How to Record a Podcast on Your Phone: Step-by-Step Guide
Your phone is already enough to kick off your first podcast episode. You do not need a studio, pricey gear, or recording experience. Plenty of popular podcasters started the exact same way too. Many still stick with only a phone and a free app. This guide shows every step, from your first idea onward. By the end, your podcast audio is ready without interacting with any other device.
What You Need to Record a Podcast on Your Phone
Most people already have everything on this list before they read a single tutorial:
  • A smartphone — any iPhone or Android model from the last five years will work
  • A free recording app — covered in the next section
  • A quiet space with soft furnishings to reduce echo and minimal background noise
  • An external microphone (optional) — not required to start, but a meaningful upgrade when audio quality becomes your next priority
That is the complete list to get your first episode going. You do not need a soundproof room, a computer, or paid software. Your first podcast can still be published with only those basics.
Best Apps to Record a Podcast on Your Phone
Picking the right app can shape your whole recording experience. It is the first choice that matters before your episode begins. Each option below works well on a phone, but they serve different use cases.
App
Platform
Best For
Key Feature
Cost
Dolby On
iOS + Android
Beginners wanting high-quality phone recordings
Automatic audio enhancement and noise reduction
Free
Spreaker Studio
iOS + Android
Solo and live recording
Built-in sound effects and live streaming
Free (paid tiers available)
GarageBand
iOS only
iOS users who want editing control
Multi-track recording and full editing suite
Free
Voice Memos
iOS only
Quick solo drafts and test recordings
Instant, zero-setup recording
Free (built-in)
Riverside
iOS + Android (mobile browser)
Remote guest interviews
Local-track recording for each speaker
Free tier available
A few notes on making your choice:
  • If you want great podcast audio without wasting time, try Dolby On. It’s free and makes your voice sound better automatically. The whole recording process also feels really simple and easy.
  • If you are on iPhone and want more control over your audio in editing, GarageBand is a powerful free alternative.
  • If you plan to record with a remote guest, skip the other apps and go straight to Riverside. The quality difference over a regular phone call is substantial.
How to Record a Podcast on Your Phone Step by Step
Once your app is installed and your space is ready, recording a podcast on your phone takes less than 10 minutes to set up. Here is the full sequence from opening the app to saving your raw file.
How to Record a Podcast on Your Phone — Step by Step
  1. Download and open your chosen recording app. Make a free account if the app asks for one. Riverside (formerly Riverside.fm) needs an account before you can start recording. GarageBand, Voice Memos, and Dolby On let you record without one.
  2. Set up your physical space first. Before you create a new project, check your environment. Close windows and doors, turn off fans and air conditioning units, and move to a room with carpet, curtains, or upholstered furniture. Hard walls and bare floors create audible echo.
  3. Check your phone’s available storage. A 30-minute WAV file can exceed 300 MB. Clear space before you start, or confirm your cloud backup settings will not interrupt the session mid-recording.
  4. Plug in your headphones. Even basic earbuds let you hear audio problems in real time. They also prevent speaker bleed into the microphone, which matters most during remote interviews.
  5. Start a new recording or create a new project first. Most apps have a Record or New Project button. After that, give your project a name before recording. Doing so will help you find the audio later without wasting much time.
  6. Record a 15-second test clip. Speak at your normal podcast volume, stop, and play it back. Listen for background hum, echo, or low volume. Adjust your position or environment before you continue with the full episode.
  7. Position your phone correctly. Hold or prop the phone 6 to 8 inches from your mouth with the microphone end pointing toward you. On most phones, the primary microphone is at the bottom edge. Keep that end facing your voice.
  8. Hit record and start talking. Talk like you normally would during a regular conversation. If you slip up, pause for a moment and restart the sentence. That short break shows up clearly in the waveform later. It makes those parts much easier to spot while editing.
  9. Stop the recording and export the file immediately. Tap stop, then save or export. Do not close the app without confirming the file is saved. Export the raw audio to your camera roll or cloud storage as a backup before you begin any editing.
Before You Hit Record: Room Setup and Mic Placement Tips
These adjustments cost nothing and produce the biggest single improvement in audio quality:
  • Choose a room with soft surfaces. Bedrooms, walk-in closets, and rooms with carpeting or heavy curtains absorb sound well. A wardrobe full of clothes is one of the most effective free acoustic environments available to most people.
  • Turn off all noise sources before you start. Air conditioners, fans, refrigerators, and running water all produce a constant background hum that is difficult to fully remove in editing.
  • Hold the phone 6 to 8 inches from your mouth. If you hold your phone closer than 4 inches, then some consonants may sound distorted. Contrarily, moving farther than 12 inches will make the room noise start competing with your voice.
  • Point the microphone toward your mouth, not at the ceiling. This usually means holding the device at a slight upward angle rather than fully vertical.
  • Monitor with headphones as you record. If your headphones make the audio sound echoey or far away, the final file will sound that way too. Fix it now instead of finding the problem after recording. .
  • Keep the phone still while you speak. Handling noise from fingers shifting on the casing carries directly into the microphone. Lean your phone against something sturdy or place it on a small stand. Keeping it still helps the recording stay clean.
Should You Use an External Microphone? (And Which One)
Your phone's built-in mic can sound good. With the right room setup and mic placement, you can record an episode ready to publish without extra spending. It also captures sound from every direction. Because of that, background noise and room echo can still mix with your voice.
An external microphone solves this problem at the source. For phone podcasters, the Hollyland LARK A1 is the most practical option. It connects directly to your phone via USB-C or Lightning, so there is no Bluetooth pairing, no additional app, and no driver installation. It uses 3-Level Intelligent Noise Cancellation to reduce background noise before it reaches your recording, and its omnidirectional pickup pattern keeps the focus cleanly on your voice. The setup process is straightforward. Plug it in, open your recording app, and it works.
If you record while moving, such as walking commentary, on-location interviews, or sessions in multiple rooms, the Hollyland LARK M2 is worth considering. It is a 9g wireless clip-on microphone with up to 40 hours of battery life that removes the physical connection between you and your phone entirely.
How to Record a Podcast Interview Remotely on Your Phone
The biggest mistake podcasters make when recording a remote guest is using a standard phone call, WhatsApp, or FaceTime. Compressed audio codecs used in those services strip out vocal quality, and the resulting audio is often noticeably degraded. There is also no way to separate the two voices into individual tracks for editing.
The right tool for this use case is Riverside. It records each participant’s audio locally on their own device and then uploads the separate high-quality tracks to the cloud. Even if the internet connection drops mid-interview, both recordings continue independently. Here is how to get started from your phone:
  1. Open Riverside in your mobile browser or download the Riverside app.
  2. Create a free account and start a new studio session.
  3. Copy the guest invite link and send it by text or email.
  4. Your guest clicks the link and joins directly in their browser — no app download required on their end.
  5. Hit record. Both audio tracks record locally and sync to the cloud when the session ends.
  6. Download the individual speaker tracks and bring them into your editing app of choice.
Editing and Exporting Your Podcast on Your Phone
You do not need a computer to handle basic post-production. Trimming silence at the start and end of a recording, cutting obvious mistakes, and adding a simple fade in or out can all be done on your phone before export. For most solo episodes, that level of editing is all you need.
Mobile editing options:
  • GarageBand (iOS): The most capable free mobile editor; import your audio file and work on a visual timeline
  • Ferrite Recording Studio (iOS): Purpose-built for podcast editing on iPhone, with chapter markers and noise reduction tools
  • Dolby On: It lets you trim your recording and boosts the audio automatically before you export it.
When you export, use MP3 at 128 kbps mono for voice-only episodes. If you recorded in stereo with multiple microphones or included music, use 192 kbps stereo. MP3 is the standard format accepted by every major podcast hosting platform.
Can you record a good-quality podcast just using your phone’s built-in microphone?
Yes, with the right environment. Recording in a quiet room with soft furnishings and holding the phone 6 to 8 inches from your mouth produces surprisingly clean audio. A built-in mic is a legitimate starting point for any new podcaster. An external microphone improves clarity and noticeably reduces background noise, but it is not required to publish a first episode.
What is the best free app for recording a podcast on your phone?
Dolby On is one of the easiest free apps for phone podcast recording. It makes your voice sound better automatically with very little setup. For iOS users who want more editing flexibility, GarageBand is free and significantly more capable on the production side, though it requires a separate hosting and distribution step.
How do I record a podcast with a guest on my phone?
Use Riverside on mobile. It records each participant’s audio locally on their own device, which produces far better results than a standard phone call or video chat. Your guest only needs a link to join, with no app download required on their end. Avoid WhatsApp and FaceTime for any episode you intend to publish.
What audio format should I export my podcast in from my phone?
MP3 at 128 kbps in mono is the standard for voice-only podcast episodes. It balances file size with audio quality and is accepted by every major podcast hosting platform. If your episode includes music or was recorded in stereo with multiple microphones, export at 192 kbps stereo instead.
Do I need headphones to record a podcast on my phone?
Headphones are strongly recommended. They stop speaker audio from getting picked up by the microphone, especially during remote interviews. They also help you notice echo, background noise, or low volume right away. That gives you time to fix everything before the recording ends.
Your phone already has everything needed for your first podcast episode. So, pick a free app from the table above. Then find a quiet room and record a short test. Most sound problems start with the room or microphone placement. Therefore, better equipment cannot fix those mistakes on its own. And if you want even cleaner audio later, you can count on the Hollyland LARK A1 for a better audio upgrade.
