Friends usually get excited about podcast ideas before making an actual plan. Different opinions can slow everything down if nobody makes decisions early. A quick conversation about the topic, responsibilities, and recording setup saves time later. Once everyone agrees, recording the first episode feels much less stressful. You'll find everything needed to go from planning together to sharing your first episode.
Figure Out Your Show Concept Before You Hit Record
The number one reason friend podcasts fail has nothing to do with bad audio or missed uploads. It is misalignment on what the show actually is. Everyone usually imagines the podcast a little differently at first. Those small disagreements can slow the whole group before recording even starts. Talk about your format, topic, and episode length before touching the microphones. Getting everyone on the same page early makes every recording feel much more relaxed.
Before anyone buys equipment or books a recording session, your group needs to sit down and agree on four things.
1. Your Niche or Topic: What is your show about? Be specific. “Pop culture” is not a niche. “Weekly reactions to prestige TV dramas” is. A tighter focus gives every episode a direction and makes it easier to generate ideas long-term.
2. Show Format: How will each episode be structured? Common formats include:
Roundtable discussion: All hosts weighing in on a shared topic
Interview-based: One or two hosts interviewing a guest
Storytelling or narrative: Scripted or semi-scripted episodes with a throughline
Debate or commentary: Structured disagreement on a topic
For a friend group, roundtable and commentary formats are the easiest entry points because they rely on natural conversational dynamics.
3. Episode Length: Decide on a realistic target length before you start. Twenty to forty minutes works well for conversation-driven shows. Committing to ninety-minute episodes right away is a fast path to burnout.
4. Target Audience: Who are you making this for? Even a rough answer helps. “People our age who are obsessed with true crime and also find it funny” is enough to guide tone and content decisions.
Once those four questions have clear answers, you have a working show concept.
Before you move on, your group should agree on:
The show’s core topic or niche
The episode format
Target episode length
Who the audience is
A working show name
How to Choose a Podcast Name as a Group
Naming a show together can spiral into a long debate if you let it. Keep it efficient:
Brainstorm separately first. Have everyone come to the session with five to ten ideas written down. This prevents groupthink and gives you more raw material.
Check availability before you commit. Search the name on Apple Podcasts and Spotify. If something very close already exists, move on.
Favor clarity over cleverness. A name that tells listeners what the show is about is more searchable than an abstract inside joke.
Test it out loud. If you would not say it confidently when someone asks what podcast you do, reconsider it.
Assign Roles Before the First Recording
Most podcast groups don't struggle because of talent. They struggle because nobody knows who should do what. If editing belongs to everyone, it usually gets ignored. The same thing happens when nobody takes charge of publishing. Clear responsibilities keep your episodes moving instead of collecting dust in a shared folder.
Here are the core roles every friend podcast needs covered:
Role |
Responsibility |
Lead Host |
Keeps conversation on track, hits time cues, manages episode pacing |
Episode Planner / Researcher |
Prepares the topic outline, gathers talking points, books guests if applicable |
Editor |
Does the audio edit, adds intro/outro, exports the final file |
Uploader / Publisher |
Uploads to the hosting platform, writes show notes, schedules release |
Roles can overlap, especially in a two-person show. One person can handle both editing and publishing. What cannot happen is leaving all of those roles unassigned and hoping they sort themselves out.
A good practice is that after your planning session, each person sends one message to the group confirming their role. That small act of acknowledgment reduces the chance of misunderstandings two months in.
Pro Tip: Rotate the episode planner role every few episodes. It distributes the prep workload and keeps the show from feeling like one person’s project.
Choose Your Equipment (for Multiple Speakers)
Most podcast equipment guides are written for solo hosts. Recording with several people needs a different game plan from solo podcasts. One thing should never change during your setup. Every person needs their own microphone for clear and balanced audio. One mic passed between two people produces unusable audio. Both voices need to be captured cleanly and, ideally, on separate tracks.
Here is how to approach equipment based on your budget and setup.
1. Budget / Phone-Based Setup: If you want to start immediately without buying desktop gear, a smartphone-based setup is completely viable. The Hollyland LARK A1 is a practical option here. It uses a USB-C or Lightning receiver that plugs directly into a smartphone with no app pairing or extra hardware required. Each host clips on a lavalier mic, and the 3-Level Intelligent Noise Cancellation handles most ambient room noise. For a first episode recorded on a phone, it removes a significant amount of friction.
2. Desktop USB Setup: If you are recording on laptops, a USB dynamic or condenser mic per person is the standard starting point. The Audio-Technica AT2020USB-Xis a reliable entry-level option. Plug each mic into a separate laptop, record each track independently, and combine them in your editing software.
3. XLR Setup with Audio Interface: For better sound quality, XLR microphones paired with an audio interface give you more control. This is worth considering once you know the show is going to stick, not necessarily for episode one.
4. Video Podcast Upgrade: If your group plans to film the show as well, the Hollyland LARK MAX 2 is worth a look. Each host wears a wireless transmitter, and the system records isolated audio per host at 48 kHz / 32-bit Float with AI Noise Cancellation. That setup pairs well with a camera or video-enabled recording session.
Do You Each Need Your Own Microphone?
Yes, without exception. Sharing a single microphone means one host is always too close or too far, and the audio levels will be inconsistent throughout the episode. No amount of editing fully fixes this. Every person who speaks on your show needs their own mic.
Decide How You’ll Record: In-Person or Remote
Your recording style decides what gear and setup your group actually needs. These are two different workflows, and confusing them leads to preventable problems.
Recording In-Person
If everyone is in the same room, the goal is clean, isolated audio from each person. Set up one microphone per host, ideally in a treated or soft-furnished room to reduce echo. Record each microphone as a separate track in your digital audio workstation (DAW). GarageBand on Mac or Audacity on either platform both support multi-track recording for free.
Key tips for in-person recording:
Everyone wears headphones to prevent bleed between microphones
Keep microphone levels consistent before you start
Record a short test clip and listen back before doing the full episode
Recording Remotely
Many friends record from different cities or work around busy schedules. That's why remote recording has become the normal choice for many podcasts. Zoom can still do the job with local multi-track recording and Original Sound turned on. Still, podcast recording platforms save more time by syncing high-quality local audio automatically in your browser.
Best Apps and Platforms for Remote Podcast Recording
Riverside.fm: Records locally in up to 4K video and lossless audio per participant. One of the most reliable options for remote co-hosts. Free tier available with limited recording hours.
Zencastr: Browser-based, no download required, records local audio per participant. Beginner-friendly with a free tier.
SquadCast: Similar to Riverside, with strong stability for multi-host sessions. Good option if reliability is the priority.
Cleanfeed: Straightforward browser tool with high-quality audio. Better suited for audio-only shows with no video component.
As a last resort, Discord’s Go Live audio can work in a pinch, but it does not record locally. If you use it, you will need a third-party recording tool running simultaneously, and audio quality will vary.
Edit Your Audio Without Overcomplicating It)
Many first-time podcasters spend too much time editing their episodes. Don't chase perfection before publishing your first recording. Focus on audio that sounds clean and easy to follow. A simple editing process is more than enough when you're getting started.
Recommended tools:
Audacity: Free, available on Windows and Mac. Handles multi-track editing, noise reduction, and export well.
GarageBand: Free on Mac. User-friendly interface for basic editing and mixing.
Descript: Edits audio the way you edit a text document. Useful for quickly removing filler words and long pauses without learning a traditional DAW.
Basic editing steps for a beginner episode:
Import all recorded tracks into your editing software
Sync the tracks so all hosts’ audio lines up correctly
Trim dead air at the beginning and end of the episode
Remove any obvious mistakes, long pauses, or cross-talk that derailed the conversation
Level the volume between hosts so no one sounds significantly louder
Add your intro music at the start and outro music at the end
Export the final file as an MP3 at 128 kbps (stereo) or 64 kbps (mono) — both are standard for distribution
Note: Your first episode does not need to sound like a produced broadcast show. Most listeners give new shows significant grace when the content is engaging. Done and published beats endlessly refined and unreleased every time.
Choose a Podcast Hosting Platform and Publish
A podcast hosting platform stores your audio files and generates an RSS feed. It is the technical link that distributes your show to Apple Podcasts, Spotify, and every other directory. You cannot submit directly to those directories without a hosting platform first.
Beginner-friendly hosting options:
Spotify for Creators: Free to use, straightforward upload process, distributes to major directories automatically. The simplest starting point for a group with no budget.
Buzzsprout: Paid plans with better analytics and a clean interface. Free tier available with some limitations on storage. Good choice if you want more insight into how the show is growing.
Podbean: Solid mid-range option with free and paid tiers. Reliable storage and functional distribution tools.
Once your account is set up, the publishing workflow is: record and edit your episode, upload the audio file to your hosting platform, fill in the episode title and show notes, and publish. Your hosting platform generates the RSS feed and handles distribution from there.
How to Submit Your Podcast to Apple Podcasts and Spotify
This only needs to be done once. After that, new episodes publish automatically through your RSS feed.
Apple Podcasts:
1. Go to podcastsconnect.apple.com and sign in with an Apple ID
2. Once logged in, click the Get Started button and set up your account.
3. Click the plus icon and select the New Show option
4. Click on the “Add a show with an RSS feed” option and click Next.
5. Enter your RSS feed URL from your hosting platform and click Add.
6. Review your show details and click Publish to submit for review
7. Approval typically takes 24 to 72 hours
Spotify:
1. Go to creators.spotify.com, log in or create an account, and agree to the terms
2. Click your profile image and select “Add a new show”
3. Click on the “Find an existing show” option and choose “Somewhere else” to enter your RSS URL
4. Paste the RSS feed URL link and click Next.
5. Click Send Code and check your registered email
6. Enter the code and click Next to verify ownership
7. Complete remaining details
8. Approval is usually within a few hours
Record and Release Your First Episode
The first episode does not need to be your best episode. It needs to exist. Here is a simple, repeatable structure for a friend-group podcast episode.
Basic episode template:
Intro (1–2 minutes): Brief welcome, introduce the hosts, and state what the episode covers. Keep it tight because listeners decide in the first two minutes whether to stay.
Main topic or discussion (15–35 minutes): This is the core conversation. Use your episode planner’s outline to give it shape, but let it breathe naturally.
Segment or recurring bit (5–10 minutes): You can also add a fun segment that shows up every episode. It could be a recommendation, a friendly debate, or a listener question. Regular listeners will start looking forward to that familiar part each time.
Outro and CTA (1–2 minutes): Thank listeners, tell them where to find you, and ask them to subscribe or leave a review.
Tips for the first episode as a group:
Agree before recording on rough time limits per person per topic. This prevents one host from naturally dominating while others go quiet.
Record a short 30 to 60-second trailer episode first. This low-stakes format is common for new shows on Apple Podcasts and Spotify, and it lets you submit to directories while preparing your first full episode.
Do a brief sound check together before starting the actual recording. Two minutes of confirmation prevents an hour of unusable audio.
Name your episode files clearly (e.g., “ShowName_EP001_RAW”) before the edit so the person handling the edit has no confusion about which files to use.
Normalize imperfection out loud on episode one. Acknowledging that you are new works better than pretending otherwise.
How to Keep Your Friend Podcast Going Past Episode 3
Most friend podcasts do not fail because of bad audio or the wrong platform. They fade because scheduling gets complicated and momentum stalls. A few simple systems prevent that from happening.
Block recurring recording time now. Schedule your next three to four recording sessions before you record episode one. Putting your recording day on a shared calendar makes everyone more likely to show up. It's much easier to keep a scheduled session than a plan that never gets a date.
Build a topic backlog before launching. Have five to ten episode ideas written down before your first episode goes live. This removes the “what are we even recording this week” paralysis.
Try releasing a new episode every other week when you're getting started. A weekly schedule can feel like too much for busy friend groups. Releasing every other week is easier to keep up with. It also gives everyone extra time for editing and unexpected changes.
Protect the fun. Too much pressure can take the fun out of making a podcast together. Before long, recording starts feeling like another chore instead of something everyone enjoys. If the process stops being enjoyable, recalibrate before someone quietly checks out.
What equipment do I need to start a podcast with friends?
You only need a good microphone for each person and a phone or laptop. Headphones are a smart pick because they catch audio problems early. You can skip them for super casual recordings while you're outside. If you're recording with a phone, keep things simple from day one. The Hollyland LARK A1 dual wireless kit connects quickly without extra gear. Recording each person's audio on separate tracks also keeps conversations clear.
Can we record a podcast with friends remotely?
Yes, and it is more common than recording in the same room. Use a dedicated remote recording platform like Riverside.fm or Zencastr instead of recording a Zoom call. These tools capture each person’s audio locally on their device, which produces significantly better quality than a compressed video call recording.
How many co-hosts should a friend podcast have?
Two to three hosts is the practical sweet spot. It creates natural conversational tension without turning into a talking-over-each-other situation. More than four hosts creates real scheduling complexity and makes it harder for listeners to track who is speaking during the episode.
How much does it cost to start a podcast with your friends?
You can start for free using a smartphone, a free recording app, and Spotify for Podcasters as your hosting platform. The main optional investment is a dedicated microphone per person, typically $50 to $100 each at the entry level. Paid hosting platforms and editing software can come later once the show has momentum.
Do we need a formal agreement before starting?
You do not need one to launch. But if the show grows or you plan to monetize it, a simple written agreement covering content ownership and revenue split is worth drafting early. Expectations about money and credit are much easier to set at the beginning than to renegotiate after the show has an audience.
Getting a podcast going with friends is really about showing up and staying consistent. Your first episode won't be perfect. But guess what? It's not a big deal! Every recording helps your group feel more comfortable and sound better together. So stop waiting for everything to feel ready. Grab your friends, set a recording day, and hit record. A few months from now, you will be glad you started and not just talking about it.
