Android gives you more than one way to capture audio, which is helpful but can also create confusion when you just need to hit record. Whether you need a quick voice memo, a reliable lecture recording, or clean audio for a video project, the right method depends on your device, your purpose, and how much quality matters. This guide covers four practical approaches, from the app already sitting on your phone to an external microphone that makes a genuine difference.
How to Record Audio on Android: 4 Methods From Built-In Apps to External Mics
Quick Comparison: Which Recording Method Is Right for You?
Not sure which approach fits your situation? Use this table to find the right starting point, then jump to that section for step-by-step instructions.
Method |
Best For |
Audio Quality |
Setup Needed |
Built-In Voice Recorder |
Quick memos, meetings, lectures |
Basic |
None |
Google Recorder |
Transcribed interviews, searchable notes |
Good |
None on Pixel; quick install on others |
Third-Party App |
Podcasters, WAV recording, format control |
Good to Very Good |
App install |
External Microphone |
Content creators, journalists, voice-overs |
Excellent |
Mic and USB-C receiver |
Method 1 — Use the Built-In Voice Recorder App
The simplest way to record audio on Android is the app that shipped with your phone. Every major Android manufacturer includes a native voice recorder, and it requires zero setup, zero accounts, and zero downloads. This is the right choice for meetings, lectures, personal memos, and any situation where you need to capture audio without delay.
Steps to record using the built-in voice recorder:
Open your app drawer and search for “Voice Recorder,” “Recorder,” or “Sound Recorder” — the exact name varies by manufacturer.
Tap the app to open it.
Press the red microphone or record button to begin recording.
Hold your phone 6 to 12 inches from the sound source with the microphone side facing the speaker.
Tap the pause button if you need to stop temporarily without ending the session.
Tap the stop button when the recording is complete.
Enter a name for the file when prompted, or accept the auto-generated timestamp.
Tap the recordings library icon to access, play back, or share your saved files.
Most native apps save files to an internal “Recordings” folder and allow direct sharing via email, messaging, or cloud storage from within the app.
Note: Samsung’s Voice Recorder app includes a few extras not found on other native recorders. Meeting mode distributes capture across multiple directions for group discussions, and Interview mode focuses on two opposing speakers. These modes are exclusive to Galaxy devices and worth exploring if you own one.
Where to Find the Voice Recorder on Different Android Phones
The app exists on virtually every Android phone, but the name and location differ depending on who made your device.
Samsung: Search for “Voice Recorder” in your app drawer, or look inside the Samsung folder. Preinstalled on all Galaxy devices.
Google Pixel: The preinstalled app is called “Recorder” and is actually Google Recorder — covered separately in Method 2.
Other OEMs (OnePlus, Motorola, Xiaomi, Sony, etc.): Search “record” or “voice” in the app drawer. The app may be labeled “Sound Recorder,” “Voice Memos,” or “Audio Recorder.” If it does not appear, check Settings under Apps for a preinstalled recorder you may have overlooked.
Method 2 — Record with Google Recorder (Pixel and Select Devices)
Google Recorder is a fundamentally different product from a standard voice memo app. Available natively on Pixel phones and installable on many stock Android devices via the Play Store, it adds features that make your recordings searchable and usable after the session ends — not just an audio file sitting in a folder.
What makes Google Recorder stand out: - Real-time transcription: Converts speech to text as you record. On Pixel devices, this runs entirely on-device with no internet connection required. - Speaker labeling: Identifies and labels different voices in a conversation, which is useful for interviews, panels, and multi-person meetings. - Searchable recordings: Search the text of any recording using keywords to jump directly to a specific moment in a long file. - Background and screen-off recording: Continues capturing audio after the display turns off, which preserves battery during extended sessions.
Steps to use Google Recorder:
Open the Recorder app on your Pixel (preinstalled). On non-Pixel devices, search “Recorder by Google” in the Play Store and install it.
Tap the large red record button at the bottom of the screen.
Watch the live transcript populate in real time to confirm the microphone is active.
Tap the pause icon to pause and resume as needed throughout the session.
Tap the stop icon (square) to end the recording.
Add a descriptive title to the recording for easier retrieval later.
Tap any saved recording in your library to play it back, read the full transcript, or export and share the audio file.
Note: Real-time transcription performs best on Pixel 2 and newer due to on-device AI optimization. Users on Samsung or other OEM devices may experience slower or less accurate transcription depending on available processing resources.
Method 3 — Use a Third-Party Recording App
The native recorder on your phone handles basic tasks, but most built-in apps share the same limitations: no WAV or lossless format support, no manual gain control, no scheduled recording, and limited file organization for managing longer or more complex projects. A third-party app fills those gaps without requiring any hardware changes.
Here are four reliable options, each with a clear reason to choose it:
RecForge II: Best for podcasters and audio project work. Supports WAV, FLAC, OGG, and MP3 with manual gain control and organized take management for multi-session projects.
Easy Voice Recorder: Best for note-takers and students. Fast, reliable, and low-friction. The free version covers most everyday needs; the Pro version adds WAV export.
Hi-Q MP3 Recorder: Best for high-quality MP3 output. Records at up to 320kbps, delivering clean portable files without the storage demands of uncompressed formats.
ASR Voice Recorder: Best for long-form capture. Includes auto-resume after interruptions, cloud backup, and bookmark tags useful for journalists or researchers managing hours of material.
For most users, Easy Voice Recorder is the lowest-friction starting point. Podcasters and anyone editing audio in a DAW will find RecForge II more capable and worth the minor learning curve.
Method 4 — Connect an External Microphone for Significantly Better Audio
The built-in microphone on every Android phone shares the same fundamental constraints: it is small, omnidirectional, and physically mounted inside a device designed primarily as a communication tool. That means it picks up handling noise, keyboard vibrations, air conditioning hum, and room reverb with as much enthusiasm as the voice you actually want to capture. Gain sensitivity is fixed, dynamic range is limited, and noise rejection is effectively nonexistent.
For interviews, voice-overs, podcasts, or any content where audio quality shapes how an audience perceives the work, an external microphone is the most impactful single upgrade available.
What to look for when connecting an external mic to Android:
Connection type: Most modern Android phones use USB-C. Look for a microphone with a USB-C output or a wireless receiver with a USB-C dongle for a direct, adapter-free connection.
Wired vs. wireless: Wired USB-C mics are reliable and introduce zero latency, making them solid for stationary recording setups. Wireless clip-on systems allow greater freedom of movement, which matters for video recording or interviews where the phone is mounted on a tripod.
Confirming the external input is active: Once a USB-C mic or receiver is plugged in, most recording apps automatically switch to the external input. If the built-in mic appears to remain active, open the app’s settings and look for “Input Source” or “Microphone Source” to manually select the external or USB option.
Steps to set up and verify an external microphone:
Connect the microphone’s USB-C connector or receiver dongle to your phone’s USB-C port.
Open your recording app of choice.
Speak into the external mic and watch the audio level meter respond to confirm the app is receiving signal from the external input.
If the built-in mic appears to still be active, navigate to the app’s settings and select the external audio source manually.
Record a 15 to 30-second test clip and play it back through headphones before committing to the full session.
Recommended Wireless Microphone: Hollyland LARK A1
For Android users who want external mic audio quality without a complicated setup process, the Hollyland LARK A1 is a practical starting point.
Direct USB-C connection: The LARK A1 includes a USB-C receiver that plugs directly into your Android phone with no adapters, no Bluetooth pairing, and no driver installation required.
3-Level Intelligent Noise Cancellation: The system actively filters background noise at three selectable intensity levels, which directly addresses the ambient pickup problem that makes built-in Android mics frustrating in real-world recording environments.
Zero-configuration operation: Clip the transmitter onto the speaker, plug in the receiver, and the system is ready to record. This simplicity makes the LARK A1 well-suited for field recording, classroom capture, and on-location content work.
For Content Creators and Vloggers: Hollyland LARK M2
If you shoot Android video for TikTok, YouTube, or travel content, the Hollyland LARK M2 is worth considering. Its 9g clip-on transmitter is light enough to go unnoticed on a collar or lapel, and the 40-hour battery life covers a full day of mobile shooting without reaching for a charger. The LARK M2 uses a wireless receiver, so confirm USB-C compatibility with your specific Android device before purchasing.
5 Tips to Improve Your Android Audio Recording Quality
These habits apply regardless of which method you chose and will meaningfully improve the quality of every recording you make.
Position the mic 6 to 12 inches from the sound source. Distance is the largest single variable in recording clarity. The greater the distance, the more ambient noise competes with the signal you actually want.
Record in a soft-furnished space. Hard walls, floors, and ceilings create reflections that make recordings sound hollow or reverberant. A bedroom, carpeted office, or room with curtains and upholstered furniture absorbs those reflections naturally.
Enable airplane mode before you start. Incoming calls, SMS alerts, and notification sounds interrupt recordings and introduce audio artifacts. Airplane mode eliminates all of them in a single tap.
Choose WAV or a lossless format when quality matters. If the recording will be edited, mixed, or shared publicly, start with the least-compressed format your app supports. MP3 is fine for personal memos; WAV is the better starting point for anything that goes to an audience.
Run a short test before the full session. Record 15 to 30 seconds, play it back through headphones, and listen for a blocked mic, low input level, or background interference before starting the take that matters.
Q: Can I record audio on Android with the screen off?
Yes. Google Recorder and most third-party apps, including RecForge II and Easy Voice Recorder, continue recording when the screen is off. Samsung’s native Voice Recorder also supports background recording. Dismiss any battery optimization prompts that appear after starting a session, and check the notification bar periodically to confirm the recording is still active.
Q: What is the best audio format for recording on Android?
WAV delivers the highest quality and is the best choice if you plan to edit or share the recording publicly; it is uncompressed and preserves every detail of the captured signal. M4A is a practical middle ground for everyday use. Choose MP3 when file size and broad compatibility matter more than maximum fidelity.
Q: Why does my Android recording sound muffled or distant?
The most common causes are recording too far from the sound source, capturing audio in a room with hard reflective surfaces, or having the built-in mic obstructed by a phone case or a finger. Placing a clip-on external microphone close to the speaker’s mouth resolves all three issues by moving the capture point off the phone body entirely.
Q: Can I record audio and video at the same time on Android?
Yes. The native camera app captures audio automatically through the built-in mic during video recording. For better audio quality, connect a wireless microphone before opening the camera app and it will feed the external signal into the video file. Alternatively, run a recording app simultaneously and sync the separate audio track to the video in post-production.
The Bottom Line
The built-in voice recorder is the right tool for quick captures and everyday memos. Google Recorder adds real value for anyone who needs searchable, transcribed recordings. Third-party apps give podcasters and audio-focused creators the format control that native apps lack. When audio quality is non-negotiable, an external microphone is the only upgrade that makes a meaningful difference in the result. If you’re ready to take that step, explore the Hollyland LARK A1 for a plug-and-play starting point built for Android.
