YouTube Shorts puts short-form video in front of billions of users without needing a pro setup. Whether you’re picking up the format for the first time or expanding from another platform, the process breaks down into five stages: gear, filming, editing, uploading, and optimization. This guide walks you through each one in order, so your first Short is ready to publish before the day is out.
Getting started with Shorts is meant to be easy. A modern smartphone is genuinely sufficient to get started. But two overlooked upgrades, lighting and audio, have an outsized effect on whether viewers stay or scroll past.
Here’s what your minimal setup should include:
- Smartphone — Any current iOS or Android device will record at the resolution Shorts requires. You don’t need a dedicated camera.
- Stable light source — Natural window light works well. If you’re filming indoors without a good window, a small LED panel (available for under $30) eliminates the flat, muddy look that undermines otherwise solid content.
- Microphone — Your phone’s built-in mic picks up room noise, wind, and handling vibration. If you are recording on the spot, the Hollyland LARK A1 plugs straight into your iPhone Lightning port or Android USB-C with no setup. There is no app pairing and no driver install needed. Its three-level intelligent noise cancellation keeps your voice clean in noisy places. This feature matters because weak audio often makes viewers leave a Short in the first few seconds.For creators who film while moving, like walking, vlogging, or showing something, the Hollyland LARK M2 is a tiny wireless clip mic about the size of a coin. Its 40-hour battery lasts through long shooting days. The mic stays almost hidden on your clothing while giving broadcast-quality audio.
- Tripod or phone mount — Essential for talking-head or product-demo Shorts where handheld shake reads as unprofessional.
- YouTube app (latest version) — Needed for in-app filming and upload; update before you start to avoid interface discrepancies.
Understanding YouTube Shorts Specs (Quick Reference)
Film to these specs from the start and you won’t need to resize, crop, or re-export at any point in the process.
Spec |
Requirement |
Aspect Ratio |
9:16 (vertical) |
Resolution |
1080 × 1920 recommended |
Max Length |
Up to 3 minutes (as of 2024) |
File Format |
MP4 or MOV |
Hashtag |
Add #Shorts in title or description |
Note: The 3-minute limit was extended in 2024 from the original 60-second cap. While longer Shorts are now supported, sub-60-second videos still tend to perform strongest for new channels because they’re easier to loop — a metric the algorithm weights heavily.
How to Film YouTube Shorts
There are two ways to film Shorts. But guess what? Neither is objectively better. Your choice should depend on how much editing control you want and how familiar you already are with video tools.
Option A — Film Directly in the YouTube App
The in-app Shorts camera is the fastest route from idea to published video, and everything you need is contained in one interface.
- Open the YouTube app and tap the “+” icon at the bottom center of the screen.
- Select “Short” from the menu that appears.
- On the recording screen, set your clip length (15 seconds or 3 minutes for the quick-take mode; for longer recordings, use the full upload flow instead).
- Use the timer feature to give yourself a hands-free countdown before recording starts.
- Use speed controls (0.3× to 3×) to create slow-motion or time-lapse segments without any external editing.
- Record your Short in multiple segments using the hold-to-record interface — YouTube stitches them together automatically.
- Tap Add Sound to include licensed music from YouTube’s built-in audio library before or after filming. All tracks here are pre-cleared for use, which eliminates copyright risk entirely.
- Tap the checkmark when done to move into the lightweight in-app editor. Tap Next and select Upload Short.
Pros: Fastest turnaround, no file management, music is automatically rights-cleared, and you stay entirely within the YouTube ecosystem.
Option B — Film Externally and Upload
This path gives you full control over your edit before anything reaches YouTube’s platform.
- Film using your phone’s native camera app or any external camera, making sure your aspect ratio is set to 9:16 from the start. On most iPhones, this means shooting in portrait mode; on Android, check your camera settings for a vertical video mode.
- Transfer your footage to whichever editing app or software you prefer (covered in the next section).
- Complete your edit, then export at 1080×1920 in MP4 or MOV format.
- Open the YouTube app or go to studio.youtube.com and tap or click “Create” → “Upload video.”
- Select your exported file. YouTube automatically classifies files under 3 minutes that are filmed vertically as Shorts — no manual flagging required during upload.
Pros: Full creative control over transitions, captions, pacing, and effects that the in-app editor doesn’t support.
Both paths end at the same upload and publish stage. The only meaningful difference is where your editing happens.
How to Edit YouTube Shorts?
Whether you filmed in-app or externally, editing is where pacing, captions, and visual polish come together. Keep edits tight becauseShorts perform better when the video moves quickly from one moment to the next, rather than relying on fancy or complicated edits.
Using YouTube’s Built-In Editor
After filming in-app or selecting a file to upload, YouTube surfaces a built-in editor with the following tools:
- Timeline trimming to cut the beginning and end of your clip
- Text overlays with font and color options
- Filters for quick color grade adjustments
- Voiceover recording directly within the editor
- Licensed audio from YouTube’s Audio Library, searchable by mood, genre, or tempo
This editor is best suited for simple Shorts — a talking-head video with a text hook, or a product clip with a music track underneath. If you need multi-layer captions, custom transitions, or B-roll cutting, a third-party app will serve you better.
Using Third-Party Editing Apps
- CapCut — The most widely used app for Shorts specifically. Auto-caption generation is accurate and fast, templates are optimized for vertical video, and the transition library is extensive. Free tier is sufficient for most use cases.
- InShot — Particularly strong for trimming, speed ramping, and text placement. The UI is cleaner than CapCut for beginners who don’t need advanced features.
- DaVinci Resolve (desktop) — The right choice if you’re already editing long-form YouTube videos and want your Shorts output to go through the same color and audio pipeline. Not recommended as a starting point for mobile-only creators.
Regardless of the app, export your final file at 1080×1920 resolution, H.264 codec, MP4 container, before uploading to YouTube.
How to Upload and Publish Your YouTube Short?
The upload process is straightforward, but the fields you fill in during this stage directly affect how discoverable your Short will be.
- Open the YouTube app or navigate to studio.youtube.com.
- Tap or click “Create” → “Upload videos.”
- Select your Short file. Vertical videos under 3 minutes are automatically classified as Shorts by YouTube’s system.
- Write your title: include the topic keyword naturally, keep it under 60 characters so it doesn’t truncate in the feed (e.g., “How to Make Sourdough Bread in 90 Seconds”).
- In the description, add #Shorts as your first or second hashtag. Include 2–3 additional relevant hashtags, but don’t stack 20 — it reads as spam and doesn’t improve classification.
- Set visibility: Public pushes immediately, Scheduled lets you pick a publish time, and Private holds the video until you’re ready.
- Tap “Upload Short.” The video processes within a few minutes and appears in the Shorts feed once approved.
Note: Shorts do not require a custom thumbnail image upload the way long-form videos do. The key frame you select during upload is how your Short will appear in the Shorts feed and on your channel page.
How to Optimize YouTube Shorts for More Views?
Publishing is not the finish line.How you set up a Short at the moment of upload, and how you engage with it in the first hour, affects whether the algorithm distributes it broadly or keeps it contained.
- Hook in the first 2 seconds: The algorithm measures both average watch time and loop rate. Viewers who leave in the first two seconds suppress distribution. Open with a question, a visual payoff, or a stated outcome (“Here’s how I cut my editing time in half”) — not an introduction.
- Use a keyword-rich title: YouTube search indexes Short titles. Match the natural phrasing someone would actually type. Descriptive titles outperform clever titles for discoverability, especially on new channels without an existing audience.
- Include #Shorts in the title or description:Since 2024, this remains a confirmed classification signal that helps YouTube route your content to the Shorts feed rather than the standard video feed.
- Post when your audience is active: Once you have 10+ Shorts published, check YouTube Studio Analytics → Audience tab for peak engagement hours. For new channels with no data yet, 12–3 PM local time is a reasonable default for initial posts.
- Reply to comments in the first hour after posting: Early engagement signals — comments, shares, and likes — are weighted by the algorithm when deciding whether to expand distribution to non-subscribers.
- Build a series structure: Shorts with a recurring format (same topic, same visual style, same opening line) generate returning viewers. Viewers who come back to watch again often raise your watch rate. They are more likely to watch the whole Short and let it play again.
Common YouTube Shorts Mistakes to Avoid
- Filming in landscape and cropping to vertical — Cropping a 16:9 video into 9:16 forces YouTube to letterbox or blur the edges. Always film in vertical from the start.
- Using audio not cleared through YouTube’s library — Unlicensed background music gets your Short muted or removed. Use the YouTube Audio Library or royalty-free tracks with appropriate licenses.
- Posting with no hook in the opening frame — A black screen, a logo, or a slow pan gives the algorithm nothing to work with and viewers no reason to stay.
- Skipping captions — A significant portion of Shorts are watched on mute. Open captions (burned into the video or added via CapCut’s auto-caption tool) measurably increase retention.
- Deleting underperforming Shorts too early — Shorts can resurface in the feed days or weeks after posting. Deleting them permanently removes any future distribution opportunity.
How long can YouTube Shorts be?
As of 2024, YouTube Shorts can be up to 3 minutes long, extended from the original 60-second limit. To qualify as a Short, the video must be filmed and exported in vertical format (9:16 aspect ratio). Videos that exceed 3 minutes are classified as standard uploads regardless of orientation.
Do you need a certain number of subscribers to post YouTube Shorts?
Anyone can make and upload Shorts. But to unlock basic earnings like fan support through Super Thanks, your channel needs 500 subscribers and 3 million Shorts views. Full ad revenue still needs 1,000 subscribers. You also need either 4,000 public watch hours in the past 12 months or 10 million Shorts views in the last 90 days.
Can you make YouTube Shorts from a desktop computer?
Yes. Edit your vertical video in any desktop software — DaVinci Resolve, Premiere Pro, or CapCut for desktop — then upload through studio.youtube.com. YouTube automatically classifies vertical videos under 3 minutes as Shorts during the upload process. No special settings are required on the desktop upload side.
Why is my video not showing up as a Short?
The most common cause is incorrect aspect ratio. Your video must be filmed and exported at 9:16 (vertical). Landscape (16:9) or square (1:1) videos are not classified as Shorts even if you add the #Shorts hashtag. Re-export from your editing app at 1080×1920 and re-upload.
Does audio quality matter for YouTube Shorts?
Yes — poor audio causes early drop-off even on short videos. Viewers tolerate average visuals, but distorted or echo-heavy audio reads as low quality immediately. If you’re filming on a smartphone, a plug-and-play external mic like the Hollyland LARK A1 (compatible with both iPhone and Android via direct connection) noticeably improves the production and sound quality without costing much.
The full Shorts workflow is five stages: set up your gear, choose your filming path, edit for pace and captions, upload with a keyword title and #Shorts hashtag, then engage early to signal distribution. None of these stages requires expensive equipment or advanced skills.
After your first 10 Shorts are live, open YouTube Studio Analytics and look at loop rate and average view duration by video. Those two numbers will tell you more about what’s working than any general advice can.
