How to Start a Podcast on YouTube: A Step-by-Step Guide
There is not as much grinding to launch a podcast on YouTube as most users usually think. Many people search the platform daily for fresh content to watch. A dedicated Podcasts section also helps new shows reach more viewers. That makes YouTube a strong place to share your first episodes. This guide explains the full process from your first idea onward. You will learn how to prepare, upload, and improve each episode.
What Is a YouTube Podcast and Why It’s Worth Starting
A YouTube podcast is different from a typical YouTube video. It follows a series instead of separate, unrelated uploads. Each episode keeps the same style, topic, and overall identity. That consistency helps people recognize your show over time. Every new episode also strengthens your podcast's name and main focus.
What Is a YouTube Podcast (and Why It’s Worth Starting)
YouTube includes a separate Podcasts section for podcast listeners. People can also find and follow shows through YouTube Music. Set up your podcast correctly with playlists or an RSS feed. After that, your episodes can appear in YouTube's podcast discovery areas with other content.
Publishing on YouTube can help more people discover your podcast. The platform recommends content based on viewers' interests and searches. Millions of people already look for topics like yours every day. Your goal is to make your episodes easy for them to find.
Plan Your Podcast Before You Record Anything
Many new podcasts stop after only a few episodes because creators skip planning first. Before you buy a microphone or open YouTube Studio, spend time on four or five core decisions. These choices shape your entire workflow and prevent expensive rework later.
Choose Your Niche and Format
Your niche should be specific enough to attract a defined audience but broad enough to sustain hundreds of episodes. “Business” is too broad. “Marketing for e-commerce founders” is workable. The narrower your focus, the faster trust builds with listeners who feel the show was made for them specifically.
Your format determines how much production work each episode requires. The most common options:
  • Solo commentary: Easiest to produce; you control the schedule entirely. Works well for educational or opinion-driven content. Requires strong scripting or high-comfort speaking.
  • Interview: Adds credibility and draws in guest audiences. Requires scheduling coordination and a microphone setup that handles two voices cleanly.
  • Co-host panel: Conversational and natural. Two or more hosts must coordinate availability every single episode, which increases friction over time.
  • Hybrid: Alternates between solo and interview episodes. Flexible, but complicates consistent branding.
Start with solo or interview format for your first launch. Both have clear, well-defined production paths.
Name Your Show and Define Your Core Premise
Your podcast name should describe what listeners get, not just who you are. A name like “The E-Commerce Growth Show” is more searchable than “The Sarah Chen Podcast” unless Sarah Chen already has a significant following. Aim for something memorable, keyword-relevant, and easy to spell from memory.
Write one clear sentence explaining who your podcast is for and what people will learn. You can later use this idea in your channel description, episode notes, and podcast artwork. Finishing this step early helps you avoid making major changes later.
Set Up Your Equipment for Podcast-Quality Audio
New podcasters routinely under-invest in audio and over-invest in video. That is the wrong priority. Listeners forgive average video quality. They do not forgive audio that sounds echoey, muffled, or difficult to follow. Poor audio ends listening sessions within the first 60 seconds.
You do not need a professional studio. You need a clean signal from a reliable microphone, a reasonably quiet room, and a straightforward recording setup.
Microphone (Your Most Important Investment)
Microphone quality is the single most impactful technical decision you will make for your podcast. Everything else can be upgraded later or compensated for in post-production. A bad microphone cannot be fully fixed in editing.
Tier
Product
Best For
Key Features
Beginner / Plug-and-Play
Hollyland LARK A1
Solo podcasters recording on a phone or laptop
USB-C and Lightning connectivity, 3-level intelligent noise cancellation, zero technical setup required
Professional / Interview-Ready
Hollyland LARK MAX 2
Two-person setups, interview podcasts, professional audio workflows
48kHz/32-bit Float audio, AI noise cancellation, wireless OWS monitoring earphones, 32-bit Float internal backup recording
The Hollyland LARK A1 makes it easy to start recording without extra hassle. Plug it directly into your phone or laptop and start recording immediately, with no drivers, audio interfaces, or technical configuration needed. For solo hosts who want professional-sounding audio without a learning curve, it removes every barrier between you and your first episode.
The Hollyland LARK MAX 2 is built for podcasters who need precision. Its 32-bit Float recording captures audio with exceptional dynamic range, meaning even if your input levels are not perfect during the session, you can recover the audio cleanly in post-production without distortion. The wireless OWS monitoring earphones let you hear what your microphone is capturing in real time, which matters most during interviews or two-person recordings where catching a problem early saves the entire take.
Camera, Lighting, and Background (Keep It Simple)
A podcast can launch on YouTube using only a static cover image and an audio file. If you want to record video, here is a minimal setup that works:
  • Camera: A quality webcam (Logitech Brio or equivalent) or a mirrorless camera with clean HDMI output
  • Lighting: One ring light or softbox positioned at eye level reduces shadows and improves image quality immediately
  • Background: A clean wall, a bookshelf, or a simple backdrop; anything that does not distract from the conversation
  • Headphones: Wear them during recording to catch audio issues before they make it into the final file
Do not delay your launch waiting for a perfect camera setup. Start with what you have and upgrade once the show is generating consistent output.
Recording Software
Your software choice depends on your platform and workflow:
  • Audacity: Free, cross-platform, capable of solo recording and basic editing. The default starting point for most beginners.
  • GarageBand: Free on Mac. Clean interface, reliable performance, basic effects included.
  • Riverside.fm: Browser-based remote recording that captures separate local tracks per participant. The best option for remote interviews where audio quality is non-negotiable.
  • Zencastr: Similar to Riverside; records lossless audio locally from each guest. Offers a useful free tier.
  • Adobe Audition: Professional-grade editing suite. Worth using if you are already in the Adobe Creative Cloud ecosystem.
Set Up Your YouTube Channel for Podcasting
Your YouTube channel is the main place where your podcast lives. Setting it up for a podcast is slightly different from creating a regular YouTube channel.
Create or Optimize Your YouTube Channel
  1. Match your channel name to your podcast show name. Consistency between the two makes it easier for listeners to find you across platforms and builds brand recognition faster.
  2. Write a keyword-inclusive channel description. Include your niche, your target audience, and your publishing schedule. Example: “Weekly interviews with e-commerce founders on scaling past seven figures.”
  3. Upload a channel banner that matches your podcast's brand. YouTube recommends a banner size of 2560 × 1440 pixels. Keep your text and graphics inside the center safe area so they appear correctly on different devices. Also, upload your square podcast cover art separately while creating or setting up your podcast. This image is different from your channel banner. It represents your podcast across YouTube's podcast sections.
  4. Set a channel icon that matches your podcast branding, either a logo or a professional headshot.
  5. Add relevant links in your About section, including your website and social profiles.
Upload Podcasts to YouTube
After creating a channel, the next stage is to upload your podcasts. You can do that by following the steps below:
  1. Go to YouTube.com and sign in.
  2. Click your profile image and select YouTube Studio.
  1. On the Dashboard page, click the Create button in the top-right corner of the screen, and select the New podcast option.
  1. You can upload podcast videos from your computer by clicking the Create a new podcast option. Or, if you already have podcasts uploaded on your YouTube channel, you can choose the Set an existing playlist as a podcast option (discussed in detail in the upcoming section) to designate the content as a podcast on your channel.
  2. But to bring podcasts from another platform to your YouTube channel, click the Submit RSS feed option.
  1. When the Submit RSS feed dialog box appears, click Next.
  1. Go to that specific platform where your podcasts exist, and copy its RSS feed URL. Then paste it into the Enter RSS feed URL field on YouTube, and click Next.
  1. The next step is to verify whether you're the true owner of the podcast. To do that, click the Send code button on the Verify ownership page to receive an email on your registered email address.
  1. Enter the code, and click the Verify button.
  1. Now select what episodes you want YouTube to upload from the RSS feed by choosing one of the options:
  • Upload all episodes in the RSS feed
  • Upload episodes published since (choose a date)
  • Do not upload any old episodes
  1. Then click Next.
  2. Once you are directed to the Visibility tab, click Save and click Done when the next dialog box appears.
  1. Now go to the YouTube Studio, select Content from the left sidebar menu, and click the Podcasts tab to check your uploaded files via RSS feed.
  1. Once the uploading process is complete, click the recently uploaded podcast and click on the Details option (pencil icon) to edit podcast details.
  1. Make sure the visibility is set to Public. If it is not, click the Visibility dropdown menu on the right side of the screen, and select Public.
  1. Click Save.
You do not need a separate podcast hosting service if YouTube is your only publishing platform. However, an RSS feed becomes essential the moment you want episodes distributed to Spotify, Apple Podcasts, or Amazon Music. Make this distribution decision before you launch, so you build the right infrastructure from day one.
Create a Podcast Playlist or Assign the Existing Playlist as Podcasts
A dedicated playlist groups your episodes in publishing order and signals to YouTube that these videos function as a connected series.
  1. Open YouTube Studio and select the Content section.
  2. Open the Playlists tab (or click the Create button and choose New podcast).
  1. Find the playlist you want to use and open its Options menu (three vertical dots).
  1. Pick the choice to turn that playlist into a podcast (Set as podcast).
  1. Enter your podcast name, write a short description, and upload a square thumbnail.
  2. Now place your full podcast episodes inside that podcast playlist.
  3. This helps people find your show on YouTube and YouTube Music.
  1. how.
Note: Add every new episode to this playlist at the time of upload. Episodes published outside the playlist are not counted within your official podcast series by YouTube’s system.
Record and Edit Your First Episode
Your podcast idea, recording gear, and channel are now ready. The next step is recording your first episode. Focus on creating something you can publish instead of chasing perfection.
Recording Best Practices
  1. Record in a soft, closed room: Bedrooms with carpet and curtains perform better than empty offices with hard walls because soft furnishings absorb echo without any dedicated acoustic treatment.
  2. Position your microphone 6 to 8 inches from your mouth: Speak across the mic rather than directly into it to reduce plosive sounds on P and B consonants.
  3. Run a 30-second test recording before every session: Play it back through headphones and catch any problems before recording the full episode.
  4. Minimize background noise: Close windows, turn off fans or air conditioning, and silence your phone.
  5. Monitor your audio in real time: For LARK MAX 2 users, the wireless OWS monitoring earphones let you hear your microphone signal live, so positioning issues or room problems can be fixed immediately rather than discovered in the edit.
Editing Your Episode
Editing does not mean perfecting every breath and pause. It means removing what degrades the listener experience. Prioritize cutting:
  • Long pauses exceeding two seconds that break the episode’s pace
  • Excessive filler words (“um,” “uh,” “you know”) that accumulate and distract
  • Mistakes, false starts, and restarts the listener has no reason to hear
  • Background noise spikes caused by doors, traffic, or sudden sounds
Beyond those cuts:
  • Use your recording software’s noise reduction tool on any consistent background hum Add a short intro and outro (5 to 15 seconds each) using royalty-free music from the YouTube Audio Library or Epidemic Sound
  • Export audio as a high-quality MP3 or AAC file for audio-only uploads, or render video episodes as MP4 (H.264 codec)
Two hours of editing for a 30-minute episode is a reasonable benchmark. Do not let perfectionism extend that indefinitely and delay publishing.
Create Your Video File
YouTube requires a video file for every upload, even when the episode is audio-only content. You have three practical options:
  • Static branded image with audio: Save your podcast cover image as a JPG or PNG file. Open a video editor like DaVinci Resolve, Shotcut, OpenShot, iMovie (Mac), or Clipchamp (Windows). Place the image with your audio in the timeline. Export the completed video as an MP4 file. Then, upload the MP4 file to YouTube.
  • Audiogram or waveform animation: Tools like Headliner or Descript generate animated audio visualizations with your cover art as the background. These perform better than static images and require minimal extra effort.
  • Full video recording: If you recorded video during the session, edit and export it as an MP4. Full video episodes generate higher watch time and more engagement than static or audiogram formats.
Start with a static image or audiogram if video recording adds too much complexity to your workflow right now. Upgrade to full video once your publishing system is stable.
Upload and Optimize Your Episode on YouTube
Finding listeners on YouTube follows a different process than podcast apps. On Spotify or Apple Podcasts, podcast information helps people discover new shows. YouTube depends much more on how each episode is presented. Strong titles, custom thumbnails, descriptions, and chapters can attract more viewers.
Write an SEO-Optimized Title and Description
  1. Lead your title with the episode topic, not the episode number. “How to Scale a Shopify Store to $1M (E-Commerce Growth Show, Ep. 14)” outperforms “Episode 14 of The E-Commerce Growth Show” in search results.
  2. Place your primary keyword within the first 60 characters of the title. YouTube truncates longer titles in search and browse results.
  3. Open your description with the episode’s core topic and primary keyword within the first two sentences. Example: “In this episode of The E-Commerce Growth Show, strategist Mark Torres shares his framework for scaling Shopify stores past seven figures.”
  4. Include full show notes in the description body — key takeaways, guest bio if applicable, and all resources or links mentioned during the episode.
  5. Add timestamps in the description body to generate clickable chapters (see next section).
  6. Use 3 to 5 relevant tags, include the show name, the episode topic, and two or three keyword phrases your target listener is likely to search.
Thumbnail Design
Creating your own thumbnails gives your podcast channel a more professional look. Some AI thumbnail tools can also pick strong facial expressions and build matching designs automatically.
Effective podcast thumbnails include:
  • Large, readable text summarizing the episode topic or guest name. Text must be legible at 120 x 68 px, the smallest display size YouTube uses.
  • A face, either yours, your guest’s, or both. Human faces consistently increase click-through rates.
  • Consistent visual style across all episodes. Use the same font, color palette, and layout, so listeners recognize your show immediately in a crowded feed.
  • High contrast between text and background so the thumbnail reads clearly in both light and dark mode.
Create a reusable template in Canva or Adobe Express so each new episode thumbnail takes five minutes, not fifty.
Add Chapters and Timestamps
Chapters divide your episode into navigable sections, which improves listener retention and can help your video surface for specific sub-topic queries. A chapter titled “How to Find Your Podcast Niche” within a longer episode can generate standalone search traffic.
To add chapters, include timestamps in your description using this format:
0:00 Introduction
2:15 [Topic One]
8:40 [Topic Two]
18:00 [Topic Three]
The list must start at 0:00 and include at least three timestamps for YouTube to activate the chapter feature. Chapters also appear in YouTube’s video preview in search results, giving your episode a visual advantage over episodes that lack them.
Build a Consistent Publishing System
Consistency matters more than production quality in the early stage. One episode per month with pristine audio will grow slower than one episode per week with good-enough audio. Build a system that makes publishing on schedule the default, not the exception.
Practical steps to build that system:
  • Batch-record before you launch publicly: Have 3 to 4 episodes ready before your first upload goes live. This buffer removes deadline pressure and gives you space to improve your workflow before the audience arrives.
  • Use a content calendar: A simple spreadsheet with episode titles, recording dates, and target publish dates is enough to keep the workflow on track.
  • Set a realistic cadence: Weekly works if your episodes are under 30 minutes and your production workflow is efficient. Bi-weekly is sustainable for longer or more complex formats. Choose the schedule you can maintain for six months, not just the first three weeks.
  • Repurpose every episode: Cut 30 to 60-second highlights for YouTube Shorts, pull quotes for social posts, and repurpose key insights as short-form written content. One episode can generate multiple content pieces with relatively little extra effort.
Inconsistency is the most common cause of podcast failure, not bad equipment or imperfect editing. A realistic schedule that you actually keep beats an ambitious one you abandon by week four.
How to Grow Your YouTube Podcast Audience
Growth follows consistency and optimization, not the other way around. Once your publishing rhythm is established, these are the highest-leverage actions available to you:
  • Optimize every episode title and description for YouTube search. Research what people are actually searching for and build episode topics around those queries, treating each upload like a targeted content asset.
  • Make time to answer viewer comments after each new podcast episode. Early conversations can encourage more people to join the discussion. Try to reply soon after your episode becomes public. Strong audience activity may help YouTube recommend your content to more viewers.
  • Collaborate with guests who bring their own audiences. Every interview episode introduces your show to the guest’s followers, particularly when guests share the episode on their own channels.
  • Create Shorts from your best episode moments. A 45-second clip from a longer episode can generate thousands of views that funnel new viewers back to the full episode.
  • Cross-promote on platforms where your audience already spends time. Instagram clips, LinkedIn excerpts, and short text threads can drive traffic back to your YouTube channel.
  • Participate genuinely in your niche’s communities. Forums, Facebook groups, and Discord servers build word-of-mouth visibility that no algorithm can replicate.
How to Monetize a YouTube Podcast (Quick Overview)
Earning money becomes more likely as your audience keeps growing. Regular viewers and more subscribers create better income opportunities. Most YouTube podcasters earn through these four main methods:
  • YouTube Partner Program (YPP): Requires 1,000 subscribers and 4,000 watch hours (or 10 million Shorts views in 90 days). Once eligible, your videos earn ad revenue passively.
  • Channel memberships: Paying subscribers gain access to bonus episodes, early releases, or exclusive content. A small but loyal audience can generate meaningful recurring revenue at this tier.
  • Sponsorships: Brand integrations within episodes are typically the highest-earning format for mid-size podcasts. Rates are usually calculated on a cost-per-mille (CPM) basis per 1,000 listeners or viewers.
  • Affiliate marketing: Recommending products relevant to your niche and earning a commission on resulting sales works especially well for shows with a targeted, high-trust listener base.
Focus on audience volume and content quality first. Revenue follows a consistent, growing show.
Do I need a camera to start a YouTube podcast?
A camera is not required when launching a podcast on YouTube. Connect your audio RSS feed to your channel first. YouTube will match each episode with your podcast artwork automatically. Plain images often make viewers leave much sooner. Adding animated waveforms or simple motion graphics can hold attention longer. You can also include a basic camera setup as your channel grows.
Can I run a YouTube podcast without a separate podcast hosting service?
YouTube alone is enough if it is your only publishing destination. You do not need another hosting platform in that case. Reaching apps like Apple Podcasts usually requires an RSS feed first. You can get one through podcast hosting companies or tools like Spotify for Creators. Choose your publishing plan before setting everything up.
How long should YouTube podcast episodes be?
There is no universally ideal length. Conversational and interview formats tend to perform well at 20 to 60 minutes. Educational solo episodes often work best at 10 to 20 minutes. The right length is whatever fully serves your topic without padding. Check your YouTube Studio retention data regularly and use it to calibrate.
Does YouTube have an official podcast section?
Yes. YouTube has a special section where people can find podcasts more easily. You can publish episodes in two different ways through YouTube Studio. Upload video episodes and group them into a podcast playlist. Another option is connecting an audio RSS feed to import episodes automatically from your podcast host.
Starting a podcast on YouTube is easier than many people think. Pick one clear topic and get a dependable microphone. Set up your YouTube channel before recording any episodes. Record a practice episode, upload it, then keep making new content. Thumbnails, chapters, and SEO can help people find your podcast. Still, they mean little without published episodes. Share your first episode even if it feels unfinished. You can make each new episode better than the last.
