How to Hide a Lavalier Microphone: Placement Techniques for Every Clothing Type
A visible microphone in the frame breaks the illusion of professional production. Whether you’re wiring a subject for a documentary interview, shooting a vlog, or covering a wedding ceremony, hiding a lavalier microphone is a skill every videographer and audio crew member needs. This guide explains microphone placement methods for different clothing styles. It also covers useful accessories that keep the capsule secure. You will also learn ways to stop clothing noise before it affects a recording.
Quick Reference: Best Lav Mic Hiding Positions at a Glance
This table gives a quick starting point based on what you are wearing. It can also help during a shoot when clothing or recording conditions change.
Position
Best Clothing Type
Sound Quality
Rustle Risk
Primary Technique
Collar edge / shirt placket
Button shirts, dress shirts
Excellent
Low–Medium
Clip to collar seam; angle capsule toward mouth at 45°
Jacket lapel underside
Suits, blazers
Excellent
Low
Clip inside lapel fold; face capsule upward through fold
Between shirt buttons
Dress shirts, button-downs
Good
Low
Thread capsule through button gap; tape cable inside; build strain-relief J-loop
Sternum under clothing (skin mount)
All tops
Good
High
Moleskin base layer plus Transpore tape; capsule face-up 3–4 inches below collarbone
Inside neckline / décolletage
Dresses, low-cut tops
Good
Medium
Clip to neckline hem or tape at bra strap bridge
Hair placement
Any clothing
Fair
Medium–High
Secure capsule near hairline with small clip or skin-safe tape
Note: The Hollyland LARK M2S, at 7g with a no-logo design, is compact enough to work in all six positions without requiring additional accessories. Bulkier transmitters are typically limited to waistband or inside-pocket placement, both of which add cable runs and reduce audio quality.
Gather these items before wiring talent:
  • Medical or skin-safe tape (Transpore or Hy-Tape): Strong enough to hold through a full shoot but gentle enough to remove without irritating skin.
  • Moleskin or Rycote Stickies: Creates a noise-reducing buffer layer between the capsule and fabric. Moleskin is available at any pharmacy; Rycote Stickies are purpose-built for audio work.
  • Small gaffer tape strips: Secures cable runs along clothing seams and prevents swing-induced rustle.
  • Cable clips or rolling clips: Anchors cable at regular intervals for wired setups.
  • Your lav mic and transmitter: The transmitter’s physical size is the single variable that most determines which techniques are available to you.
The Hollyland LARK M2S is used as the demonstration unit throughout this guide. Its 7g TX, button-sized profile, and no-logo design allow it to work in nearly every placement scenario. The titanium clip can engage directly with fabric or disengage completely for tape-based skin mounting, which removes the need for most accessories above in basic setups.
How to Hide a Lav Mic on a Shirt or Jacket?
A shirt or jacket offers the most anchor options of any clothing type. The three most reliable placements are the collar or shirt placket, the jacket lapel, and the gap between shirt buttons. Each requires a slightly different approach.
Collar and Shirt Placket
This is the cleanest placement for most interviews and on-camera work. The capsule sits close to the mouth, is fully concealed from the front, and can be secured without tape.
  1. Position the subject so their collar or shirt placket is relaxed and not pulled tight.
  2. Hold the capsule against the collar seam from the back side of the fabric.
  3. Engage the clip from behind so the capsule face points outward and slightly upward, angled approximately 45 degrees toward the mouth.
  1. Run the cable under the shirt and along the torso toward the transmitter at the waistband.
  2. Test by having the subject speak at normal volume and gently turn their head left and right. If rustle appears during head turns, the cable run is too tight. Add a small amount of slack near the attachment point and re-test.
LARK M2S: The LARK M2S’s titanium clip grips the collar seam from behind, keeping the smooth, logo-free design visible on the fabric. The 7g weight won’t pull the collar out of shape or cause visible drooping, even on lightweight dress shirts.
Jacket Lapel
A jacket lapel gives you extra fabric for microphone placement. This helps hide the capsule more effectively. It can also reduce small handling and clothing noises.
  1. Pull or open the folded front part of the jacket (lapel) outward so you can see the inside of the fabric.
  2. Position the clip on the inside of the lapel, with the capsule threading through or resting against the lapel fold.
  3. Angle the capsule upward so it faces toward the chin when the lapel falls naturally back into position.
  4. Route the cable into the jacket interior, following the lapel seam toward the inner breast pocket or waistband.
  1. Confirm the lapel lies flat with no visible bump or lift at the clip point before rolling.
LARK M2S Tip: The LARK M2S’s compact profile means the lapel lies naturally after clipping. There is no visible ridge or outline from the outside, even on lighter-weight blazer fabrics.
Between Shirt Buttons
This position delivers the highest concealment on a plain dress shirt and works best with a compact wireless system where only a short capsule lead needs routing.
  1. Identify the button gap closest to the sternum, typically the second or third button from the collar.
  2. Feed the mic from inside the shirt. Then push the tiny mic head outward through a gap so it ends up sitting flat with the outside of the clothing.
  1. Apply a small piece of Transpore tape inside the shirt to hold the cable against the inner fabric.
  2. Create a J-loop just behind the button gap by forming a short backward loop in the cable and taping it flat. This loop acts as a strain relief.  If the shirt pulls during movement, the loop absorbs the tension before it reaches the capsule.
  3. Route the remaining cable down the inside of the shirt to the transmitter at the waistband or inside pocket.
LARK MAX 2: When using the Hollyland LARK MAX 2 transmitter, clip the transmitter inside the jacket pocket or under the T-shirt. Make sure the LED indicator faces inward toward the body. The indicator is bright enough to bleed through thin or light-colored fabrics when facing outward.
How to Hide a Lav Mic Under Clothing?
Placing the mic under the shirt keeps it completely hidden. This position also increases the chance of fabric noise. When set up carefully, it can still record clear audio.
  1. Ask the subject to locate the top of their sternum and move approximately 3 to 4 inches below the collarbone. This is your target placement zone.
  2. Apply a patch of moleskin slightly larger than the capsule body directly to the skin at that position. The moleskin acts as both an adhesive base and a noise-dampening layer between the capsule and the shirt fabric above.
  3. Press the capsule face-up onto the center of the moleskin patch, so the capsule faces toward the shirt rather than toward the chest.
  4. Apply a second strip of Transpore tape over the top and sides of the capsule body to lock it in place.
  5. Route the cable along the natural centerline of the torso, taping it down at the navel and again at the waistband.
  6. Build a J-loop at the waist just before the cable reaches the transmitter. This is your primary strain relief point for under-shirt mounts.
Getting Clean Audio When Hidden Under a Shirt
Placing the mic under fabric adds a barrier that can attenuate high-frequency content and make speech sound muffled. Three factors directly affect how much degradation occurs.
Fabric type: Thin cotton jersey attenuates far less than heavy denim or wool. If the subject is wearing a thick or layered top, evaluate whether under-shirt placement will deliver acceptable audio before committing to it.
Capsule angle: The capsule face should point as directly toward the shirt surface as possible. A tilted capsule picks up more reflected sound from the chest cavity, producing a hollow, boxy tone.
Clothing tension: If the fabric presses tightly against the capsule, breathing and movement create constant friction rustle. Prevent this by forming a small moleskin tent over the capsule: fold a strip of moleskin into a shallow arch so the capsule is suspended just below the fabric surface rather than pressed flat against it.
LARK MAX 2: When physical placement alone doesn’t fully resolve rustle under fabric, the LARK MAX 2’s AI Noise Cancellation provides a hardware-level backup. Toggle it on via the dedicated button on the receiver unit, or open the HollyAudio app and navigate to the NC level setting to choose the appropriate suppression strength. Treat this as a complement to correct physical technique, not a replacement for it.
LARK M2S: When skin-mounting the LARK M2S, disengage the titanium clip entirely and clip it on your clothing. The mic sits against the chest without creating a visible bump under fitted clothing.
Hiding a Lav Mic for Different Clothing Types
Standard collar and sternum placements don’t apply to every wardrobe situation. Here is how to adapt the technique for four common garment types.
Suits and Blazers
Challenge: Multiple fabric layers aid concealment but make cable routing complex.
A suit is the most forgiving garment for hiding a mic. Use the lapel buttonhole if one is present, threading the capsule cable through it from the inside so only the capsule face is visible from the outer lapel.
  1. Route the cable from the lapel or buttonhole placement into the jacket lining.
  2. Run it toward the inside breast pocket, where the transmitter can sit upright without creating an obvious chest bulge.
  3. If a waistband clip is preferred, exit the jacket lining at the bottom hem and route the cable under the dress shirt to the waistband.
  4. Secure all cable runs with small gaffer tape tabs at the lapel entry point and at any fabric seam crossing.
Dresses and Low-Cut Necklines
Challenge: No collar, no pockets, and exposed décolletage leave few obvious anchor points.
For a dress with a defined neckline hem, engage the LARK M2S titanium clip directly to the inside of the hem, with the no-logo face hidden against the skin side of the fabric.
At 7g, the LARK M2S does not distort the strap or pull the bra out of position during movement.
T-Shirts and Casual Tops
Challenge: A thin single-layer fabric means any bump is visible from the front, with no lapel, placket, or natural anchor point.
  1. Create a small fabric tuck at the center chest by pinching the shirt between two fingers and folding approximately half an inch of fabric inward.
  2. Tape the tuck closed on the inside with a small gaffer tape strip, forming a hidden pocket in the shirt fabric.
  3. Mount the capsule flat against the inside of the tuck, or use the sternum skin-mount technique beneath the shirt for deeper concealment.
  4. Ease for LARK M2S Users: The LARK M2S’s smooth, no-logo design reduces visible outline through thin jersey fabric compared to branded transmitters or capsule bodies with raised buttons or logos.
High-Neck Tops and Turtlenecks
Challenge: The neckline is fully enclosed, so collar-level placement is inaccessible. Placement must shift lower toward the sternum.
  1. Skip collar placement entirely and go directly to the sternum skin-mount.
  2. Position the capsule as high on the sternum as the neckline allows, without the capsule touching or pressing against the overlying fabric.
  3. Apply extra moleskin padding around the capsule body to prevent the fabric from contacting and rubbing against the sides of the mic during movement or deep breathing.
  4. Keep a generous J-loop at the waist to absorb any movement transmitted from the upper body and neck.
How to Reduce Fabric Rustle When a Lav Mic Is Hidden?
Rustle is the most common problem after placement. Work through these steps in order of effectiveness.
  1. Apply a moleskin tent over the capsule. Fold a small strip of moleskin into an arch over the capsule so it hangs in an air gap between skin and fabric. Direct fabric contact on the capsule body is the primary source of friction-induced rustle.
  2. Build a strain relief loop at every major bend in the cable. Any cable segment that crosses a joint or follows a moving body part needs a J-loop taped in place so that body movement is absorbed before it reaches the capsule.
  3. Leave deliberate slack. The cable between the capsule and the first tape point should have a small amount of vertical give. A taut cable turns every body movement into a direct tug on the capsule.
  4. Have the talent move before recording. Ask the subject to take a few steps, turn their head, and gesture naturally while you monitor audio in headphones. Identify when rustle appears and trace it to its source before rolling.
  5. Dress the fabric after placement. Lightly press the clothing flat around the capsule area and smooth any loose fabric away from the mic body before the first take.
LARK M2S Minimal Contact with Fabric: The LARK M2S’s compact profile creates a smaller contact surface against fabric than larger transmitter bodies, which directly reduces friction-induced rustle. This is a physical design advantage, not just a convenience feature.
The Power of LARK MAX 2’s Noise Cancellation: When physical methods still leave residual noise, the LARK MAX 2’s AI Noise Cancellation provides a hardware-level second pass.
  1. Press the multi-function button on the LARK MAX 2’s TX once to activate noise cancellation.
  1. Or, open the HollyAudio app, connect LARK MAX 2, and go to its settings page. Then, toggle on the NC Level button for the connected TX to enable noise cancellation.
  1. When the noise cancellation feature is active from any of the above methods, the TX LED will turn green.
Note: The names of the functions in the HollyAudio app can be slightly different, depending on the application's version.
Cable Management for Wired Lav Capsule Setups
For body-pack transmitters with a separate capsule on a short lead, keep cable runs simple and secured:
  • Route the cable along natural body contours by following seams, bra straps, and waistbands rather than running cable across open fabric.
  • Tape the cable at 6-inch intervals using small gaffer tape tabs, pressing against clothing seams where possible.
  • Build a J-loop strain relief at the capsule end before the cable enters the garment interior.
  • Never allow cable to hang freely between two attachment points. Any free-hanging section will swing during movement and generate audible noise.
Note: The LARK M2S and LARK MAX 2 work as fully wireless transmitter systems. Cable tips mentioned earlier only apply to short capsule connections on certain setups. These small internal links are much easier to manage. They are simpler than running a full wired cable from the person to a separate recorder.
Common Mistakes When Hiding a Lav Mic and How to Fix Them
Mistake
Fix
Capsule angled away from the mouth
Re-angle the capsule to face the mouth at roughly 45°. The capsule should always point in the general direction of the sound source.
Cable too tight, creating a pull on the capsule
Add a J-loop strain relief near the capsule. Give the cable a small amount of deliberate slack before the first anchor point.
Mic body visible through fabric
Switch to the skin-mount technique or use a smaller, logo-free wireless transmitter body such as the LARK M2S.
Sound is muffled or tonally degraded
Reduce fabric layers between capsule and mouth. Consider moving to a collar or lapel placement rather than under-shirt.
Mic shifts or falls loose during movement
Add a second tape point and replace moleskin or skin tape if adhesion has weakened from sweat or skin oils.
No test recording made before the shoot
Always monitor and record a brief test take before rolling. Adjust placement while there is still time to fix it.
Where is the best place to hide a lavalier microphone for an interview?
The collar edge or shirt placket works well for interviews. It keeps the microphone close to the mouth for clear sound. This position also reduces fabric noise. For people wearing jackets, the inside of the lapel is another good option. It fully hides the capsule from view and often needs no tape.
How do you hide a lav mic on a woman’s dress without a collar?
Clip the capsule to the inside of the neckline hem, or tape it to the bra strap bridge at the center front. For better concealment, use a chest skin-mount method. Place moleskin directly on the skin for support. Secure the capsule facing upward on the upper chest. Run the cable under clothing toward a waistband or pocket. The transmitter can then be placed at the hip or waist area.
Can you hide a lavalier microphone in someone’s hair?
Yes, though hair placement produces the lowest audio quality of any position. Secure the capsule near the hairline using a small clip or skin-safe tape, with the capsule face oriented toward the mouth. Use this as a last resort when no clothing anchor point is available. Expect more handling noise and reduced clarity compared to any chest-level placement.
What is the best tape to use for attaching a hidden lav mic to skin?
Transpore surgical tape from 3M is the most widely used option. It is strong, breathable, and removes cleanly from most skin types. For longer shoots or oily skin, Hy-Tape provides a stronger hold. Rycote Stickies are a purpose-built alternative that combines a cushioning layer with a skin-safe adhesive, which also provides some built-in rustle reduction.
Does hiding a lav mic under clothing affect sound quality?
Yes. Placing a mic under a shirt adds a fabric layer that attenuates high frequencies, which makes speech sound slightly muffled or boxy. The degree of degradation depends on fabric thickness and capsule position. Thin cotton jersey has minimal impact, while heavy wool or layered fabric causes more noticeable muffling. A correctly angled capsule and moleskin tent minimize the effect significantly.
How do I stop my hidden lav mic from picking up fabric noise?
Place moleskin above the capsule to create space from clothing. This helps stop fabric from touching the mic directly. Add a small J-shaped loop in the cable near the capsule. This reduces pulling when the body moves. Leave a bit of slack between cable points for extra freedom. If fabric noise still remains, the LARK MAX 2’s AI Noise Cancellation can reduce it during recording.
Where you place the mic and what clothing you wear decide your starting method. Fabric noise risk then decides if you need a physical fix or a built-in feature. In most cases, a small wireless system helps avoid many hiding issues from the beginning. A simple, low-profile transmitter also makes concealment much easier..
