Ready to spin your own DJ podcast? It is a fun way to grow loyal listeners and share your music journey. You also get to build your name beyond live performances. Still, pressing record is only the beginning. You need clean audio, the right podcast style, and legal music. You also want platforms that keep your episodes online. Don't worry. This guide explains everything in the right order.
What Makes a DJ Podcast Different from a Standard Podcast
A standard podcast is built around spoken word: conversation, storytelling, or commentary. A DJ podcast is built around recorded music, which changes nearly every downstream decision you face.
The music content creates copyright exposure that spoken podcasts never encounter. The file sizes are larger, pushing some hosting platforms past their limits. The audience expects a specific audio experience. They want not just an interesting voice, but a seamless, well-mixed set that reflects your taste and skill.
These details can change where you publish and what equipment you need. They also affect editing, exporting, and sharing each episode. Learning this early can save you from removed episodes and the wrong publishing choice.
Choose Your DJ Podcast Format Before You Buy Anything
Your format choice is one of the most important decisions you will make before spending money or recording your first episode. It determines your gear list, your copyright exposure, and the audience you can realistically build.
There are three viable formats for a DJ podcast.
1. Pure Mix / Set Recording
You record a DJ set and publish it as-is. There is no spoken intro, no commentary, no interview segments. The mix is the episode.
This format is the easiest to produce and the most natural starting point for working DJs. But it does carry the highest copyright risk on mainstream podcast platforms. Mixcloud is purpose-built for this format, and most established DJ podcast series in house, techno, drum and bass, and similar genres operate there.
2. Mix + Hosted Commentary
You record the mix, then record a spoken intro and outro. Some DJs add brief commentary between tracks or segments, typically 60 to 90 seconds at each end of the episode.
This style gives people more reasons to remember your name. Your audience connects with you as a person, not only as a DJ. It increases the production setup slightly because you now need a microphone, but the copyright situation remains the same as the pure mix format.
3. Interview + Mix Hybrid
Invite a guest DJ, producer, or artist to join your show. Include a full mix or a shorter mix during the conversation. This style is similar to Resident Advisor Podcast or Rinse FM. Guest episodes often reach more people because guests share them with their followers. You will need extra planning, clear voice recordings, and good scheduling before each episode.
Format Comparison
Format |
Equipment Needed |
Copyright Risk |
Audience Type |
Pure Mix |
DJ controller/CDJ, audio interface, DJ software |
High on mainstream platforms |
Genre-specific listeners |
Mix + Commentary |
Above + microphone |
High (same as above) |
Genre fans + personal brand followers |
Interview + Mix |
Above + interview mic setup |
High for mix content; low for spoken segments |
Broadest reach; community-driven |
Pick your format before you purchase anything else. If you start with a pure mix format, you can add commentary or interviews later. Starting in the wrong direction costs time and money.
The Equipment You Actually Need to Get Started
You can split your DJ podcast equipment into two main groups. One group records your DJ mix. The other records your voice. Everyone needs the first group. The second depends on the podcast format you picked earlier.
Mix Capture Gear
DJ Controller or CDJ/Mixer Setup: This is the main equipment that creates your DJ mix. A DJ controller, such as the Pioneer DDJ-FLX6 or DDJ-1000, sends MIDI commands to DJ software running on your computer. Its built-in sound card then plays the audio. CDJs and standalone mixers read music directly from USB drives. They process the sound inside the unit and send the master output straight to speakers without an external audio interface.
Audio Interface Required if you are running a standalone mixer with an analog output into a computer for recording. An interface like the Focusrite Scarlett 2i2 converts the analog signal from your mixer into a clean digital recording. If you are using a controller with a built-in USB soundcard and DJ software, you may already have everything you need.
DJ Software Serato DJ Pro, rekordbox, and Traktor Pro all include built-in recording functions. All three can capture a high-quality WAV file of your mix internally, without any third-party software. This is the cleanest and most reliable recording method for most DJs.
Headphones Essential for monitoring your mix during recording. What you already use for regular DJing works fine here.
Spoken Audio Gear (For Commentary or Interview Formats)
If your format includes any spoken content, microphone quality will directly affect how professional your podcast sounds. A clean mix paired with a thin or noisy voiceover undermines the overall production value.
For DJs recording commentary at home or conducting in-person artist interviews, the Hollyland LARK MAX 2 is worth considering. Its wireless design lets you move freely without being tethered to a desk, which is useful if you want to speak while you are near your gear. The 32-bit Float internal recording captures audio at a safe level regardless of input gain, meaning you will not ruin a take by accidentally peaking. The built-in AI Noise Cancellation handles the kind of background hum and room noise that home studio environments typically produce.
A standard condenser microphone is also a good choice in a treated studio. It fits best when your recording space stays the same. You only need this equipment for podcasts with regular talking. If your show is only DJ mixes, you can leave it out completely.
Software for Editing and Hosting
Audacity (free, cross-platform): More than capable for trimming, normalizing, and basic editing
GarageBand (free, Mac): Clean interface, useful for adding intro and outro music beds
Adobe Audition: Professional-grade, subscription-based; well suited to multitrack interview formats
Logic Pro: Best option if you are already invested in Apple’s ecosystem and want finer control
Note: You do not need all of these tools. Pick one editing application and get familiar with it. You can complete most DJ podcast editing tasks in Audacity without paying anything.
How to Record Your DJ Mix fora Podcast
Recording a clean mix is the most important technical step in the entire workflow. A poorly recorded set cannot be fully salvaged in editing. The three methods below cover the majority of DJ setups.
Method 1: Internal Software Recording (Recommended)
All three major DJ platforms, Serato DJ Pro, rekordbox, and Traktor Pro, include a built-in recording function. This method captures the mix directly from the software’s master output, bypassing room acoustics and cable noise entirely.
Open your DJ software and locate the recording panel (labeled “REC” in Serato and rekordbox Performance mode, or “Audio Recording” in Traktor).
Set the recording level so peaks fall around -6 dBFS. This leaves headroom for editing and mastering later.
Record a 2-minute test mix and listen back before your full session. Confirm the levels are correct and there is no clipping.
Record your full mix in WAV format, not MP3. WAV preserves audio quality through the editing stage.
Save the file with a clear name, for example “ShowName_EP001_RAW.wav”.
Method 2: Routing a Hardware Mixer to an Audio Interface
This method applies to DJs using vinyl, CDJs, or standalone mixers not connected to DJ software.
Connect the master output (RCA or XLR) of your mixer to the input of your audio interface.
Connect the audio interface to your computer via USB.
Open your recording software and select the audio interface as the input source.
Set recording levels so peaks hit -6 dBFS. Adjust input gain on the interface until the signal is consistent.
Press record, play your set, and monitor levels throughout. Stop and check for clipping before committing to a full recording.
Record in WAV at 24-bit / 48 kHz minimum.
Method 3: USB Audio Output from a DJ Mixer
Several modern mixers from Pioneer DJ and Allen and Heath support direct USB audio recording to a computer without a third-party audio interface.
Connect your mixer to your computer via USB.
Set the mixer as the audio input source in your recording software.
Confirm the mixer’s USB send level is set correctly in the mixer’s system menu.
Follow the same level-setting and WAV recording process as Method 2.
Pro Tip: Always run a test pass before your full recording session. Even a 3-minute test mix protects you from discovering a clipping issue or a disconnected cable only after a 90-minute recording.
Edit and Prepare Your Audio for Publishing
Editing a DJ mix for podcast release is not the same as mastering. Your goal is to clean the recording, balance the levels, and add any spoken elements. Keep the workflow focused.
Trim dead air from the start and end. Cut any silence before the first track and after the last. Leave one to two seconds of lead-in so the mix does not start abruptly.
Set your final audio to -14 LUFS before uploading to Spotify. Pick -16 LUFS if your podcast is going on Apple Music. Audacity includes a free Loudness Normalization effect for this task.
Insert your voiceover intro and outro (if applicable). Place the intro before the first track and the outro after the last. Match the spoken segment volume to the mix volume before exporting.
Apply light EQ and compression if needed. A gentle high-pass filter cutting below 60 Hz and a limiter set to -1 dBTP will tighten up a thin or inconsistent mix. Avoid heavy processing; preserve the mix’s natural dynamics.
Export as MP3 at 320 kbps. Music content requires a higher bitrate than speech-only podcasts, which typically use 128 kbps. At 320 kbps, a 60-minute mix will be approximately 140 MB.
Note: If your mix was recorded cleanly at the right levels, steps 1 and 2 may be all you need before exporting. Do not over-process.
Copyright Rules You Must Understand Before You Publish
Many DJ podcasters wish they had learned this before releasing their first episode. Uploading a mix with commercial songs copies protected recordings. Most podcast platforms do not have licenses for that music. Copyright detection systems can quickly find those tracks after upload. Your episode may disappear, or your entire podcast could be removed.
What this means in practice:
Apple Podcasts and Spotify (via standard podcast hosts): These platforms do not license recorded music. DJ mixes containing commercial tracks uploaded here are at significant risk of removal. If your show has spoken content only, or uses original and royalty-free music, you are fine.
Mixcloud: Mixcloud has licensing agreements with major record labels and music publishers for streaming in many countries. The platform is made for DJ mixes, making it one of the safest mainstream places to stream recorded sets legally.
SoundCloud: It falls between the other options. Many DJ mixes stay online for a long time. Still, Content ID claims can mute songs or remove uploads. Earning money from this content is also limited.
Audiomack: Similar to SoundCloud. Popular with hip-hop and electronic DJ audiences, but without licensing protection for commercial music.
Platform |
DJ Mix Policy |
Mixcloud |
Licensed for DJ mixes; uploads are permitted and protected |
SoundCloud |
Partial tolerance; Content ID claims are common |
Audiomack |
Partial tolerance; popular for specific genres |
Apple Podcasts |
No music license; mixes at risk of removal |
Spotify |
To share your podcast on every major directory without copyright problems, stick to original or royalty-free music. You can also get synchronization and master licenses from the copyright owner and record label. Another option is the two-platform method explained in the next section.
Choose the Right Hosting Platform for a DJ Podcast
Hosting platform selection is where your format decision and copyright reality converge into a practical choice. There is no single platform that works for every DJ podcast, but there is a right platform for each format type.
Platform |
Music Licensing |
RSS Feed |
Best For |
Mixcloud |
Yes (licensed) |
No standard RSS |
Pure mix distribution; established DJ audience |
SoundCloud |
Partial |
Yes (via RSS) |
Mix hosting with moderate distribution |
Audiomack |
Partial |
Limited |
Hip-hop and electronic DJ audiences |
Buzzsprout / Podbean |
No |
Yes |
Talk+mix hybrid with original or licensed music only |
Spotify for Creators |
No - Commercial music is not covered by a blanket license. You must use audio with the proper permissions or licenses. |
Limited but Managed - Offers basic podcast feed support, but some settings and distribution options are limited by the platform. |
Podcasts with spoken content, interviews, or audio made with original or properly licensed music. |
The two-platform strategy is the most practical approach for DJs who want both music distribution and broad podcast directory placement.
Host your full mix on Mixcloud, where it is protected by PRO licensing and discoverable by the DJ community. Separately, create a companion podcast episode on a standard host such as Buzzsprout, Podbean, or Spotify for Podcasters. This companion episode includes your introduction, song comments, show notes, and a short clip from the mix. You can share it on Apple Podcasts and Spotify without the same copyright concerns as a full DJ mix.
This setup lets you build a dedicated presence on Mixcloud while also growing a listener base through standard podcast directories. Over time, the two audiences cross-pollinate and reinforce each other.
Publish and Distribute Your First Episode
Once your audio is ready and your hosting accounts are set up, follow this launch sequence:
Create show artwork. The standard specification is 3000x3000 pixels, saved as a JPG. Use clean visuals with legible text at small sizes, since artwork displays as a small thumbnail in most apps.
Write show notes with a full tracklist. Every episode should include the artist name, track name, and label for each song in the mix. This builds listener trust and significantly improves the episode’s searchability.
Name episodes consistently. A format like “Show Name EP001 - Genre/Mood - Date” makes your back catalog easy to navigate and helps new listeners find relevant episodes.
Upload to your chosen host and generate your RSS feed. Standard podcast hosts create this automatically. Mixcloud does not generate a standard RSS feed, which is why a two-platform setup is recommended for directory distribution.
Submit your RSS feed to podcast directories. Apple Podcasts, Spotify, and Pocket Casts each require a one-time submission. After that, new episodes appear automatically with each upload.
Share the episode link across your social channels on launch day. Instagram, Facebook DJ groups, and Reddit communities like r/DJs and genre-specific subreddits are strong starting points.
How to Grow Your DJ Podcast Audience
Building a DJ podcast from the ground up takes time without outside promotion. These practical ideas are made for podcasts built around music.
Publish on a consistent schedule. Bi-weekly performs better than monthly for audience retention. Listeners need a reliable publishing rhythm to form a habit around your show.
Cross-promote with featured artists and guest DJs. If you feature someone’s music or have them as a guest, tag and message them directly when the episode goes live. Most artists will share content that highlights their work.
Build a community around the show. A Discord server or dedicated Instagram account gives listeners a place to engage between episodes and creates a feedback loop that helps you improve the show over time.
Optimize episode titles and show notes for search. Include genre keywords, mood descriptors, and artist names in every episode title and description. “Deep House Mix March 2026” will be found; “Episode 12” will not.
Repurpose mix segments as short-form video. Export a 30 to 60-second clip with a waveform or visualizer overlay for Instagram Reels or TikTok. Short video drives audio listeners more effectively than audio-only social posts.
Engage in DJ forums and communities. r/DJs, the DJ TechTools community, and genre-specific Facebook groups are active with listeners who are already looking for new shows to follow.
Can I put my DJ mixes on Spotify?
Spotify removes DJ mixes that contain copyrighted music without proper permission. Uploading those mixes through regular podcast hosts can also lead to removal. If your music is not cleared, publish the full mix on Mixcloud instead. You can also release DJ mixes on Spotify through an approved music distributor after getting permission for every track in the mix.
Do I need a music license to publish a DJ podcast?
Most of the time, yes. Publicly sharing a recorded DJ mix copies protected music. Mixcloud pays for streaming rights through its music licensing agreements. Those rights do not include offline listening or downloads. Downloadable podcast apps need separate permission from copyright owners and record labels. You can also avoid this issue with original or royalty-free music.
What’s the best software to record a DJ mix?
For most DJs, the recording function built into their existing software, Serato DJ Pro, rekordbox, or Traktor Pro, is the best option. It captures a clean digital signal directly from the software output with no extra equipment needed. For hardware-only setups, Audacity paired with an audio interface is a free and reliable alternative.
How long should a DJ podcast episode be?
It depends on genre and format. Club and festival sets typically run 60 to 90 minutes. Mixtape-style episodes work well at 30 to 45 minutes, especially for new shows still building an audience. Mix-plus-commentary episodes often land between 45 and 75 minutes. Start with a consistent length and adjust based on listener feedback.
Do I need professional equipment to start?
No. A DJ controller you already own, the built-in recording function in your DJ software, and free editing tools like Audacity are enough to publish a first episode. Professional equipment improves quality over time, but your mix selection and publishing consistency matter more to listeners in the early stages.
Starting your DJ podcast gets easier when you follow these steps. First, choose your format, then pick your gear and record. Next, edit your episode and share it with listeners. Your first episode does not need to sound flawless. Just get it published and let yourself improve. Pick a format from this guide and try recording. Make a 30-minute test mix with your current setup. Upload it to Mixcloud and see what happens. Trust me, you will learn a lot from trying. Once episode one is live, keep the momentum going. A steady posting schedule beats chasing perfect results forever.
