Launching a podcast is easier than most new creators expect. Your iPhone already gives you a strong place to begin. This article covers recording, editing, publishing, and sharing every episode. You will also learn how listeners can find your show. Apple Podcasts and Spotify are both part of the process. No recording studio or special background is needed to begin.
What You Need to Start a Podcast on Your iPhone
Get these three things ready before recording your very first podcast episode.
A recording app: Your iPhone doesn’t come with a dedicated podcast recorder, but several free and low-cost apps handle it well. You’ll choose one in the next section.
A microphone (or your iPhone’s built-in mic as a starting point): The built-in microphone works for a first attempt, but a dedicated mic makes a noticeable difference in audio clarity and listener retention.
A podcast hosting account: Directories like Apple Podcasts and Spotify don’t accept direct file uploads. You need a hosting platform to store your audio and generate an RSS feed that directories pull from.
That’s the complete list. You don’t need a mixing board, a soundproofed room, or a professional editing suite. Your iPhone handles the recording; the apps and platforms handle the rest. The next sections follow the full process in the right order. You can go from getting started to publishing without jumping back..
Upgrade Your Audio Quality with a Microphone
The iPhone’s built-in microphone is designed for phone calls and voice memos, not podcast recording. It picks up room echo, handling noise when you shift the phone, and ambient sounds you won’t notice until you play back the recording. For most listeners, poor audio quality is the primary reason they stop following a new podcast after the first two minutes.
A dedicated microphone is the single highest-return upgrade you can make before publishing. The Hollyland LARK A1 is one of the most beginner-friendly options for iPhone podcasters because it requires no audio interface and no driver installation. The transmitter clips to your collar, the receiver plugs directly into your iPhone’s Lightning or USB-C port, and you’re ready to record immediately. Its 3-Level Intelligent Noise Cancellation filters out consistent background noise (fan hum, air conditioning, street traffic) automatically, so you don’t have to treat your room before recording.
If you plan to record interviews away from home or want complete freedom of movement, the Hollyland LARK M2 is worth a look as an upgrade. At 9 grams per transmitter and with up to 40 hours of total battery life, it handles long recording sessions and disappears into any shoot.
Hollyland LARK A1 |
Hollyland LARK M2 |
Use Case |
Solo podcast at a desk or home setup |
On-the-go recording, interviews, mobile creators |
Connection Type |
Wired receiver (Lightning or USB-C) |
Wireless, USB-C receiver |
Key Feature |
Plug and Play, 3-Level Noise Cancellation |
9g transmitter, 40-hour battery life |
When the Built-In Mic Is “Good Enough”
If budget is a concern right now, recording your first episode with the iPhone’s built-in microphone is a reasonable starting point. Find the quietest room in your home, sit close to the phone (about 6 inches away), and position soft furnishings like a couch or curtains behind you to reduce echo. The audio won’t match a dedicated microphone, but it’s acceptable for testing whether podcasting is the right fit before you invest in gear.
Choose Your Podcast Recording App
The recording app you pick can make the whole process feel easier. A good choice keeps editing and exporting simple from the start. These three apps are great options if you are recording on an iPhone for the first time.
App |
Cost |
Best For |
Key Limitation |
GarageBand |
Free (pre-installed on iPhone) |
Beginners who want full recording and editing control |
Not podcast-specific; slight learning curve |
Ferrite Recording Studio |
Free (Pro upgrade ~$19.99) |
Podcasters who want a purpose-built mobile editing workflow |
Free version has export and track limits |
Spotify for Creators |
Free |
Total beginners who want to record and publish in one place |
Less editing flexibility than dedicated apps |
Recommendation: If you want control over your audio, use GarageBand to record and edit, then export to your hosting platform. If you want the fastest possible path from recording to a live show, Spotify for Creators handles recording, hosting, and distribution inside a single app.
Record Your First Podcast Episode
With your app installed and your microphone connected, follow these steps during your first recording session:
Set up your recording environment. Choose a small, quiet room with soft surfaces. Close doors and windows, turn off fans or HVAC units if possible, and silence any nearby devices. Place your phone on a stable surface or clip the LARK A1 transmitter to your collar.
Enable Airplane Mode. Before you press record, switch your iPhone to Airplane Mode. This prevents incoming calls, text banners, and app alerts from interrupting the recording mid-sentence.
Open your recording app and check the input source. In GarageBand, create a new Audio Recorder project and confirm the input is set to your external mic if one is connected. In Spotify for Creators, tap the record button to open the recording screen.
Record a 30-second test clip. Speak at your normal podcast volume, then play back the clip and listen for background noise, distortion, or echo. If the audio sounds muddy, move closer to the mic or find a quieter spot before continuing.
Record your full episode. Speak 6 to 8 inches from the microphone. Don’t stop and restart every time you stumble. Instead, pause, take a slow breath, and continue from the last clean sentence. You’ll clean up errors in editing. A natural, conversational tone matters far more than a perfect read.
Save your project before closing the app. GarageBand auto-saves, but always confirm your project file is stored before exiting the app.
Pro Tip: Keep a glass of water within reach during your recording session. Staying hydrated reduces mouth noise and lip smacks, which a close microphone picks up more than you’d expect.
How to Structure a Podcast Episode
A simple episode structure keeps listeners engaged without requiring a full content script. Start with a hook that grabs attention right away. Tell listeners what they can expect from this episode in one or two short sentences. Move into your main content, whether that’s a solo topic breakdown, a how-to walkthrough, or a guest interview. Close with a brief outro that includes a call to action such as subscribing, leaving a review, or visiting your website. That three-part pattern (hook, content, call to action) is all you need to complete episode one.
Edit Your Podcast on iPhone
Editing doesn’t mean making the episode flawless. It means removing the distractions that pull a listener out of the content. Here is a minimal editing workflow that works inside GarageBand or Ferrite:
Trim the start and end. Delete any dead air before you start speaking and after you finish. These are the two easiest edits and the ones most beginners overlook.
Remove obvious mistakes. Long stumbles, false starts, and extended silences can be cut by selecting the section and deleting it. In GarageBand, use the split tool to isolate the region. In Ferrite, use the region selection tool to mark and delete.
Level your audio. If parts of the episode are noticeably quieter or louder than others, adjust the volume using GarageBand’s automation track or Ferrite’s volume envelope feature. Aim for a consistent, comfortable listening level from start to finish.
Add an intro and outro (optional). A short royalty-free music clip at the beginning and end of your episode makes it feel more produced. Search Free Music Archive or Pixabay for royalty-free tracks, then import the clip into GarageBand as a second audio track and reduce its volume under your voice.
Export as an MP3. Use 128 kbps for spoken-word content to keep file sizes manageable without sacrificing clarity. In GarageBand, tap the share icon and select “Song” to export an audio file. Rename it with your show title and episode number before uploading.
Your first episode doesn’t need to sound like a studio production. It needs to be listenable and authentic. Publish episode one, note what you want to improve, and apply those changes to episode two.
Choose a Podcast Hosting Platform
A podcast hosting platform does three things: stores your audio files, generates an RSS feed from your published episodes, and makes that feed available to directories. You cannot skip this step. Apple Podcasts and Spotify do not accept direct audio file uploads from individual creators.
Here are three hosting platforms well-suited to beginners:
Platform |
Cost |
Best For |
Free Tier? |
Free |
Absolute beginners; built-in recording, hosting, and distribution |
Yes, fully free |
Buzzsprout |
From $15/month |
Beginners who want clean analytics and an easy-to-navigate dashboard |
Yes (limited upload hours per month) |
Podbean |
From $12/month |
Creators who want affordable storage with monetization options available later |
Yes (limited storage) |
Once your hosting account is set up, upload your exported MP3, write an episode title and brief show notes, set a publish date, and copy your RSS feed URL. You will need that URL in the next step when you submit to directories.
Note: Your episode artwork needs to be uploaded to your hosting platform, not just to individual directories. Most hosts display it on your podcast’s public page and pass it through to Apple Podcasts and Spotify automatically with every new episode.
Submit Your Podcast to Apple Podcasts and Spotify
Once you have at least one published episode and a live RSS feed URL from your hosting platform, you’re ready to submit to the two most important podcast directories.
Apple Podcasts
Go to podcasters.apple.com and click the Sign in button. You will be directed to the Apple Podcast Connect page.
Enter your Apple ID and password. Once done, click the Get Started button to continue.
Set up your account, agree to the terms and conditions, and click the Save button.
Once you are logged in, click the “+” button to add a new show.
Select the “Add a show with an RSS feed” option and click Next.
Copy the RSS feed URL from the hosting platform, such as Buzzsprout.
Then, paste your RSS feed URL into the submission field and click the Add button.
Apple will validate the feed and automatically pull in your show title, description, and artwork.
Review the details and submit. Approval typically takes 24 to 48 hours.
Once approved, your podcast appears in the Apple Podcasts directory within a few hours of acceptance.
Spotify
If you are using Spotify for Creators as your host, your podcast is automatically distributed to Spotify. No separate submission is needed.
If you are using a different host such as Buzzsprout or Podbean, go to creators.spotify.com and Log in.
Put checkmarks on the Spotify terms, and click the Accept Terms button.
Click your profile image and choose Add a new show.
Select the “Find an existing show” option and choose “Somewhere else.”
Paste the RSS URL and click Next.
To verify ownership, click the Send code button to receive a confirmation email.
Then, enter the code and click the Next button.
Complete the submission. Spotify typically makes new shows available within a few hours of verification.
Most other directories, including Amazon Music, Pocket Casts, and iHeartRadio, accept RSS feed submissions through a similar process. Check whether your hosting platform offers one-click distribution to multiple directories at once, which can save time.
Create Your Podcast Artwork and Episode Description
Apple Podcasts requires a square cover image between 1400x1400 pixels and 3000x3000 pixels in JPEG or PNG format. Keep the file under 512KB before uploading anywhere. Canva has free podcast templates already sized for these exact rules. That makes it a great pick if you're just getting started. Upload your cover to the hosting platform before sending your show anywhere else. Then write a short description with two or three simple sentences. Mention your podcast topic, who should listen, and one or two natural keywords. That helps new listeners find your show through search.
Can I record a podcast on iPhone without any extra equipment?
Yes. The iPhone’s built-in microphone produces acceptable audio when you record in a quiet, soft-furnished room with the phone positioned close to your mouth. It won’t match a dedicated microphone, but it is a practical way to test your format and episode structure before spending money on gear.
What is the best free app to record a podcast on iPhone?
GarageBand is the most capable free option, handling both recording and basic editing without cost or file limits. Spotify for Creators is the better choice if you want to record and publish without managing a separate hosting account. The right pick depends on how much editing control you want over your audio.
How long does it take to get a podcast on Apple Podcasts?
Apple Podcasts typically reviews and approves new submissions within 24 to 48 hours. Before submitting, your RSS feed must include at least one fully published episode and a valid square cover image that meets Apple’s size requirements. Incomplete or improperly formatted feeds are rejected and must be corrected before resubmission.
Do I need a podcast hosting platform, or can I upload directly to Spotify?
You need a hosting platform. Podcast directories use RSS feeds to access your audio; they do not store files from individual creators directly. Spotify for Creators functions as both a hosting platform and a directory, so it covers both needs if you use it as your primary host. Other hosts like Buzzsprout generate an RSS feed you submit to Spotify separately.
What microphone works directly with an iPhone for podcasting?
The Hollyland LARK A1 plugs directly into an iPhone via a Lightning or USB-C receiver with no adapter or audio interface required. It includes 3-Level Intelligent Noise Cancellation and a clip-on transmitter, making it a straightforward, low-friction choice for beginners recording at a desk or on the go.
Starting a podcast on your iPhone only takes six simple steps. First, grab your gear and choose a recording app. Next, record your episode and clean up the audio. And then upload to a podcast hosting platform. After that, send your show to podcast directories. You do not need expensive gear or years of experience. All you need to do is open a recording app. And find the quietest room possible. Then, record a few minutes of a test episode and play it back. Change one thing you did not like and record again. Your first episode will not be perfect, and that is completely okay. The biggest win is getting your podcast out there.
