DaVinci Resolve ranks among the most capable free video editors. It handles the full YouTube production process inside one application. But its multi-page layout can feel confusing for new users. Therefore, this guide explains every stage from project setup to final export. It also covers timeline setup, color grading, and audio mixing. The process ends with exporting a YouTube-ready file in proper settings. Everything shown here focuses only on real YouTube creator needs.
Setting Up a YouTube-Ready Project in DaVinci Resolve
Getting your project settings right before you import a single clip saves significant rework later. DaVinci Resolve separates project settings (which govern the master timeline behavior, color science, and rendering defaults) from individual timeline settings (which can override the project on a per-sequence basis). For most YouTube creators, keeping these in sync is the safest approach.
To create a new project, open the Project Manager, click the blank project tile, name your project, and double-click to open it. Then navigate to File > Project Settings (or press Shift+9) and confirm the following before you do anything else.
Master Settings to configure:
Timeline Resolution: Set to 1920x1080 for standard YouTube or 3840x2160 for 4K channels.
Timeline Frame Rate: Match your camera’s native frame rate (more on this below).
Playback Frame Rate: Match the timeline frame rate.
Color Science: Set to DaVinci YRGB. Leave Color Processing Mode at SDR unless you shoot in HDR.
Output Color Space: Rec.709 Gamma 2.4 for standard YouTube delivery.
Once you save these settings, create your first timeline by going to File > New Timeline and confirming that the timeline inherits the project settings rather than creating a custom override.
Quick-Reference Table: Common YouTube Creator Setups
Creator Type |
Resolution |
Frame Rate |
Color Space |
Vlogger / Talking Head |
1920x1080 |
30fps |
Rec.709 |
Cinematic / Travel |
1920x1080 or 4K |
24fps |
Rec.709 |
Gaming / Screen Capture |
1920x1080 or 4K |
60fps |
Rec.709 |
1080x1920 |
30fps |
Rec.709 |
Tutorial / Educational |
1920x1080 |
30fps |
Rec.709 |
Choosing the Right Frame Rate and Resolution for Your Channel
The most common beginner confusion point is mixing frame rates between camera footage and timeline settings. Here is a practical set of rules to follow:
Use 30fps for vlogs, talking-head videos, tutorials, and any content that looks natural and documentary-style. YouTube’s algorithm and viewer expectations align with this standard.
Use 24fps for cinematic-feeling travel, short film, or narrative content. It reads as intentionally filmic rather than accidental.
Use 60fps for gaming, sports, product demos, or any content where motion clarity and smoothness matter more than aesthetic feel.
Use 1080p if your audience watches primarily on phones or average monitors, or if you are prioritizing faster export and upload times.
Use 4K if you own a 4K camera, want extra reframing flexibility in the edit, or want to future-proof your archive. YouTube still re-encodes, but 4K uploads are treated with higher-quality compression passes.
Note: If your camera shoots at 25fps (common in PAL-region cameras), set your timeline to 25fps. Mismatched frame rates cause subtle playback judder that no amount of post-processing will fix cleanly.
Importing and Organizing Footage
With your project configured, bring your media into DaVinci Resolve using the Media Page (click the photo icon at the bottom of the screen).
Step-by-step import process:
In the left panel of the Media page, navigate to your footage folder using the folder browser.
Select your clips (Ctrl+A / Cmd+A to select all) and drag them into the Media Pool in the center panel.
Right-click inside the Media Pool and select New Bin. Create bins named by shoot day, clip type, or content category (e.g., “A-Roll,” “B-Roll,” “Music,” “Graphics”).
Drag your imported clips into the appropriate bins to keep your project organized.
If your machine struggles with playback, right-click selected clips and choose Generate Optimized Media or Generate Proxy Media. Proxies create lightweight stand-in files that maintain sync with originals and are swapped out automatically at export.
DaVinci Resolve supports MP4, MOV, MXF, R3D, and BRAW natively, so most camera formats load without transcoding. The proxy workflow is particularly valuable for creators editing 4K footage on mid-range laptops.
Editing Your Video on the Cut and Edit Pages
DaVinci Resolve offers two editing environments: the Cut Page and the Edit Page. Understanding when to use each one prevents the most common workflow frustration beginners experience.
The Cut Page is designed for speed. Its dual-timeline layout, Smart Cut tools, and source tape behavior let you assemble a rough cut quickly without managing multiple timeline tracks manually. It is ideal for solo YouTube creators who need to turn around a video in a few hours.
The Edit Page mirrors the traditional NLE layout (similar to Premiere Pro or Final Cut Pro) and gives you full control over multi-track timelines, precise trimming tools, and advanced clip manipulation. Use it for the refinement pass after your rough cut is done.
Using the Cut Page for Fast YouTube Assembly
The Cut Page’s source tape loads all clips in your bin as a continuous reel, so you can scrub through footage without clicking individual clips.
Click the image with a cut icon at the bottom to open the Cut Page.
In the source viewer on the left, scrub through your footage to find a usable section.
Press I to mark an In point and O to mark an Out point.
Click F9 (Insert) or F10 (Append) to place the marked clip onto the timeline, or drag it directly to the lower timeline strip.
Repeat for each clip. Use the Split Clipt button (the scissor icon) to split and remove sections with a single drag.
Use Timeline Sync to lock audio and video tracks so cuts stay aligned when you rearrange.
The Cut Page’s dual-timeline display (a zoomed-out overview strip below a magnified working strip) keeps you oriented in the full video while working on individual sections.
Refining Your Edit on the Edit Page
Once your rough cut is assembled, switch to the Edit Page (press Shift+4 or click the film-strip icon). Here you have access to the full trim toolkit.
The most important technique for YouTube dialogue content is the J-cut and L-cut. A J-cut lets the audio from the next clip begin while the previous clip’s video is still visible, creating a natural conversational transition. An L-cut does the reverse: the current video continues while the next clip’s audio begins. Both make dialogue flow more naturally and avoid the choppy, jump-cut feel that undermines viewer retention.
Use the Trim Edit Mode (press T) to grab the edge of any clip and roll the trim point. Hold Alt/Option while clicking to trim only one side of an edit independently.
The magnetic timeline behavior in the Edit Page prevents accidental gaps when you delete clips, which keeps your workflow clean without manual gap-closing.
Adding Titles, Text, and Simple Transitions
For YouTube-specific text elements, use the Text+ generator rather than the basic Title generator. Text+ gives you per-character animation, gradient fills, and outline controls that work well for lower thirds, chapter headings, and name tags.
To add Text+, go to the Effects Library (Toolbox > Titles > Text+), drag it onto a video track above your footage, and double-click to edit the content in the Inspector panel on the right.
Recommended transitions for YouTube:
Cross Dissolve for smooth scene transitions
Dip to Black for section breaks or dramatic pauses
Cut (no transition) for fast-paced content and most dialogue sequences
Avoid the stock wipe, page curl, and 3D transitions included in the Effects Library. They read as dated and distract from the content. Restraint in transitions consistently improves perceived production quality.
Color Grading Your YouTube Videos
Color grading is where DaVinci Resolve genuinely earns its reputation. The Color Page (press Shift+6) gives you node-based grading with hardware-grade scopes and professional controls. For YouTube, the goal is not a dramatic look; it is consistency, accuracy, and resilience to YouTube’s re-compression.
A simple two-node workflow for YouTube:
Select the color palette icon to open the Color Page. Click on the first clip in the Color Page timeline strip at the bottom.
Right-click in the Node Editor (top right) and add a Serial Node. Name the first node “Primary Correction” and the second “Look.”
On the Primary Correction node, use the Lift/Gamma/Gain wheels (or the Custom Curves) to balance shadows, midtones, and highlights. Lift controls blacks, Gamma controls midtones, and Gain controls highlights.
Use Color Wheels to correct any color cast in your footage. If your whites have a yellow tint, push the Gain wheel slightly toward blue.
On the Look node, apply your stylistic grade: a slight orange-teal grade, a warm look, or a LUT (see below).
Once a clip is graded, right-click it in the timeline strip and select Apply Grade to copy it to similar clips, or use the Gallery to save and paste grades across shots.
Using Scopes to Color Grade for YouTube’s Display Standards
Open the Scopes panel (go to View > Scopes or press Ctrl+Shift+W / Cmd+Shift+W) and set the display to Parade and Vectorscope.
The Parade scope shows your red, green, and blue channels as separate waveforms. Keep your highlights below 100 IRE and your shadows above 0 IRE. Anything crushed to pure black or blown to pure white loses detail and becomes more pronounced after YouTube’s re-encoding pass. The Vectorscope shows your color saturation. For YouTube-safe Rec.709 delivery, keep saturation within the inner target box. Over-saturated reds and yellows in particular compress poorly on YouTube and often appear blotchy or noise-like after upload.
Applying LUTs for a Consistent Channel Look
A LUT (Look-Up Table) applies a preset color transformation to your footage and is the fastest way to build a repeatable channel aesthetic.
To load a LUT in DaVinci Resolve, right-click inside the Color Page node editor, select Add Node > LUT, then right-click that node and choose 3D LUT > Browse to navigate to your LUT file. Alternatively, drop a LUT onto the Look node and adjust the Key Output Gain slider in the node to reduce intensity (0.5 is often a good starting point rather than full strength).
Free LUTs are available from sources like Ground Control, Lutify.me, and many camera manufacturers. Paid LUTs from colorists like Dehancer or Film Riot’s packs are worth considering if you want a distinctive and well-tested channel look.
Mixing Audio in Fairlight for YouTube
Audio quality directly affects watch time. Viewers tolerate imperfect visuals far longer than they tolerate audio that is too quiet, too loud, tinny, or full of background noise. Open the Fairlight Page to access DaVinci Resolve’s professional audio mixer.
Core audio mixing workflow for YouTube:
Identify your dialogue track in the mixer. It will typically appear as a mono or stereo track labeled by its camera source.
Set your dialogue track’s peak levels to sit between -12 dBFS and -6 dBFS. Anything consistently above -6 dBFS will clip or distort; anything below -18 dBFS will be too quiet relative to background music.
Apply the EQ plugin (right-click the track’s FX bin > Fairlight FX > Equalizer) to roll off low-frequency rumble below 80 Hz using a High Pass filter. Boost presence slightly around 2kHz-5kHz if the voice sounds muddy.
Apply the Dynamics plugin. Set the compressor threshold to catch peaks above around -12 dBFS and use a 3:1 to 4:1 ratio to even out volume inconsistencies in recorded speech.
Apply Noise Reduction (Fairlight FX > Noise Reduction) on clips with background hum or room noise. Print a noise profile from a section of clean room tone, then apply it across the clip.
Set music and ambient B-roll tracks 15 to 20 dB lower than your dialogue track. Dialogue should always be dominant.
Use the Loudness Meter to check your integrated LUFS reading before export. To open the Loudness Meter in Davinci Resolve 21, click the Meters button (represented by bars) in the top-right corner (next to the Mixer button).
Meeting YouTube’s -14 LUFS Loudness Standard
LUFS (Loudness Units relative to Full Scale) is the measurement YouTube uses to normalize all video audio during playback. YouTube targets -14 LUFS integrated loudness. If your video is louder, YouTube turns it down. If it is quieter, viewers manually raise their volume or abandon the video.
To check your mix, play the full timeline and watch the Integrated reading in the Loudness Meter panel. Your goal is a reading of -14 LUFS (+/-1). If you are consistently hitting -18 or -20 LUFS, increase your dialogue track’s gain. If you are at -10 LUFS, pull it back. The Normalization function in the Fairlight mixer can automate this adjustment once you are satisfied with your relative track balance.
Starting with Clean Audio (Upstream Tip)
Fairlight’s noise reduction tools are powerful, but they work best when the source audio is already reasonably clean. For creators who record direct-to-camera, starting with a reliable wireless microphone drastically reduces the amount of noise reduction work needed in post. The Hollyland LARK M2, for example, weighs just 9 grams and offers up to 40 hours of battery life, making it a practical option for vloggers who need clean dialogue capture without managing bulky gear. Clean recordings translate directly into less processing on the Fairlight page and better results through YouTube’s compression.
Export Settings for YouTube — Getting It Right on the Deliver Page
The Deliver Page (press Shift+8 or click the rocket icon) is where your finished timeline becomes an upload-ready file. Incorrect export settings are one of the most common reasons YouTube videos look soft, over-compressed, or visually degraded after upload.
Recommended YouTube export settings (manual configuration):
Setting |
Recommended Value |
Why It Matters |
Format |
MP4 |
Universal YouTube compatibility |
Codec |
H.264 (1080p) / H.265 (4K) |
Best quality-to-file-size ratio |
Resolution |
Match timeline (1920x1080 or 3840x2160) |
Avoids unnecessary scaling |
Frame Rate |
Match timeline (24 / 30 / 60fps) |
Prevents frame duplication artifacts |
Quality |
Restrict to 16,000 kbps (1080p) / 35,000–45,000 kbps (4K) |
Gives YouTube more data to work with during re-encode |
Audio Codec |
AAC |
Required for YouTube |
Audio Bitrate |
320 kbps |
Maximum quality for stereo audio |
Audio Channels |
Stereo |
Standard YouTube playback |
Adding your export to the Render Queue:
Set your In and Out points on the Deliver Page timeline (or leave blank to export the full timeline).
Configure all settings in the left-side panel.
Click Add to Render Queue at the bottom of the settings panel.
Repeat for any additional exports (such as a short-form version or audio-only file).
Click Render All in the Render Queue panel on the right. DaVinci Resolve will process your timeline and save the file to your specified output folder.
Pro Tip: Rendering to an intermediate format like ProRes 422 or DNxHR before uploading to YouTube can further improve quality, especially for high-motion content. Upload the ProRes file and let YouTube’s encoder work from the highest quality source available rather than a pre-compressed H.264 file.
YouTube Preset vs. Custom Settings — Which to Use
DaVinci Resolve includes a built-in YouTube preset under the preset dropdown at the top of the Deliver Page’s settings panel. It is a reliable starting point for most creators.
YouTube Preset |
Manual H.264/H.265 Settings |
Best for |
Casual uploads, first-time exports |
High-motion content, 4K, color-critical work |
Codec |
H.264 |
H.264 or H.265 (your choice) |
Bitrate control |
Automatic |
Manual restriction for higher ceiling |
Audio |
AAC, auto bitrate |
AAC, 320 kbps manually set |
Setup time |
Under 1 minute |
2-3 minutes |
For gaming channels, action vloggers, or any content with significant fast motion, manual settings with a higher bitrate ceiling consistently produce cleaner results after YouTube’s re-compression. The preset is fine for talking-head tutorials and low-motion content.
Workflow Tips to Edit YouTube Videos Faster in DaVinci Resolve
Once you have the core workflow down, these efficiency habits compound over time and meaningfully reduce editing hours per video.
Learn the core keyboard shortcuts: B activates the Blade tool for splitting clips, Space bar plays and pauses, I and O mark in and out points, and Ctrl+Z / Cmd+Z undoes any action. These four cover 80% of your timeline interactions.
Save a custom export preset: After configuring your YouTube export settings, click the preset dropdown and choose Save As New Preset. Name it “YouTube 1080p Master” or similar. It will be available for every future project.
Use Power Bins for channel-wide assets: Power Bins appear in the Media Pool across all projects. Store your channel logo animation, intro/outro sequences, lower-third templates, and licensed music bed here so they are always accessible.
Create Timeline Templates: Once you have a polished intro with your logo, music, and text styled correctly, export the sequence as a DaVinci Resolve timeline and re-import it at the start of each new project.
Use the Cut Page’s Source Tape for long footage: Rather than scrubbing through individual clips, the source tape lets you review all footage in one continuous pass, which is especially efficient for talking-head or interview footage.
Set Viewer quality to Half or Quarter during editing: Under the viewer’s playback quality dropdown, dropping resolution during the edit pass keeps playback smooth on lower-spec machines without affecting export quality.
Q: Is the DaVinci Resolve free version good enough for YouTube?
Yes. The free version includes the full Edit Page, Cut Page, Color Page, Fairlight audio mixer, and Deliver page. You can complete a professional YouTube workflow without spending anything. The Studio version adds neural engine noise reduction, certain effects plugins, and collaboration features, but most YouTubers will never need them.
Q: What is the best export format for YouTube in DaVinci Resolve?
H.264 at a bitrate of at least 16,000 kbps is the standard recommendation for 1080p uploads. For 4K content, H.265 at 35,000-45,000 kbps delivers strong quality. Always match your export frame rate to your timeline frame rate and set audio to AAC at 320 kbps.
Q: Why does my video look different after uploading to YouTube?
YouTube re-encodes every upload using its own compression. To preserve quality, export at a higher bitrate than YouTube’s minimum, use Rec.709 color space, and avoid over-saturated color grades. Uploading from a ProRes or high-bitrate H.264 master gives YouTube’s encoder more quality to work with.
Q: Which DaVinci Resolve page should I use to edit YouTube videos?
Most YouTube creators use the Cut Page for fast rough assembly and the Edit Page for precision trimming and multi-track work. Color grading happens on the Color Page, audio mixing and cleanup on the Fairlight Page, and export configuration on the Deliver Page.
Q: Can I use DaVinci Resolve for vertical YouTube Shorts?
Yes. In Project Settings, set your timeline resolution to 1080x1920 for a 9:16 portrait aspect ratio. The rest of your workflow, including editing, color grading, audio mixing, and export, works exactly the same as a standard horizontal video.
YouTube editing in DaVinci Resolve follows six main stages. Proper project setup comes first in the workflow. After that, you import and organize video clips carefully. Editing takes place inside Cut and Edit pages. Color work happens inside the Color page section. Audio mixing is done in the Fairlight workspace area. Final export happens from the Deliver page using YouTube settings. Every step is included in the free version. Saving the export preset after the first render saves time. The advanced color grading guide improves the visual style further.
