Starting a video podcast feels overwhelming until you break it into a clear sequence. The decisions are interconnected: your format determines your gear, your gear shapes your software choice, and your software determines your publishing workflow. This guide walks through every stage in order, from concept to distribution, so you can move forward with confidence rather than stall in endless research.
How to Start a Video Podcast: A Complete Step-by-Step Guide
What Is a Video Podcast (and Why It’s Worth Starting)
A video podcast is a recorded show that combines audio and video, distributed through an RSS feed to podcast directories such as Apple Podcasts and Spotify, and typically published simultaneously on YouTube. Unlike a traditional YouTube channel, a video podcast is built on an episodic, audio-forward structure where the content holds value even when listeners never watch a single frame.
The distribution model is what distinguishes it. A YouTube channel lives exclusively on YouTube. A video podcast reaches every platform that accepts an RSS feed, including Apple Podcasts, Spotify, Amazon Music, and dozens of third-party podcast apps, with YouTube serving as an additional discovery layer on top.
Audience behavior is driving the format’s growth. Spotify has reported significant year-over-year increases in video podcast consumption as it expanded native video support. YouTube now accepts podcast RSS feeds and maintains dedicated podcast pages. Audiences increasingly expect to choose how they consume a show: watch the full episode on a screen, listen through earbuds on a commute, or catch a 90-second clip on a short-form platform.
For creators, video adds trust signals that audio alone cannot deliver. Watching someone speak builds familiarity faster than listening, which strengthens audience loyalty over time. It also multiplies repurposing potential: one recorded session produces a YouTube video, an audio podcast, social media clips, and written show notes simultaneously.
Plan Your Video Podcast Before You Record Anything
Most beginner podcasters skip planning and jump straight to equipment research. That shortcut is exactly why so many shows publish a handful of episodes and then quietly disappear. The four decisions below take an hour to work through but eliminate the most common causes of early abandonment.
Choose Your Niche and Target Audience
Specificity matters far more than broad appeal at launch. “A podcast about business” competes with thousands of established shows. “A podcast for independent florists on the business side of shop ownership” is findable, shareable, and builds a loyal audience faster. Define the exact person you are creating for and the specific problem or interest you are addressing. When that foundation is clear, every downstream decision (from episode topics to guest selection) becomes straightforward rather than paralyzing.
Decide Your Show Format
The four primary formats are solo commentary, interview, co-host, and panel. Each carries a different equipment profile. A solo show requires one microphone and one camera. An interview format requires a separate microphone for each participant and a reliable method for capturing each audio source cleanly, which is where wireless microphone systems become particularly relevant. Choose the format that fits both the content you want to make and the practical constraints of your current setup. Starting with a simpler format and building in complexity over time is the smarter path.
Plan Episode Length and Cadence
Episode length should follow content density, not an arbitrary number. Interview-format episodes naturally run longer (45 to 90 minutes) because conversation develops gradually. Solo commentary episodes work better in tighter windows (15 to 30 minutes) where every minute is intentional. Cadence matters more than length: a consistent weekly or bi-weekly publishing schedule builds listener expectation and algorithmic momentum. Set a cadence you can sustain for at least six months before you plan your launch.
Name Your Show and Define Your Branding
Your show name should be clear, specific, and easy to say out loud. Clever wordplay that obscures the topic filters out potential listeners before they ever click play. Once the name is finalized, create cover artwork at a minimum of 3000 x 3000 pixels in JPEG or PNG format. Both Apple Podcasts and Spotify require artwork at that resolution. Establish your visual identity, including color palette, typography, and thumbnail style, as early as possible because it travels with the show across every platform you publish on.
Pre-Production Checklist - [ ] Niche and target audience defined - [ ] Show format chosen (solo / interview / co-host / panel) - [ ] Episode length and publishing cadence set - [ ] Show name finalized - [ ] Cover art created at 3000 x 3000 px (JPEG or PNG)
Video Podcast Equipment You Actually Need
Equipment research generates more anxiety than almost any other part of starting a video podcast. The options are numerous and the price ranges are wide. What follows organizes gear by category, offers a beginner and professional option in each, and is direct about what is genuinely necessary versus what is an optional upgrade.
Microphone: Your Most Important Investment
Audio quality matters more than video quality. Viewers will tolerate slightly soft or grainy footage if the voice is clear, but the majority will stop watching within the first minute if audio sounds muffled, echoey, or distorted. This makes the microphone the first and most important item in your equipment budget at every tier.
Two types work well for video podcasting. USB desktop condenser microphones plug directly into your computer, require no additional hardware, and suit static solo formats where having the microphone visible in frame is an acceptable visual element. Wireless lavalier microphones clip to clothing, remove visible cables from the frame, and give you freedom of movement, making them well-suited to both polished studio setups and interview formats where multiple participants each need a dedicated audio source.
For wireless lavalier use at the professional tier, the Hollyland LARK MAX 2 is a standout recommendation. It records at 48 kHz with 32-bit float processing, capturing audio without clipping regardless of sudden volume spikes, which is a significant advantage during live interviews. AI noise cancellation actively strips background noise from the signal in real time. The included OWS open-wax earphones allow wireless audio monitoring without a physical cable connecting you to the recorder. A built-in backup recording feature stores audio directly on the transmitter as an on-device safety copy, which is invaluable when a primary recording drops mid-interview. For a studio-based video podcast or any show with regular guests, the LARK MAX 2 handles the full range of recording scenarios cleanly.
At the beginner tier, the Hollyland LARK A1 is a plug-and-play wireless microphone built for creators recording directly to a smartphone. It connects via USB-C or Lightning depending on your device, requires no configuration, and applies three-level intelligent noise cancellation to keep voice audio clear even in imperfect environments. For anyone starting on a phone before building out a full camera setup, the LARK A1 is a low-friction, high-value entry point.
Camera
Your smartphone is a legitimate starting camera. The iPhone 13 and newer and the Google Pixel 7 and newer record high-quality video fully suitable for a video podcast. Mount it at eye level on a tripod or phone stand and you have a capable setup without additional cost.
The step-up option is a mirrorless or DSLR camera with clean HDMI output. The Sony ZV-E10 and Sony A6400 are popular among video podcasters for their image quality and compatibility with capture cards for direct computer recording. For solo formats, a single front-facing camera covering a medium shot is sufficient. Interview formats benefit from multiple camera angles, though that addition can wait until the show is established and running consistently.
Lighting
A properly lit subject on a modest camera will always outperform a poorly lit subject on an expensive one. Natural light from a window works well for beginners: position your face toward the window rather than sitting with the window behind you, which creates silhouetting.
For a step up, a single key light placed at roughly 45 degrees to your face and slightly above eye level produces a clean, dimensional result. Ring lights are the most common beginner option because they mount directly behind the camera and minimize facing shadows. A key light paired with a diffusion softbox delivers a noticeably more professional look with minimal added complexity. A three-point lighting setup (key, fill, and backlight) is the standard for interview formats where production quality is a visible part of the brand identity.
Backdrop and Recording Environment
Your background competes with your face for viewer attention and should be either intentionally designed or intentionally neutral. A clean bookshelf or furnished room corner reads as natural and professional without requiring any additional investment. A fabric or paper roll backdrop removes the environment entirely and keeps focus on the subject. Virtual backgrounds work as a backup option but often produce visible edge artifacts around hair that appear noticeably artificial on most cameras.
Acoustic treatment matters as much as visual backdrop. Echo and room reverb are problems that microphones cannot fully compensate for after the fact. Soft materials absorb reflected sound: thick rugs, curtains, upholstered furniture, and acoustic foam panels all reduce reverb time in a room. Recording in a small, furnished space (or inside a walk-in closet with hanging clothes on both sides) consistently produces better audio than recording in a large, sparse room regardless of microphone quality.
Optional but Helpful Gear
A capture card such as the Elgato Cam Link 4K connects a mirrorless camera to your computer via USB so it functions as a high-quality webcam within your recording software. A teleprompter app on a secondary device helps solo hosts maintain eye contact with the lens during scripted segments. An external monitor shows your recording preview in real time so you can verify framing and exposure before you begin. None of these items are required to launch; introduce them when a specific limitation in your existing setup makes them the logical next investment.
Equipment Comparison: Beginner vs. Mid-Range vs. Professional
Category |
Beginner |
Mid-Range |
Professional |
Microphone |
Hollyland LARK A1 |
Hollyland LARK MAX 2 |
Hollyland LARK MAX 2 + desktop condenser |
Camera |
Smartphone |
Webcam (Logitech Brio) or entry mirrorless |
Mirrorless camera + capture card |
Lighting |
Window light or ring light |
Ring light + softbox |
3-point lighting kit |
Software |
OBS Studio (free) |
Descript or Riverside.fm |
Adobe Premiere Pro / Final Cut Pro |
Set Up Your Recording Space
Having the right equipment is only half the equation. How you configure the room determines whether that equipment reaches its potential or wastes it. The setup steps below apply at any budget level.
Select the right room. Small rooms with soft furnishings absorb sound far better than large, open spaces. A furnished home office, bedroom, or spare room with carpet and curtains is an effective starting environment. If your best available option has hard walls or tile floors, add soft materials before recording: a thick rug on the floor and a heavy curtain between you and the nearest reflective wall make an audible difference.
Treat the acoustics. Acoustic foam panels mounted on the walls near your recording position significantly reduce room echo. A no-cost alternative is to record inside a walk-in closet with clothes hanging on both sides, which creates dense sound absorption around the microphone. Test a room by clapping sharply once and listening for a lingering echo. If the sound rings clearly, the room needs treatment before you commit to regular recording sessions there.
Position the camera at eye level. A camera placed at or slightly below eye level fills the frame naturally and produces a flattering, engaged perspective on the subject. Anything significantly above eye level creates an unflattering downward angle. Lock in the lens position with a tripod, monitor arm, or a stable elevated surface before each session and do not adjust it between takes.
Set the lighting angle correctly. A key light at 45 degrees to one side and slightly above eye level creates natural dimension without harsh shadows. A fill light or reflector on the opposite side softens the shadow. A hair or backlight positioned behind and above the subject adds visual separation from the background, producing a more polished and three-dimensional final image.
Check the frame before every recording. Everything visible in your background communicates something to the viewer. Before each session, look at your camera preview and remove anything distracting from the frame. Visible cables, cluttered surfaces, or an unintentional open doorway erode perceived production quality faster than any camera limitation.
Recording Space Setup Checklist - [ ] Room selected for low echo and soft furnishings - [ ] Acoustic treatment added (panels, rugs, curtains, or closet recording) - [ ] Camera positioned at eye level on a stable mount - [ ] Key light at 45 degrees to face, slightly above eye level - [ ] Background reviewed through camera preview; distractions removed - [ ] Cables managed and kept out of frame
Choose Your Recording Software
Recording software falls into two distinct categories based on your production setup. Choosing the wrong tool for your situation creates problems in post-production that are time-consuming to fix. Match the software to the recording scenario first.
Solo or single-location recording: You are the only on-camera host, or all participants share the same physical environment. Any video recording software that cleanly handles your camera input and audio source is adequate. OBS Studio, Descript, and ScreenFlow all work well for this use case.
Remote guest or interview recording: You are recording with a guest in a different location. Platform choice matters significantly here. Zoom compresses audio and video during real-time transmission, and recording that compressed stream produces noticeably lower-quality output. Riverside.fm and SquadCast both record each participant locally on their own device and upload the high-resolution files after the session. The result is studio-quality audio from both sides regardless of internet conditions during the call.
Tool |
Type |
Cost |
Best For |
OBS Studio |
Solo / local |
Free |
Full recording control, live streaming |
Riverside.fm |
Remote interview |
From $15/mo |
High-quality remote guest recording |
Descript |
Solo or remote |
From $12/mo |
Combined recording and transcript editing |
SquadCast |
Remote interview |
From $20/mo |
Remote recording with redundant backup |
ScreenFlow |
Solo (Mac only) |
$149 one-time |
Screen recording with built-in editing tools |
Regardless of software, apply these recording settings as a baseline: video at 1080p minimum (1920 x 1080) at 30 or 60 frames per second, audio at 48 kHz sample rate, and record to local storage rather than stream-to-record wherever that option exists.
Record and Edit Your First Episode
How to Record Your Video Podcast
Run a test recording before every real session. Play back two minutes of footage and confirm that audio is not peaking or clipping, the lighting looks as intended, and your framing places your eyes in the upper third of the frame. Identifying a setup problem before the real recording begins saves significant time in post-production.
Record five to ten seconds of silence at the start of every session before speaking. This room tone sample is used during editing: noise-reduction software analyzes those silent seconds as a noise profile and applies it to reduce consistent ambient background noise across the full recording.
Keep the physical setup identical from session to session. Small changes in microphone position, lighting angle, or camera framing between episodes create visible inconsistency that erodes the professional feel of the show over time. A photo of your full recording setup saved on your phone is all you need to recreate it exactly each week.
For interview episodes, brief your guests before the session begins. Send a short preparation note covering microphone placement, headphone use to prevent audio bleed, internet connection quality, and background setup. Guests who understand that their audio is recorded locally on their own device (via Riverside.fm or SquadCast) approach the session with more confidence and better prepared audio.
How to Edit Your Video Podcast
The main video editing software options for podcasts, with a one-line summary for each:
DaVinci Resolve: Free, professional-grade, powerful color grading capabilities, steeper initial learning curve than entry-level alternatives.
Adobe Premiere Pro: Industry standard subscription software (~$55/month), integrates with After Effects for motion graphics and titles.
Final Cut Pro: Mac only, one-time purchase (~$300), fast rendering, widely used by solo video creators and video podcasters.
Descript: Transcript-based editing where deleting words from the text transcript removes the corresponding audio and video automatically. The most beginner-friendly option for creators who want to minimize technical editing complexity.
The core editing sequence for a video podcast episode follows a consistent order: trim dead air and filler sections from the beginning and end of the recording first, then work through the body removing significant stumbles or extended pauses. Add your intro and outro segments. Sync the audio track with the video timeline if they were recorded on separate devices. Apply basic color grading to normalize exposure across the episode. Add lower-third captions identifying speakers, especially for interview episodes.
Auto-captioning tools in Descript and Adobe Premiere generate accurate, searchable text from your audio track and improve accessibility for hearing-impaired audiences. Captions also unlock more effective social media clip repurposing, since short clips with visible text perform significantly better on platforms where video plays silently by default.
The most common editing mistake for new podcasters is over-editing. A well-planned recording session with clean audio and good lighting requires minimal editing time. Spending ten or more hours editing a 30-minute episode is a signal to invest in improving the recording setup, not in more post-production hours. Set a practical “good enough” standard, launch the show, and refine your process across subsequent episodes.
Host, Publish, and Distribute Your Video Podcast
Choose a Podcast Hosting Platform
A podcast hosting platform stores your audio (and sometimes video) files and generates an RSS feed. That RSS feed is the standardized file that tells podcast directories what episodes exist, in what order, and how to access them. Without a hosting platform producing an active RSS feed, you cannot appear in Apple Podcasts, Spotify, or any other podcast directory.
When evaluating platforms specifically for a video podcast, the criteria that matter most are video file hosting support, per-episode storage limits, analytics quality, and price at the tier you need.
Platform |
Video Support |
Free Plan |
Best For |
Buzzsprout |
Limited (audio-first) |
Yes (500 MB/mo, 90-day limit) |
Beginners hosting video on YouTube separately |
Podbean |
Yes |
Yes (5 hours storage) |
Video podcast hosts wanting native video support |
RSS.com |
Yes |
No (from $8.99/mo) |
Straightforward hosting with clean RSS tools |
Spotify for Podcasters |
Yes |
Yes (unlimited) |
Creators prioritizing Spotify-native distribution |
For most beginner video podcasters, the practical workflow is to host audio on a podcast platform to generate the RSS feed and upload the full video file separately to YouTube. This sidesteps storage limitations and places the video where video discovery actually happens at scale.
Upload to YouTube
YouTube is the most important single discovery channel for video podcasts. It functions as its own search engine with a recommendation algorithm that surfaces content to audiences who are not yet subscribers of your show.
For every upload, write a keyword-focused title rather than a generic episode number and guest name. Write a full-length description with relevant search terms integrated naturally. Add chapter markers with timestamps directly in the description: chapters improve watch time by letting viewers navigate to the sections most relevant to them. Create a custom thumbnail using your face with a clear text overlay, which consistently outperforms auto-generated thumbnails in click-through rate.
Submit to Podcast Directories
Once your hosting platform is live and your RSS feed is active, submitting to the major podcast directories is a one-time process for each platform. Most major directories accept RSS feeds directly and auto-update when new episodes are published:
Apple Podcasts: Submit via podcastsconnect.apple.com
Spotify: Submit via podcast.spotify.com
Amazon Music / Audible: Submit via music.amazon.com/podcasts
YouTube Podcasts: Submit your RSS feed via YouTube Studio
Most hosting platforms include guided one-click submission tools that simplify this process. Initial review and approval on Apple Podcasts typically takes one to five business days.
Write show notes and episode descriptions carefully for every episode. They serve as searchable text inside podcast apps and form the foundation of your SEO-optimized YouTube descriptions. Include the episode topic, guest name where relevant, key talking points, and links to any resources mentioned during the episode.
How to Grow Your Video Podcast Audience
Growth strategy is a broad topic that deserves its own dedicated guide. At the launch stage, the following foundational practices produce the most consistent early results:
Optimize titles and descriptions for search. Both Spotify and YouTube index episode titles and descriptions. Write them the way a potential listener might actually type a search query, not as creative teasers that obscure the topic.
Repurpose clips for short-form platforms. A 60 to 90-second moment from a longer episode (a sharp answer, a surprising insight, or a compelling disagreement) performs well on Instagram Reels, TikTok, and YouTube Shorts, reaching audiences who would not otherwise encounter a full-length episode.
Ask guests to share. An interview guest sharing your episode with their own audience is the most cost-free amplification available. Make it easy: send a direct link, a ready-made clip, and a suggested caption.
Publish on a consistent schedule. Regularity signals credibility to both audiences and platform algorithms. An unpredictable posting cadence is among the most common reasons early audience growth stalls.
Engage in niche communities. Relevant subreddits, Facebook Groups, newsletters, and Discord servers are places where your target audience already spends time. Participating genuinely, rather than simply dropping links, builds organic awareness and word-of-mouth discovery over time.
Video Podcast Equipment Cost Breakdown
Budget uncertainty is one of the most common reasons aspiring creators delay launching. The three tiers below present realistic starting points. No tier requires buying everything at once: prioritize microphone investment first at every level.
Tier |
Microphone |
Camera |
Lighting |
Editing Software |
Approx. Total |
Beginner |
Hollyland LARK A1 (~$50) |
Smartphone |
Window light or ring light (~$30) |
Free (DaVinci Resolve / OBS) |
~$80–150 |
Mid-Range |
Hollyland LARK MAX 2 (~$300) |
Webcam or entry mirrorless |
Ring light + softbox (~$80) |
Free / Descript (~$12/mo) |
~$400–600 |
Professional |
3-point lighting kit (~$200+) |
Adobe Premiere / Final Cut Pro |
$800–1,500+ |
Prices are approximate and subject to change. The principle that applies across every tier: invest in audio before upgrading video. A well-recorded voice on modest footage outperforms a visually polished show with poor audio in both listener retention and audience growth.
Do I need a separate camera, or can I use my phone?
A smartphone is a fully capable starting camera for a video podcast. The iPhone 13 and newer, as well as the Google Pixel 7 and newer, record high-quality video suitable for professional distribution. Mount it at eye level on a tripod or phone stand and pair it with good lighting. Upgrade to a dedicated camera when video quality becomes a specific, noticeable limitation in your actual output.
What is the difference between a video podcast and a YouTube channel?
A video podcast distributes through an RSS feed to directories including Apple Podcasts, Spotify, and Amazon Music, in addition to YouTube. A YouTube channel lives exclusively on YouTube. The practical difference is reach: a video podcast captures both the video-watching audience on YouTube and the audio-first listeners who prefer podcast apps over a screen.
Do I need to show my face on a video podcast?
No. Screen-share formats, slide-based presentations, and B-roll video with voiceover are all valid approaches. That said, face-on-camera formats build audience connection faster and tend to perform better in YouTube’s recommendation algorithm, which weighs watch time and viewer retention. If camera discomfort is the barrier, start recording face-on-camera and build familiarity over time. The awkwardness typically fades quickly.
How long should video podcast episodes be?
There is no universal rule. Interview-format episodes naturally run 45 to 90 minutes because conversation develops gradually over time. Solo commentary episodes work well between 15 and 30 minutes when the content is dense and intentional. Match length to the content. Do not pad episodes to reach a target runtime, and do not cut strong content to meet an arbitrary limit.
Which is better for a video podcast: a wireless lavalier mic or a USB desktop mic?
Both are effective depending on your format. A USB desktop condenser on a boom arm works well for static solo setups. A wireless lavalier such as the Hollyland LARK MAX 2 keeps cables out of frame, offers freedom of movement, and scales naturally to interview formats where each guest needs a dedicated mic. For shows involving movement or multiple guests, wireless is the stronger long-term choice.
How many episodes should I record before launching?
Recording three episodes before publishing is the widely recommended launch baseline. It gives new listeners immediate content to continue with after the first episode, creates a buffer if your real-world publishing schedule slips, and reduces the pressure of the first-episode publication moment while giving you time to refine your format before it goes live.
Start Recording: Your Next Steps
Starting a video podcast does not require a perfect setup. It requires a clear concept, clean audio, and consistent publishing. Work through the steps in sequence: define your format before buying gear, invest in audio before upgrading your camera, and have three complete episodes ready before your launch date.
Ready to take the next step? Explore the Hollyland LARK MAX 2 for wireless audio built around interview-format and studio video podcasting, or read our guide to the best wireless microphones for podcasting to compare options across every budget tier.
