Getting your podcast live involves two distinct phases that most beginners conflate: hosting and distribution. You need a hosting platform to store your audio and generate an RSS feed, and you need to submit that feed to directories like Spotify and Apple Podcasts so listeners can find you. This guide walks through every step, from preparing your audio file to confirming your episode is live across major platforms.
How to Post a Podcast: Step-by-Step Guide to Hosting and Distribution
What Does “Posting a Podcast” Actually Mean?
“Posting a podcast” is actually two separate actions that happen in sequence. First, you upload your episode to a podcast hosting platform such as Buzzsprout, Podbean, or Spotify for Podcasters. That platform stores your audio file and generates an RSS feed, which is a structured URL that describes your show and its episodes.
Second, you submit that RSS feed URL to podcast directories like Apple Podcasts, Spotify, and Amazon Music. The directories read your feed and make your episodes searchable to listeners. You only submit once per directory. After that, every new episode you upload to your host appears automatically across those platforms.
Podcast Host |
Podcast Directory |
What it does |
Stores audio and generates RSS feed |
Distributes your feed to listeners |
Examples |
Buzzsprout, Podbean, Transistor |
Apple Podcasts, Spotify, Amazon Music |
How often you use it |
Every episode |
Once per directory (setup only) |
Step 1 — Record and Prepare Your Episode Audio
Before you upload anything, your audio file needs to meet a minimum quality standard. Directories will accept low-quality audio, but listeners will not.
Have the following ready before you move to your hosting dashboard:
Record in a quiet space. Background noise is the most common reason new podcasts lose listeners early. A treated room, a closet, or a dedicated recording corner all work. If you record interviews or remote guest sessions, a wireless microphone makes a significant difference. The Hollyland LARK MAX 2 delivers 48 kHz / 32-bit Float audio with AI Noise Cancellation, giving you clean, studio-quality recordings regardless of your environment.
Export as MP3. Use 128 kbps for solo speech episodes, or 192 kbps for interview or music-heavy content. MP3 has the broadest compatibility across directories and hosting platforms.
Edit your audio. Trim silence from the start and end, remove long pauses, and normalize levels to around -16 LUFS. Free tools like Audacity or GarageBand handle this without any technical expertise.
Name your file consistently. A convention like show-name-ep001.mp3 keeps your archive organized as the episode count grows.
Step 2 — Prepare Your Episode Assets
Most upload errors and directory rejections happen because required metadata is missing or incorrectly formatted. Have these assets ready before you open your hosting dashboard:
Episode title: Clear, descriptive, and searchable. Include the guest name or core topic, not just “Episode 12.”
Show notes and episode description: A summary of 150 to 500 words. Apple Podcasts displays roughly the first 250 characters in search results, so lead with the most relevant information.
Cover art: 3000x3000 pixels, JPG or PNG, under 500 KB. Both Apple Podcasts and Spotify enforce these specs strictly. Use a solid background with legible text since thumbnails display at very small sizes.
Episode number and season tag: Optional but recommended. Numbering helps directories sort and surface your content correctly.
Explicit content flag: If your episode contains profanity or mature content, mark it explicitly. Failure to do so can result in removal from directories.
Note: Apple Podcasts validates cover art strictly. If your image is the wrong dimensions or exceeds the file size limit, your submission will be rejected, often without a clear explanation. Verify your artwork before uploading.
Step 3 — Choose a Podcast Hosting Platform
A podcast hosting platform is not optional. Apple Podcasts and Spotify both require an RSS feed, and only a hosting platform generates one. Your host also stores and serves your audio files, meaning every listener’s app pulls the episode from your host’s servers when they press play.
Here are five widely used options:
Platform |
Best For |
Free Tier |
Key Feature |
Buzzsprout |
Beginners |
Yes (limited storage; episodes expire) |
Intuitive dashboard with guided onboarding |
Spotify for Podcasters |
Zero-budget start |
Yes (fully free, no episode limits) |
Built-in Spotify distribution and analytics |
Podbean |
High-volume publishers |
Yes (limited storage) |
Unlimited storage on paid tiers |
Transistor |
Teams and multi-show operators |
No (14-day trial) |
Multiple shows under one account |
Captivate |
Data-driven podcasters |
No (7-day trial) |
Advanced analytics and growth tracking |
How to decide:
If keeping costs at zero is the priority, start with Spotify for Podcasters. It is fully free with no episode caps.
If you want the smoothest onboarding experience, Buzzsprout walks you through setup step by step.
If you manage more than one show or work with a co-host team, Transistor or Captivate are stronger long-term fits.
Your choice now is not permanent. Most platforms support podcast migration, which forwards your RSS feed from one host to another automatically so your directory listings stay intact.
Step 4 — Upload Your Episode to Your Hosting Platform
The upload process is consistent across most major hosts. With your account created and assets ready, follow these steps:
Log in to your hosting dashboard and navigate to the episode creation area, usually labeled “New Episode” or “Add Episode.”
Upload your MP3 file. Most platforms accept files up to 200 to 500 MB. Processing typically takes one to three minutes.
Enter your episode title exactly as you prepared it in Step 2.
Paste your show notes and description into the episode description field.
Set the episode type. Select from: Full (standard episode), Trailer (used to introduce a new show), or Bonus (supplementary content). Choose “Full” for regular episodes. This option would be available depending on the platform.
Add season and episode numbers if you use a numbered format.
Upload or confirm cover art. Some hosts inherit the show-level artwork by default; others allow unique art per episode.
Apply the explicit content tag if applicable.
Preview the episode if your platform offers that option. Confirm the title, description, and audio file are all correct.
Save as draft. Do not publish yet. Publishing is covered in Step 6.
Once you save the episode, the RSS feed entry is created in the background. When you publish, the feed updates and directories pull the new entry automatically.
Step 5 — Submit Your Podcast to Directories
This step only happens once, when you launch a new show. After publishing at least one episode, your RSS feed is live and ready to submit. Every subsequent episode you publish will appear on all approved directories with no further action from you.
Before you start: Find your RSS feed URL in your hosting platform’s dashboard settings, usually labeled “RSS Feed” or “Podcast Feed.”
Go topodcastsconnect.apple.com and sign in with your Apple ID. Note that your Apple ID must have a valid credit card on file, or you won't be able to log in, even though listing is free.
Click the Add (+) button and select "New Show," then choose "Add a show with an RSS feed."
Paste your RSS feed URL, verify ownership, and submit for review.
Approval typically takes anywhere from a few minutes to several days.
Spotify for Creators
Go tocreators.spotify.com and log in. (The old podcasters.spotify.com address now redirects here.)
If you are not using Spotify's own hosting, select the option to add an existing podcast via RSS feed.
For those who want to get their RSS URL, go to Settings > Availability, and click the “Turn On” button under RSS Distribution.
Amazon Music / Audible
Visitamazon.com/podcasters.
Submit your RSS feed URL and complete the required form.
Allow three to five business days for review.
YouTube Music
Go to YouTube Studio atyoutube.com/podcasts. (The old Google Podcasts Manager has been shut down and no longer works.)
Choose to submit your RSS feed and verify ownership via the emailed code.
Select which episodes to import. Note that YouTube automatically converts each audio episode into a video with a static image or waveform.
iHeartRadio
Go to iHeartRadio's podcast submission page and submit your RSS URL along with your show information.
Review times can extend up to two weeks.
Pro Tip: Some hosting platforms, including Buzzsprout and Spotify for Podcasters, offer one-click or automatic distribution to multiple directories from within your dashboard. If your host supports this, use it. It saves time and reduces the chance of submission errors during launch.
Step 6 — Publish or Schedule Your Episode
Once your episode is uploaded and all metadata is filled in, you have two options: publish immediately or schedule for a future date and time.
Publishing immediately sets the episode live right away. Your RSS feed updates within minutes, and directories that have already approved your show will pull the new episode, typically within one to a few hours.
Scheduling in advance is the better long-term approach. It lets you record multiple episodes in batches and release them on a consistent schedule without requiring manual action each time. Set a specific date and time, and your hosting platform publishes automatically.
Best practices for this step:
Pick a consistent release day. Listeners build habits around your schedule. Shifting release days disrupts that behavior and can affect your directory ranking signals.
Schedule at least 24 hours in advance when possible. This gives directory caches time to update before your audience expects the episode.
Review your draft one more time before scheduling. Reading your show notes after a short break will catch errors you missed immediately after writing them.
No re-submission to directories is required. Once your show is approved, new episodes appear automatically across all connected directories. You never need to revisit Apple Podcasts Connect or Spotify for Podcasters for routine episode releases.
How to Verify Your Episode Is Live
After publishing, confirm the episode is accessible before you share it anywhere:
Check your hosted episode URL. Your hosting platform generates a direct playback link for each episode. Open it and confirm the audio file loads and plays correctly.
Search your podcast name on Spotify and Apple Podcasts. New episodes typically populate on Spotify within one to a few hours and on Apple Podcasts within a day.
Validate your RSS feed using a free tool like Podba.se Feed Validator to surface any formatting errors or missing required tags.
If the episode has not appeared within 72 hours, log in to each directory’s dashboard and check for error messages. Common causes include mismatched RSS URLs, failed cover art validation, or a missing explicit content flag.
How long does it take for a podcast to appear on Apple Podcasts after submitting?
Apple Podcasts typically takes 24 to 72 hours to review and approve a new show. Once approved, future episodes appear automatically when your RSS feed updates, usually within a few hours of publishing. If your show has not appeared after 72 hours, log in to Apple Podcasts Connect and check for submission errors or validation issues.
Do I need a separate hosting platform if I use Spotify for Podcasters?
No. Spotify for Podcasters functions as both a free hosting platform and a distributor. It stores your audio, generates your RSS feed, and distributes episodes to Spotify automatically. You can also submit to other directories through their dashboard, making a separate host unnecessary for podcasters who want a fully free publishing setup.
Can I post a podcast episode directly to Spotify or Apple Podcasts without a host?
No. Both platforms require an RSS feed URL to ingest your content, and only a podcast hosting platform generates that feed. There is no direct audio file upload option in either directory. A hosting platform is a required part of the workflow, regardless of which directories you want to reach.
What audio file format should I upload?
MP3 is the universal standard across all major hosting platforms and directories. Use 128 kbps for solo speech episodes and 192 kbps for interview-style or music-heavy content. Most hosts also accept M4A and WAV, but MP3 ensures the broadest compatibility. Always export at the correct bitrate from your original file to avoid quality loss from re-encoding.
How often should I post new podcast episodes?
Consistency matters more than frequency. Weekly or bi-weekly schedules tend to support better listener retention than daily or irregular publishing. Start with a cadence you can sustain long-term, then increase output as your production process becomes more efficient. Use your hosting platform’s scheduling feature to queue episodes in advance and protect your release consistency.
What to Do Next
Once your show is live, posting future episodes is straightforward. Directory submission is a one-time setup step. From here on, publishing a new episode only requires uploading your file (Step 4) and publishing or scheduling it (Step 6). No re-submission to any directory is ever needed.
To keep building from this foundation, consider focusing on writing stronger show notes to improve search visibility, tightening your recording workflow for better audio from the first take, or developing a consistent content calendar to grow and retain your audience. Each of these is a natural next step once the publishing workflow is running reliably.
