Low on budget but high on hopes to have your own podcast? Well, the good news is that you don't need a fancy setup or costly gear to get started! If you have got a smartphone or a laptop, you're already set to start recording. So grab a few free tools, then spend about an hour getting everything ready. You can record, edit, host, and post your first episode without paying anything. This guide shows every step, from your first idea to going live. And soon, your podcast can appear on Apple Podcasts and Spotify for everyone.
What Do You Actually Need to Start a Podcast for Free?
The podcasting world has produced a myth that quality audio requires serious investment before you can get started. Truth is, many successful podcasts started with phone microphones and free apps. Before downloading anything, run this quick inventory check across three categories.
Hardware (what you likely already own)
Smartphone (iOS or Android) — sufficient microphone quality for early episodes
Laptop or desktop computer — needed for Audacity or GarageBand
Earbuds or wired headphones — usable as a makeshift mic and essential for monitoring playback
A quiet room with soft surfaces (rugs, curtains, a closet packed with clothes) — your free acoustic treatment
Software (all free downloads or browser-based)
Audacity — free, cross-platform audio editor for Windows and Mac
GarageBand — free on all Mac and iOS devices
Spotify for Creators — browser-based recorder, no download required
Hosting (free tier options)
Spotify for Podcasters (formerly Anchor) — unlimited storage, RSS feed auto-generated
Buzzsprout free tier — 2 hours per month, episodes deleted after 90 days
Podbean free tier — 5 hours of total storage
If your phone mic starts feeling weak, check out the Hollyland LARK A1. It's a solid first upgrade after recording a few episodes. It connects directly to your phone via USB-C or Lightning with no app, driver, or configuration required, and it includes noise cancellation built specifically for voice recording.
Note: Your phone mic is enough to start. Hardware upgrades make sense after you have published a few episodes and confirmed that podcasting is worth continuing.
Plan Your Podcast Before You Hit Record
Skipping the planning stage typically means re-recording. So make these three choices now, and you will save yourself time later.
Choose your niche and topic focus. Pick a subject you can discuss consistently for at least 20 episodes. Broad topics like “everything about life” are harder to sustain and grow than specific ones like “remote work advice for new parents.” Narrower focus makes it easier to attract a loyal audience and easier to plan individual episodes.
Decide on your episode format. Solo commentary, co-hosted conversation, and interview-based are the three most common formats. Each has different recording and editing requirements. Solo is the simplest to produce. Interviews require either a shared room or a free remote recording tool.
Set a realistic episode length. Most beginner shows benefit from staying between 15 and 30 minutes. Shorter episodes are easier to edit, more likely to be listened to in full, and far less overwhelming to produce consistently.
Choose a Format That Matches Your Setup
Format |
Best For |
Free Tool Needed |
Solo |
Single host, no scheduling dependencies |
Audacity or GarageBand |
Co-hosted (in-person) |
Two hosts recording in the same room |
Interview (remote) |
Guest-based shows with remote participants |
Riverside.fm free tier or Zencastr free tier |
Set Up Your Free Recording Software
Two free options can manage almost every beginner setup. So pick the one that fits your device and your editing style.
Option 1: Audacity (Windows and Mac — recommended for most beginners)
Download Audacity at audacityteam.org. No account required.
Open the application. Go to Edit > Preferences > Audio Settings > Recording tab > Devices and confirm your microphone input is selected.
In the bottom-left corner of the main window, set your sample rate to 44,100 Hz (44.1 kHz). This is the podcast audio standard.
Set recording channels to Mono for solo episodes. Mono halves the file size and is the correct format for a single-voice recording.
Click the red Record button. A waveform will appear as you speak; this confirms audio is being captured.
When finished, stop the recording and go to File > Export Audio.
Then click the Format dropdown menu and choose MP3. Next, set the bit rate to 128 kbps for voice-only episodes. And click the Export button.
Option 2: GarageBand (Mac and iOS only)
GarageBand comes pre-installed on all Macs and iPhones.
Open GarageBand, select Empty Project, and click Choose.
Select the Mic or Line tile, change input settings from the Details section (if needed), and click the Create button.
Use the default track for recording.
The interface is simpler than Audacity and requires less initial configuration.
When your episode is ready, use Share > Export Song to Disk and save as MP3.
Option 3: Spotify for Creators (zero-software option)
For absolute beginners who want to skip local software entirely, Spotify for Creators includes a browser-based recorder at podcasters.spotify.com. Record directly in your browser and your files are stored automatically within the hosting platform. This is the fastest path to a first episode but offers the least flexibility for detailed editing.
Record Your First Episode
The recording environment affects audio quality more than your microphone does. Follow these steps before and during your recording session.
Find a soft room: Bedrooms and walk-in closets consistently outperform kitchens and bathrooms. Fabric, carpet, and soft furniture absorb echo. Hard surfaces like tile and bare drywall create reverb that is difficult to remove in editing.
Position yourself correctly: Keep your mic 4 to 6 inches from your mouth and aim it slightly off-axis, pointed toward the corner of your lips rather than directly at them. This cuts down loud pops from hard "P" and "B" sounds.
Do a 30-second test recording first: Record yourself reading two sentences, then play it back with headphones. Listen for three issues: excessive echo, background hum from fans or appliances, and clipping (distorted peaks from speaking too loudly). Fix any issues before committing to the full episode.
Mark mistakes mid-recording: When you stumble or misspeak, clap once sharply and pause for two seconds before continuing. The clap creates a visible spike in the waveform, making every mistake instantly easy to locate during editing.
Overrecord by design: It is much easier to cut content in editing than to fill gaps. Recording 15 to 20 percent more than your target length is normal and expected, especially in early episodes.
Edit Your Episode With Free Tools
Podcast editing does not require professional skills. Focus on these five core tasks in sequence, and your episode will sound clean and complete.
Remove mistakes and dead air. In Audacity, use the Selection Tool to highlight sections you want to delete, then press the Delete key. Target pauses longer than two seconds, stumbled sentences, and any sharp noise spikes visible in the waveform.
Trim the beginning and end. Cut everything before your actual intro and everything after your sign-off. A clean start and end are the most noticeable edits a first-time listener will register.
Normalize audio levels. In Audacity, go to Effect > Volume and Compression > Normalize and set the peak amplitude to -1 dB. This brings quiet recordings up to a consistent listening volume without distorting louder passages.
Add intro and outro music (optional but effective). Stay royalty-free to avoid copyright issues. Reliable free sources include:
Free Music Archive at freemusicarchive.org
YouTube Audio Library at studio.youtube.com/channel/music
ccMixter at ccmixter.org
Import the music as a second Audacity track and use the Envelope Tool to fade it in at the start and beneath your voice.
Export the final file. File > Export Audio > Export as MP3. Use 128 kbps for voice-only episodes or 192 kbps if your episode contains background music.
Pro Tip: Descript’s free tier lets you edit audio by editing a text transcript. Delete a word from the transcript and the corresponding audio disappears with it. If waveform editing feels intimidating, Descript is a strong Audacity alternative for first-time editors.
Create Your Podcast Cover Art for Free
Before your podcast goes live, you'll need a square cover image. A 3000 × 3000 pixel image is your best choice. Apple accepts at least 1400 × 1400 pixels. Whereas Spotify accepts 640 × 640 pixels. Save it as a JPEG or PNG file under 4 MB.
Canva (canva.com) has a free podcast cover art template preset at exactly this resolution. Search “podcast cover” in the Canva template library to find numerous starting points that require no design background. Keep your cover simple, so people can read it at a glance. Use a big, bold title, skip extra text, and pick colors with strong contrast.
Cover art checklist before uploading:
-3000 x 3000 px
JPEG or PNG format
File size under 3 MB
Show title readable at 100 px wide
No copyright-protected images or fonts
Choose a Free Podcast Hosting Platform
Your podcast host does three things: stores your audio files, generates an RSS feed, and distributes your episodes to directories. You cannot submit directly to Apple Podcasts or Spotify without a host. They pull content from the RSS feed your host creates, not from files you upload directly.
Platform |
Free Tier Limits |
Best For |
RSS Feed Included |
Spotify for Podcasters |
Unlimited storage, no upload caps |
Most beginners; simplest setup |
Yes |
Buzzsprout |
2 hours/month; episodes deleted after 90 days |
Short-term testing before committing |
Yes |
Podbean |
5 hours total storage |
Slightly more detail in free analytics |
Yes |
Recommendation: Start with Spotify for Podcasters. It is the only major free tier with no storage limit and no episode expiration policy. Your RSS feed is generated automatically the moment you publish your first episode. You do not need to build or manage one manually.
To get started, create a free account at podcasters.spotify.com, upload your MP3 file, fill in your show name and episode description, and publish. Your RSS feed URL will appear in your dashboard immediately.
Submit Your Podcast to Apple Podcasts and Spotify
Apple Podcasts and Spotify together reach the large majority of podcast listeners. Prioritize these two directories before anything else.
Submitting to Apple Podcasts:
Copy your RSS feed URL from your hosting platform dashboard.
Go to podcastsconnect.apple.com and sign in with your Apple ID (create one free if needed).
Click the “+” icon and select “New Show.”
Paste your RSS feed URL and click Validate.
Apple will pull your show details directly from the RSS feed. Confirm that your show name, description, and cover art appear correctly.
Click Submit. Review typically takes 2 to 5 business days.
Submitting to Spotify (if you are not hosting on Spotify for Podcasters):
Go to podcasters.spotify.com and create a free account.
Select “Add your podcast” and paste your RSS feed URL.
Verify ownership via a confirmation code sent to the contact email listed in your RSS feed.
Complete your show profile and submit for review.
Note: If you are already hosting on Spotify for Podcasters, your podcast is automatically listed on Spotify. You only need to separately submit your RSS feed to Apple Podcasts and any other directories.
Additional directories worth submitting to (all free, all RSS-based):
Amazon Music / Audible at music.amazon.com/podcasts/submit
iHeartRadio at iheartradio.com/vip/affiliate-podcasts
Pocket Casts at pocketcasts.com/submit
YouTube Music via RSS import through your hosting platform
Publish Consistently Before Worrying About Growth
The most valuable free investment you can make in your podcast is time and repetition. No directory ranking, algorithm tactic, or microphone upgrade replaces a consistent publishing schedule.
Before submitting to directories, publish at least 3 to 5 episodes. Listeners who discover your show through a search result or recommendation are significantly more likely to subscribe if there is a back catalog waiting for them. A single episode at launch can feel unfinished. Three episodes signal commitment.
Once you submit, set a publishing cadence you can realistically sustain. For most beginners, bi-weekly (every two weeks) is more sustainable than weekly. Six months of bi-weekly episodes consistently outperforms a burst of weekly releases followed by a two-month gap.
For each new episode, write brief show notes directly inside your hosting platform’s dashboard. Include a one-paragraph episode summary, two or three relevant keywords, and timestamps for any major topic shifts. Show notes are indexed by podcast apps and help new listeners decide whether an episode fits what they are looking for. They take about ten minutes to write and meaningfully improve discoverability over time.
Can I really start a podcast with just my phone?
Yes. Smartphone mics are sufficient for early episodes, particularly in a quiet room. Voice Memos on iOS and the default recorder app on Android both produce usable audio. When you are ready to improve quality without complicated setup, the Hollyland LARK A1 connects directly to your phone via USB-C or Lightning with no additional apps or drivers needed.
Is free podcast hosting actually free - what’s the catch?
Most free tiers limit monthly upload hours or total storage, and some insert advertising on your episode page. Spotify for Podcasters is the exception: unlimited storage, no enforced ads, and built-in Spotify distribution. For most beginners, it is one of the free hosting options currently available.
How long should my first podcast episode be?
You can get started by recording 15 to 30 minutes of your first episode. You will have enough time to share something people actually care about. You will also finish editing without feeling like it takes forever. More listeners may finish the episode, which can help your podcast grow.
Do I need a website to start a podcast?
No. Every major hosting platform generates a public podcast page with a shareable URL. You can always make a website after your podcast starts growing. You don't need one at launch, and podcast apps won't ask for it.
How do I get my podcast on Apple Podcasts?
Publish at least one episode through your hosting platform, then copy your RSS feed URL. Go to podcastsconnect.apple.com, sign in with an Apple ID, paste the URL, validate, and submit. Approval typically takes 24 hours to a few days.
It doesn't require spending bucks to have your first podcast. Record and edit episodes with Audacity or GarageBand. Host your show on Spotify for Podcasters and create an RSS feed. Then submit your podcast through Apple Podcasts Connect. Canva helps you make clean cover art in just minutes. Record a quick 10-minute test episode. Don't stress about making everything perfect right away. Every episode teaches you something new and builds your confidence.
