How to Make YouTube Shorts on PC: Step-by-Step Guide
YouTube Shorts isn’t only a mobile experience. If you manage your channel on a desktop, you can create, edit, and publish Shorts entirely from your PC — no phone required. The key is getting the format right before you upload. This guide walks you through three practical methods, from a simple browser upload to a full desktop editing workflow, so you can choose the path that fits how you already work.
YouTube Shorts Format Requirements for PC
Before you record a single frame or open YouTube Studio, make sure your video meets these specs. YouTube classifies a video as a Short based on its technical properties — not because you used a specific app or tool. Get these wrong and your video lands in regular uploads, not the Shorts shelf.
  • ✅ Aspect ratio: 9:16 vertical (portrait orientation — not landscape)
  • ✅ Resolution: 1080×1920 pixels recommended for full HD quality
  • ✅ Length: Up to 60 seconds for standard Shorts classification; YouTube has expanded this to up to 3 minutes for eligible creators, but under 60 seconds is the safest threshold if you want guaranteed Shorts shelf placement
  • ✅ File format: MP4 (H.264 codec) is the most compatible export format for YouTube uploads
  • ✅ Hashtag: Include #Shorts in your title or description — this acts as a classification signal alongside the format specs
There’s no dedicated “Shorts creation mode” on the desktop version of YouTube Studio. Everything depends on having a correctly formatted video file ready before you upload.
Method 1 — Upload a Short Directly Through YouTube Studio
If you already have a vertical clip ready — whether recorded on a phone, camera, or screen recorder — the fastest path is uploading it straight through YouTube Studio in your browser. The desktop uploader is fully functional and works identically to publishing any regular video.
  1. Go to studio.youtube.com and sign in to your channel.
  2. Click the “Create” button (the camera icon with a plus sign) in the top-right corner.
  3. Select “Upload videos” from the dropdown menu.
  4. Drag and drop your file into the upload window, or click “Select Files” to browse your computer.
  1. Write your title. Keep it descriptive and include #Shorts — for example: 5 Quick Desk Setup Tips #Shorts. This is one of the most important classification signals.
  2. Add a description. Write 2–3 sentences summarizing the video and include 3–5 relevant hashtags, including #Shorts.
  1. Select a thumbnail. YouTube will auto-generate options, but you can upload a custom thumbnail image (1280×720 or cropped to match your Shorts frame).
  1. Set your audience. Choose whether this content is “Made for Kids” or not — this affects how comments and features work.
  1. Choose your visibility. Select Public to publish immediately, or use Scheduled to pick a day and time.
  2. Click “Publish” (or “Schedule”), and your Short is live.
Note: YouTube Studio on desktop does not include the in-app Shorts camera or music library available in the mobile app. However, the upload, metadata, and publishing workflow is exactly the same — you’re not missing any critical publishing functionality.
How YouTube Automatically Detects Your Short
YouTube uses a combination of signals to decide whether to place your upload on the Shorts shelf: the video must be in vertical (9:16) orientation, be 60 seconds or under (or up to 3 minutes under the extended Shorts spec), and ideally include #Shorts in the title or description. If any of these signals are missing — especially the aspect ratio — YouTube will treat the upload as a standard video instead.
Method 2 — Edit Your Short on PC with a Video Editor
If your footage needs trimming, captions, music, or any real editing work, you’ll want to process it in a desktop video editor before uploading. This is the workflow most PC-based creators use, and it gives you full creative control over the final output.
The general workflow:
  1. Create a new project and set the canvas to 1080×1920 (9:16 vertical) before you import any footage.
  2. Import your footage — raw clips from a camera, phone transfer, or downloaded files.
  3. Trim your video to fit within your target length.
  4. Add text overlays, captions, transitions, or background music as needed.
  5. Review the full clip in the preview window to check framing and pacing.
  6. Export as MP4 (H.264, 1080×1920) at a standard frame rate (30fps or 60fps).
  7. Upload the exported file to YouTube Studio using the steps in Method 1 above.
Top desktop editor options:
  • CapCut for PC — Free, beginner-friendly, includes pre-built Shorts and vertical video templates. Best starting point for new creators.
  • DaVinci Resolve — Free, professional-grade, handles color grading and advanced edits. Steeper learning curve but no cost.
  • Adobe Premiere Pro — Paid subscription, industry standard, ideal if you’re already in the Adobe ecosystem.
Setting Up a Vertical Canvas in Popular Desktop Editors
The most common mistake PC creators make is starting a project in the default 16:9 (landscape) canvas and trying to fix it later. Set vertical format first — before you edit anything.
In CapCut for PC: 1. Click “New Project” on the home screen. 2. In the project settings, look for Ratio and select 9:16. 3. The timeline canvas will switch to vertical — you’re ready to import footage.
In DaVinci Resolve: 1. Open or create a new project, then go to File → Project Settings. 2. Under Master Settings, set Timeline resolution to 1080 × 1920. 3. Click Save — your timeline is now configured for vertical video.
A Note on Audio Quality for Your Shorts
Clear audio makes a significant difference in Shorts retention — viewers scroll fast, and poor sound is one of the first reasons they keep moving. If you’re recording talking-head footage or voiceover, built-in laptop or camera microphones often pick up room noise and HVAC hum that becomes distracting in short-form content. A clip-on wireless mic is one of the simplest upgrades you can make. The Hollyland LARK M2 is a compact, 9g option that attaches to your collar, pairs wirelessly with your recording device, and lets you capture clean audio for the clip — then you transfer the footage to your PC and edit as normal, no additional audio cleanup required.
Method 3 — Use Screen Recording to Capture Shorts Content
Screen recording is the go-to method for gaming clips, app walkthroughs, software tutorials, and reaction content. The main challenge: your screen is 16:9 by default, so you’ll need to crop or frame your capture to vertical before uploading.
  1. Choose your recording tool.
  • Xbox Game Bar (Windows built-in): Press Win + G to open, then hit the record button. Ideal for quick gaming clips with minimal setup.
  • OBS Studio (free, cross-platform): Use this when you need scene switching, overlays, or more precise control over what’s captured.
  1. Record your clip. Aim for under 60 seconds to guarantee Shorts classification.
  2. Crop or reframe to 9:16. Most screen recordings capture your full monitor in 16:9. In your video editor, use a vertical crop (1080×1920) and position your focal content — gameplay action, cursor, face cam — within the vertical frame. Avoid simple letterboxing with black bars if possible; it tends to reduce engagement.
  3. Add captions or on-screen callouts if needed to make the content readable at mobile viewing size.
  4. Export as MP4 and upload via YouTube Studio using Method 1.
Pro Tip: If you use OBS, you can set a custom canvas size of 1080×1920 to record vertically from the start, eliminating the reframe step entirely. Go to Settings → Video and set the Base Canvas Resolution to 1080×1920.
How to Optimize Your Short Before Publishing on PC
After your file uploads and before you hit publish, take two to three minutes to complete these optimization steps inside YouTube Studio. This is where discoverability is won or lost.
  • Title: Write a clear, benefit-focused title and place #Shorts at the end. Keep it under 60 characters. Example: How to Set Up Dual Monitors on a Budget #Shorts
  • Description: Add 2–3 sentences describing what viewers will learn or see. Follow with 3–5 hashtags: always include #Shorts plus 2–3 topical tags relevant to your content.
  • Thumbnail: YouTube auto-selects a frame for Shorts, but you can upload a custom thumbnail that also displays in search results and some shelf placements. Use bold text and high contrast if you go custom.
  • Audience setting: Always specify whether the content is “Made for Kids.” Incorrect settings can limit features and affect how the algorithm distributes your video.
  • Visibility: If you’re publishing immediately, select Public. Use Scheduled if you want to hit a specific day or time for your audience.
  • Chapters/timestamps: Not needed for Shorts — skip this step.
Q1: Can I make YouTube Shorts on PC without a phone?
Yes — completely. As long as you have a vertical video file (9:16, under 60 seconds) and access to YouTube Studio in a browser, you can create, edit, and publish a Short entirely from your PC. The mobile app offers a built-in Shorts camera, but you don’t need it for a fully functional workflow.
Q2: Why isn’t my upload showing as a Short?
The most common reason is that the video wasn’t exported in 9:16 vertical format — YouTube sees it as a regular horizontal or square video. Check your export resolution, re-export at 1080×1920, and re-upload. Also confirm that #Shorts appears in the title or description, and that the video is under 60 seconds.
Q3: Is there a YouTube Shorts editor built into YouTube Studio on desktop?
YouTube Studio on desktop includes basic in-browser trimming, but there’s no dedicated Shorts creation tool comparable to the mobile app experience. If your footage needs any real editing — cuts, captions, music, graphics — use a desktop editor like CapCut for PC or DaVinci Resolve first, then bring the finished file into Studio for upload.
Q4: What’s the best free video editor for YouTube Shorts on PC?
CapCut for PC is the most accessible option for beginners — it includes preset vertical templates that match Shorts dimensions and has a simple drag-and-drop interface. For creators who want more control over color, audio, and effects without paying for software, DaVinci Resolve is the most capable free option available.
Final Thoughts
Making YouTube Shorts on PC is a completely viable workflow — it just requires a bit of upfront setup around format. Get your video into 9:16 vertical, stay within the length limit, edit in a desktop tool if needed, and use YouTube Studio’s browser uploader to publish. The process is repeatable and doesn’t require a phone at any step.
