Your phone can already record pretty impressive audio without extra setup. Need a lecture, voice memo, or podcast idea? You're good. Both iPhone and Android include recording apps that open in seconds. This guide explains those apps in a simple, easy-to-follow way. You will also learn easy tips for cleaner, clearer sound every time. We will even cover when an external microphone actually makes a noticeable difference.
How to Record Audio on an iPhone
Apple includes a dedicated recording app on every iPhone, so there is no setup required. Voice Memos is quite easy to use from the start. Your recordings automatically sync across Apple devices when iCloud is turned on.
Where to Find Voice Memos on iPhone
Voice Memos comes pre-installed on every iPhone. Look for the app icon with a black background and a red and white waveform on your Home Screen. If you cannot find it, swipe down from the middle of the screen to open Spotlight Search and type “Voice Memos.” Because the app connects to iCloud, any recording you save on your iPhone appears automatically on your iPad or Mac without a manual transfer.
To record audio on your iPhone:
Open the Voice Memos app.
Tap the large red Record button at the bottom of the screen to start.
Speak clearly toward the bottom edge of your phone, where the microphone is located.
Expand the recording pane upwards. Tap Pause if you need to stop briefly and then resume the same recording.
Tap the default name (usually your location) at the top of the file to rename it to something more descriptive.
Tap the checkmark to end and save the recording.
To share the file, tap the recording, tap the three-dot menu (…), select the Share option, and choose AirDrop, email, Messages, or any cloud service on your phone.
Recordings are saved as .m4a files, which are compatible with most audio editing apps and playback devices.
Pro Tip: If your recording runs long, trim the silence from the start and end directly inside Voice Memos. Tap the recording, tap the three-dot menu, select “Edit Recording,” and drag the trim handles inward. This saves you from needing a separate app for basic cleanup.
How to Record Audio on an Android Phone
Android phones don't all come with the same recording app. The one you get depends on your phone's brand. Below are the two most common options, as well as another choice for other Android devices.
Using Google Recorder (Pixel Phones)
Google Recorder comes pre-installed on Pixel phones and adds a useful bonus: real-time transcription, which is helpful for interviews and lectures.
Open the Recorder app (search your app drawer if it is not on your home screen).
Tap the red Record button to begin.
Speak toward the bottom edge of your Pixel phone.
Tap Pause to hold the recording, or tap the Stop button (the square icon) to finish.
Once you hit the Stop button, the recordings are saved automatically to your internal list.
To change the name of the recorded file, tap the default title and rename it.Using the Built-In Voice Recorder on Samsung and Other Android Phones
Samsung Galaxy phones include the Voice Recorder app. Most other Android devices (OnePlus, Motorola, Xiaomi, Infinix) ship with a similar app called Voice Recorder or Sound Recorder in the app drawer.
Open Voice Recorder or Sound Recorder from your home screen or app drawer.
Tap the red Record button to start.
Point the bottom edge of your phone toward the audio source.
Tap Pause to interrupt and Resume (or the record button again) to continue.
Or tap Stop to end the session.
Confirm the save prompt. Samsung devices store recordings under Internal Storage > Recordings, accessible through the My Files app.
On phones like Infinix, you might also see the rename prompt after ending the recording session.
So rename the file and tap Save. Your recordings will be saved in the designated recording folder.
Note: If your Android phone does not include a built-in voice recorder, download Easy Voice Recorder from the Google Play Store. It replicates the native experience on unsupported devices and works reliably across most Android versions.
Tips to Get Better Audio Quality When Recording on Your Phone
The built-in microphone on your phone is small, omnidirectional, and positioned to handle phone calls, not studio-quality audio. A few habit changes can dramatically improve what you capture without spending anything.
Move closer to the source: Built-in microphones fade quickly with distance. Keep the mic within 12 to 18 inches of the speaker for voice recordings. Every additional foot adds more room noise to the mix.
Reduce background noise before pressing record: Close windows, turn off fans, and move away from HVAC vents. Because the mic picks up sound from all directions, ambient noise competes directly with the audio you want.
Switch to Airplane Mode: Incoming calls, texts, and push notifications create interference spikes in recordings. Enabling Airplane Mode for the duration of your session eliminates that risk entirely.
Avoid hard, reflective surfaces: Recording in an empty room creates audible echo. Soft furnishings, carpet, curtains, and even a closet full of clothes absorb sound reflections and make your recordings noticeably cleaner.
Keep the phone still during recording: Holding your phone while recording can add unwanted bumps and vibration sounds. So the best thing you can do is to keep it stable. You can grab a small mobile stand or place it on a hard surface to capture the audio. This helps keep extra handling noise out of your recording.
Run a short test before the real take. Record 10 seconds of audio and play it back before committing to a full session. Confirm the volume is neither too quiet nor clipping before you start.
Should You Use a Third-Party App?
For most users, the native app is enough. The built-in recording apps cover everyday recording without any trouble. They also save files in common formats, making sharing and editing much easier.
A third-party app is worth considering only if you need something the native app does not provide:
Voice Record Pro (iOS): Exports in WAV, MP3, and MP4 (AAC) at higher bit rates, which is useful if you plan to edit in a desktop audio editor.
Easy Voice Recorder (Android): Adds auto-gain control and cloud backup options absent from some stock Android recorder apps.
GarageBand (iOS, free): The better choice if you want basic multi-track recording and mixing directly on your phone.
If your primary goal is capturing clean voice audio quickly and sharing it, the native app remains the faster and simpler option.
How to Get Professional-Sounding Audio on Your Phone
Even with perfect recording technique, the built-in microphone on your phone has hard physical limits. It is small, positioned at the bottom edge of the device, and captures everything around it, including table vibrations, handling noise, and room reverb alongside your voice. These limits come from the hardware, so good recording habits can only help so much.
The most effective single upgrade is adding a dedicated external microphone. A clip-on lavalier or compact wireless mic moves the microphone element close to your mouth, which reduces room pickup, improves clarity, and gives recordings a noticeably more polished character.
For most people starting out, the Hollyland LARK A1 is the practical choice here. It connects directly to your phone via USB-C or Lightning with no pairing process and no app required. Its three-level intelligent noise cancellation handles less-than-ideal recording environments automatically. You plug it in, and it works. Users creating video content for social platforms may prefer the Hollyland LARK M2 instead, which operates wirelessly, weighs just 9 grams, and offers up to 40 hours of total battery life for extended shoots or run-and-gun filming.
Q: What is the best free app to record audio on my phone?
Voice Memos on iPhone and Google Recorder on Google Pixel phones are the best free options for most users. Both are pre-installed, require no configuration, and produce reliable audio for everyday needs. Third-party apps are only worth adding when you specifically need high-bitrate export formats, live waveform monitoring, or automatic cloud backup the native app does not provide.
Q: Can I record audio while using other apps on my phone?
Yes. On both iOS and Android, audio recording apps support background operation. Start your recording, switch to another app, and the recording continues uninterrupted. If your recording stops after switching apps, open the recording app’s settings and enable background audio or background app refresh to keep it active during multitasking.
Q: How do I share or transfer a recorded audio file from my phone?
On iPhone, tap the recording in Voice Memos, tap the three-dot menu, and select Share to send via AirDrop, email, or a cloud service. On Android, open your recordings app or the Files app, find the recording, and share it through your preferred method. Most files are saved as .m4a or .mp3, which are compatible with virtually any device or editing application.
Your phone's built-in recorder is enough for everyday audio without extra gear. If you're making podcasts, interviews, or social media videos, an external microphone like the Hollyland LARK A1 can make your audio sound much clearer than software tips alone.
