Motorcycle Vlog Setup: The Complete Gear Guide for Riders Who Want Great Footage
Starting a motorcycle vlog needs more than mounting a camera and recording. The gear you pick decides if your footage looks good or forgettable. This guide shows what you need in a clear and simple way. It explains which cameras stay steady at high riding speeds. It also covers the best mounting spots for clean angles. You will learn how to record clear audio while riding. It also explains how to keep your gear powered all day.
What Makes a Motorcycle Vlog Setup Different?
Most vlogging gear is designed for people standing still or walking slowly. A motorcycle changes every assumption.
Three forces work against you simultaneously. Vibration from the engine travels through the frame, through your mount, and directly into your camera sensor, producing the jello-effect wobble that kills otherwise usable footage. Wind turbulence at highway speeds overwhelms any built-in microphone, turning your narration into unintelligible noise. And rider mobility is limited, meaning you cannot adjust, reframe, or troubleshoot equipment while moving.
These three challenges, vibration, wind, and limited access, change everything. They make a bike setup very different from a normal YouTube vlog rig.
Choosing the Right Camera for Motorcycle Vlogging
Camera choice sets the ceiling on your footage quality, but the wrong category of camera creates problems that no amount of technique can fix.
Action Cameras (Best for Most Riders)
Most riders should begin with an action camera for their setup. The GoPro Hero series and DJI Osmo Action line are common picks. They have earned this place because they suit real riding needs.
Key specs that matter for motorcycle use:
  • Electronic image stabilization: GoPro’s HyperSmooth and DJI’s RockSteady are the benchmark stabilization systems in this category. Both use digital correction to counteract vibration and movement in real time.
  • Rugged, waterproof build: Neither system requires a separate housing for rain riding, which simplifies mounting and reduces bulk.
  • Compact form factor: Smaller cameras accept more mounting positions and add less weight to a helmet's chin bar.
  • Field of view options: A wide field of view (FOV) suits handlebar mounts quite well. It shows both the road ahead and your cockpit clearly. A tighter or linear view cuts down the fisheye look. This works better on helmet shots where a natural view matters more.
A few real compromises you should keep in mind: Action cameras compress video more, unlike most mirrorless cameras. They also struggle when the light starts getting low. In bright daytime rides, this is not a big concern. But during early mornings or tunnel runs, you will see the limits clearly.
Mirrorless or Vlogging Cameras (Upgrade Path)
Riders who want a more cinematic image quality eventually look at options like the Sony ZV-E10. The image output is noticeably better: cleaner color, shallower depth of field, and stronger low-light performance.
But here are a few things you should know! Mirrorless cameras are larger, heavier, and lack the native ruggedness of action cams. Mounting one securely on a handlebar rig requires a gimbal, which adds cost and complexity. These cameras work best for stationary shots, b-roll at fuel stops, or handlebar setups where a gimbal stabilizer can do the work the smaller camera sensor cannot.
Many experienced creators end up using two cameras together. One action camera stays on the helmet and records without effort. The other is a mirrorless camera mounted on a handlebar gimbal. If you are just starting, a single action camera is the better choice.
Camera Mounting Positions — Where to Mount and Why?
Mounting position is a creative and technical decision at the same time. Where the camera sits determines the visual style, the stability profile, and how safely you can manage it.
Helmet Mount (Chin or Top)
The chin mount has become the industry default for motorcycle vlogging, and it earns that position on merit. Mounted at the chin bar of a full-face helmet, the camera sits roughly at eye level, producing a POV perspective that feels natural to viewers rather than the disorienting overhead angle of a top mount.
Top-of-helmet mounting produces shots that are heavy on sky, light on road, and more susceptible to shaking because the camera sits at the farthest point from your head’s center of mass. Mounting the camera on the chin keeps it near your line of sight. This position helps cut down on shaking in turns and on rough roads.
Pro Tip: Not every helmet supports a chin mount in the same way. Different brands shape their chin bars differently. Before buying, make sure your helmet can take an adhesive or clamp mount.
Handlebar and Fork Mount
The handlebar perspective gives viewers a cockpit-level view of the road ahead, which works well for scenic routes and technical riding sequences. But vibration is the main issue here. Engine pulses move straight through the handlebars into the camera. Without any cushioning, the video starts to look shaky and warped with a jello effect.
Setup steps for a clean handlebar mount:
  1. Choose a mount system designed for motorcycles, such as a RAM Mount ball head with a dedicated vibration isolator attachment.
  2. Attach the camera using a manufacturer-approved cage or adapter, not adhesive alone.
  3. Test at low speed in a parking lot before a full ride. Watch the test footage before committing to a long shoot.
  4. Route any cable carefully so it cannot contact the brake lines or throttle assembly.
Chest Mount
A chest-mounted camera captures a hands-on-bars perspective that works well as a secondary angle and provides good footage of throttle inputs, gear changes, and lane positioning. Comfort becomes relevant on rides longer than an hour. Chest harnesses need to sit snugly without restricting upper body movement or interfering with jacket armor placement.
Use this as a supplementary angle rather than a primary setup.
Rear/Chase Angle (Optional Add-On)
A second action camera mounted on the tail section or pillion seat bracket captures the bike from behind, which adds visual variety and works especially well on scenic roads. Running both cameras at once needs careful storage planning. Recording on two devices fills up space much faster. Therefore, using 128GB or 256GB cards in each camera helps avoid running out mid-ride. Also, a simple file naming system after the ride makes editing easier and faster.
Audio for Motorcycle Vlogging — Solving the Hardest Problem
More motorcycle vlogs fail at audio than at video. Riders invest in good cameras and mounts, then neglect the microphone, and the result is content that viewers cannot tolerate past the first thirty seconds. This section deserves as much attention as the camera section above.
Why Built-In Camera Mics Fail on a Motorcycle?
Built-in action camera microphones use omnidirectional capsules designed to capture ambient audio in controlled environments. At highway speed, wind turbulence around a helmet or camera body creates a low-frequency roar that completely masks voice audio. Engine vibration compounds the problem by adding mechanical noise directly into the camera body. No amount of post-production noise reduction recovers clean voice from footage recorded this way. The fix has to happen at the recording stage.
Wireless Lavalier Mics — The Practical Fix
For riders who narrate their content, whether at rest stops, during slow sections, or even while riding, a compact wireless lavalier microphone solves the wind noise problem by capturing audio close to the source rather than at the camera.
The Hollyland LARK M2S is the strongest recommendation in this category for motorcycle use specifically. At 7 grams, the transmitter body is light enough to clip inside a helmet liner or attach to a jacket collar without shifting at speed. The titanium clip design holds position through vibration and movement without the bulk of traditional lavalier clips. Its no-logo invisible profile keeps the setup clean for riders who prefer a minimal look. Battery life is 30 hours, which covers a full day of touring without needing to manage transmitter charging between sessions. Pair the transmitter inside the helmet or on the collar; the receiver connects to the camera or to a separate recording device if your camera does not have an audio input.
This is not a workaround solution. It directly addresses the core problem: getting clean voice audio at speed.
Helmet Intercom Systems as a Secondary Audio Option
Riders who already own a Cardo Packtalk or Senna intercom system sometimes ask whether they can route audio from the intercom to the camera. Well, this is possible in some cases, but it comes with clear limits. Most modern intercom units can output audio via an aux cable or Bluetooth connection, and some riders do use this setup. The practical issues are Bluetooth latency (audio and video can fall out of sync), audio compression artifacts from the intercom processing, and compatibility limitations that vary by unit and camera. If you already own an intercom, it is worth testing. For anyone building a setup from scratch, a dedicated wireless lavalier is a more reliable primary solution.
Foam Windscreens and Deadcat Covers
Physical wind protection on the microphone capsule itself significantly reduces turbulence noise before it even reaches the recording, working alongside rather than instead of a wireless mic system.
Windscreen options and placement:
  • Foam windscreen (supplied): Most lavalier mics include a small foam cover. Use it. Do not remove it for a cleaner look.
  • Deadcat fur cover: A fur-style deadcat windscreen over the capsule reduces wind turbulence noise by an estimated 60 to 70 percent. Several aftermarket options fit standard lavalier capsule sizes.
  • Placement: Positioning the mic in a slightly sheltered location, such as under the chin bar rather than directly exposed to airflow, compounds the benefit of the windscreen.
Power and Battery Management on Long Rides
Action cameras typically deliver 60 to 90 minutes of recording time per charge under normal conditions. Stabilization features and cold temperatures reduce that further. For any ride longer than an hour, a power strategy is not optional.
  • USB-C power bank: A compact, high-capacity power bank routed to the camera via a weather-resistant USB-C cable allows continuous recording without interruption. Secure the bank in a tank bag or tail pack and route the cable cleanly away from controls.
  • Spare batteries with rotation schedule: Carry two or three spare batteries and plan battery swaps at natural stops. A small labeled case keeps charged and depleted batteries separated.
  • Bike-mounted USB charger: A 12V-to-USB-C adapter wired to the accessory circuit provides continuous power when the engine is running. Many touring riders use this to charge devices and power cameras simultaneously.
  • Memory card planning: 64GB is the practical minimum for a half-day ride. Full-day touring, especially with two cameras running, warrants 128GB cards in each camera. Format cards before every ride, not at home the night before.
Complete Setup Recommendations by Budget
Setup Tier
Camera
Mount
Audio
Power
Entry (Under $300)
GoPro Hero (previous gen) or DJI Osmo Action 4
Chin helmet mount
Hollyland LARK M2S
1 spare battery + USB power bank
Mid ($300–$700)
GoPro Hero 13 or DJI Osmo Action 5
Chin mount + handlebar vibration mount
Hollyland LARK M2S
Bike USB charger + 2 spare batteries
Advanced ($700+)
Sony ZV-E10 + action cam (dual rig)
Custom RAM mount + gimbal
Hollyland LARK M2S
Full power management system
The audio solution stays consistent across all three tiers. Wind noise is not a problem that resolves itself as you spend more on a camera. Address it at every level.
Quick Setup Checklist Before Every Ride
Run through this before departure. Most avoidable footage losses happen in the first five minutes of a ride.
  1. Charge all batteries the night before, including the camera and mic transmitter/receiver.
  2. Format memory cards in-camera, not via a computer, to clear any file system errors.
  3. Check the mount security on the helmet, handlebars, and any secondary positions. Tug each mount firmly.
  4. Confirm the field of view setting matches your intended angle (wide for handlebars, linear for helmet chin).
  5. Arm the wireless mic and confirm the receiver is connected and showing a signal.
  6. Record a 30-second test clip at the end of your driveway and review the audio before committing to a long ride.
  7. Check storage remaining on each card. If it reads under 20GB, swap to a fresh card.
  8. Secure all cables away from brake levers, throttle, and clutch.
  9. Start recording before pulling out of the driveway, not after you’re already moving.
  10. Note your battery swap schedule for the ride so you are not troubleshooting storage mid-route.
What is the best camera for motorcycle vlogging?
The GoPro Hero 13 and DJI Osmo Action 5 Pro are the two strongest choices for most riders right now. Both offer class-leading stabilization, a rugged weather-resistant build, and broad mount compatibility. Either one outperforms a mirrorless camera for active riding use. Choose based on your preferred ecosystem and whether you already own other GoPro or DJI accessories.
How do I reduce wind noise in motorcycle videos?
Use an external wireless lavalier microphone rather than the built-in camera mic. Add a deadcat fur windscreen to the capsule and position the mic in a sheltered location, such as under the helmet chin bar, rather than directly exposed to airflow. Built-in camera mics cannot be saved with post-production alone at highway speeds.
Where should I mount my GoPro on my motorcycle?
The chin mount on a full-face helmet is the most stable and visually compelling option for most riders. It produces a natural eye-level POV with minimal distortion. Handlebar mounts are a strong secondary angle but require a vibration dampener, such as a RAM Mount vibration isolator, to prevent jello-effect footage from engine frequency.
Can I vlog while riding a motorcycle?
Set all the camera and audio equipment before you start. Then begin recording and let it capture the journey. Once everything is set, the gear runs on its own while riding. You don't need to adjust anything during the ride. For speaking while moving, a wireless lavalier mic helps you talk inside the helmet. Longer explanations are better done during stops where the sound is clearer.
What microphone works best for motorcycle vlogging?
A compact wireless lavalier designed for active and sports use is the right category. The Hollyland LARK M2S is made for this kind of setup. It uses a tiny 7g titanium clip transmitter. The battery can last up to 30 hours. Plus, its clean design has no visible branding at all. The clip holds firmly inside a helmet liner or jacket collar. Also, it stays in place even during long riding sessions.
Two main factors decide if your motorcycle vlog feels worth watching. Clear sound and good camera placement matter more than complex setups. Even a simple setup with clean audio works pretty great. It often performs better than multiple cameras with noisy wind sound.
Start with one reliable action camera and a chin mount first. Add a wireless lav mic for clearer spoken audio recording. For a starter, use this equipment on several rides until it feels stable. Later, you can add more angles or upgrade gear gradually.
