How to Use a Wireless Lavalier Microphone: Step-by-Step Guide
A wireless lavalier microphone gives you clean, hands-free audio without being tethered to your camera. But unboxing one for the first time can leave you staring at two small units and a cable, unsure where to start. This article shows each stage step by step. It starts with charging and pairing the system. Next, it explains how to attach the mic properly. Then it shows how to connect it to your device. Finally, it helps you adjust audio levels correctly. We’ll use the Hollyland LARK M2 as the primary reference so every step maps to real hardware.
What Is a Wireless Lavalier Microphone System?
A wireless lavalier system has two parts: a transmitter and a receiver. The transmitter clips to the speaker’s clothing and captures audio. The receiver plugs into your camera, phone, or computer and delivers that audio signal wirelessly. This cable-free setup is ideal for vloggers, interviewers, presenters, and event videographers who need freedom of movement without sacrificing audio quality.
Confirm you have the following before powering anything on:
  • Transmitter unit: The clip-on body that captures audio
  • Receiver unit: Connects to your camera, phone, or computer
  • Charging case or USB-C cable: The LARK M2 includes a compact charging case with a USB-C port that charges both units simultaneously
  • Output cable: 3.5mm TRS for cameras, 3.5mm TRRS / USB-C for phones. Match it to your recording device’s input
  • Windscreen or deadcat: Optional but strongly recommended for outdoor shoots
Note: The microphone capsule is built directly into the transmitter body. There is no separate capsule to attach. The case ships with the transmitter, receiver, an output cable, and a USB-C charging cable.
Step 1: Charge and Power On the System
Starting with depleted batteries is one of the most common causes of pairing failures and signal drops. Charge both units fully before your first shoot.
To charge the LARK M2:
  1. Place both the transmitter and receiver into their designated slots in the charging case.
  1. Connect the USB-C cable to the port on the case body, not directly to the individual units.
  1. Watch the LED indicators on the case front. Each illuminated dot represents a portion of remaining charge. All dots lit and solid means both units are fully charged.
  1. A full charge from empty typically takes around 1.5 hours.
To power on:
  1. Remove both units from the charging case.
  2. On the transmitter, press and hold the power/function button for around three seconds until the LED activates.
  1. On the receiver, press and hold its power button until the LED or display activates.
  1. Both units complete startup within a few seconds.
First-use tip: The LARK M2 ships from the factory with the transmitter and receiver pre-paired. Removing both units together and powering them on as a pair preserves that factory link automatically. Avoid powering units on separately or at a distance from each other during the first boot, as this can disrupt the factory pairing and require a manual re-link.
Step 2: Pair the Transmitter and Receiver
The LARK M2 uses automatic pairing in most situations. Understanding the manual pairing process means you can recover quickly if something goes wrong.
Auto-pairing (standard workflow):
  1. Store both units in the charging case together after every use.
  2. Remove them and power them on. The LARK M2 transmitter and receiver communicate through the case and re-establish their link on startup automatically.
  3. Watch the LED indicators on both units. A blueblinking LED means the unit is searching for its partner. A solid blue LED means the link is confirmed and active.
  1. The blink-to-solid transition typically takes two to five seconds.
Manual pairing (if auto-pairing fails or you are adding a second transmitter):
  1. First, make sure both units are powered off.
  2. Then, press and hold the multi-function button on the transmitter for approximately six seconds (while the TX is in the turned-off state) until the LED begins flashing rapidly. This places the unit in pairing mode.
  3. Repeat the same hold sequence on the receiver.
  4. Once both units detect each other, the LEDs shift from rapid blinking to solid, confirming a successful link.
If pairing does not work, place both units close together. Keep them about one to two meters apart during setup. Check that both devices have enough battery power. Also confirm neither device was reset to factory settings. A factory reset removes saved pairing information completely. You must repeat the full pairing steps to reconnect them.
Step 3: Clip and Position the Lavalier Microphone
Mic placement affects recording quality more than anything else. Many beginners lose clean sound because positioning is not done carefully.
Step 3 — Clip and Position the Lavalier Microphone
The three rules of lavalier mic placement:
  1. Position the capsule 15 to 20 cm (6 to 8 inches) below the chin. This distance produces natural voice tone without the bass buildup that comes from being too close or the thin, distant quality that results from being too far away.
  2. Center the mic on the chest or place it slightly off-center. Centering keeps the pickup pattern aimed toward the mouth even when the speaker turns their head slightly.
  3. Capsule faces upward toward the mouth. An inverted or sideways capsule pressed against fabric will sound muffled.
Attaching the LARK M2:
The transmitter body is the microphone on the LARK M2. Open the spring clip on the back of the transmitter and attach it to a shirt collar, lapel, or the placket between shirt buttons. Confirm the front face points upward and outward rather than flat against the fabric.
You can also use the magnetic attachment to attach the mic. Or, use the provided lanyard to wear the TX like a necklace.
The LARK M2’s compact 9g body reduces clothing rustle risk compared to bulkier transmitter designs. For loose or textured fabric, a small strip of gaffer tape alongside the clip prevents the unit from shifting during recording.
Common placement mistakes to avoid:
  • Clipping too high (at the collarbone) or too low (mid-chest or below)
  • Allowing fabric to fold over or press against the capsule face
  • Placing the unit under a heavy jacket without a fabric opening
  • Leaving cables free to swing and brush against clothing between takes
Step 4: Connect the Receiver to Your Camera, Phone, or Computer
With the transmitter clipped and the system paired, connect the receiver to your recording device. The connection method depends on what you are recording to.
Connecting to a Camera
  1. Locate the 3.5mm output port on the LARK M2 receiver.
  1. Run the included 3.5mm TRS cable from the receiver output into your camera’s external microphone input, usually labeled “MIC.”
  1. In your camera’s audio settings, set the input source to External Mic or Line In based on your receiver’s output level.
  2. Watch your camera’s audio meters while someone speaks into the transmitter to confirm the signal is arriving.
Connecting to a Smartphone
  1. Connect the LARK M2 receiver to your phone using a 3.5mm TRRS adapter (for phones with a headphone jack) or a USB-C adapter (for phones without one).
  1. Open your camera app. Most apps switch to the external input automatically when a cable is detected, but verify this in the app’s audio settings.
  2. For a simpler smartphone workflow, the Hollyland LARK A1 is worth noting here. It offers dedicated USB-C and Lightning receiver options, making smartphone recording fully plug-and-play without any additional adapter required.
Connecting to a Computer
  1. Run the receiver’s USB-C output into your computer’s USB-C input port, or use USB-C if your receiver supports it.
  1. In your computer’s audio settings, select the external input as the active recording source.
  2. Confirm the signal level in your recording software before starting your session.
Step 5: Set Your Audio Levels and Gain
Gain staging determines whether your audio is clean and usable or buried in noise and distortion. Setting levels correctly here saves significant post-production time.
Too little gain amplifies your noise floor when you boost in post. Too much gain clips the signal at 0 dBFS, which is unrecoverable. The target for spoken dialogue is a peak of approximately -12 dBFS, leaving enough headroom to handle sudden volume spikes without distortion.
Setting gain on the LARK M2:
  1. Power on the full system and have the speaker use their normal recording voice.
  2. On the LARK M2 receiver, use the gain adjustment button (volume knob) to set levels.
  1. Cross-check against the audio meters in your camera or recording software.
  2. Run a 20-second test recording, play it back through headphones, and fine-tune only if the level is clearly off.
For cameras without automatic gain control options, set the audio input level inside the camera’s audio menu to match what the receiver is outputting. Avoid enabling automatic gain control (AGC) if you can, as it creates audible volume pumping during quiet pauses.
Pro Tip: If you want to remove gain management from your workflow entirely, the Hollyland LARK MAX 2 features 32-bit float internal recording on the transmitter body. This captures the full dynamic range with no clipping, regardless of how input levels are set. Even if your camera recording clips, the backup file stored directly on the transmitter will be clean and recoverable in post.
Step 6: Monitor Your Audio in Real Time
Recording audio without monitoring it is the fastest way to discover a problem after it is too late to fix. A quick check before rolling catches noise issues, pairing dropouts, and gain problems before they cost you a reshoot.
Step 6 — Monitor Your Audio in Real Time
Your monitoring options:
  • Camera headphone jack: Most DSLRs and mirrorless cameras include a 3.5mm headphone output. Connect headphones and enable monitoring in the camera’s audio menu. The practical limitation is latency: a slight delay between speaking and hearing the output can be disorienting during extended takes.
  • Dedicated wireless monitoring via LARK MAX 2: The Hollyland LARK MAX 2 supports real-time monitoring through its OWS (open-ear wireless) earphones, which connect directly to the receiver. This creates a direct audio connection with low latency. It lets the speaker or operator hear the microphone live without waiting for the camera.
When recording in a quiet and controlled space, a quick test recording is usually enough. Play it back through headphones to confirm everything sounds right without extra equipment.
Tips for Capturing Clean, Professional Audio
Small habits at setup and on-set prevent the most common audio problems from reaching post-production.
  • Use a windscreen outdoors: Even a light breeze against an unprotected capsule produces low-frequency rumble that is difficult to remove cleanly. Attach a foam windscreen or deadcat before every outdoor session.
  • Avoid rooms with hard, reflective surfaces: Empty rooms, bathrooms, and tiled spaces introduce reverb that makes voices sound thin and distant. Soft furnishings and curtains absorb reflections effectively.
  • Brief the speaker on head movement: Turning more than 45 degrees away from the transmitter can noticeably drop audio levels mid-take. A quick mention before rolling prevents the problem.
  • Always run a test recording first: Record 20 to 30 seconds of normal speech, play it back through headphones, and confirm there are no dropouts, noise issues, or clipping before committing to the real take.
  • Keep transmitters away from 2.4 GHz devices: WiFi routers and other Bluetooth or wireless devices operating on the same frequency band can cause dropouts. Maintain separation where possible, particularly in home offices or event venues packed with wireless equipment.
  • Toggle AI Noise Cancellation when background noise is unavoidable: On the Hollyland LARK MAX 2, AI Noise Cancellation is activated through the multi-function button on the transmitter or through the HollyAudio app. Use it when HVAC systems, outdoor ambient noise, or similar constant sources cannot be removed from the environment.
Advanced Settings: Noise Cancellation, Internal Backup Recording, and App Control
Once the standard setup is working, the following features on the Hollyland LARK MAX 2 move your workflow from functional to professional-grade.
AI Noise Cancellation processes the incoming audio signal in real time and suppresses steady-state background sources such as air conditioning, fans, and ambient crowd noise. On the LARK MAX 2, press the multi-function button once on the TX button. Or, use the NC Level settings to enable noise cancellation through the HollyAudio app.  An LED indicator on the transmitter turns green, confirming that AI noise-canceling is active. Use it in any environment where background noise is present but cannot be addressed at the source.
32-Bit Float Internal Recording
The LARK MAX 2 transmitter records audio directly to onboard storage at 32-bit float resolution, independent of your camera. Because 32-bit float captures a complete dynamic range without clipping, this file is a reliable backup even if the camera recording peaks out.
To use it:
  1. Enable 32-bit float internal recording via the hardware button on the transmitter or inside the HollyAudio app before your session begins.
  2. The transmitter’s LED or display confirms the recording mode is active.
  1. After recording, connect the transmitter via USB-C to your computer and retrieve the audio file from onboard storage.
A backup track can be extremely useful during live events and documentary recordings. It also helps in places where unexpected loud sounds may happen at any time.
HollyAudio App
The HollyAudio app (popularly called the LarkSound app) connects to the LARK MAX 2 via Bluetooth and provides access to settings beyond what hardware buttons alone can reach:
  • Per-channel gain adjustment
  • Noise cancellation level
  • EQ settings
  • Monitoring volume
  • Safety track configuration
Download the HollyAudio app, open it with the LARK MAX 2 powered on, and select the connected device. All adjustable parameters appear in a single panel and apply in real time without interrupting an active recording.
How far can a wireless lavalier microphone transmit?
Most wireless lav systems offer a line-of-sight range of 30 to 100 meters, depending on the environment. The Hollyland LARK M2 is rated for up to 300 meters in open, unobstructed conditions. Indoors, with walls and competing wireless signals present, expect a practical range of roughly 30 to 50 meters. Keeping the transmitter and receiver in a clear line of sight gives the most consistent signal.
Can I use a wireless lavalier mic directly with my smartphone?
Yes, with the right connection. Most receiver units output via 3.5mm, which requires a TRRS adapter for phones with a headphone jack or a USB-C adapter for those without one. For a simpler alternative, the Hollyland LARK A1 offers dedicated USB-C and Lightning receiver options, making smartphone recording fully plug-and-play with no additional adapter required.
Why is my wireless mic cutting out or dropping signal?
The most common causes are 2.4 GHz interference from nearby WiFi routers or Bluetooth devices, physical obstructions between the transmitter and receiver, low battery, and exceeding the effective range. Start by charging both units to full battery capacity. Then bring them closer together and increase the distance from other wireless devices. If the problem continues, pair the units again from scratch. Also check that nearby devices are not using the same frequency channel.
How do I reduce clothing noise on a lav mic?
If you have the LARK M2, you can clip it or use the magnetic attachment on your shirt. For wired lav mics on loose or textured garments, place a small strip of moleskin or gaffer tape behind the capsule to cushion it against direct fabric contact. Secure any cable at intervals with additional tape so it cannot swing freely against clothing during movement.
Do I need to adjust gain if I’m using a wireless mic with a DSLR?
Yes. The receiver sends audio to the camera, but built-in camera preamps often add unwanted hiss. For cleaner recordings, keep the camera input level very low, usually around one to three steps. Turn off automatic gain control if that option is available. Set the audio level on the transmitter or receiver instead. Aim for peaks between -12 and -6 dB. The ideal way to bypass camera-side gain management entirely is to use 32-bit float internal recording on the Hollyland LARK MAX 2 as a backup track.
The basic process follows six main steps. First, charge all devices fully. Then confirm both units are properly paired. Attach the transmitter at chest height with the mic pointing upward. Connect the receiver to your recording device next. Adjust gain so audio peaks near -12 dBFS. Always listen through headphones before starting recording. Do a short test recording before every shoot begins. Most issues appear early and can be fixed quickly.
