cost of slightly higher CPU usage.
Step 5: Arm the Track and Start Recording
Click the Record Enable button on the track header, which looks like a small red circle. The track header will glow red to confirm the track is armed and ready. When you are set, press R on your keyboard or click the red Record button in the transport bar at the top of the screen.
GarageBand counts in by default with one bar of metronome clicks before recording begins. You can disable the count-in or silence the metronome using the controls in the transport bar if you prefer to start immediately. As you speak or play, a red waveform region grows in the track lane to confirm audio is being captured.
Step 6: Stop, Review, and Save Your Take
Press the spacebar to stop recording. The captured region appears in the track lane as a colored waveform block. Press Return to move the playhead back to the beginning, then press the spacebar again to play back what you recorded. Click the region to select it, and drag its edges to trim any unwanted silence at the start or end.
To save the project, press Command + S. GarageBand also auto-saves periodically, but a manual save after a strong take is a reliable habit. The project saves as a .band file that stores all audio regions and settings in one place.
How to Record Audio on GarageBand on iPhone or iPad
Setting Up an Audio Track in GarageBand for iOS
Open GarageBand on your iPhone or iPad and tap the “+” icon to create a new project. GarageBand for iOS will display a list of instrument and track types.
Swipe through the options and select Audio Recorder. This is the correct track type for capturing live sound from a microphone, whether built-in or external. The other instrument tracks, such as Keyboard or Drums, are built for playing software instruments and will not record a live audio signal the same way.
Choosing Your Microphone Input on iOS
GarageBand for iOS detects the active input automatically. If you are using the built-in microphone, no configuration is needed. Plug in a wired headset and GarageBand switches to the headset microphone. Connect a Lightning or USB-C microphone and the app recognizes it as the active input right away. The current input source is displayed near the top of the Audio Recorder screen. Tap the input label to toggle between available sources if more than one device is connected.
Recording Your Audio on iPhone
Use the on-screen gain slider to adjust your input level before recording. As with the Mac version, aim for peaks in the yellow range to preserve headroom and avoid distortion. When your level looks healthy, tap the red Record button. GarageBand counts in, then begins capturing. Tap Stop when you are finished. Your recorded region appears in the track lanes view. Tap the region and press play to review the take. From there you can trim the edges, record another pass, or move forward to arrangement and mixing.
How to Use an External Microphone with GarageBand
On Mac: USB microphones connect directly to any USB or USB-C port. Once connected, macOS recognizes the device and it appears in System Settings > Sound > Input. Select it there, then choose it from the Input dropdown inside GarageBand’s Smart Controls. If you are using a professional XLR microphone, you need an audio interface such as the Focusrite Scarlett 2i2. The interface connects via USB, GarageBand treats it as the input device, and the XLR microphone plugs into the interface itself.
On iPhone or iPad: Lightning and USB-C microphones connect directly to your device’s port with no audio interface, no drivers, and no additional configuration. GarageBand detects them immediately as the active input.
For iOS users who want portable, high-quality wireless audio without any interface complexity, the Hollyland LARK A1 is worth a close look. It uses dedicated USB-C or Lightning receivers that plug straight into your iPhone or iPad, so GarageBand recognizes it as a standard input the moment you connect it. The LARK A1’s 3-Level Intelligent Noise Cancellation reduces ambient background noise at the hardware level, giving you a cleaner raw recording before you touch any plugin inside GarageBand. It is a practical, compact option for podcasters, vocalists, and content creators who record on the move.
Tips for Getting Better Audio Recordings in GarageBand
A few consistent habits will improve your recordings well before you consider plugins or effects:
Target -12 dBFS to -6 dBFS on peak levels. This leaves enough headroom to prevent clipping while keeping the signal clearly above the noise floor.
Record in a room with soft surfaces. Carpets, curtains, and bookshelves absorb reflections that would otherwise make vocals sound hollow or roomy.
Always wear headphones when Input Monitoring is active. Speakers and an open microphone in the same room will generate a feedback loop within seconds.
Use GarageBand’s built-in Noise Gate. Open Smart Controls on your audio track, add the Noise Gate plugin, and set a threshold that cuts background hiss between phrases without chopping the beginning of your words.
Run a five-second test recording before the real take. This catches level issues, accidental mute states, and room noise problems while they are still quick to fix.
Troubleshooting Common GarageBand Audio Recording Problems
Problem |
Likely Cause |
Fix |
No audio input signal |
Mic not selected as system input |
Check System Settings > Sound > Input (Mac) or reconnect device (iOS) |
GarageBand does not detect external mic |
Permission or driver issue |
Grant GarageBand microphone access in Privacy & Security settings; restart the app |
Recording sounds distorted or clipped |
Input gain too high |
Lower input gain so peaks stay below -6 dBFS |
Noticeable latency during monitoring |
Buffer size too large |
Reduce I/O buffer size in GarageBand Preferences > Audio/MIDI (Mac only) |
Is GarageBand free for recording audio?
Yes. GarageBand is free on all Mac, iPhone, and iPad devices. No subscription, upgrade, or in-app purchase is required to record audio. The app ships pre-installed on most Apple devices and is available at no cost through the Mac App Store and the iOS App Store.
Can I record multiple audio tracks at the same time in GarageBand?
On Mac, yes. You can record-enable multiple audio tracks simultaneously as long as your audio interface supports multiple inputs. On iPhone and iPad, GarageBand records one track at a time, though you can overdub additional passes on separate tracks after your first take is complete.
Why is GarageBand not detecting my microphone on Mac?
Start by confirming the microphone is selected in System Settings > Sound > Input. If it appears there but GarageBand still does not pick it up, go to System Settings > Privacy & Security > Microphone and verify that GarageBand has been granted access. Restart GarageBand after granting permission for the change to take effect.
What audio format does GarageBand record in?
GarageBand captures audio internally as AIFF or CAF files stored inside the project bundle. When you export using Share > Export Song to Disk, you can choose MP3, AAC, AIFF, or WAVE depending on where and how you plan to use the finished file.
Do I need an audio interface to record on GarageBand?
No. The built-in microphone or a USB-C and Lightning microphone works without any interface. An audio interface is only necessary when you want to connect a professional XLR microphone, which requires phantom power and analog-to-digital conversion that the interface provides.
Next Steps
Recording audio in GarageBand is a repeatable, predictable process once your input is configured and your levels are dialed in. Focus on capturing a clean take first, because a well-recorded source needs far less correction than a fixed problem. From here, explore GarageBand’s built-in EQ and compression to polish your audio, or check out our related guides on reducing background noise and choosing the right microphone for your recording space.
