Starting a Podcast: Every Piece of Equipment You Actually Need
Buying podcast gear can feel confusing because everyone recommends something different. Most beginners see endless tech terms, as well as pricey setups they probably will never need. This guide keeps everything simple, covering each gear category for home recording. You will see microphones, recording software, and even your recording space explained clearly. This article talks only about equipment, while editing, publishing, and making money come later.
The Complete Podcast Equipment Checklist at a Glance
Check the table below before looking at each equipment category. It helps you see what you truly need and what you can skip, depending on your setup and budget.
Equipment
Essential or Optional
What It Does
Microphone
Essential
Captures your voice; the single highest-impact purchase you will make
Closed-back headphones
Essential
Lets you monitor audio in real time and catch problems during recording
Recording software (DAW)
Essential
Records, edits, and exports your audio files
Audio interface
Conditional
Required only if you use an XLR microphone; converts analog signal to digital
Pop filter
Recommended
Reduces harsh plosive sounds (P, B, T) caused by bursts of air hitting the mic
Boom arm
Recommended
Positions your mic correctly and frees up desk space
Shock mount
Recommended
Isolates the microphone from desk vibrations and handling noise
Acoustic treatment
Recommended
Reduces echo and room noise; often costs nothing
Wireless mic system
Optional
Useful for in-person interviews, co-hosts, or mobile recording scenarios
Microphone: The Most Important Purchase You’ll Make
Your microphone is the single decision that shapes everything else in your setup. A quality mic in a decent room will almost always outperform an average mic in an untreated studio. Before choosing a specific model, you need to settle one fundamental question: USB or XLR?
Microphone — The Most Important Purchase You’ll Make
This is not really a quality debate. It is a decision about complexity, budget, and how much setup you are willing to manage. USB microphones connect directly to your computer and work immediately. XLR microphones require an audio interface as a middleman. Both paths can produce excellent podcast audio; the right choice depends on where you are in your podcasting journey.
USB Microphones (Best Starting Point for Most Beginners)
USB microphones are the default recommendation for first-time podcasters for one simple reason: plug it in, and you are recording. There is no additional hardware, no extra cables, and no signal chain to configure.
Popular starting-point models include the Audio-Technica AT2005USB, which operates as both USB and XLR (making it a genuinely future-proof first mic), and the Blue Yeti, a large-diaphragm condenser that offers strong clarity for home studios that have some basic acoustic treatment in place.
When shopping for a USB mic, you will encounter two microphone types:
  • Dynamic microphones pick up sound in a tighter pattern and reject background noise effectively. They are the better choice for untreated rooms, apartments with ambient noise, or any space that is not acoustically controlled.
  • Condenser microphones are more sensitive and capture more detail, but they also pick up more of the room around you. Best suited for quieter, softer recording environments.
For most beginners recording at home without acoustic panels or a treated space, a USB dynamic microphone is the most forgiving starting point.
XLR Microphones (Better Long-Term Quality, More Gear Required)
Think of XLR as the next step once you want more control. These microphones need an audio interface, so the setup costs more. It also takes extra time to put everything together. Even so, you get more room to expand your setup later.
The Shure SM7B is the most frequently referenced XLR dynamic mic in podcasting, used by professionals and well-known creators across the industry. The Rode PodMic offers a more accessible entry into the XLR world without sacrificing much on sound quality.
Main reasons to choose XLR from the start:
  • You already plan to invest in a proper audio interface
  • You are building a multi-guest or studio setup
  • You want maximum control over gain staging and signal quality
  • You anticipate professional or commercial use over the long term
If you are recording your first few episodes and still deciding whether podcasting is a long-term commitment, USB is the more practical starting point. Upgrading later is straightforward.
Wireless Microphones (Ideal for Interviews and On-the-Go Recording)
A desktop microphone is not the right tool for every recording scenario. If you are conducting in-person interviews, co-hosting with someone in the same room, recording at an event, or producing a video podcast where cable management is an issue, a wireless lavalier system is the more practical choice.
The Hollyland LARK A1 is worth highlighting for beginners in this scenario. It is a compact two-person wireless mic system with a receiver that connects directly via USB-C or Lightning, meaning no audio interface is required. It includes 3-Level Intelligent Noise Cancellation and works with both smartphones and computers. For anyone recording interviews on a phone or wanting a portable setup without a complicated signal chain, the LARK A1 is a practical fit.
Creators stepping up their interview audio quality can look at the Hollyland LARK MAX 2, which adds 48 kHz / 32-bit Float recording, AI Noise Cancellation, and onboard backup recording so no audio is lost if the wireless connection drops. This is a meaningful upgrade for video podcasters or creators who cannot afford unusable interview audio.
Key specs at a glance:
  • LARK A1: Plug-and-play USB-C/Lightning receiver, 3-Level Intelligent Noise Cancellation, beginner-friendly price point, smartphone compatible
  • LARK MAX 2: 48 kHz / 32-bit Float, AI Noise Cancellation, onboard backup recording, OWS wireless monitoring, built for professional interview workflows
Audio Interface: Only Buy This If You Go the XLR Route
An audio interface connects your XLR microphone to your computer. It manages analog-to-digital conversion, translating the electrical signal from your mic into digital audio your recording software can work with. It also supplies phantom power (typically 48V), which condenser XLR microphones require to operate at all.
Audio Interface — Only Buy This If You Go the XLR Route
If you are using a USB microphone, you do not need an audio interface. That is the complete answer.
For those going the XLR route, the Focusrite Scarlett Solo is the most commonly recommended beginner interface. It handles one microphone input at a time, which is all most solo podcasters need. If you plan to record a co-host or guest simultaneously in the same room, the Focusrite Scarlett 2i2 adds a second XLR input for a modest price increase.
What to look for in a beginner audio interface:
  • At least one XLR input with 48V phantom power
  • A dedicated gain control knob for easy level adjustment
  • Direct monitoring capability so you can hear yourself in real time without software delay
  • USB connectivity (most modern interfaces use USB-A or USB-C)
Interfaces in the $100 to $150 range cover everything a beginner needs without overcomplicating the setup.
Headphones: Why You Can’t Skip These
Many beginners skip good headphones, but they really are something you should not leave out. You need them for real-time monitoring while recording and quality review during editing.
Headphones — Why You Can’t Skip These
Closed-back headphones are specifically what you want for recording. Their sealed ear cup design prevents audio from the headphone speaker from leaking back into your microphone, which would add an unwanted layer of noise to your recording. Open-back headphones, common in audiophile listening, create exactly that kind of bleed and are not suitable for live recording monitoring.
While recording, your headphones help you notice problems right away. A mic that is too close to your mouth, sudden background noise entering the room, or a gain level that is clipping. During editing, they give you an accurate picture of what your listeners will actually hear.
Entry-level closed-back options that audio engineers consistently recommend include the Sony MDR-7506 (flat, accurate response, widely used in broadcast environments) and the Audio-Technica ATH-M20x (one of the best value options available under $60). Either pair is appropriate for both recording monitoring and post-production review.
Recording and Editing Software (DAW)
Your digital audio workstation (DAW) is where you record, arrange, and edit your podcast episodes before exporting them for distribution. The good news is that some of the best options for beginners are completely free.
  • GarageBand (Mac/iOS): Free, pre-installed on Apple devices, and fully capable for podcast production. Covers recording, basic editing, and multi-track arrangement without a significant learning curve overhead.
  • Audacity (Windows/Mac/Linux): Free, open-source, and cross-platform. Less intuitive than GarageBand but powerful once you learn the basics. The most common recommendation for Windows users starting out.
  • Hindenburg Journalist: A paid option built specifically for spoken word content. Its automatic leveling tools and simplified interface make it popular with journalists and podcast producers who want fast turnaround without deep audio engineering knowledge.
  • Adobe Audition: Part of the Adobe Creative Cloud suite. More powerful than the beginner options and better suited to creators already in the Adobe ecosystem.
For remote guest recording, your standard DAW is not the right tool. Use a dedicated remote recording platform instead:
  • Riverside.fm: Records each participant locally at full quality, then syncs the files. The most reliable option for remote podcast interviews.
  • Zencastr: A browser-based alternative with a free tier, suitable for early-stage productions.
Start with a free DAW and upgrade only once you know what your specific workflow actually requires.
Accessories That Make a Real Difference
Three low-cost additions that deliver measurable improvement to recording quality:
  • Pop filter: A circular mesh screen that sits between your mouth and the microphone. It diffuses the burst of air that causes harsh plosive sounds on P, B, and T consonants. Cost: $10 to $20, and often bundled with entry-level USB mics.
  • Boom arm: A desk-mounted adjustable arm that holds your microphone at the correct position and angle without consuming desk space. It also keeps your mic away from your keyboard and desk surface, reducing the vibration noise that shock mounts alone cannot fully address. Cost: $20 to $50 for a reliable beginner option.
  • Shock mount: A suspension cradle that holds the microphone body and isolates it from vibrations traveling through the desk or boom arm. Prevents low-frequency rumble and handling noise from appearing in your recording. Many microphones ship with a basic shock mount included.
Acoustic Treatment: Make Your Recording Space Sound Better
Here is the advice most gear guides skip! Your recording environment matters more than your equipment tier. A $400 microphone in a live, echo-heavy room will often sound worse than a $100 to $150 mic recorded in a treated space.
Acoustic Treatment — Taming Your Recording Space
You do not need to build a soundproofed studio. Basic acoustic treatment simply means reducing the hard surfaces that reflect sound back toward your microphone. Practical approaches:
  • Record inside a walk-in closet surrounded by hanging clothes (one of the best free acoustic environments in any home)
  • Hang thick blankets or moving pads on the walls closest to your recording position
  • Add rugs, curtains, and soft furniture to reduce room reflections
  • Use a portable reflection filter behind the microphone for a focused, low-cost solution
Budget acoustic foam panels are available for under $30 and address mid-to-high frequency reflections effectively. Treating your space before upgrading your microphone is almost always the higher-return move.
Podcast Equipment by Budget: What to Buy at Each Level
Use this table to build a setup that matches your current investment level without buying gear you are not ready to use.
Budget Tier
Approx. Spend
Core Gear Included
Starter
Under $100
USB dynamic mic (e.g., Audio-Technica AT2005USB), basic closed-back headphones (e.g., ATH-M20x), free DAW (GarageBand or Audacity), pop filter
Mid-Range
$100–$300
Better USB mic or entry XLR + Focusrite Scarlett Solo, closed-back headphones, boom arm, pop filter, basic acoustic foam panels
Pro-Ready
$300+
XLR dynamic mic (e.g., Shure SM7B or Rode PodMic), quality interface (Focusrite Scarlett 2i2), studio headphones, acoustic panels, wireless mic system (e.g., Hollyland LARK A1 or LARK MAX 2)
The starting point is more accessible than most beginners expect. A USB microphone and a free recording app in a lightly treated space is a fully functional podcast setup. Add gear as your show grows, and your specific needs become clearer.
Do I need an audio interface to start a podcast?
No, not unless you are using an XLR microphone. USB microphones connect directly to your computer and handle their own analog-to-digital conversion internally. An audio interface is only required when you move to the XLR signal chain. If you want to keep your first setup simple and affordable, a USB mic removes this requirement entirely.
Can I record a podcast on my phone?
Yes, and it is a reasonable way to test your concept before committing to equipment. But built-in phone microphones pick up significant background noise and room echo. Adding a plug-in wireless mic like the Hollyland LARK A1 (USB-C or Lightning connection, no additional hardware required) significantly improves smartphone audio quality and is a practical step up without purchasing a full desktop setup.
What is the difference between a condenser and a dynamic microphone for podcasting?
Dynamic microphones have a tighter pickup pattern and reject ambient noise more effectively, making them the better choice for home recording in untreated rooms. Condenser microphones are more sensitive and capture finer detail but also pick up more of the surrounding room. Most podcasters recording at home without acoustic treatment will get cleaner results starting with a dynamic microphone.
Do I need soundproofing before I start recording?
No. Soundproofing and acoustic treatment are different things. Full soundproofing is unnecessary for podcast production. Simple acoustic treatment, like soft furniture or a clothes closet, helps reduce echo inside your room. Closing windows and sealing door gaps can also lower outside noise. Pick the quietest room you have, then add more treatment if needed.
How much should a beginner spend on podcast equipment?
A fully functional starter setup is achievable for $100 to $150, centered primarily on a USB microphone and a pair of closed-back headphones. The biggest quality improvements come from the microphone choice and the recording environment, not from total spend. Avoid purchasing accessories until you have recorded enough to understand what your specific workflow actually requires.
You can start your podcast with a USB mic, closed-back headphones, and free recording software. This equipment is good enough to record and share your first episode. Great podcasts grow because people keep showing up with good content. After recording a few episodes, you will quickly notice what slows you down. From there, choosing your next upgrade becomes much easier.
