The Complete Starting a Podcast Checklist: Every Step Before You Hit Record
Starting a podcast gets way easier when you know what’s next. A lot of beginners make things harder by jumping around. This checklist keeps everything moving in a simple, clear order. It starts with your idea and ends with getting published. Just follow each step and check things off as you go. By the end, you’ll be ready to put your podcast out.
How to Use This Checklist
This checklist follows the actual launch sequence from concept to live directory listing. Work through each step in order rather than jumping ahead to recording before your planning and branding are locked in. Treat it as a literal sign-off list: complete each item before moving to the next phase. Skipping early stages is the most common reason a first launch gets delayed or abandoned halfway through.
Step 1: Define Your Podcast Concept
The planning phase is the one most people skip in their excitement to start recording. Spending 30 minutes locking in these four decisions prevents hours of wasted audio, mid-run re-branding, and confused audience positioning. Clear concept work also makes every downstream step faster, from writing your show description to pitching potential guests.
Step 1 — Define Your Podcast Concept
Concept Checklist
  • Choose your niche and validate that an audience exists. Search your topic on Apple Podcasts and Spotify. Existing shows are a positive signal, not a reason to avoid the space. They confirm listeners are already looking for this content.
  • Define your target listener. Choose one specific listener and understand their everyday situation. Know their biggest challenge and what they need most. Your episodes can then speak directly to those needs. A broad audience can make your content feel unclear. Clear listener details keep your show focused and relatable.
  • Select your show format. Options include solo commentary, co-hosted conversation, interview, narrative storytelling, and hybrid approaches. Your choice affects equipment needs, recording complexity, and how much editing time each episode will require.
  • Decide on episode length and publish frequency. Both commitments should work naturally with your actual schedule. A consistent 20-minute weekly show will outlast an inconsistent hourly one every time.
  • Research 3 to 5 existing podcasts in your niche. Listen to at least two full episodes from each. Identify what they do well and where gaps remain. Your show should answer one clear question: why would a listener choose this over what already exists?
Step 2: Gather Your Equipment
Good audio is the one technical non-negotiable in podcasting. Listeners will forgive imperfect content, but most will stop listening within the first few minutes if the audio sounds bad. The reassuring truth is that a professional-sounding setup does not require a professional budget, particularly if you are recording on a smartphone.
Step 2 — Gather Your Equipment
Essential Equipment
Microphone(the most important decision in your setup)
For beginners recording on a smartphone, the Hollyland LARK A1 is a practical starting point. It is a wireless clip-on mic with a direct USB-C or Lightning receiver, which means it plugs straight into your phone with no audio interface or complex driver installation required. The built-in 3-Level Intelligent Noise Cancellation manages typical room noise automatically, making it workable even if your recording space is not acoustically treated.
For anyone targeting studio-quality audio from the start, the Hollyland LARK MAX 2 offers a significant step up. It captures audio at 48 kHz / 32-bit Float, includes AI Noise Cancellation, and has built-in backup recording on the transmitter body, so a dropped wireless signal never costs you a finished take.
  • Closed-back headphones for monitoring. Open-back headphones bleed sound into the mic during recording. Closed-back headphones isolate your ears so you can hear your actual recorded signal, not just the room.
  • Pop filter or windscreen. Reduces plosive sounds (the hard “p” and “b” bursts) that are difficult to remove cleanly in editing after the fact.
  • Mic stand or boom arm. Holding a mic by hand introduces handling noise. A stand keeps the mic at a consistent distance from your mouth throughout a session.
  • Quiet recording space. A walk-in closet with hanging clothes or a soft-furnished room with carpet and curtains will outperform an empty, hard-walled office. Soft surfaces absorb sound reflections before they reach your mic.
Optional but Recommended
  • Audio interface. Only necessary if you are using an XLR dynamic microphone. Wireless and USB mics like the LARK A1 and LARK MAX 2 connect directly, making an interface unnecessary for most beginners.
  • Acoustic foam panels. Worth adding if your space has hard surfaces that create audible echo. Not required if you are recording in a naturally soft room.
  • Portable backup recorder. A dedicated field recorder provides insurance against software crashes or computer issues mid-session.
Step 3: Set Up Your Recording and Editing Software
Recording software and editing software are not always the same tool. Recording simply saves your raw voice and other sounds. Editing later turns those recordings into something ready to publish. New podcasters often think one app takes care of everything. Know the difference before you record anything important. Make a quick test clip before starting your actual episode. This helps spot setup problems before they ruin your recording.
Recording Software
  • GarageBand (Mac, free): An accessible starting point for Mac users with a short learning curve and clean audio quality out of the box.
  • Audacity (Windows and Mac, free): Offers more granular control than GarageBand and is widely used across beginner and intermediate setups.
  • Descript (paid, starts around $16/month): Edits audio by editing a text transcript, which significantly lowers the technical barrier for first-time editors.
  • Adobe Audition: Industry-standard for podcasters who want full control over noise reduction, EQ, compression, and multitrack editing.
Editing Checklist
  • Choose your DAW and install it before your first recording session. Don’t wait until your audio files pile up on your hard drive.
  • Download any required drivers or audio interface plugins and confirm your microphone is detected correctly by the software.
  • Record a 2-minute test session and listen back on headphones. Check for latency, clipping, background hiss, and room echo before recording real content.
  • Set your sample rate to 44.1 kHz or 48 kHz before recording. Export finished episodes as MP3 at 128 kbps mono as a minimum for voice content, or WAV if your hosting platform supports lossless uploads.
Step 4: Build Your Podcast Brand
Branding feels like it can wait, but podcast directories require artwork, a show description, and complete metadata before they will approve your submission. Getting these details right the first time prevents an unnecessary re-brand after your show is already live.
Step 4 — Build Your Podcast Brand
  1. Finalize your podcast name. It should be easy to spell when heard aloud, specific enough to be searchable, and not already registered as an active show on Apple Podcasts or Spotify.
  2. Write your show description. Aim for 2 to 3 sentences that clearly state who the show is for and what listeners will gain from it. Be clear about what your podcast actually talks about. Specific topics give people a stronger reason to subscribe.
  3. Design your podcast artwork. Apple Podcasts requires 3000 x 3000 pixels, RGB color mode, JPEG or PNG format, and a file size under 512 KB. Prioritize legibility as a small thumbnail in a directory listing over how it looks at full resolution.
  4. Record or license your intro and outro music. Keep the intro under 15 seconds. Use royalty-free sources such as Epidemic Sound, Artlist, or Free Music Archive to avoid copyright claims on your episodes.
  5. Write a show tagline. One clear sentence for directory listings and social profiles that states exactly what the show delivers.
  6. Secure matching social media handles. Claim your show name on the platforms where your target audience is active, even if you do not plan to post immediately. Handles disappear fast.
Step 5: Record and Prepare Your First Episodes
Try having three finished episodes ready before launch day. That way, one delay won’t mess up your first week. New listeners can keep going after finishing their first episode. People often binge shows when they discover something they enjoy. One episode alone gives them nothing else to check out.
Step 5 — Record and Prepare Your First Episodes
  • Record a minimum of 3 episodes before launch day. Publishing three episodes simultaneously is the widely accepted launch standard. It creates an immediate library and signals that your show is active and ongoing.
  • Outline each episode before recording. Note the main topic, three to five key points, a brief intro hook, and a call to action at the end. You do not need a word-for-word script, but a clear outline reduces rambling and cuts editing time significantly.
  • Complete a room check before each session. Silence your phone, close windows and doors, turn off HVAC systems if possible, and post a note outside if others share the space.
  • Record a full test episode and listen back. Check for hiss, echo, plosives, and any background noise before committing to recording your actual content.
  • Edit for pacing. Remove long silences, obvious filler words, and false starts. The episode does not need to sound clinically clean, but it should move at a comfortable, listenable pace.
  • Export at the correct format and bitrate. MP3 at 128 kbps is the minimum for voice-only content. Mono reduces file size without affecting perceived audio quality for spoken-word recording.
  • Write show notes for each episode. Include the episode title, a 100 to 200 word summary, timestamps for key segments, any guest bio and links, and a clear call to action directing listeners to subscribe, review, or visit a URL.
Step 6: Choose and Configure Your Podcast Hosting
A podcast host is basically the home for your show. It stores your audio and creates the RSS feed automatically. Podcast apps rely on that feed to find new episodes. Without a host, your podcast has no feed to submit. And without that feed, your show cannot appear anywhere.
  • Understand what a podcast host does. It stores your audio files, generates and maintains your RSS feed, and provides analytics on downloads and listener location.
  • Compare plans before committing. Key factors are monthly storage limits, analytics depth, episode caps, customer support quality, and whether the plan allows future monetization. Beginner-tier pricing typically ranges from free to around $20 per month.
  • Popular platforms to evaluate: Buzzsprout, Transistor, Podbean, and Spotify for Podcasters (formerly Anchor). Each has different strengths in analytics quality, pricing structure, and ease of use.
  • Upload a test episode and confirm the audio plays cleanly from the host’s built-in player before submitting your RSS feed to any directory.
  • Complete every metadata field. Show title, episode title, podcast category, language, explicit content rating, and artwork must all be filled in. Incomplete metadata delays or blocks directory approval.
  • Copy your RSS feed URL and save it. You will paste it into each podcast directory submission form in the next step.
Step 7: Submit to Podcast Directories
Directory submission is a one-time setup action per platform. Once your RSS feed is approved, every new episode you upload to your host publishes automatically across all directories. Submit to the highest-priority directories first and build in lead time before your launch date.
Step 7 — Submit to Podcast Directories
  1. Apple Podcasts: Submit via Apple Podcasts Connect at podcastsconnect.apple.com. Approval typically takes 24 to 72 hours but can stretch to 5 business days. Submit here first.
  2. Spotify: Submit via Spotify for Podcasters at podcasters.spotify.com. If you host directly with Spotify for Podcasters, your show is already listed. Otherwise, submit your RSS feed manually.
  3. Amazon Music / Audible: Submit via Amazon Music for Podcasters. Review time is generally 24 to 48 hours.
  4. iHeartRadio: RSS submission via their podcast intake form. A large listener base makes this worth including in your initial round of submissions.
  5. YouTube Music: Google Podcasts shut down in 2024, so listeners moved toward YouTube. YouTube and YouTube Music now play a bigger discovery role. Check whether your host supports sending your RSS feed there. You can also check the options inside YouTube Studio. Set everything up so your episodes reach YouTube Music listeners.
  6. Additional directories (optional): Pocket Casts, Overcast, and Player.fm are worth submitting to once your primary directories are confirmed live.
Note: Before announcing your launch publicly, verify that your artwork, description, and at least one episode display correctly in every directory. A broken listing on launch day is preventable with a 10-minute check.
Step 8: Plan Your Launch
A planned launch with a specific date and a small communications push to your existing network will outperform a quiet upload every time. You do not need a full marketing campaign, but you do need a minimum viable action plan for the first week.
Step 8 — Plan Your Launch
  • Set a specific launch date and commit to it. Soft launches, where you upload without telling anyone, produce minimal traction and waste the momentum available in your first week of visibility.
  • Prepare announcement content for your social channels in advance. Write captions and schedule them so you are not scrambling on launch day alongside everything else.
  • Email your existing network directly. A personal email or direct message with a subscribe link converts at a significantly higher rate than a social media post. Even 20 personal emails can generate your first loyal listeners.
  • Ask 5 to 10 trusted contacts to leave an early review on Apple Podcasts. Early reviews improve your show’s credibility in search results and extend your window of visibility in new-release discovery sections.
  • Publish a trailer episode before your full launch. A 60 to 90-second preview tells potential subscribers what the show is, gives directories something to index, and builds anticipation before your first full episode drops.
How many episodes should I have ready before launching a podcast?
Drop at least 3 episodes when your podcast officially goes live. This gives new listeners more content after finishing episode one. It also shows you’re serious about keeping your podcast active. Three episodes give your launch a solid starting point. If possible, prepare 5 episodes before the big launch day.
Do I need an expensive microphone to start a podcast?
No. A plug-and-play wireless mic like the Hollyland LARK A1 connects directly to a smartphone via USB-C or Lightning, requires no audio interface, and includes built-in noise cancellation suited to typical home recording environments. When audio quality becomes a higher priority, the Hollyland LARK MAX 2 adds 32-bit Float recording and AI Noise Cancellation for a more professional result.
What is an RSS feed and do I need to create one?
An RSS feed keeps podcast apps updated with new episodes. Your hosting service creates and updates this feed automatically. You’ll find its RSS URL inside your host dashboard. Submit that URL to Apple Podcasts and Spotify during setup. After approval, new episodes appear there without extra submissions.
How long does it take to get listed on Apple Podcasts?
Apple Podcasts typically approves new shows within 24 to 72 hours, though it can occasionally take up to 5 business days. Submit your show at least one week before your planned launch date to ensure a listing delay does not push back your entire timeline.
Do I need a website to start a podcast?
A website is not required to launch, but it is recommended. A simple landing page gives you a permanent home for show notes, episode archives, and guest links that is not subject to any platform’s algorithm or policy changes. It also makes your show discoverable through Google search in a way that a directory listing alone cannot fully replicate.
You now have the full checklist from your idea to launch. The smartest move now is choosing a clear launch date first. Then, plan each stage backward from that date. Most beginners can finish everything within 2 to 4 weeks. Just follow each step in order without rushing through anything. Pick your launch date, start at Step 1, and keep moving forward.
